SRI rest problem
invernesspl
C?ID=345478
Hi,
Not sure this is a problem with the software or not?
I've just done a SRI reset on a 2018 Seat Ateca Xcellence. The software said successful as usual, and on the dash the car confirms oil service is 365 days etc.
WHen I turn ignition off the car still displays 'Inspection due' on the instrument cluster. It also says Inspection due when you go to the car menu on the dashboard.
Why has this not reset?
Derek
UK (ilexa)
C?ID=56983
Hello
Many V.A.G. cars have separate oil service and inspection routines on them, so it sounds like this car is due a full inspection
You'll need to reset the inspection counters. This can usually be done through the SRI reset option by choosing one of the inspection routines, or if not there there's usually one for distance since last inspection, and another for time since last inspection in the instrument panel adaptations
If you are stuck, please post an autoscan so we can see the system details on the car
Best regards
Derek
invernesspl
C?ID=345478
Hi,
Thanks for the reply. I'll post an autoscan when I'm with the car next.
There was only 2 options in the drop down menu for SRI. one was fixed servicing and the other time & distance. No other options were available.
invernesspl
C?ID=345478
Hello
Best regards
Derek
Actually... I've got a saved autoscan for it here. Ignore all the fault codes, The battery had been allowed to go flat and once charged all these faults were gone after a rescan.
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: VSSZZZ5FZJ6572868 License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 4B 52 5F D6 D7
VIN: VSSZZZ5FZJ6572868 Mileage: 20650km-12831miles
Address 01: Engine (J623-DFFA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BC HW: 04L 907 309 P
Component: R4 2.0l TDI H25 3191
Revision: B4H25---
Coding: 01190012032605093000
Shop #: WSC 33361 790 00117
ASAM Dataset: EV_ECM20TDI01104L906026BC 004002
ROD: EV_ECM20TDI01104L906026BC_004.rod
VCID: 6C81C7D84601FA6BBFA-8038
17158 - Databus
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:42
Engine RPM: 0.00 /min
Coolant temperature: 9 °C
Intake air temperature: 11 °C
Voltage terminal 30: 11.140 V
Unlearning counter according OBD: 30
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Acceleration: 0.000 m/s²
U0428 00 [032] - -
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:41
Voltage terminal 30: 10.860 V
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 61038000000325
Coding: 22EE8A9234270C6E077F070662CB2844512C30E0E046147B30605078E003430000100212121212A635351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 76B5E5B0084D30BB59E-8022
0297 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 179
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:41
8196 - Databus
[FCAN : ACC_10 message is not received]
Reset counter: 181
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:42
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0477661168
Coding: 132C0C0607
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E253D9060FDB8FB41E-806A
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Fault Frequency: 75
Reset counter: 190
Mileage: 15436 km
Date: 2019.11.29
Time: 15:48:39
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition met
Control Module Voltage: 8.034 V
Vehicle speed: 0.0 km/h
Engine RPM: 148.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 13 [008] - Open Circuit
Reset counter: 181
Mileage: 20420 km
Date: 2020.10.03
Time: 06:13:14
ZAT_pressed: OFF
Enabling immobilizer: Condition not met
Control Module Voltage: 14.471 V
Internal_key_position: Kessy_defect
Vehicle speed: 1.5 km/h
Engine RPM: 959.0 /min
Driver door: Open
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
1057291 - Antenna for Keyless Entry System; Passenger Side
B1170 13 [008] - Open Circuit
Reset counter: 181
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: Timeout
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: Timeout
ZAT_pressed: OFF
Control Module Voltage: 12.144 V
Engine RPM: 0.0 /min
Actuation to the inside: active
Driver door: Open
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Part No SW: 5F0 907 044 AL HW: 5F0 907 044 AL
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 06100104200114011005000000101020
Shop #: WSC 33361 790 00116
VCID: 70B9D3A86A291E8B832-8024
Air quality sensor:
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001810701448
ROD: EV_BCMBOSCH_018.rod
VCID: 094F9E4C69B34F4324C-805C
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21321380X81A955555A0
Coding: 80007E
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY180082AGR
Subsystem 3 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Serial number: 00002856223980760909
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Reset counter: 181
Mileage: 20420 km
Date: 2020.10.03
Time: 06:13:03
11018 - Bulb for Left Brake Light
B12C2 15 [008] - Open or Short to Plus
Reset counter: 181
Mileage: 20420 km
Date: 2020.10.03
Time: 06:13:06
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 141
Mileage: 13986 km
Date: 2019.10.13
Time: 13:55:37
204293 - Remote key 1
B1479 54 [008] - Missing Calibration / Basic Setting
Reset counter: 179
Mileage: 20410 km
Date: 2020.09.24
Time: 00:09:30
569092 - Databus
[LCM links - LCM_Feh_LM_L_alt aktiv]
Fault Frequency: 15
Reset counter: 181
Mileage: 20409 km
Date: 2020.08.10
Time: 15:45:45
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 B HW: 5QA 919 283
Component: PDC 4 KanalH07 0044
Serial number: 000308419618101
Coding: 0601150001
ASAM Dataset: EV_EPHVA14AU3700000 009033
ROD: EV_EPHVA14AU3700000_009_AU37.rod
VCID: 49CF5E4C29330F43E4C-801C
13637426 - Databus
Reset counter: 179
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:42
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 2A00608150FF8728749C8145004087
196743 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
[FCTSEN_INC_BLOCKAGE]
Reset counter: 179
Mileage: 20327 km
Date: 2020.08.10
Time: 10:54:27
Voltage terminal 15: 12.9 V
Control Module temperature: 50 °C
Velocity_vehicle_reference: 14.32 m/s
Longitudinal_acceleration_vehicle_reference: 0.81 m/s²
196807 - Databus
[VDY_VEH_VEL_NOT_AVAIL]
Reset counter: 179
Mileage: 20409 km
Date: 2020.08.10
Time: 15:45:44
Voltage terminal 15: 13.2 V
Control Module temperature: 60 °C
Velocity_vehicle_reference: 8.11 m/s
Longitudinal_acceleration_vehicle_reference: -0.13 m/s²
196808 - Databus
[VDY_VEH_YWR_NOT_AVAIL]
Reset counter: 179
Mileage: 20409 km
Date: 2020.08.10
Time: 15:45:42
Voltage terminal 15: 14.4 V
Velocity_vehicle_reference: 21.66 m/s
Longitudinal_acceleration_vehicle_reference: -5.47 m/s²
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[FAULT_VBAT_BUSMON_LOW]
Reset counter: 189
Mileage: 20420 km
Date: 2020.10.05
Time: 06:06:03
Voltage terminal 15: 9.3 V
Control Module temperature: 15 °C
Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W4P73CEN.
Coding: 98CCC0C0000000005C5400CC008800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0557927C45AB2B23404-8050
Subsystem 1 - Part No SW: ----------- HW: 454 000 304 18
Serial number: 357000000008C5506F2P
Subsystem 2 - Part No SW: ----------- HW: 454 000 204 18
Serial number: 35800000000BF5298E2$
Subsystem 3 - Part No SW: ----------- HW: 454 802 803 18
Serial number: 35100072D2A140000005
Subsystem 4 - Part No SW: ----------- HW: 454 800 204 18
Serial number: 35200FBD12314000000H
Subsystem 5 - Part No SW: ----------- HW: 454 801 403 18
Serial number: 355009222C3130000004
Part No SW: 5Q0 953 507 HR HW: 5Q0 953 549 E
Revision: -------- Serial number: 14041804220290
Coding: 1404
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 0D47AA5C1DDB5363084-8058
Part No SW: 5F0 920 951 E HW: 5F0 920 951 E
Component: KOMBI 303 0310
Coding: 27A42012AB80060001886A011000000080000000
Shop #: WSC 73430 031 00117
VCID: 2A0D01C08C75245B0D6-807E
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_AWV_0x1B keine Kommunikation]
Reset counter: 181
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:57
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 181
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:40
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 181
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:40
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 08041810802582
Coding: 030500F40F086A00EB0322480A0F00010001070000000000000000000000
Shop #: WSC 33361 790 00136
ROD: EV_GatewNF_AU37.rod
VCID: 38292B8842D986CB8B2-806C
Generator:
Subsystem 2 - Part No SW: 5F0 959 537 E HW: 5F0 959 537 E
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000H0548160318
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 7588600000180414265D
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [008] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
Fault Frequency: 19
Reset counter: 181
Mileage: 20410 km
Date: 2020.09.24
Time: 00:18:43
Terminal 30 power supply: 11.5 V
Terminal 15: On
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00013.03.18
Coding: 0001
VCID: 4CC1675826411A6BDFA-8018
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000122752018
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 33331CA45BBF6593BE0-8066
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000315984199
Coding: 00311220D001040000001000
Shop #: WSC 33361 790 00135
VCID: 47CB58743F27F933F28-8012
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000020510307
Coding: 3D0000
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B23348473EFADD3660-806E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 11041810522466
Coding: 000000070100065601000900000000000000000000000000000000000000
VCID: 72BDD9A064252C9B756-8026
0030 - Power Output Module for LED Headlamps; Left
U1170 00 [008] - No Communications
[KN_LED_DK3_L no communication]
Fault Frequency: 32
Reset counter: 181
Mileage: 20409 km
Date: 2020.08.10
Time: 15:45:46
66672 - Control Module for Light Activation/Adjustment; Left
U116E 00 [008] - No Communications
[LCM_Feh_LM_L no communication]
Reset counter: 181
Mileage: 20409 km
Date: 2020.08.10
Time: 15:45:46
131353 - Power Output Module for LED Headlamps; Left
[LED_Feh_LM_L_03 no communication]
Reset counter: 181
Mileage: 20409 km
Date: 2020.08.10
Time: 15:45:46
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000316024288
VCID: 46D55570382DE03B09E-8012
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000020593843
Coding: 250000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 858 B HW: 5QA 035 858 B
Component: MU-S-ND-ER H41 0468
Serial number: SEZAZ2U0327506
Coding: 04238601D70A000011110101008808232F0100D601200500C6
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SK25.rod
Subsystem 1 - Part No SW: 575 919 606 HW: 575 919 606
Component: ABT_High-2_N H41 1041
Serial number: SEZ8Z9V1S01JBQ
Subsystem 2 - Part No SW: 6P0 919 866 AB HW: -----------
Component: ECE1 2018 --- 0915
6720 - Rear View Camera
B1102 31 [008] - No Signal
Reset counter: 176
Mileage: 19276 km
Date: 2020.07.02
Time: 12:54:54
Voltage terminal 30: 12.0 V
7195 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 181
Mileage: 20419 km
Date: 2020.09.25
Time: 22:22:08
Voltage terminal 30: 12.9 V
BAP-BAP_Function_ID: 02
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Reset counter: 150
Mileage: 12793 km
Date: 2019.09.17
Time: 10:37:59
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EA5FD90207D78FB01E-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LEDPLUSRightKEBODVW416.rod
End----(Elapsed Time: 01:55, VBatt start/end: 11.6V/11.7V. VIgn 11.6V)-----
Look at these Adaptation channels in your instrument cluster:
IDE03349 -- FIX: Max. distance until next mileage-related inspection
IDE03350 -- FIX: Maximum time until next time-dependent inspection
IDE03351 -- FIX: Distance covered since last mileage-dependent inspection
IDE03352 -- FIX: Time since last time-dependent inspection
I bet "distance since" or "time since" exceeds the respective "maximum until".
Derek
UK (ilexa)
C?ID=56983
VAG cars have more complex service reminders than many cars, and it depends whether the car is on fixed or variable / long life service routine, and which type of oil has been used
The time and distance one sounds right for the inspection, but alternatively, to do it via the instrument cluster adaptations, select the instrument cluster, then choose adaptations
You'll then need to change the stored value in two channels which record the time and distance since the last inspection
The channels to look for will start with FIX. Look for a channel called "FIX distance since last mileage dependent inspection" (or very similar wording) and for one called "FIX time since last time dependent inspection" or similar wording).
The channels will show the time and distance since the last inspection reset and would normally be set to zero after the inspection has been carried out
Best regards
Derek
PS, duplicate of Uwe's post really, but as I'd just finished typing it :)
