Cluster/Immo Dying?
SBxx83
Atlanta
C?ID=416193
Hey guys, so my mk5 Jetta is having major problems suddenly. Yesterday I went out to start it and the cluster was dead, I mean completely unresponsive to anything. All of the lighting worked and I could operate the windows, trunk, sunroof, radio, etc. The car would crank and then die. I hooked up VCDS and did a full scan. It said it couldn't communicate with the Immo or Instrument cluster and engine start was being blocked.
Today I go out to the car to grab something and the cluster is back on. Cautiously excited I started the car. It cranked right up and all of the warning lights went off except for the airbag light, this light has never stayed lit before this. I also noticed a clicking sound coming from the glove box area which I had noticed before but would stop after a few seconds after starting the car. I captured video, for the sound, of the clicking. I took a chance and drove the car for about 30 minutes to get it up to temp. When I got home I ran another full auto scan. I have attached both of the scans below.
A few days before these problems occurred I did replace the MAF sensor and the rear left lock actuator.
Any suggestions on what to check before I break down and purchase a new cluster would be a great help.
Autoscan with the cluster "dead"
Monday,04,January,2021,18:58:14:64391
VIN: 3VWDF71K85M617169   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62 72
17-Instruments -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 06A 906 032 QF    HW: Hardware No
   Component: 2.5l R5/4V      G   6608
   Revision: 00000000    Serial number: VWZ7Z0E1678953
   Coding: 0000001
   Shop #: WSC 00066 000 00000
   VCID: 72BDDE4288A099EB547-8026
16497 - Intake Air Temp. Sensor (G42)
            P0113 - 002 - Signal too High - Intermittent
19537 - Engine Temperature too Low
            P3081 - 008 -  - Intermittent
28827 - No Communication with Instrument Cluster
            U0155 - 008 -
17978 - Engine Start Blocked by Immobilizer
            P1570 - 008 -
Readiness: 0010 1000
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   VCID: 3A2D3662905021AB5C7-806E
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   VCID: 6889BC2ABE7C633BFA3-803C
01273 - Fresh Air Blower (V2)
            010 - Open or Short to Plus
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000038962
   Coding: F40D8E02400418000014000000140000002077035C
   VCID: 2F3B17365B12F403FB9-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0060
   Revision: 00000000    Serial number: AUZ4Z7D4020959
   VCID: 2B0303266F0A8823D71-807E
                    Reset counter: 113
                    Mileage: 252549 km
                    Time: 00:00:04
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD00YAST
   Coding: 0012627
   VCID: 2E050A325C18FD0BF0F-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME076941525
   Subsystem 3 - Serial number: 6342MSME0859326AF
   Subsystem 4 - Serial number: 6351HSME060D017E8
   Subsystem 5 - Serial number: 6361HSME0607105C%
   Subsystem 6 - Serial number: 63727SME053A1534Y
   Subsystem 7 - Serial number: 63827SME0611012DS
            002 - Lower Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel        Labels: None
   Part No SW: 1K0 953 549 J    HW: 1K0 953 549 J
   Component: Lenksäulenmodul 010 0040
   Coding: 0002041
   VCID: 392F296E95562AB355D-806C
   Component: Lenkradmodul    007 0050
Address 17: Instruments
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C030B30
   Coding: 3D7F03620F1002
   VCID: 290FF92E65F69A3325D-807C
                    Reset counter: 153
                    Mileage: 251717 km
                    Time: 00:00:01
                    Reset counter: 115
                    Time Indication: 15
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TN5FB03
   VCID: 78A9EC6AEEDCF3BB6A3-802C
                    Reset counter: 115
Address 25: Immobilizer
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 A    HW: 3C0 959 760 A
   Component: Sitzverstellung     0601
   Revision: 00002000    Serial number: 00000000000000
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   VCID: 36352252A448C5CBB8F-8062
01552 - Motor for Central Locking; Drivers Door (V56); Lock
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.2       1502
   VCID: 3039144A462CEBFBE23-8064
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component:    KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13100F880106281B0906050FA0080F0490A540
   Shop #: WSC 00053 444 05056
   VCID: 025D8E82B800A96B447-8056
   Component: LIN BACKUP HORN H02 1301
                    Fault Frequency: 13
                    Reset counter: 113
                    Mileage: 252549 km
                    Time: 00:00:51
                    Fault Status: 01101100
                    Fault Frequency: 61
                    Reset counter: 113
                    Mileage: 252549 km
                    Time: 00:00:27
                    Reset counter: 112
00122 - Outside Warning Light/Door Exit Light; Rear Left
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 113
                    Mileage: 252549 km
                    Time: 00:00:27
                    Reset counter: 153
                    Mileage: 252549 km
                    Time: 00:00:51
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000010209
   VCID: 698FB92EA5765A33E5D-803C
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 372B2F56A3423CC3A39-8062
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
   Part No SW: 1K0 035 180     HW: 1K0 035 180
   Component: Radio ZSW       015 0016
   Revision: 00015000    Serial number: VWZ5Z7E6260639
   Coding: 0010010
   VCID: 5DE79DFE613E3693195-8008
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 313F114E4D26E2F3EDD-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D1E424820D9EB947-8066
End----(Elapsed Time: 01:13, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Full Scan Today
Tuesday,05,January,2021,13:57:46:64391
VIN: 3VWDF71K85M617169   License Plate: CPT1913
Mileage: 252640km-156983mi   Repair Order:
VIN: 3VWDF71K85M617169   Mileage: 252640km-156983miles
   Coding: 0000001
            U0155 - 008 -  - Intermittent
            P1570 - 008 -  - Intermittent
Readiness: 0010 1100
   Coding: 0021122
   Coding: 00065493
   Coding: 00217125
                    Reset counter: 115
   Coding: 0012627
            004 - No Signal/Communication - Intermittent - MIL ON
   Coding: 0002041
   Part No: 1K0 920 971 C
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   Shop #: WSC 14702 009 13958
00003 - Control Module
            014 - Defective
01335 - Drivers Seat/Mirror Position Control Module (J543)
                    Reset counter: 153
                    Mileage: 251717 km
                    Time: 00:00:01
                    Fault Frequency: 23
                    Reset counter: 155
                    Time Indication: 15
                    Reset counter: 155
   Component: IMMO            3HL 2120
   Coding: 0001271
                    Fault Frequency: 14
                    Reset counter: 115
                    Fault Frequency: 62
                    Reset counter: 115
                    Reset counter: 112
                    Reset counter: 115
                    Reset counter: 153
                    Mileage: 252549 km
                    Time: 00:00:51
   Coding: 0001271
   Coding: 0010010
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:16, VBatt start/end: 14.0V/13.8V)-----------
siLc
Tallinn, Estonia
C?ID=330192
Could very well be a dying cluster. Though check fuse 17 in the engine bay fuse box (under the plastic cover) - thats supply voltage for the cluster. Should be getting battery voltage from it. There is another ignition voltage fuse (nr 2) for the cluster in the dash fusebox but that also feeds other systems which appear to be working correctly.
SBxx83
Atlanta
C?ID=416193
Thanks siLc, I'll check that out once I pickup my multimeter from Summit
NostraJackAss
Change ignition switch, remove cluster, clean contacts, apply Stabiliant 22a, reinstall after cure time, see what happens?
Clear codes full reboot.
If controller still shows error, change cluster.
SBxx83
Atlanta
C?ID=416193
Hey Jack, thanks for the suggestions. Question? Any idea what that clicking sound, in the video, from behind the glove box might be? :confused:
NostraJackAss
Did you follow the clicking yet or pull fuses to see what stops it & observe WD in RTFB or use a stethoscope/fingering it?
SBxx83
Atlanta
C?ID=416193
Hey Jack, I went through my Bentley last night and wrote down the possible culprits. I will be pulling the fuses for those today and will update back here. My worry is that it's the CCM, fingers crossed it's not, could possibly be the blower motor control since the "dealer" replaced it before I picked up the car.
SBxx83
Atlanta
C?ID=416193
Mk5 with Climatronic. The temperature regulating flaps might make a clicking sound but thats a bit loud for this. Autoscan shows it being unhappy with the cabin fan - is that working OK?
Try Climatronic flap alignment - http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Climatronic
Sorry for the late reply, it's been either below freezing and/or raining here for the past week. That seemed to do the trick!! :D Thanks for the suggestion. Fingers crossed it doesn't come back.
SBxx83
Atlanta
C?ID=416193
So, just an update. I am still waiting for the Stabiliant 22a to come in that I ordered but so far I haven't had a problem with the Cluster not coming on or the car not starting.
She's idling rough now, I suspect it may be the new MAF sensor that I put in it. I will be swapping the old one back in to see if that resolves the issue. Will update.
One question, I did a search and wasn't able to come up with anything. Is there a list that anybody can point me to that names all of the parts/sensors/modules that should be reset/recoded/etc after replacement?
