StuartWood
Hi Team.
Tried installing Cruise control in my 2016 Caddy today however, I am unable to get it to work
Cruise control P/N 5K0953502M
Clock spring P/N 5K0953569 BF
i WAS UNABLE TO DISPLAY THE CRUISE CONTROL - ERROR CHANNEL NOT AVAILABLE
I did ensure the cruise control stalk was selected.
In 17, Bit5-6 I selected Cruise control system installed
Full scan below too.
I read on the internet and stated I needed to go in to Coding II and enter the code, however, I was unable to?
Could someone please direct me as to where I have gone wrong?
Saturday,09,January,2021,15:19:12:16996
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WV1ZZZ2KZGX038443 License Plate: CADDY
Mileage: 70530km-43825mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZGX038443 Mileage: 70530km-43825miles
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 T HW: 04E 907 309 BK
Component: R4 1.4l TFS H23 2363
Revision: R9H23---
Coding: 00190032232411080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM14TFS01104E906027T 001007
ROD: EV_ECM14TFS01104E906027T.rod
VCID: 35372039B5C550E3904-8060
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 70531 km
Date: 2021.01.09
Time: 00:35:01
Engine RPM: 0.00 /min
Coolant temperature: 45 °C
Intake air temperature: 31 °C
Voltage terminal 30: 12.345 V
Acceleration: 0.000 m/s²
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 129
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 42495000000608
Coding: 1079429B9265A4860879427A498525E37900F0
Shop #: WSC 35110 790 50316
VCID: 3FDB421187F99AB34A8-806A
0297 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 246
Mileage: 58859 km
Date: 2020.04.01
Time: 00:00:14
8213 - Databus
[ACAN: MO1_Sta_MotMo signal failure value]
Reset counter: 31
Mileage: 70530 km
Date: 2021.01.09
Time: 09:22:13
Part No SW: 1K8 907 426 AB HW: 1K8 907 426 AB
Component: AC Manuell H20 0808
Revision: 00001002
Coding: 0010004003
VCID: 73B3DE21FB310ED37E0-8026
Part No SW: 5K0 937 085 AD HW: 5K0 937 085 AD
Component: BCM PQ35 B+ 122 0183
Revision: BB122001
Coding: 611B0A3A8825086E08C80084950000EC03E10008424F8920648087000041
Shop #: WSC 35110 377 00144
VCID: 75B7E039F5C510E3504-8020
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 14081 27 0512
Coding: 009795
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0479
Revision: -------- Serial number: 39211525100940
Coding: 0001150001
ASAM Dataset: EV_EPHVA14VW364GP00 001006
ROD: EV_EPHVA14VW364GP00_VW36.rod
VCID: 76B5E735E8431BFB59E-8022
Part No SW: 7E0 959 655 D HW: 7E0 959 655 D
Component: VW10Airbag017 008 0016
Revision: -------- Serial number: 003PH000YDKQ
Coding: 000000000000000000000000000000003137
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 372B2A31AFC9A2F3828-8062
Part No SW: 5K0 953 521 GE HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20150901200423
Coding: 1082160100
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 75B7E039F54510E3504-8020
Subsystem 1 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 2451508312400746AB2B
Coding: 240000
Part No SW: 2K5 920 876 HW: 2K5 920 876
Component: KOMBI H04 1009
Coding: 1808000300
VCID: 72BDDB25842B07DB756-8026
Part No SW: 7N0 907 530 BA HW: 7N0 907 530 AL
Component: J533 Gateway H58 1663
Revision: H58 Serial number: 270815F1002262
Coding: 357421
VCID: 70B9D12D8AA735CB832-8024
Component: IMMO H04 1009
VCID: 6A8DC345ACFBCF1BCD6-803E
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0132656
VCID: 71BFD4298DAD3CC38CC-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 309 3501
Revision: 00H22000
VCID: 392F2C09955DB48374C-806C
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.9 V
PD
Temperature: 28.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0132656
VCID: 72BDDB2588AB07DB756-8026
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 A HW: 1K8 035 150 A
Component: MU-E--ER 857 6495
Serial number: 28081500012116
Coding: 063307002800000041510001001020001F0000D60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2313EE610B51DE534E0-8076
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1663
Coding: 032F7856
VCID: 71BFD42981AD3CC38CC-8024
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 118
Mileage: 58859 km
Date: 2020.04.01
Time: 00:01:45
End----------(Elapsed Time: 01:00, VBatt start/end: 12.5V/12.5V)-----------
