Please i need an assistance on abs long coding.Attached is the full scan of the vehicle.
Chassis Type: AW-VW27 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 3C 44 55 5F CA D6 D7
VIN: AAVZZZAWZKU101836 Mileage: 56750km-35262miles
CA-Sunroof -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DKJA) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 H HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 5177
Revision: D7H20000
Coding: 0125003223241D080000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM10TFS01104C906025H 001006
ROD: EV_ECM10TFS01104C906025H_001.rod
VCID: 2502F1A22485B3AC51-8070
13 Faults Found:
4531 - Fan 1 Control Circuit
P0691 00 [039] - Short to GND
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:57
Engine RPM: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 105 °C
Intake air temperature: -40 °C
Ambient air pressure: 470 mbar
Voltage terminal 30: 2.161 V
4348 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 00 [039] - -
[A/C control moduleRead out DTC]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:47
Voltage terminal 30: 7.281 V
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:47
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
[ABS brake control moduleRead out DTC]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:49
10258 - Vehicle Speed Sensor
P0501 00 [167] - Implausible Signal
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:47
U0428 00 [039] - -
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:47
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:47
5531 - Camshaft Position Sensor (G40)
P0343 00 [167] - Signal too High
Mileage: 56750 km
Date: 2020.10.22
Time: 00:29:03
Engine RPM: 361.50 /min
Normed load value: 25.1 %
Ambient air pressure: 410 mbar
Voltage terminal 30: 57.457 V
5533 - Camshaft Position Sensor B Bank 1 (G300)
P0368 00 [167] - Signal too High
Mileage: 56750 km
Date: 2020.10.22
Time: 00:29:03
4654 - Brake Booster Pressure Sensor
P0556 00 [039] - Implausible Signal
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:49
4130 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0108 00 [039] - Signal too High
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:48
20567 - Intercooler Temperature Sensor (Bank 1)
P007D 00 [039] - Short to Plus
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:48
4278 - Implausible Data Received from ABS Control Module
U0415 00 [167] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:47
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 043 P HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1602
Revision: 00005008 Serial number: CU501904067441
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW27.rod
VCID: 44C44C26CFFF6AA466-8010
Part No SW: 2Q0 614 517 AE HW: 2Q0 614 517 L
Component: ESC_base H13 0242
Serial number: 08508636190409
Coding:
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0_004.rod
VCID: 71AAD5F2A0CDAF0CFD-8024
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[IISOEMCalibrationError]
Reset counter: 136
Mileage: 56732 km
Date: 2020.10.09
Time: 00:00:04
1360 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [153] - -
[LWI_SensorNotCalibrated]
MIL ON - Confirmed - Not Tested Since Memory Clear
Reset counter: 146
Mileage: 56732 km
Date: 2020.10.11
Time: 01:52:23
0883 - Control module not coded
U1013 00 [153] - -
[VehicleConfigUncoded]
Reset counter: 136
Mileage: 56732 km
0797 - Rear Left Wheel Speed Sensor
C101C 4A [137] - Incorrect component(s) installed
Reset counter: 155
Mileage: 56750 km
Date: 2020.10.22
Time: 00:29:46
0798 - Rear Right Wheel Speed Sensor
C101D 4A [137] - Incorrect component(s) installed
Reset counter: 155
Mileage: 56750 km
Date: 2020.10.22
Time: 00:29:44
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 2G2 820 045 D HW: 2G2 820 045 D
Component: SG_AC_Manuell H50 0301
Coding: 012100000800000001000800020000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001011
ROD: EV_ACManuePrehMQBA0_VW27.rod
VCID: 2208EABE35AB449434-8076
590082 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Fault Frequency: 101
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:27
Compressor shut-off condition: Malfunction at
refrigerant pressure sensor
Compressor current: specified value: 0.000 A
Voltage terminal 30: 14.1 V
Outside temperature: 28.5 °C
Engine RPM: 926 /min
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:26
Temperature downstream of evaporator: 32.3 °C
System run time-Engine running time: 68 s
Engine RPM: 986 /min
Part No SW: 2Q0 937 090 A HW: 2Q0 937 090
Component: BCM A0 Std+ H98 0926
Serial number: 00001912300922
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_204.rod
VCID: 302C10F66B47E604B2-8064
Driver door control module:
Subsystem 1 - Part No SW: 2Q2 959 405 B HW: 2Q2 959 163 B
Component: FHSG_DRV 002 0005
Serial number: 00000000000029144904
Coding: 1F0037
Front passenger door control module:
Subsystem 2 - Part No SW: 2Q2 959 406 B HW: 2Q2 959 164 B
Component: FHSG_PSG 002 0005
Serial number: 00000000000029549375
Coding: 058037
Serial number: 000000000ZY190640754
Serial number: 00000000000046784169
Subsystem 5 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000029621205
Coding: 1F0000
Subsystem 6 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000029578694
Coding: 070000
589829 - Window Regulator; Rear Driver Side
B131F 54 [009] - Missing Calibration / Basic Setting
Reset counter: 0
Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: 0
Zusaetzliche Umgebungsdaten-Automatic high beam
assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not
operated
Zusaetzliche Umgebungsdaten-Parking light right: Not
operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: 33
Zusaetzliche Umgebungsdaten-Status
Bremslichtschalter (CAN): OFF
Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
590853 - Window Regulator; Front Drivers Side
B14D1 54 [009] - Missing Calibration / Basic Setting
Reset counter: 0
operated
operated
591108 - Window Regulator Motor; Front Driver Side
U120D 00 [008] - No Communications
[Motor für Fensterheber vorn Fahrerseite-> keine Kommunikation]
Reset counter: 195
Mileage: 56750 km
Date: 2020.10.21
Time: 00:00:15
operated
operated
Zusaetzliche Umgebungsdaten-voltage measurement: 12.0 V
591363 - Motor for External Mirror Folding; Driver Side
B1745 07 [008] - Mechanical Failure
Reset counter: 195
Mileage: 56750 km
Date: 2020.10.21
Time: 00:01:04
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
operated
operated
Zusaetzliche Umgebungsdaten-last wakeup: 45
Zusaetzliche Umgebungsdaten-voltage measurement: 14.5 V
591372 - Motor for External Mirror Folding; Driver Side
B1745 01 [008] - Electrical Failure
Reset counter: 195
Mileage: 56750 km
Date: 2020.10.21
Time: 00:01:02
operated
operated
Zusaetzliche Umgebungsdaten-voltage measurement: 14.4 V
592133 - Window Regulator; Front Passenger Side
B14D2 54 [009] - Missing Calibration / Basic Setting
Reset counter: 0
operated
operated
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418019114
Coding: 0471055011
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000.rod
VCID: 4CD46406E7AFA2E4AE-8018
14 Faults Found:
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [009] - Open Circuit
Fault Frequency: 49
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 02:36:29
13637408 - Databus
[Bremsensteuergerät - ESP_02.ESP_Gierrate - Fehlerspeicher
auslesen]
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:23
13637409 - Databus
[Bremsensteuergerät - ESP_10.ESP_WegimpulsHL - Fehlerspeicher
auslesen]
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
13637410 - Databus
[Bremsensteuergerät - ESP_10.ESP_WegimpulsHR - Fehlerspeicher
auslesen]
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:25
13637412 - Databus
[Bremsensteuergerät - ESP_10.ESP_WegimpulsVR - Fehlerspeicher
auslesen]
Fault Frequency: 13
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:47
13637411 - Databus
[Bremsensteuergerät - ESP_10.ESP_WegimpulsVL - Fehlerspeicher
auslesen]
Fault Frequency: 13
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:47
13637419 - Databus
[Bremsensteuergerät - ESP_02.ESP_Laengsbeschl - Fehlerspeicher
auslesen]
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:23
13637421 - Databus
[Bremsensteuergerät - ESP_21.ESP_v_Signal - Fehlerspeicher
auslesen]
Fault Frequency: 22
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:47
13637422 - Databus
[ESP - ESP_19.ESP_HL_Radgeschw_02 - Fehlerspeicher auslesen]
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
13637423 - Databus
[ESP - ESP_19.ESP_HR_Radgeschw_02 - Fehlerspeicher auslesen]
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:25
13637424 - Databus
[ESP - ESP_19.ESP_VL_Radgeschw_02 - Fehlerspeicher auslesen]
Fault Frequency: 13
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:47
13637425 - Databus
[ESP - ESP_19.ESP_VR_Radgeschw_02 - Fehlerspeicher auslesen]
Fault Frequency: 13
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:47
13637426 - Databus
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:23
13688835 - Databus
[Steuergerät für Rear Cross Traffic Alert -
RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
Component: VW22Airbag 010 0248
Revision: --------
Coding: 88CCC000000000005C0000CF008800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 02488A3E956BA49414-8056
Subsystem 1 - Part No SW: ----------- HW: 442 061 704 19
Serial number: 3577Y20B5301172311AH
Subsystem 2 - Part No SW: ----------- HW: 442 061 704 19
Serial number: 3587Y209D308DEE2454J
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 404 19
Serial number: 3517711A93011D80F144
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 404 19
Serial number: 3527711A73011D84308+
Subsystem 5 - Part No SW: ----------- HW: 442 131 705 19
Component: FrontSensor_D 290 118A
Serial number: 355AG11BB306E67261F.
10 Faults Found:
1049093 - ROD - Unknown Error Code
- 00 [009]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
1049094 - ROD - Unknown Error Code
- 00 [009]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
1049095 - ROD - Unknown Error Code
- 00 [009]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
1052933 - Databus
[NWD: 0x0FD ESP_21 error value ESP_v_Signal]
Reset counter: 195
Mileage: 56751 km
Date: 2020.10.22
Time: 09:13:49
1053189 - Databus
[NWD: 0x0B2 ESP_19 error value ESP_VL_Radgeschw_02]
Reset counter: 195
Mileage: 56751 km
Date: 2020.10.22
Time: 09:13:49
1053190 - Databus
[NWD: 0x0B2 ESP_19 error value ESP_VR_Radgeschw_02]
Reset counter: 195
Mileage: 56751 km
Date: 2020.10.22
Time: 09:13:49
1053191 - Databus
[NWD: 0x0B2 ESP_19 error value ESP_HL_Radgeschw_02]
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
1053192 - Databus
[NWD: 0x0B2 ESP_19 error value ESP_HR_Radgeschw_02]
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
1055237 - Databus
[NWD: 0x11E ESP_08 error value ESP_v_ref]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
B13BC F2 [137] - No function
Fault Frequency: 96
Mileage: 56732 km
Date: 2020.10.11
Time: 31:02:02
Part No SW: 2G0 920 740 C HW: 2G0 920 740 C
Component: KOMBI 310 2660
Coding: 24A4010829800008010822085001000000000000
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_DashBoardVDDMQBA0 001037
ROD: EV_DashBoardVDDMQBA0_VW27.rod
16776973 - Databus
[RKA_01 keine Kommunikation]
Fault Frequency: 25
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
13637376 - Databus
[Steuergerät für Bremse: bitte Fehlerspeicher auslesen]
Fault Frequency: 70
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:46
9456433 - Key
B104B 31 [008] - No Signal
Fault Frequency: 21
Date: 2020.10.11
Time: 02:51:13
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 24041910801173
Coding: 030100046F085600FB0000481C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 6E90CE8EB1F3B0F4E0-803A
Generator:
Component: 0-00-02-00-04
Subsystem 2 - Part No SW: 2G0 959 442 J HW: 2G0 959 442 J
Component: E221__MFL-DC1 H03 0052
Serial number: 39190000869500089143
Coding: 28FFFF
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 1010E9F0
8782090 - Cruise Control Switch
B1154 96 [008] - Component internal failure
Fault Frequency: 37
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:23
Terminal 30 power supply: 13.8 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [008] - Warning Triggered
Reset counter: 188
Mileage: 56733 km
Date: 2020.10.11
Time: 02:36:30
Terminal 30 power supply: 9.8 V
Terminal 15: On
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H05 0052
Serial number: 00000516668563
Coding: 90014500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15_001_VW27.rod
VCID: 383C28D683373E44FA-806C
10 Faults Found:
2240523 - Databus
[databus error value received - ESP_10 - ESP_Wegimpuls_HL]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:29:47
2240519 - Databus
[databus error value received - ESP_10 - ESP_QBit_Wegimpuls_HL]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:09
2240524 - Databus
[databus error value received - ESP_10 - ESP_Wegimpuls_HR]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:29:45
2240520 - Databus
[databus error value received - ESP_10 - ESP_QBit_Wegimpuls_HR]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:09
2240521 - Databus
[databus error value received - ESP_10 - ESP_Wegimpuls_VL]
Mileage: 56750 km
Date: 2020.10.22
Time: 00:28:09
2236417 - Databus
[databus unreasonable message - LWI_QBit_Lenkradwinkel]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
2240516 - Databus
[databus error value received - ESP_02 - ESP_Gierrate]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
2240515 - Databus
[databus error value received - ESP_02 - ESP_QBit_Gierrate]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
2236426 - Databus
[databus unreasonable message - LWI_Lenkradwinkel]
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
1572884 - Warning Lamp for Blind Spot Detection in Right Exterior Mirror
C122D 15 [008] - Open or Short to Plus
Reset counter: 31
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CE420313
Coding: 0007
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 33261FFA9A51DD1CCF-8066
1053952 - Databus
[DEM_VEH_SPD_INVALID_FAULT]
Fault Frequency: 18
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:47
Engine RPM: 0 /min
Vehicle speed: 0.53 km/h
Terminal 15 status: Terminal 15 on
Voltage terminal 30: 11.04 V
Power steering current consumption: 0.50 A
max.value: 0.50 A
End stage temperature: 35 °C
Steering assistance: engine output: 0.00 %
Engine angle: 0 °
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: -0.13 Nm
Status: OK
1057792 - Databus
[DEM_WHEEL_SPD_INVALID_FAULT]
Fault Frequency: 48
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
Engine RPM: 957 /min
Vehicle speed: 0.00 km/h
System status: Driving mode
Voltage terminal 30: 13.98 V
Power steering current consumption: 0.52 A
max.value: 44.97 A
End stage temperature: 37 °C
Steering assistance: engine output: 100.00 %
Engine angle: 63 °
Steering assistance: target engine torque: 0.03 Nm
Steering torque: -0.14 Nm
Status: OK
1094656 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:22
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 178C000009200003
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41CA4532D0ED7F8C4D-8014
9 Faults Found:
13706047 - Databus
[Empfangener Fehlerwert im Signal LV_Abblendlicht_re_def]
Reset counter: 191
Mileage: 56735 km
Date: 2020.10.11
Time: 06:13:53
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:23
66673 - Control Module for Light Activation/Adjustment; Right
U116F 00 [008] - No Communications
Reset counter: 191
Mileage: 56735 km
Date: 2020.10.11
Time: 06:13:51
131361 - Power Output Module for LED Headlamps; Right
U1171 00 [008] - No Communications
Reset counter: 191
Mileage: 56735 km
Date: 2020.10.11
Time: 06:13:52
13705985 - Databus
[Fehlerwert im Signal ESP_HL_Radgeschw]
Fault Frequency: 54
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:24
13705987 - Databus
[Fehlerwert im Signal ESP_HR_Radgeschw]
Fault Frequency: 54
Reset counter: 155
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:25
13705984 - Databus
[Fehlerwert im Signal ESP_VL_Radgeschw]
Fault Frequency: 23
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:46
13705986 - Databus
[Fehlerwert im Signal ESP_VR_Radgeschw]
Fault Frequency: 23
Reset counter: 195
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:46
U1400 00 [008] - -
[Funktionseinschraenkung durch Unterspannung - unterer
Grenzwert unterschritten]
Reset counter: 188
Part No SW: 3Q0 035 824 C HW: 3Q0 035 824 C
Component: MU-S--ER 724 0890
Coding: 02720000BE00000041110001000918211F0500C60120010003
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2D1209827C758BEC99-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H52 8130
Serial number: VWZ6ZJW1132501
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to
communication error - BapErr_retry not successful]
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:26
Voltage terminal 30: 14.0 V
BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake (0x26) - function restriction due to communication
Reset counter: 148
Mileage: 56733 km
Date: 2020.10.11
Time: 01:56:26
Part No SW: 4K0 907 594 AB HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 508000727001
VCID: 74A4DCE6DFDF9A2416-8020
0376 - Databus
[Brake control module: message counter error ESP_21]
Fault Frequency: 11
Reset counter: 195
Mileage: 56735 km
Date: 2020.10.11
Time: 05:44:31
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
1136 - Databus
U1123 00 [174] - Received Error Message
[CAN signal value implausible/error]
Fault Frequency: 37
Reset counter: 0
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:49
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
1136 - Databus
Fault Frequency: 38
Reset counter: 0
Mileage: 56733 km
Date: 2020.10.11
Time: 02:37:49
End----------(Elapsed Time: 01:19, VBatt start/end: 14.2V/14.2V)-----------
