Here it is:
Wednesday,11,September,2019,13:33:50:06899
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWVA7AU3KW224506 License Plate: JOHNH
Mileage: 869km-539mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVA7AU3KW224506 Mileage: 869km-539miles
Address 01: Engine (J623-DLRA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0002
Revision: --H13---
Coding: 092500122466010E3004
ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
ROD: EV_ECM20TFS0208V0906259Q.rod
VCID: 4EC56E8630568A47085-801A
23079 - Control unit for information electronics 1
U1054 00 [036] - No Communication
Mileage: 844 km
Date: 2019.09.11
Time: 11:39:34
Engine speed: 0.00 /min
Coolant temperature: 28 °C
Intake air temperature: 31 °C
Voltage terminal 30: 12.226 V
Engine: operating status: ES
ECU_STATE: ENG_STOP
Engine oil temperature: 27.0 °C
Time since engine start: 0.0 s
T_ES: 2464 min
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Large increment: not activated
T_AST_SAE: 0 s
Part No SW: 0GC 300 014 B HW: 0GC 927 711 H
Component: GSG DQ381 H06 2405
Revision: 00H06V08
ROD: EV_TCMDQ381061_VW37.rod
VCID: 2411EC2E0E5A50178E1-8070
Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
Component: ESC H35 0108
Revision: 00000000 Serial number: 61429000000153
Coding: 01FA6BA150222170457C030060C96980D60A84A2C0069677384250D8D2A84B0B0000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 065596A698A68207F05-8052
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 6103275986
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004046
VCID: 43D34FB2EB14772F97B-8016
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420010000110500001211140A
VCID: 6D87C90A9D10515F11F-8038
Air quality sensor:
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
Serial number: 01001916500071
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 0B43A79283C4FF6FAFB-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 190527 043 0551
Serial number: 190604063926
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0205
Serial number: SBY19M06D17H11M45S03
Coding: 0008DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000026041904220842
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418319173
Coding: 0471155811
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CC1648EC64AB857661-8018
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 330000C159FFC728949C810580401600000000000000000004
VCID: 44D14CAEEE1A7017AE1-8010
1127 - Databus
[FAULT_TIMEOUT_PSD_04]
Reset counter: 70
Mileage: 844 km
Date: 2019.09.11
Time: 11:44:27
Control Module temperature: 38 °C
Voltage terminal 15: 12.1 V
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Reset counter: 70
Mileage: 844 km
Date: 2019.09.11
Time: 11:39:34
Control Module temperature: 34 °C
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Reset counter: 70
Mileage: 844 km
Date: 2019.09.11
Time: 11:39:34
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 29051941350960
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3829285EA2D224F7329-806C
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR0C2JUZ
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47CB5BA2DF2C5B0F4B3-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000BKQM62
Coding: 303344
Subsystem 2 - Part No SW: ----------- HW: 480 001 506 19
Serial number: 35700000000C99BCDC3A
Subsystem 3 - Part No SW: ----------- HW: 480 001 506 19
Serial number: 35800000000D659DDC34
Subsystem 4 - Part No SW: ----------- HW: 480 402 106 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001BAF027B83E82F
Subsystem 5 - Part No SW: ----------- HW: 480 401 906 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001B2EFDF5B528B.
Subsystem 6 - Part No SW: ----------- HW: 480 401 706 19
Component: FrontSensor_D 005 6149
Serial number: 35500019EF001347554
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 706 19
Component: FrontSensor_P 005 6149
Serial number: 35600019EF00134777B7
Part No SW: 5G1 920 891 B HW: 5G1 920 891 B
Component: KOMBI 403 4191
Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
VCID: 2C01040E668A9857461-8078
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 03061911601883
Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E85CE069016AA47285-803A
Component: 0-01-0d-01-04
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H12 0052
Serial number: 29190001202500079221
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6062501505
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00021.05.19
Coding: 0001
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000162295012
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F157A41A8F5BF757-8064
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0518970496
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D27394A8DF001DFE1F-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0518489593
Coding: 020111
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS002 0287
Serial number: YE007SEJ06806
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000031062255
Coding: 111000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C21344E96EA08D7D61-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD05AV8-
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E050E065096EA47685-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 09061910804233
Coding: 000000050900165206710F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3537216AB5C0D99F29F-8060
13705489 - Databus
[PSD_04 data bus missing message]
Reset counter: 70
Mileage: 844 km
Date: 2019.09.11
Time: 11:44:27
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS002 0287
Serial number: YE007SDR02869
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000031175699
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 853 0890
Coding: 027310020000000041220002001808009F0507F401200405C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 33331F72BBB4C7AF07B-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H60 8214
Serial number: VWZ6ZJW1431865
Subsystem 2 - Part No SW: 5NA 919 866 E HW: -----------
Component: NAR 2018/19 --- 0810
6678 - Digital sound System control module
U106A 00 [008] - No Communication
[Control module for sound system: no communication]
Reset counter: 54
Mileage: 453 km
Date: 2019.09.01
Time: 20:37:50
Voltage terminal 30: 13.6 V
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H11 0610
Serial number: 05021915K11797
Coding: 0003070000000201002213548150A90084000E20012000
ROD: EV_MFKBoschMQBB_002_VW37.rod
VCID: 40D940BEFA026C378A9-8014
1122664 - Databus
[TIMEOUT_PSD_04]
Reset counter: 70
Mileage: 844 km
Date: 2019.09.11
Time: 11:44:27
Control Module temperature: 36 °C
Outside air temperature: 27.5 °C
Vehicle speed: 0.00 km/h
System run time: 596.5 s
Voltage terminal 15: 12.0 V
mid: 01 F0
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 190419202206
VCID: 2F3B1302579CE34F633-807A
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F2D5A99D83DFFCD7-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 02:01, VBatt start/end: 12.3V/12.3V)-----------
