Hello there,
I got an Audi A6 C6 from 2007 with battery drain issue.
I was checking the values in Can Gateway for Can Status and saw that WakeUp line remain active and Comfort and Infotainment remain on, and they don't go to static.
I'm attaching here the full scan of the car.
Can somebody help me with some ideeas?
Thursday,07,January,2021,01:35:23:32554
VCDS Version: 20.12.0.1 (x64) HEX-NET CB: 0.4529.4
Workshop Code: 022 21992 002029
VIN: WAUZZZ4F07N133416 License Plate:
Mileage: 334060km-207575mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56
61 62 72 76 77
VIN: WAUZZZ4F07N133416 Mileage: 334060km-207575miles
Address 01: Engine Labels: 059-907-401-BPP.clb
Part No SW: 4F5 910 401 HW: 4F0 907 401 C
Component: 2.7L V6TDI G000SG 0010
Revision: --H04--- Serial number:
Coding: 0011322
Shop #: WSC 66565 257 00032
VCID: 5EF06B9E8948BF7450-800A
P1653 - 002 -
Fault Status: 01100010
Mileage: 334065 km
Date: 2006.11.23
Time: 12:34:33
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 11.86 V
Bin. Bits: 00101000
Torque: 70.2 Nm
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Coding: 0020871
Shop #: WSC 02325 785 00200
VCID: 65824472AC1EECAC91-8030
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:49:04
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0024
Hex Value: 0x018E
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100693421
Coding: 0000001
Shop #: WSC 02323 785 00200
VCID: 63865A6AA22A929C7F-8036
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 350BK077762900
Coding: 0010006
Shop #: WSC 21992 022 02029
VCID: 3326EA2A524A421CCF-8066
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000680115
Subsystem 3 - Serial number: 0123.02.070000000100011520ÿ
Subsystem 4 - Serial number: 011520ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000030145981
Coding: 0000278
VCID: 5BF6628A9A5AAA5C37-800E
9 Faults Found:
01853 - Heated Seat; Left Front (Z45)
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Temperature: 19.0°C
01854 - Heated Seat; Front Right (Z46)
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Temperature: 19.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Temperature: 19.0°C
Fault Status: 01100101
Reset counter: 118
Mileage: 331253 km
Date: 2020.12.12
Time: 13:43:10
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Temperature: 19.0°C
02785 - Front Right Upper Body Outlet Position Sensor (G388)
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Voltage: 13.40 V
(no units): 225.0
(no units): 255.0
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Voltage: 13.40 V
(no units): 40.0
(no units): 255.0
02763 - Potentiometer for Indirect Ventilation Flap Motor (G330)
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Voltage: 13.40 V
(no units): 30.0
(no units): 255.0
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:42
Temperature: 21.0°C
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0012122
Shop #: WSC 02335 785 00200
VCID: 312AE022A856700CBD-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3175619
VCID: 1A78278ED5E09354EC-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0P29SM
Coding: 0013362
VCID: 291A0842808608CC75-807C
Subsystem 1 - Serial number: 6332CSME171C3B679
Subsystem 2 - Serial number: 6342CSME17640F2C9
Subsystem 3 - Serial number: 6352QSME233B1569H
Subsystem 4 - Serial number: 6362QSME223029332
Subsystem 5 - Serial number: 63734SME2111531DS
Subsystem 6 - Serial number: 63834SME221C1D7DA
00589 - Airbag Igniter 1; Passenger Side (N131)
002 - Lower Limit Exceeded - MIL ON
00590 - Igniter 2 for Passenger Airbag (N132)
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026070550132
Coding: 0002041
VCID: 6680437E5118E7B498-8032
Component: Lenkradmodul H02 0030
Part No SW: 4F0 910 930 C HW: 4F0 920 932
Component: KOMBIINSTR. M73 H20 0170
Revision: 00200000 Serial number: 5HP725V27
Coding: 2308103
VCID: 23061A6AE2AAD29C3F-8076
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008072198218
Coding: ECEE73C41B3104
VCID: 271E0E7A96923EBC63-8072
Part No SW: 4E0 910 888 P HW: 4E0 919 887 L
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364CV077644546
VCID: 3B36C20A7A1A8A5C17-806E
02927 - DVD Read Error
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:38
Hex Value: 0x4565
Hex Value: 0x9922
Hex Value: 0x0201
Hex Value: 0x0204
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0000618
Shop #: WSC 02327 785 00200
VCID: 2C14F1568F741DE48E-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H29 0250
Revision: 02500029 Serial number: 01214849120000
Coding: 0131243
VCID: 3522D4325C3E5C2CE1-8060
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000017603
Coding: 0000018
Shop #: WSC 02324 785 00200
VCID: 25020472EC9E2CAC51-8070
02246 - Loudspeaker; Center
Fault Status: 00111011
Reset counter: 156
Mileage: 334065 km
Date: 2006.11.23
Time: 12:48:26
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000397229
Coding: 0001103
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0000618
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000511
Shop #: WSC 80093 222 69422
VCID: 200C1566F3BCC98422-8074
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 3D32CC12640E846C29-8068
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394CW077742356
Coding: 0000001
VCID: 2E10FB5EB9686FF4A0-807A
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000028180
Shop #: WSC 02690 995 00000
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 6002350090
Coding: 344630393135313035442056413036303032333530303930
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0000042
Fault Status: 01101000
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:38
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0000042
Reset counter: 116
Mileage: 334065 km
Date: 2006.11.23
Time: 12:45:38
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330705102425
Coding: 0200006
VCID: 281C0D469B8C31C46A-807C
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007636221
Coding: 0010930
End----(Elapsed Time: 01:40, VBatt start/end: 11.6V/11.5V. VIgn 11.6V)-----
