5F module
kczach
C?ID=123637
Hi guys,
I scanned my car today after updating to latest version. This is the error I got. The only difference between this and my last scan is the 8 after the 4 zeros. I did change some adaptations but don't believe I changed any coding in the 5F module since there isn't anything in the long coding helper to change. I'm afraid to change the 8 back to a zero willy nilly .
help would be appreciated.
Chris
Wednesday,06,January,2021,09:35:51:49599
VCDS Version: Release 20.12.0 (x64) Running on Windows 10 x64
Address 5F: Information Electr. Labels: 4G1-035-MIB-HGH2.clb
Control Module Part Number: 4G1 035 025 D HW: 4G1 035 025 C
Component and/or Version: MU-H-LNS-US 053 0902
Software Coding: 017551020000800013220002041A00102F0007E5F17001047E
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 (AU57)
VCID: 1F471D3C067C637C1B-804A
U1014 00 [009] - -
Reset counter: 154
Mileage: 35997 km
Date: 2021.01.06
Time: 09:17:42
Voltage terminal 30: 11.7 V
Byte_Coding_Condition-byte_6_condition: ERROR
kczach
C?ID=123637
This is previous coding:
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 D HW: 4G1 035 025 C
Component: MU-H-LNS-US 053 0902
Serial number: A741C0H7535311
Coding: 017551020000000013220002041A00102F0007E5F17001047E
Shop #: WSC 02391 785 00200
VCID: 1F471D3C067C637E12-804A
Subsystem 1 - Part No SW: V03 959 802 DL HW: -----------
Component: NAR 2019 --- 0069
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY807NQ1
Multimedia Operating Unit:
Serial number: 90349QD60002J
Compact Disc Database:
Component: Gracenote2--- --- 3011
@kczach: Hi. "the 8 after the 4 zeros" happens to be Byte 6 on the long-code string which has the value hex80, or in binary 1000 0000. This means that you have set the software switch on Bit 7 - which controls one of the audio channels (#12) in the module.
Should be OK to flip this setting, clear the DTC and see what happens!
kczach
C?ID=123637
Thanks Don,
I flipped the setting and life is good now. Not sure how it got changed in the first place though. I guess it's good to keep logs.
Thanks for your input.
Cheers
Like this?
