My son has a 2017 Audi S1 with the 2 litre 231bhp TSI engine. It has covered approx 15000 miles and is regularly serviced.
However, this morning he started the car up and said it made a loudish noise which he couldn't describe and an error message flashed up saying the Stop/Start system was not working. He turend the engine off, restarted and all appeared well. The stop/start sytem appeared to work OK throughout his short journey.
When he returned home we put the VCDS on the car and came up with the following:
The fault code was cleared and has not yet reappeared.
Was this a glitch? What was the noise?
Any thoughts?
Tuesday,05,January,2021,09:16:12:03359
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WAUZZZ8XXHB076535 License Plate:
Mileage: 24580km-15273mi Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 10 14 15 16 17 19 20 22 25 42 44 46 47 52 55 5F
62 72 A9
VIN: WAUZZZ8XXHB076535 Mileage: 24580km-15273miles
Address 01: Engine (J623-CWZA) Labels:. 06K-907-425-V1.clb
Part No SW: 8X0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A1900322426010B0002
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_ECM20TFS0208X0906259 001007
ROD: EV_ECM20TFS0208X0906259.rod
VCID: 7F5AF645977DAD030A8-802A
14874 - Camshaft Position Sensor (G40)
P0341 00 [032] - Implausible Signal
Mileage: 24569 km
Date: 2021.01.05
Time: 08:34:12
Engine RPM: 1227.50 /min
Normed load value: 12.9 %
Coolant temperature: 4 �C
Intake air temperature: 2 �C
Voltage terminal 30: 11.484 V
Engine: operating status: IS
STATE_VCP: passive
Engine oil temperature: 3.0 �C
CAM_VCP[IN_1]: 35.945 �
CAM_SP_IND_VCP[IN_1]: 0.000 �
STATE_CRK_STST: CRK_STST_ACQ_SHO_LEVEL
Time since engine start: 0.5 s
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 S HW: 6R0 907 379 BA
Component: ESP9.0i H04 0006
Serial number: 08507088170228
Coding: 36DF708B8D2A33C64919306C00566C0EB1CC920C0013E2090F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 3FDAB645D7FD6D034A8-806A
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 8XA 820 043 HW: 8XA 820 043
Component: Klima 1 Zone H01 0010
Serial number: 00000000451571
Coding: 6423080890
ASAM Dataset: EV_AirCondiFrontAU210 007002
ROD: EV_AirCondiFrontAU210_007.rod
VCID: 025C7FB1E48FC0EB656-8056
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AF HW: 8X0 907 063 AF
Component: BCM PQ35 M 113 0821
Revision: AB113821
Coding: 08000A2CA805F1C0201841E82104084C53F7620A21EF5D22E408878700C5
Shop #: WSC 00046 000 00000
VCID: 005875B9EA03D2FB732-8054
Subsystem 1 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62669392
Coding: 02005D
Subsystem 2 - Part No: 8X0 951 177 A
Component: Sensor, DWA 0 005 0002
Subsystem 3 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 AL HW: 8X0 919 475
Component: PARKHILFE 4K H03 0090
Revision: 11001001 Serial number: 37031705206910
Coding: 000007
ASAM Dataset: EV_EPHVA14AU21X0000 003008
ROD: EV_EPHVA14AU21X0000_003.rod
VCID: 107845F9BAE3A27BE32-8044
Address 14: Susp. Elect. (J250) Labels: 6C0-907-359.clb
Part No SW: 6C0 907 359 HW: 6C0 907 359
Component: DAEMPFUNGS-SG H04 0007
Serial number: 28021702000043
Coding: 82
ASAM Dataset: EV_SwitcDampeContiTemic 001004
ROD: EV_SwitcDampeContiTemic.rod
VCID: 6A8C3711FCFF38ABCD6-803E
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8XA 959 655 A HW: 8XA 959 655 A
Component: Airbag10.41 H08 0011
Revision: -------- Serial number: 003NZ004BT0J
Coding: 30323236303330323438554A305238584153
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 59EE78DD2999A33354C-800C
Serial number: 3554VRB400A597JQEPMC
Serial number: 3575HRB400857I2G6PPJ
Serial number: 3585HRB405V44NL631CI
Rear end impact crash sensor:
Serial number: 3515ZRB400M578J0QH0N
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 AF HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: FF010018 Serial number: 20170304300898
Coding: 1084204000
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 005875B9EA83D2FB732-8054
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Serial number: 20 02 2017 B0042543
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8XA 920 980 G HW: 8XA 920 980 G
Component: KOMBI_MEDIUM H05 0530
Coding: 43CE01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
VCID: 54F089E94E7B9E5B87A-8000
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0090
Revision: 1P170044 Serial number: 4441P172200541
Coding: FBCF1059000100010353
VCID: 117E40FDB169AB73ECC-8044
Subsystem 1 - Part No SW: 7P0 915 181 C HW: 7P0 915 181 C
Component: Batt_Sensor H07 0270
Serial number: 34039B35475811187951
Serial number: 160628000000000006BC
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 8X0 857 511 AA HW: 8X0 857 511 AA
Component: FLA H03 0005
Revision: AA001001
Coding: 02020E64747464545425363E00
ASAM Dataset: EV_HighBeamAssisAU210 001019
ROD: EV_HighBeamAssisAU210.rod
VCID: 7DA60C4D9D71BF13184-8028
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00010.01.17
Coding: 0201
VCID: 52FC8FF1746F906B956-8006
Component: IMMO H05 0530
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 K HW: 8X0 959 793 K
Component: TSG FA H11 0415
Coding: 011E02204001000000
VCID: 55F674ED45018753704-8000
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R2 909 144 AM HW: 6R2 909 144 E
Component: EPS_TRW_ALow 323 3142
Serial number: CH2O0002
Coding: 802700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 03527AB5FB95C9E36E0-8056
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 8X0 035 223 D HW: 8X0 035 223 B
Component: BOSE-G3-A1Q3 H05 0160
Revision: CK005201 Serial number: 00000000069115
Coding: 030000
VCID: 3332EA75EB35B963BE0-8066
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 K HW: 8X0 959 792 K
Component: TSG BF H11 0415
VCID: 54F089E94EFB9E5B87A-8000
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 E HW: 8X0 907 357 B
Serial number: 170227-0002-034
Coding: 11B3AC1010002500
ROD: EV_HeadlRegulBasic.rod
VCID: 44D0B9A9BE1B0EDB17A-8010
Part No SW: 8XA 035 192 F HW: 8XA 035 192 A
Component: RMC Nav Plus H62 0186
Coding: 0101040200C053470023020103020100000000
VCID: 4BC2929593C5C1A3D60-801E
Subsystem 1 - Part No SW: 8X0 919 603 B HW: 8X0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9462BI0H3112023
Address 62: Door, Rear Left (J388) Labels:. 8X0-959-795.clb
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H08 0415
Coding: 010802200001000000
VCID: 50F885F97AE3E27BA32-8004
Address 72: Door, Rear Right (J389) Labels:. 8X0-959-795.clb
Component: TSG HR H08 0415
Part No SW: 8X0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 160505201239
VCID: 42DCBFB1A40F00EB256-8016
End----------(Elapsed Time: 01:35, VBatt start/end: 14.5V/14.7V)-----------
Any thoughts?
