[PQ25] Fog Lights supported in 937 087?
   #21
WebCF
C?ID=166818
56 is to indicate left-right-left or the other way around, like a thank you on the Autobahn
Interesting. How to trigger that event then?
   #22
iichel
Netherlands, eastern part
C?ID=284912
move the indicator stalk down, up and down in rapid succession
   #23
VWT6
Finland
C?ID=295527
I'm afraid this isn't possible, sorry.
Channel 53 is for high beam assist
Channel 54 is for return-to-center high beam stalk (T6 stalk)
Channel 56 is to indicate left-right-left or the other way around, like a thank you on the Autobahn
Channel 68 is to always illuminate the hazard light button
Then there are some channels to determine how long the heated front and rear windows stay on. Most of the others are already documented or unknown to me
Thank you very much. Besides those on T6 (7E0-937-090-x) the following - just in case:
Channel 38 - Interior lighting duration (x 30s)
Channel 39 - Rear window heater timer (x 30s)
(Channel 40 - Possibly mirror heater timer - can't confirm yet)
Channel 41 - Windscreen heater timer (x 30s)
Channel 42 - Head light washer, runs every n:th time of windscreen washes (0=every time, 255=never)
Channel 53 - Activate High Beam Assist (=installed)
   #25
dnoermann
C?ID=358118
If true, the labelfile should be fixed.
Always use german vcds version, too
Sometimes german version does have better explanations, and more, sometimes not.
Thanks guys, I'll bring this up during our morning lbl meeting tomorrow.
   #27
iichel
C?ID=284912
Thanks Dana. If you need any more input for the lbl files for PQ25, I'd be happy to help out.
   #28
WebCF
C?ID=166818
Why is there a difference between these two languages? I thought the original is writren in english and Sebastian translates it to german?
BTW: Whats the current state of ross-tech.de? 20.4 is still the latest version here.
   #29
VCDS itself, yes, but label files often go the other way.
Translations always lag a bit behind.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Long story shorts, we (mostly I) are lagging behind with updating these. I've put this on my todo for this week, so you should see a few changes/updates very soon. More complete documentation will follow after additional testing, as I want to make sure those bits and channels work as described.
WebCF
C?ID=166818
Hi Sebastian. Nice to read you ;)
ok, thanks for the update!
   #36
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Done updating, which means some new adaptation channels added (including those you mentioned and beyond) as well as some additional coding options which were not showing in the English version.
(ADP 068 is NOT the Emergency Flasher Button illumination, though the illumination can be a side effect triggered when changing ADP 068. You may want to not tweak that channel until I have it fully documented or make sure to verify the complete behavior of the cars exterior lighting.)
   #39
WebCF
C?ID=166818
If you feel like being lab rats...
Ill wait for the updated DRV 😅
Quick question: is it possible on my BCM to enable the rear lights already on DRL on (light switch to 0)? So that the rear light is on, regardless if low beams are on or not (DRL)?
   #40
iichel
C?ID=284912
yes it's byte 12 bit 0. but it will illuminate the front parking light (Standlicht) as well since they occupy the same BCM pins.
