A bunch of dash lights today. Yesterday everything was fine.
danonb
78660, USA
C?ID=371136
Today was a crazy day. I started my car and a bunch of dash lights came on. A few of the systems are not working now. New to VCDS and i really don't know where to start. I have read a few forums and i have had the battery checked at one store. The kid said the battery was good. I will go for a second opinion another day. I just realized at the end of the output it has the battery voltage. I have posted the output below. stabilization system, ACC, TPMS, RPM not able to go over 3800 are a few of the errors. Any help would be appreciated.
1. Audi active lane assist : currently not available
2. Acc and Audi braking guard : unavailable
3. TPMS Tire pressure : System malfunction
4. Sport differential : System fault
5. Air suspension : System fault
Tuesday,05,January,2021,21:46:04:58864
VCDS Version: 20.12.0.1  HEX-V2 CB: 0.4529.4
VIN: WAU3GAFD5FN019418   License Plate: DV81851
Mileage: 94173km-58516mi   Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C
          42 44 46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 82 85 88 89 8B
          8E 8F 90
VIN: WAU3GAFD5FN019418   Mileage: 94173km-58516miles
Address 01: Engine (J623-CREC)       Labels: None
   Part No SW: 4H2 907 551 A    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---
   Coding: 0A2A0034056E010E3004
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214H2907551A 003001
   ROD: EV_ECM30TFS0214H2907551A_003.rod
   VCID: 2A0D034B7C71765B0D6-807E
14925 - Crankshaft Position Sensor (G28)
          P0335 00 [175] - Malfunction
                    Mileage: 93988 km
                    Date: 2021.01.01
                    Time: 13:22:07
                    Engine RPM: 0.00 /min
                    Coolant temperature: 91 ∞C
                    Intake air temperature: 53 ∞C
                    Voltage terminal 30: 10.761 V
                    Engine status: Stop
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    Charge press.: average: 0.963 bar
                    Oxygen sensor before cat bank 1 (LSB) voltage: 1.953 V
                    FAC_TPS_1_SAE: 14.843750 %
                    FUP_H_SAE: 24300.0 kPa
Readiness: 1010 1101
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: 8CFDF34031BFCF02E200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71BFD427912745838CC-8024
0679 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Net_QSP_02_QSP_Ist_Moment]
                    Fault Frequency: 14
                    Reset counter: 185
                    Mileage: 93988 km
                    Date: 2021.01.01
                    Time: 12:59:33
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 67
                    Bit Info 3: 02
                    Bit Info 4: 00
                    F-Path: 2C
                    F-Type: 2E
                    Uz: B9
0722 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [Can_Motor_03_QBitDrehzahl]
                    Fault Frequency: 14
                    Reset counter: 185
                    Mileage: 93988 km
                    Date: 2021.01.01
                    Time: 12:59:33
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 67
                    Bit Info 3: 02
                    Bit Info 4: 00
                    F-Path: 29
                    F-Type: F4
                    Uz: B9
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 668123B87C0100
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D0708574D9F6163E84-8078
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [009] - Signal Amplitude Too High
                    Reset counter: 185
                    Mileage: 86561 km
                    Date: 2020.10.31
                    Time: 10:21:12
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0032
   Coding: 7E01020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2B03064F738B6F53F60-807E
10240 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_BLR_BLK8_31]
                    Reset counter: 198
                    Mileage: 92918 km
                    Date: 2020.12.21
                    Time: 22:33:23
                    Control Module temperature: 18 ∞C
                    Voltage terminal 15: 14.354 V
                    Velocity_vehicle_reference: 6.67 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.39 m/s≤
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VDC_FAIL]
                    Fault Frequency: 19
                    Reset counter: 185
                    Mileage: 93933 km
                    Date: 2020.12.31
                    Time: 09:36:00
                    Control Module temperature: 2 ∞C
                    Voltage terminal 15: 10.089 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 001009140001009
   VCID: 2809F943627D444B1B2-807C
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [ESP - Steuerger‰t nicht verf¸gbar DTC_FRAY_ESP_SYS_STATE]
                    Fault Frequency: 16
                    Reset counter: 17
                    Mileage: 93988 km
                    Date: 2021.01.01
                    Time: 13:04:59
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B125F47931373DA8-807A
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 185
                    Mileage: 93988 km
                    Date: 2021.01.01
                    Time: 13:01:26
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001195669
   ROD: EV_ParkiBrake_VW51.rod
464640 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_MO_QBIT_DREHZAHL_01_QBIT]
                    Reset counter: 185
                    Mileage: 93933 km
                    Date: 2020.12.31
                    Time: 09:36:00
                    Voltage terminal 30: 10.2 V
                    Internal Fault ID: 189
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4H0 035 746 H    HW: 4H0 035 746 F
   Component: H-BNT-NA      H41 0810
   Revision: --------    Serial number: 183IY0E7552022
   Coding: 02020000000BFDFF7F1ADF1E00000003000300000300000000
   VCID: 2D0708574D1F6163E84-8078
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDEN1001615
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000170631
   Component: CD-Database  5950
03389 - Data Set Implausible
                    Reset counter: 15
                    Mileage: 50739 km
                    Date: 2019.07.31
                    Time: 16:19:00
                    Voltage: 13.90 V
                    Bin. Bits:      010
02387 - Telephone Mount (R126)
                    Reset counter: 15
                    Mileage: 50739 km
                    Date: 2019.07.31
                    Time: 16:19:10
                    Voltage: 13.90 V
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00018089160202
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7E01020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 290FFC4779777D4304C-807C
          U1113 00 [009] - -
                    Fault Frequency: 20
                    Reset counter: 185
                    Mileage: 93933 km
                    Date: 2020.12.31
                    Time: 09:36:00
                    Voltage terminal 15: 9.864 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H32 0090
   Serial number: 005000620209147
   Coding: 02C19A030111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2C0105537685686BFFA-8078
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [ESP_ESP_01_Signal_Error]
                    Fault Frequency: 25
                    Reset counter: 185
                    Mileage: 93933 km
                    Date: 2020.12.31
                    Time: 09:36:01
                    Outside temperature: 4.0 ∞C
                    Voltage terminal 15: 10.7 V
                    Control Module temperature: 0.0 ∞C
0049 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Airbag_Airbag_01_System_error]
                    Reset counter: 180
                    Mileage: 93987 km
                    Date: 2020.12.31
                    Time: 10:50:21
                    Outside temperature: 4.5 ∞C
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 24.0 ∞C
0165 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [QSP_Signal_Error]
                    Fault Frequency: 24
                    Reset counter: 185
                    Mileage: 93933 km
                    Date: 2020.12.31
                    Time: 09:36:02
                    Voltage terminal 15: 14.1 V
End----------(Elapsed Time: 06:05, VBatt start/end: 14.6V/14.6V)-----------
Bruce
Near Philadelphia, PA, USA
There are several errors reporting low voltage... Since the battery seems ok, I'd be looking for a bad ground connection somewhere. Just because the battery has good voltage, it does not mean that voltage is properly distributed throughout the vehicle. Look carefully at the autoscan and you will see low voltage on Terminal 15.. if the battery is 14.6v and Terminal 15 on some modules is 10V, 4 volts is being lost somewhere.. I'd bet a bad ground connection.
Yeah, but 14.6V makes me pretty confident this scan was done with the engine running, so it doesn't tell us anything about the battery.
There are some modules absent from the scan. For example, 19-CAN Gateway isn't there. Did you edit them out?
I'm going to suggest you have a look at the battery history data:
Voltages in the 10.x range really shouldn't happen, except while the engine is being cranked.
danonb
78660, USA
C?ID=371136
You are correct the scan was run while the car was running. The one video i watched suggested running car or trickle charge. I don't think having the car not running for 20 or so minutes would kill the battery. What do you suggest for an accurate scan? The output was edited to no include the no faults readings. 19-CAN Gateway -- Status: OK 0000
Jef
HQ
If the car runs, lets try doing another Auto-Scan with the engine at idle and post the results. Also, what brand of computer are you using?
danonb
78660, USA
C?ID=371136
The car was at idle and i just let it run. This scan was done on a dell. Soon to be macbook air running win 10. Does the brand of computer make a difference with the scan results?
George Ab
C?ID=232965
At idle, you will read alternator voltage and not battery voltage. I would start by checking the battery, measure battery voltage with car off; then turn car ignition on (do not start) and measure battery voltage (battery under load). I just checked mine which read 12.2V and dipped to 11.9 with ignition on. My battery is a couple years old. Your battery may measure fine when not under load, but as soon as it is under load the voltage decreases significantly, which is a sign of a bad battery. If the battery is ruled out, you can take it from there.
Yes, but I wanted to check whether this car had a battery management module (I think it should, but wanted to be sure). In that case, I would suggest you look at the battery history data:
danonb
78660, USA
C?ID=371136
So i was able to look at the battery history but cant decipher what i'm actually looking at. A quick skim over the output it looks like the battery was changed 2014. Going by that the battery should be needing a replacement.
Record 4/16: Battery change history
2014-09-24-00:31*01*092*JCB*240920K1EH*10005*09606*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*09993*00006*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**
Considering this is a MY 2015, I would speculate that's the original battery?
Feel free to post all of the battery history data here.
danonb
78660, USA
C?ID=371136
Here you go. Would you recommend changing the battery?
Thursday,07,January,2021,16:35:46:58864
                Address 19: CAN Gateway
Control Module Part Number: 4H0 907 468 AF
  Component and/or Version: J533--Gateway H13 0075
           Software Coding: C0CD075200
            Work Shop Code: WSC 02391
                      VCID: 75B7E037E54F69A3504-8020
History Data
Record 1/16: No-load voltage underranging
2021-01-04-12:54*00.9*01*05140***
2021-01-03-12:43*00.0*01**
2021-01-03-12:12*00.4*01**
2021-01-02-11:40*00.1*01**
2021-01-01-18:10*00.0*01**
2021-01-01-11:32*00.0*01**
2020-12-26-09:44*00.0*01**
2019-01-09-19:30*01.1*01*01778***
2019-01-09-12:01*21.8*01**
2019-01-08-14:57*06.4*01**
2019-01-08-08:29*24.6*01**
2019-01-07-07:47*21.7*01**
2019-01-06-10:02*04.7*01**
2019-01-06-05:15*07.8*01**
2000-01-01-00:00*00.0*00*00000***
2000-01-01-00:00*00.0*00**
Record 2/16: No-load current overranging
2014-09-24-23:47*0001*045*-02.15*0-0-1-0-0-0*0*01*00001**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
Record 3/16: Shut-off stage history
2019-01-16-13:54*1*0*042*006*-27.72*0-0-1-1-0-0*0*0*00.0*00.1**
2019-01-16-13:45*1*0*043*006*-28.36*0-0-1-1-0-0*0*0*00.7*00.8**
2019-01-09-18:11*1*0*036*006*-11.19*0-0-0-0-0-0*0*0*00.0*00.0**
2018-10-25-14:12*1*0*040*006*-21.17*0-0-0-0-0-0*0*0*00.2*00.2**
2014-10-30-17:11*4*0*083*073*-27.40*0-0-0-0-0-0*0*0*00.0*00.0**
2014-10-30-16:34*4*0*085*075*-14.49*0-0-0-0-0-0*0*0*00.0*00.0**
2014-10-29-22:30*4*0*091*081*-23.58*0-0-0-0-0-0*0*0*00.0*00.0**
2014-10-28-20:50*4*0*089*079*-22.01*0-0-0-0-0-0*0*0*00.0*00.0**
2014-10-23-21:03*4*0*092*083*-30.23*0-0-0-0-0-0*0*0*00.0*00.0**
2014-10-07-14:46*4*0*090*075*-47.01*0-0-0-0-0-0*0*0*00.0*00.0**
2014-10-07-13:20*4*0*094*080*-16.08*0-0-0-0-0-0*0*0*00.0*00.0**
2014-09-29-11:03*4*0*095*081*-18.60*0-0-0-0-0-0*0*0*00.0*00.0**
2014-09-29-09:04*4*0*098*083*-14.80*0-0-0-0-0-0*0*0*00.0*00.0**
2014-09-26-09:28*4*0*098*082*-17.04*0-0-0-0-0-0*0*0*00.0*00.0**
2014-09-25-11:58*4*0*086*076*-21.60*0-0-0-0-0-0*0*0*00.0*00.0**
Record 5/16: Energy-critical vehicle states
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
Record 6/16: Energy balances (last 20 trips)
2021-01-07-16:32*039*+16*+000.3*00.00**
2021-01-07-15:28*047*+15*+001.1*00.41**
2021-01-07-14:09*048*+14*+002.6*00.80**
2021-01-07-11:27*037*+13*+000.3*00.03**
2021-01-07-11:15*037*+12*+000.3*00.01**
2021-01-07-09:40*047*+12*+001.3*00.80**
2021-01-07-07:15*045*+11*+000.9*00.68**
2021-01-07-07:05*040*+10*+000.3*00.16**
2021-01-06-22:21*048*+19*+001.5*00.30**
2021-01-06-21:47*045*+19*+000.8*00.13**
2021-01-06-19:10*050*+21*+001.5*00.40**
2021-01-06-18:18*050*+20*+002.9*00.60**
2021-01-06-17:32*048*+18*+001.9*00.38**
2021-01-06-17:04*046*+17*+003.0*00.33**
2021-01-06-16:40*036*+16*+001.1*00.10**
2021-01-06-11:14*031*+16*+001.8*00.08**
2021-01-06-10:18*032*+16*+000.1*00.00**
2021-01-06-09:24*036*+16*+000.1*00.00**
2021-01-06-09:01*037*+16*+000.1*00.00**
2021-01-06-08:59*037*+16*+000.1*00.01**
Record 7/16: Energy balances (last 20 standing times)
2021-01-07-15:53*029*-004.5*000.6*00.1*00.1**
2021-01-07-14:58*044*-000.8*000.5*00.0*00.0**
2021-01-07-11:30*031*-000.7*002.6*00.0*00.0**
2021-01-07-11:16*037*-000.6*000.0*00.0*00.0**
2021-01-07-10:29*038*-001.8*000.7*00.0*00.0**
2021-01-07-07:56*038*-000.8*001.7*00.0*00.0**
2021-01-06-22:40*031*-001.0*008.4*00.0*00.0**
2021-01-06-21:55*038*-001.0*000.4*00.0*00.0**
2021-01-06-19:35*038*-001.5*002.1*00.0*00.0**
2021-01-06-18:55*048*-001.1*000.2*00.0*00.0**
2021-01-06-17:56*044*-002.1*000.3*00.0*00.0**
2021-01-06-17:25*046*-000.6*000.1*00.0*00.0**
2021-01-06-16:47*033*-000.7*000.2*00.0*00.0**
2021-01-06-11:19*029*-000.8*005.3*00.0*00.0**
2021-01-06-10:18*030*-001.4*000.9*00.0*00.0**
2021-01-06-09:24*028*-003.3*000.9*00.1*00.0**
2021-01-06-09:01*032*-000.7*000.3*00.0*00.0**
2021-01-06-08:48*038*-000.7*000.1*00.0*00.0**
2021-01-06-08:47*038*-000.1*000.0*00.0*00.0**
2021-01-05-21:53*035*-001.2*010.7*00.0*00.0**
Record 8/16: Battery manipulation (e.g. charging)
2020-11-26-11:32*2*06*03*00*02*00*00*00*2000-01-01-00:00*01**
2014-10-30-11:34*4*06*02*00*02*00*00*00*2014-10-30-18:33*01**
2014-09-29-09:16*2*06*02*00*01*00*00*00*2000-01-01-00:00*01**
2014-09-26-09:42*2*06*01*00*01*00*00*00*2000-01-01-00:00*01**
2014-09-25-10:40*1*06*00*00*01*00*00*00*2000-01-01-00:00*01**
Record 9/16: Battery aging
2014-01-24-00:32*100*100*088*066*00006*12.60*+23*01*12.70*00000*00000**
2020-12-24-09:31*063*068*084*036*09504*12.60*+07*01*03.10*00112*00060**
2020-11-28-09:31*061*068*083*036*09346*12.60*+13*01*03.00*00111*00060**
2020-10-30-19:46*059*061*075*030*09165*12.50*+13*01*03.15*00109*00060**
2020-10-02-15:44*064*069*078*039*09013*12.50*+22*01*03.05*00108*00060**
2020-09-05-22:52*064*071*073*036*08835*12.40*+28*01*02.95*00107*00060**
2020-08-08-20:20*069*075*081*042*08662*12.50*+33*01*02.90*00105*00060**
2020-07-09-22:28*067*070*074*036*08471*12.40*+33*01*12.70*00103*00060**
2020-06-13-20:30*068*071*073*036*08328*12.40*+31*01*03.00*00102*00060**
2020-05-16-17:15*065*074*076*038*08167*12.50*+22*01*02.90*00100*00060**
2020-04-20-17:14*064*068*073*035*08013*12.40*+23*01*03.10*00100*00060**
2020-03-23-14:42*063*067*092*045*07889*12.70*+17*01*02.95*00098*00060**
Record 10/16: Dynamic energy management
2000-01-01-00:00*0*000.0*0*000.0*0*000.0*00.00**
2000-01-01-00:00*0*0*0*00.00**
2000-01-01-00:00*0*000.0*00.00**
2000-01-01-00:00*00*00.00*00.00*00.00**
Record 11/16: Recuperation
2020-11-05-21:32*000*000*007*010*0070*030*00.4*00.6*089*041*093*045*01*00339*00699*00275*00733*01346**
2020-11-05-20:38*000*000*006*000*0074*027*00.1*00.3*080*037*093*045*01**
2020-11-04-13:56*000*000*001*011*0100*015*00.2*00.6*090*042*090*042*01**
2020-11-04-13:41*000*000*004*003*0131*011*00.1*00.6*090*042*090*042*01**
2020-11-04-13:17*000*000*001*008*0149*064*00.1*00.3*074*029*090*042*01**
2020-11-03-14:46*000*000*001*009*0063*022*00.2*00.4*087*039*091*044*01**
2020-11-03-12:02*000*000*003*062*0471*089*00.8*02.1*083*038*092*044*01**
2020-11-03-11:31*000*000*000*001*0030*010*00.1*00.1*084*037*091*043*01**
2020-11-03-10:50*000*000*000*000*0040*008*00.0*00.0*087*039*090*042*01**
2020-11-03-08:47*000*000*016*033*0553*088*00.8*01.6*078*035*091*042*01**
Record 12/16: Start-Stop
2019-03-21-12:55*2*059*024*+17*02*+30.0*+02.4*14.4*1**
2019-03-04-06:50*2*059*012*+00*02*+30.0*+02.1*14.4*1**
2019-02-27-10:58*1*079*036*+15*02*+30.0*-31.2*10.5*0**
2019-02-25-16:23*2*059*021*+16*02*+30.0*+13.1*13.9*1**
2018-10-29-14:27*2*059*026*+22*02*+30.0*+05.4*14.3*1**
00007*00028*00000**
Record 13/16: Sporadic alternator faults
2000-01-01-00:00*0-0-0-0-0*000.0*00000**
2000-01-01-00:00*0-0-0-0-0*000.0**
Based on that data, I don't think the battery needs replacement.
I concur with Bruce and suspect a bad connection somewhere.
danonb
78660, USA
C?ID=371136
Any chance you know where terminal 15 is located?
All over the car. "Terminal 15" means some source of power that's on when the ignition is on, and off when the ignition is off.
danonb
78660, USA
C?ID=371136
I was afraid of that. Any recommendations on a repair manual(s) with wiring diagrams?
danonb
78660, USA
C?ID=371136
Really? $35 is too much to get complete wiring diagrams and a whole bunch of other info for your car?
I guess i misread it. I was looking at the $200 subscription price.
danonb
78660, USA
C?ID=371136
Thank you for clarifying. I ended up going with the 3 day subscription. Everything i ever wanted to know about the car is here.
