Security Access Code for HVAC Controller 08
George Ab
C?ID=232965
Unable to access my HVAC 08 controller. I replaced the Climatronic unit with an Auto Climatronic hardware part number 51G 907 044 K. I want to access adaptations to change the retention of drivers seat heater level from 10 min to active, so it keeps last setting when car is started. I tried 20103 with no joy (incorrect security code) which I found here: https://forums.ross-tech.com/index.php?threads/12448/
Thanks in advance.
Monday,04,January,2021,17:45:23:51554
VCDS Version: 20.12.0.1 (x64)
VIN: 3VW4T7AUXFM024280   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0405
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 13327 002 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C79F7E347C255E48E-8078
Readiness: 1110 1100
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4511
   Revision: 05852204    Serial number: TFK01406072403
   Coding: 0018
   Shop #: WSC 00066 790 00149
   ROD: EV_TCMDQ250021.rod
   VCID: 29770EF7483040CC75-807C
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51864000001328
   Coding: 01FA6BA1342209700079020881C32980D62C9000408194B400430050C006
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 44A9BF43CF52BDA466-8010
   Revision: 00021000    Serial number: 0338563827
   Coding: 030C0C
   VCID: 3A55C1BBBD96FB540C-806E
Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
   Part No SW: 51G 907 044 K    HW: 51G 907 044 K
   Component: Climatronic   H02 0102
   Revision: 00001
   Coding: 00020004200010010004000000101000
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001027
   ROD: EV_AirCondiBHTCMQB3rTranc_VW37.rod
   VCID: 3041E3936BEA3104B2-8064
No ASAM data for: "EV_AirCondiBHTCMQB3rTranc" (VW37)
13 Faults Found:
196866 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:53
197378 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:53
197122 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:53
328197 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:54
328199 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:54
329477 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:54
329479 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:54
329989 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:54
459015 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:53
328965 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:54
262402 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:53
262404 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:53
329991 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:38:54
   Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580608141223
   Coding: 00111A464041A26969E44000011407201800000000000000000000000000
   Shop #: WSC 00066 790 00180
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 46ADA54BF96E8FB478-8012
   Component: WWS    140714  043 0581
   Serial number:         140807083646
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M07D24H11M13S13
   Coding: 06A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO2853977F
   Coding: 181801
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00NWPF
   VCID: 518786170020580CDD-8004
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001138R0O
   Coding: 303331
   Subsystem 2 - Part No SW: -----------    HW: 480 002 406 14
   Serial number: 35700000000DD550101A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 506 14
   Serial number: 3580000000035228301/
   Subsystem 4 - Part No SW: -----------    HW: 480 403 107 14
   Serial number: 3510002C916DB80392A9
   Subsystem 5 - Part No SW: -----------    HW: 480 400 108 14
   Serial number: 35200029916DB80590EB
   Subsystem 6 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3550002991617D20A1F3
   Subsystem 7 - Part No SW: -----------    HW: 480 401 606 14
   Serial number: 3560002B11617D21A22U
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140616400091
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04297F438FD27DA426-8050
Address 17: Instruments
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003204912
   Coding: 0105000820085900CF00002A1C0F00000001050000000000000000000000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72C5299BA566431404-8026
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27140001281020044216
   Coding: 29FFFF
   Revision: 00000000    Serial number: 14000160490002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449EF839FF20D24D6-8060
   Serial number: 050814060506W6
   Coding: 003F13205000040000000000
   VCID: 40A1B353DB4AA18442-8014
   Serial number: 00000000000002981047
   Coding: 011000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 354FD2879488142CE1-8060
   Serial number: 05081406050BS9
   Coding: 003F13205C00040000000000
   VCID: 3FA3B0AFA6B4DE7C3B-806A
   Serial number: 00000000000003143183
   Coding: 191000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 021A01000B000400
   Shop #: WSC 01608 666 28888
   VCID: 3D5FCAA7ACB8CC6C29-8068
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Coding: 02730000FF00000051220001001808001F0503D40120050002
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2E7DFDEB71DE27F4A0-807A
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H43 4060
   Serial number: VWZ6Z9R1630234
9 Faults Found:
          B11CF 53 [009] - Deactivated
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:52
                    Voltage terminal 30: 12.1 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 138 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:44
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:45
0517 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:44
0518 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:45
0522 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:44
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:45
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:44
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 178
                    Mileage: 103579 km
                    Date: 2021.01.04
                    Time: 17:41:45
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Shop #: WSC 00066 790 00122
   ROD: EV_OCULowMQB.rod
   VCID: 0225795B95C6739414-8056
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 178
   Component: SAS-GEN 2     H06 0013
   Serial number: 140521200176
   VCID: 6BFB34FF824C92DCC7-803E
End-------------------------(Elapsed Time: 03:08)--------------------------
I suspect that Climatronic is too new to be fully compatible with your old Micro-CAN interface.
George Ab
C?ID=232965
Epilogue: So the Climatroinc dual zone unit I installed was from the VW China market part number 51G 907 044 K. The unit was slightly different as in place of Max AC button is a Clean Air button and could not change adaptation settings. Since retaining last seat heating value was important to me and the cost of a used unit was not prohibitively expensive I purchased a 5G0 907 044 BD Climatronic dual zone unit used in European and NAR market. Unit accepted adaptations without need of security code. My tush is warm and happy.
