Audi Q5 rear wiper motor
Mansell77
Wales
C?ID=182342
Installed a rear wiper motor, but now it does one swipe when ignition is turn on is there any way to stop this, as not good in icy condition.
Also scan shows number of problems that are to do with the boot, but they are working. Boot light works and close button works, tried clearing codes, but same comes up. (other problems on scan that i am trying to get around to looking into as well)
Newbie to all this, just used reset for service and rear break pads change, so please be nice and simple with any explanations.
Thanks advance.
Chassis Type: 8R-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 69 6D 72
  Mileage: 102870km-63920miles
Address 01: Engine (J623-CGLB)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 ML    HW: 03L 906 018 DN
   Component: R4 2.0l TDI   H23 9977
   Revision: 45H23---
   Coding: 2A194012043703080000
   Shop #: WSC 20782 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018ML 003004
   ROD: EV_ECM20TDI01103L906018DG.rod
   VCID: 0009C8FA9BC75C8402-8054
7140 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
4527 - Coolant Fan Control Circuit 1
          P0480 00 [032] - Electrical Malfunction
4891 - EGR Valve (N18)
          P0403 00 [096] - Malfunction
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 G    HW: 8R0 907 379 G
   Component: ESP8 quattro  H07 0070
   Coding: 0C9544
   Shop #: WSC 06334 000 00000
   VCID: 448104EAC75F80A466-8010
   Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
   Component: BCM2 2.0      H05 0435
   Coding: 033500
   Shop #: WSC 06335 000 00000
   VCID: 010FCDFE98CD558C0D-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000011214017
   Serial number: 2311000036289015
   Part No SW: 8T2 820 043 AE    HW: 8T2 820 043 AE
   Component: KLIMA 1 ZONE  H08 0180
   Revision: B1000000    Serial number: 01020320111713
   Coding: 34350000
   VCID: 75E7A92EDC05692C21-8020
00716 - Air recirculation Flap Positioning Motor (V113)
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Reset counter: 107
                    Mileage: 101073 km
                    Date: 2020.09.17
                    Time: 16:07:59
                    Voltage: 14.20 V
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Count: 11595
                    Count: 15548
                    Bin. Bits: 01000000
                    Bin. Bits: 00000001
                    Time: 160.00 s
   Part No SW: 8K0 907 063 M    HW: 8K0 907 063 M
   Component: BCM1 1.0      H30 0392
   Revision: 08030001    Serial number: 00000000805453
   Coding: 690040B10034A7010001000300005F5F001D260806000101000000
   VCID: 397F651EB09DCD4C05-806C
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 110214  H11 0050
   Serial number: 90243015110208021928
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 11323353
   Coding: 024D25
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000603113392
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0080
   Revision: 11001001    Serial number: 12501106105707
   Coding: 110205
   VCID: 78F9A01ACB1714443A-802C
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JPD08JX3.
   Coding: 30473331313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 489910DAF377A4C48A-801C
   Serial number: 6334MSME5E063A48N
   Serial number: 6344MSME5E06292FR
   Serial number: 6352QSME091E1E54P
   Serial number: 6362QSME071E516CO
   Serial number: 63732SME51090E42Y
   Serial number: 63832SME3D092E705
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KC700182
   Coding: 000017
   VCID: 3D77710EA4B5F16C29-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 H    HW: 8R0 920 981 H
   Component: KOMBIINSTR.   H20 0258
   Revision: 00000000    Serial number: EK325A73C
   Coding: 2F04220002002600010000
   VCID: 3F8B0B06AEB9E37C3B-806A
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E112170104
   Coding: 00CF07
   VCID: 0303C7F682D1479C1F-8056
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650685997
   Serial number: 11067000583021200181
   Part No SW: 8K0 959 793 N    HW: 8K0 959 793 N
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000113704764
   Coding: 011002204001440004
   VCID: 4B932FD6EA014FDCA7-801E
                    Reset counter: 140
                    Mileage: 102639 km
                    Date: 2020.12.15
                    Time: 14:16:11
   Revision: 00002001    Serial number: 0144633106
   Coding: 013B062220B934408420053680000000
   Part No SW: 8K0 959 792 N    HW: 8K0 959 792 N
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000113824830
   VCID: 4A9D2AD2E57B56D49C-801E
   Revision: 00000003    Serial number: 00000000882595
   VCID: 3461542A97FF3024D6-8060
   Part No SW: 4G0 035 056 D    HW: 4G0 035 056
   Component: Radio U STD   H52 0094
   Revision: AB001007    Serial number: 469CA0B7691994
   Coding: 010003020100000001
   VCID: 224DA2723D0BAE9434-8076
   Part No SW: 8T2 035 666 J    HW: 8T2 035 666 E
   Component: H-BN-EU       H51 0174
   Revision: --------    Serial number: 475C40B7564938
   Coding: 01010106000581ED01002B1E000000030000
   VCID: 428D02F2DD4B8E9454-8016
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466BZ0B0534658
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000768116
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000113890697
   Coding: 010002204001240004
   VCID: 458719EECC65B9AC71-8010
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Revision: 1G001001    Serial number: 00000144894349
   Coding: 0109080000000000
   Shop #: WSC 25397 000 00000
   VCID: 3567692E9C85292CE1-8060
            011 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10101011
                    Reset counter: 140
                    Mileage: 102639 km
                    Date: 2020.12.15
                    Time: 14:17:15
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H51 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B737F16BAA1FF5C17-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H51 0330
   Serial number: 8R0827852B
02242 - Rear Lid Lock Button in Luggage Compartment (E406)
                    Reset counter: 112
                    Mileage: 101899 km
                    Date: 2020.11.02
                    Time: 13:37:28
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000113890694
                    Reset counter: 140
                    Mileage: 102639 km
                    Date: 2020.12.15
                    Time: 14:16:11
End-------------------------(Elapsed Time: 03:22)--------------------------
Wednesday,06,January,2021,11:53:34:50271
VCDS Version: 20.12.0.1 (x64)
VIN: WAUZZZ8RXBA094368   License Plate: CV11XUM
Mileage: 102870km-63920mi   Repair Order:
VIN: WAUZZZ8RXBA094368   Mileage: 102870km-63920miles
   Revision: 45H23---
          U1113 00 [032] - -
   Coding: 0C9544
   Coding: 033500
   Coding: 34350000
                    Reset counter: 107
                    Mileage: 101073 km
                    Date: 2020.09.17
                    Time: 16:07:59
                    Voltage: 14.20 V
                    Temperature: 26.0°C
                    Temperature: 21.0°C
                    Count: 11595
                    Count: 15548
                    Bin. Bits: 01000000
                    Bin. Bits: 00000001
                    Time: 160.00 s
   Coding: 01DD13
   Coding: 024D25
   Coding: 110205
   Coding: 000017
   Coding: 00CF07
                    Reset counter: 140
                    Mileage: 102639 km
                    Date: 2020.12.15
                    Time: 14:16:11
                    Reset counter: 140
                    Mileage: 102639 km
                    Date: 2020.12.15
                    Time: 14:17:15
                    Reset counter: 112
                    Mileage: 101899 km
                    Date: 2020.11.02
                    Time: 13:37:28
                    Reset counter: 140
                    Mileage: 102639 km
                    Date: 2020.12.15
                    Time: 14:16:11
End-------------------------(Elapsed Time: 03:12)--------------------------
Is this a replacement for one that did not work? Or a retrofit into a vehicle that didn't have one to begin with?
Mansell77
Wales
C?ID=182342
It was to replace one that stopped working, but not an Audi part
Mansell77
Wales
C?ID=182342
Mansell77
Wales
C?ID=182342
Complete motor unit from a well know on line auction site
So a Chinese Replacement Auto Part? ;)
Mansell77
Wales
C?ID=182342
What kind of part is it?
more than likely yes, didn’t look. Just wondering if it could be altered via the software. If not I have to live with it and make sure I pull the blade away from the screen on cold morning start up 🙈🙉🙊
