Mk5 Golf Cluster Help Required
MB15
Scotland
C?ID=425117
Hi Guys ,
I have a faulty speedo on a MK5 Golf , Various warning lights are missing *previous owner(s) and the speedo doesn't work ,
I bought a 2nd hand cluster from eBay (Same matching codes on the stickers)
Extracted the pin from the old cluster and the "new one" using another tool
Following the Ross Tech video on Youtube
I go into Instruments 17 but doesn't give the option to log in?
Box 11 is faded into the background and the VIN is not displayed
Any idea what i`m doing wrong
AutoScan below is with the 2nd hand clocks fitted
Saturday,09,January,2021,13:43:16:38161
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
Dealer/Shop Name:
VIN: WVWZZZ1KZ6B087752   License Plate:
Mileage: 250100km-155404mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ6B087752   Mileage: 250100km-155404miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BDJ.clb
   Part No SW: 03G 906 016 GJ    HW: 028 101 222 1
   Component: R4 2,0L EDC 0000SG  7000
   Revision: 12345678    Serial number: VWZ7Z0E2478948
   Coding: 0000071
   Shop #: WSC 00046 412 57344
   VCID: 71BFDE904DA04B938CD-8024
8 Faults Found:
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    Torque: 124.0 Nm
                    Voltage: 12.08 V
                    Bin. Bits: 00000000
                    Temperature: 4.5°C
                    (no units): 144.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault - Intermittent
                    RPM: 798 /min
                    Torque: 86.0 Nm
                    Voltage: 11.48 V
                    Bin. Bits: 00000100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault - Intermittent
                    RPM: 798 /min
                    Torque: 86.0 Nm
                    Voltage: 11.48 V
                    Bin. Bits: 00000100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
16787 - EGR Valve (N18)
            P0403 - 000 - Malfunction - Intermittent
                    RPM: 840 /min
                    Torque: 56.0 Nm
                    Duty Cycle: 17.9 %
                    Duty Cycle: 4.4 %
                    Absolute Pres.: 918.0 mbar
                    Temperature: 12.6°C
18058 - Powertrain Data Bus
            P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Torque: 124.0 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Torque: 174.0 Nm
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -  - MIL ON
                    Torque: 124.0 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    (no units): 0.0
                    Torque: 124.0 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Torque: 174.0 Nm
29703 - Please check Fault Memory in Battery Monitoring Module
            U1007 - 000 -  - Intermittent
                    RPM: 1008 /min
                    Torque: 50.0 Nm
                    Voltage: 14.06 V
                    Bin. Bits: 11000000
                    Torque: 148.0 Nm
                    Bin. Bits:  1 01  0
Readiness: 0 3 0 0 0
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021121
   VCID: 40D94B54368A921B333-8014
8 Faults Found:
57511 - Unknown Error Code
            Unknown - 015 -  - MIL ON
   Part No: 1K0 820 047 DF
   Component: Climatic PQ35   090 0505
   VCID: 6B83CCF86F8CA143B61-803E
            009 - Open or Short to Ground
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000003442640
   Coding: 00890F2700041800001400001400000000087B075C
   Shop #: WSC 00046 412 843776
   VCID: 2A0D09FCA0F6784B0D7-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00063445
   Shop #: WSC 00046
01800 - Light Switch (E1)
                    Reset counter: 12
                    Mileage: 293405 km
                    Voltage: 5.00 V
                    Reset counter: 12
                    Mileage: 293427 km
                    Voltage: 5.00 V
02604 - Low Vehicle Voltage from Power Steering Control Module
                    Reset counter: 10
                    Mileage: 308321 km
                    Voltage: 5.00 V
00926 - Terminal 30
                    Reset counter: 227
                    Mileage: 308321 km
                    Voltage: 5.00 V
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0JPR5S
   Coding: 0012870
   VCID: 372B20886344D5A3829-8062
   Subsystem 1 - Serial number: 6332MSME0B640A338
   Subsystem 2 - Serial number: 6342MSME0B1A4E5DU
   Subsystem 3 - Serial number: 6351HSME081F0C3FL
   Subsystem 4 - Serial number: 6361HSME081A43352
            004 - No Signal/Communication - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AE    HW: 1K0 953 549 AE
   Component: Lenksäulenmodul 034 0070
   Coding: 0000002
   Shop #: WSC 00046 412 933888
   VCID: 75B7EA8039C867B3505-8020
   Part No: 1K0 920 952 J
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   Shop #: WSC 00011 067 57207
   VCID: 313F1E908D200B93CCD-8064
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001058018869
   Coding: 3D0F0B40070003
   Shop #: WSC 00046 412 1597440
                    Reset counter: 227
                    Mileage: 308321 km
                    Time: 00:00:09
01304 - Radio
                    Reset counter: 227
                    Mileage: 308321 km
                    Time: 00:00:12
                    Reset counter: 11
                    Time Indication: 15
   Component: IMMO            VDD 1012
01176 - Key
02241 - Engine Control Module; Immobilizer Data not Adapted
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2312
   Coding: 0000692
   VCID: 36352D8C644E2CAB99F-8062
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 33331498773C3983BE1-8066
02546 - Steering Limit Stop
                    Mileage: 80 km
                    Temperature: 4.0°C
                    Voltage: 11.20 V
                    Voltage: 11.10 V
   Part No: 1K0 959 433 AK
   Coding: 00C802087F2D8405485B018010CC
   VCID: 79AFE6B015D003D334D-802C
   Part No: 1K0 959 702 K
   Coding: 0000692
Address 56: Radio
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D0702E091186F73E85-8078
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End----------(Elapsed Time: 00:58, VBatt start/end: 12.1V/12.1V)-----------
   Coding: 0000071
8 Faults Found:
            P1641 - 000 -
                    Torque: 124.0 Nm
                    Voltage: 12.08 V
                    Bin. Bits: 00000000
                    Temperature: 4.5°C
                    (no units): 144.0
                    RPM: 798 /min
                    Torque: 86.0 Nm
                    Voltage: 11.48 V
                    Bin. Bits: 00000100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
                    RPM: 798 /min
                    Torque: 86.0 Nm
                    Voltage: 11.48 V
                    Bin. Bits: 00000100
                    Temperature: 3.6°C
                    Bin. Bits: 01110000
                    RPM: 840 /min
                    Torque: 56.0 Nm
                    Duty Cycle: 17.9 %
                    Duty Cycle: 4.4 %
                    Temperature: 12.6°C
                    Torque: 124.0 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Torque: 174.0 Nm
                    Torque: 124.0 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    (no units): 0.0
                    Torque: 124.0 Nm
                    Voltage: 11.02 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Torque: 174.0 Nm
                    RPM: 1008 /min
                    Torque: 50.0 Nm
                    Voltage: 14.06 V
                    Bin. Bits: 11000000
                    Torque: 148.0 Nm
                    Bin. Bits:  1 01  0
   Revision: 00T12001
   Coding: 0021121
8 Faults Found:
   Coding: 00063445
   Shop #: WSC 00046
                    Reset counter: 12
                    Mileage: 293405 km
                    Voltage: 5.00 V
                    Reset counter: 12
                    Mileage: 293427 km
                    Voltage: 5.00 V
                    Reset counter: 10
                    Mileage: 308321 km
                    Voltage: 5.00 V
00926 - Terminal 30
                    Reset counter: 227
                    Mileage: 308321 km
                    Voltage: 5.00 V
   Coding: 0012870
   Coding: 0000002
   Coding: 0003403
                    Reset counter: 227
                    Mileage: 308321 km
                    Time: 00:00:09
01304 - Radio
                    Reset counter: 227
                    Mileage: 308321 km
                    Time: 00:00:12
                    Reset counter: 11
                    Time Indication: 15
01176 - Key
   Coding: 0000692
                    Mileage: 80 km
                    Temperature: 4.0°C
                    Voltage: 11.20 V
                    Voltage: 11.10 V
   Coding: 0000692
Address 56: Radio
            014 - Defective
End----------(Elapsed Time: 00:57, VBatt start/end: 12.2V/12.2V)-----------
NZDubNurd
New Zealand
C?ID=230482
You use "security access 16" to login.
I suggest you follow the instructions, writing them out as a step by step list, including when to put in which access code - it's easy to confuse the codes when you do it real-time.
NZDubNurd
New Zealand
C?ID=230482
Oh, and don't you have to do it in "immobiliser", not "instruemnt cluster"???
MB15
Scotland
C?ID=425117
Cheers guys ,
I`m not sure and new to VCDS hence asking
Reading the notes in:
Instrument Cluster Swapping
"All relevant coding and adaptation values have been transferred from the OLD (ORIGINAL) cluster to the REPLACEMENT (NEW or USED) cluster"
The above has not been done as there wasn't any mention of it on the Youtube video? (I was watching the video while i was out at the car)
Is there any other info on the above , Both clusters have the same part numbers and i have extracted the pin codes from both
I did try under [Security Access 16] but the pin wasn't accepted so i thought best to leave it and make a post to ask.
It`s not showing the VIN or Immo Serial number in the Extra Box either.
MB15
Scotland
C?ID=425117
Does anyone have any idea how to match the used eBay clocks to the car ?
Just in after spending another few hours of going round in circles :rolleyes:
If i go into instruments and try and log in to [Security Access 16] with pin for the new cluster = Controller refused the key , Error 35: Invaild Key
If i go into instruments and try and log in to [Security Access 16] with old clusters code = Controller refused the key , Error 35: Invaild Key
If i go into Immobilizer and log in with the new clusters code it gets accepted and gives options:
Immobilizer (Key Adaptation)
Immobilizer (Vehicle Data Learning)
Where do i go from here? I can`t see any written resource to follow
VOLKSWAGEN GOLF DIESEL HATCHBACK - 2.0 S SDI 5dr [AC]
Year: 2005
First Registered: 27/10/2005
Siemens VDO Clocks
1K0920 952J (Code)
Car runs with the original clocks "but has a knackered speedo" I have both pins for both clusters & both cluster codes match 1K0920 952J
I don't think the coding and other Adaptation channels are all that important, but it wouldn't hurt to copy them to the replacement cluster.
If the the immo in the replacement cluster accepts the PIN, you should be able to match it to the ECU using the PIN from the old cluster in Adaptation channel 50 as described here:
MB15
Scotland
C?ID=425117
Cheers guys ,
I was back at the car today ,
Battery support connected
Login into Immobilizer (25) with the "new used" cluster`s pin = Perfect
Wait until channel 50 appears under [Vehicle Data Learning]
It says stored value [32000]
I enter the old clusters pin [test] then [save]
An additional box opens and it says:
Save Value: 32000
To Channel: 50
With WSC: 00000
Are You Sure
Clicked [YES]
[Done, Go Back]
Ignition off for 1 min and 2 mins (Key left in the ignition and out the ignition) various attempts
Ignition back on
Login into Immobilizer (25) with the original cluster`s & ecu`s pin = Pin Rejected
Login into Immobilizer (25) with the "new used" cluster`s pin = Lets me in
Car is not accepting the cluster
I have screen shots but can`t work out how to get pictures on here.
cristo_844
PT
C?ID=412536
You need to readapt keys to the new cluster!
MB15
Scotland
C?ID=425117
Yeah i`m thinking that will be the final thing to do?
I`m trying to get the new used cluster and old ECU matched first?
cristo_844
PT
C?ID=412536
yes!
Just out of curiosity...what tool did you use to read the pin?
No, that shouldn't be necessary, nor is it possible. The keys match the old cluster and the ECU. With Immo3 and Immo4a, you can match one component to the other two if the other two already match. Immo-3 and newer key have a lock bit, once they are matched to a particular Immo "personality", they cannot be matched to a different one. However, it should be possible to match that cluster to the existing keys and ECU, and once that's done, the keys should be a non-issue. I'm just not sure why the cluster is refusing to mate with the ECU and keys. I don't see anything obviously wrong with the process the OP is using in post #10.
cristo_844
PT
C?ID=412536
keys are not matched to the ECU only cluster...for me its a 5 minute job it other tools:D
using VCDS to do this joob keys need to be matched to the new cluster, if not ,car i'll never start!
cristo_844
PT
C?ID=412536
What is matched in between cluster/ecu is vin,immo ID,CS,Mac,power class and pin!
MB15
Scotland
C?ID=425117
cristo_844 I used a Czech software
(The keys will not code to the new cluster using another tool / The cluster will need matched to the ECU first / *or this cluster is U/S
Jack@European_Parts No - It is a 2nd hand cluster from eBay as in post #1
Uwe I was back at the car today (Family car)
I`m thinking this cluster must be knackered , I noticed when the ignition is turned on the cluster clock displays 00:00
as long as the ignition is on - It starts going up + 00:01 , 00:02 ect
If i turn the ignition off then back on the cluster clock displays 00:00 and starts over again *It`s as if the cluster is losing all power when turned off
(Can`t be normal that?) and must be why the cluster adaption keeps failing?
These are the fault codes logged in the Immobilizer
01176 - Key
02241 - Engine Control Module , Immobilizer Data not Adapted
000 --- Intermittent
NostraJackAss
The cluster will need a -0/-0 security access pin, a data transfer or to be defaulted to virgin status manually before being able to do an 83. 84 or 89 Mode conventional tester procedure by 0x25-10-050
