- Jan 4, 2021
- 2
- 1
- Menifee, CA, USA
- C?ID=30574
Hi Guys,
This is my first post here so I am sorry if I don't have the formula down, please bear with me. I have a customer with 2018 GTI who had me install Emmanuele design lowering springs to retain his DCC. However he did not like how stiff it was even in the comfort setting. He opted to have me install the Bilstein B16 ride control coilover kit. Unfortunately he thought these were the "plug and play" coils, not the complete kit that someone without DCC would install in order to have electronic suspension, so it has its own wiring, module, and ride select button. Long story short the "plug and play kit" would not be available for some time if we returned these so he requested we install what we had and just code out the factory DCC. I tried looking everywhere to see if anyone else had done this succesfully and the best I could find was a post from 2016 about a ROW Golf R. Needless to say it did not necessarily translate straight over to what I had so I kind of went in and tried to find everything I could myself. I tried coding Instruments Byte 4 Bit 4 to Adaptive Chassis Control (DCC) not installed but I still get the error. I have also tried unchecking "Susp. Elect." in the CAN Gateway and I also tried Bit 7 in Byte 27 in the ABS module but it doesn't specify what that is and it didn't appear to make a change. I guess my biggest challenge is that none of the coding in ABS is available so I can't really see what is selected and why. I am going to try and remove fuse 52 in fuse panel "C" (Electronic damping control module) when I get the car back and try all of the above over again. The Auto-Scan I provided is with no coding or any other changes applied. I am no genius by any stretch of the imagination here so please be nice lol. If any of you have any info on what I should do try I would greatly appreciate the advice. I can also pull wiring diagrams with alldata (some data) if needed. Thank you!
Tuesday,29,December,2020,14:37:28:61955
VCDS Version: 20.12.0.0 (x64) HEX-NET CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: 3VW447AU5HM018029 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 2B 32 3C 42 44 47 52 55
5F 75 A9
VIN: 3VW447AU5HM018029 Mileage: 49894km-31002miles
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00124464002F1000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 373E361B8EBF873CF2-8062
Readiness: 1010 1101
Part No SW: 0D9 300 020 L HW: 02E 927 770 AQ
Component: DQ250-6V MQB H54 4902
Revision: 06354004 Serial number: TFK01607301747
ROD: EV_TCMDQ250021.rod
VCID: 1E70C3BF0145D67411-804A
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
P1734 00 [002] - -
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62006000000584
Coding: 01FA6BA1542109748077020241CC6880D62A900140821636164350D1C08903
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100IPB_035.rod
VCID: 7BB6EA2BF217635C56-802E
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0411437022
Coding: 032C0C
VCID: 3B362A2BB297A35C16-806E
Part No SW: 5GM 907 044 C HW: 5GM 907 044 C
Component: Climatronic H04 1601
Revision: 00001K03
Coding: 00020014200100000005000012111402
ASAM Dataset: EV_ACClimaBHBVW37X 006142
VCID: 44C451D7CF69DCA467-8010
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Component: BCM PQ37BOSCH 028 0163
Revision: -------- Serial number: 865803081600XG
Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00156
ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 7AB8EF2FFD2D5A544D-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160905 043 0581
Serial number: 160912113909
Component: RLHS 042 0105
Serial number: S3Y16M08D04H00M56S44
Coding: 00A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5GD 959 591 A HW: 5GD 959 591 A
Component: J245 PS60.006 H07 0170
Serial number: 03691602691406160033
Coding: 181803
Humidity sensor: interior:
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 3500008141FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 06071641350368
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 383C352783A18844FB-806C
835584 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [137] - -
Fault Frequency: 8
Reset counter: 198
Mileage: 49894 km
Date: 2020.12.29
Time: 13:10:14
36363 - Valve for Damping Adjustment Front Left
C1040 13 [137] - Open Circuit
Reset counter: 198
Mileage: 49894 km
Date: 2020.12.29
Time: 13:10:14
36619 - Valve for Damping Adjustment Front Right
C1041 13 [137] - Open Circuit
Reset counter: 198
Mileage: 49894 km
Date: 2020.12.29
Time: 13:10:14
36875 - Valve for Damping Adjustment Rear Left
C1042 13 [137] - Open Circuit
Reset counter: 198
Mileage: 49894 km
Date: 2020.12.29
Time: 13:10:14
37131 - Valve for Damping Adjustment Rear Right
C1043 13 [137] - Open Circuit
Reset counter: 198
Mileage: 49894 km
Date: 2020.12.29
Time: 13:10:14
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR05AZK%
VCID: 47DE46DBFE5FF7BC82-8012
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005S5D2D
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 002 507 16
Serial number: 35700000000890D00D1G
Subsystem 3 - Part No SW: ----------- HW: 480 002 507 16
Serial number: 358000000002A0D00D1C
Subsystem 4 - Part No SW: ----------- HW: 480 400 907 16
Serial number: 3510002C920F195581D5
Subsystem 5 - Part No SW: ----------- HW: 480 402 607 16
Serial number: 3520002B72095075A13T
Subsystem 6 - Part No SW: ----------- HW: 480 400 606 16
Serial number: 3550002AB20FC7365202
Subsystem 7 - Part No SW: ----------- HW: 480 400 708 16
Component: FrontSensor_P 001 6149
Serial number: 3560002A9215E1C3A3AA
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160825500183
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 044491D78FE91CA427-8050
Part No SW: 5G1 920 856 B HW: 5G1 920 856 B
Component: KOMBI 344 8311
Coding: 0BAD091ABD88CF0502886A095000000000000000
Shop #: WSC 00066 790 00208
VCID: 2D1214737CE33DEC98-8078
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 07071610520038
Coding: 0101000830085900FB00023B9C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07025
ROD: EV_GatewConti_013.rod
VCID: 7CB4E937F71964645F-8028
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000512060046103
Coding: 35FFFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000145234005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 342401179FC96C24D7-8060
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00007.07.16
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0411650476
Coding: 01011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C342937B799A4641F-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0411637306
Coding: 010111
Component: TSG FS 020 0041
Serial number: 090916060500T0
Coding: 003E13200000020000000000
VCID: 43C652CBCA67DB9C5E-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000013793353
Coding: 011000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A382F2FBDAD9A540D-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Revision: 00000001 Serial number: VWZ8Z1GBA028T9C
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6D92D473BC63FDECD8-8038
Component: TSG BFS 020 0041
Serial number: 080916060500YX
Coding: 003E13200C00020000000000
Shop #: WSC 12345 123 61029
VCID: 42C857CFD57DD29455-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000004289925
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021203010B000400
VCID: 40CC5DC7DB71C08443-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0753
Coding: 027300020000000051220002001808009F0203F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3228070F65DD6214C5-8066
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX00AU1
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
U1111 00 [008] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 238
Mileage: 49894 km
Date: 2020.12.29
Time: 14:13:58
Voltage terminal 30: 14.5 V
BAP-BAP_Function_ID: 02
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
ROD: EV_OCULowMQB.rod
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 160702201575
VCID: 6B96DA6B8277F3DCC6-803E
End----------(Elapsed Time: 01:43, VBatt start/end: 14.5V/14.4V)-----------
