AutoScan: 3VWC57BU8KM054019
blockmap-01-04E-906-024-L_3VWC57BU8KM054019-20201205-1700.CSV
blockmap-01-04E-906-024-L_3VWC57BU8KM054019-20201205-1713.CSV
blockmap-02-09S-927-158-R_3VWC57BU8KM054019-20201205-1701.CSV
blockmap-03-5Q0-614-517-CT_3VWC57BU8KM054019-20201205-1701.CSV
blockmap-08-5GM-907-426-H_3VWC57BU8KM054019-20201205-1702.CSV
blockmap-09-5Q0-937-087-AR_3VWC57BU8KM054019-20201205-1702.CSV
blockmap-15-5Q0-959-655-AG_3VWC57BU8KM054019-20201205-1705.CSV
blockmap-17-17A-920-840_3VWC57BU8KM054019-20201205-1658.CSV
blockmap-19-3Q0-907-530-K_3VWC57BU8KM054019-20201205-1659.CSV
blockmap-42-5Q4-959-393-E_3VWC57BU8KM054019-20201205-1706.CSV
blockmap-44-5QM-909-144-B_3VWC57BU8KM054019-20201205-1706.CSV
blockmap-52-5Q4-959-392-E_3VWC57BU8KM054019-20201205-1706.CSV
blockmap-5F-17A-035-868_3VWC57BU8KM054019-20201205-1707.CSV
blockmap-OBD_3VWC57BU8KM054019-20201205-1707.CSV
Saturday,05,December,2020,17:08:08:14741
VCDS Version: 20.12.0.0 (x64) HEX-NET2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: 3VWC57BU8KM054019 License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 17 19 42 44 52 5F
VIN: 3VWC57BU8KM054019 Mileage: 46758km-29054miles
Address 01: Engine (J623-DGXA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 024 L HW: 04E 907 309 BT
Component: R4 1.4l TSI H20 5595
Revision: D4H20000
Coding: 012A0012232411086000
Shop #: WSC 00066 790 00311
ASAM Dataset: EV_ECM14TFS01104E906024L 001003
ROD: EV_ECM14TFS01104E906024B.rod
VCID: AA06E9E21C7C300B8D7-80FE
16706 - Steering Column Control Module
U0212 00 [032] - No Communications
Address 02: Auto Trans (J217) Labels: Redir Fail!
Part No SW: 09S 927 158 R HW: 09S 927 158
Component: AISIN 8G30/18 301 3552
Coding: 0100000100000000000000000000000000000000
Shop #: WSC 00066 790 00088
ASAM Dataset: EV_TCMAQ300031 001008
ROD: EV_TCMAQ300031_VW37.rod
VCID: CECE857240543C2B31F-809A
Part No SW: 5Q0 614 517 CT HW: 5Q0 614 517 AG
Component: ESC H62 0653
Revision: 00000000 Serial number: 51168000001770
Coding: 70FB6AA124252170C5770201A0CC250E562484A34005A4700041F058C202430B00000012121212B835351919323200
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 855C7A5ED5A23F73C05-80D0
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 H HW: 5GM 907 426 H
Component: AC Manuell H03 2007
Revision: 00001K06
Coding: 01020004200110001000000000010004
VCID: CDCC827E4D520733485-8098
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C86427051801GL
ROD: EV_BCMBOSCH_018.rod
VCID: 8B484C66F3C64903961-80DE
Steering Column Switch:
Subsystem 1 - Part No SW: 5Q1 953 521 AJ HW: 5Q1 953 569
Component: Lenks.Modul H03 0120
Serial number: 0100230520180C100017
921352 - Switch 3
B1727 29 [008] - Signal Implausible
139528 - Control Relay for Terminal 15 Load
B12E6 11 [008] - Short to Ground
197904 - Central Locking
B140A 4B [008] - Over temperature
788232 - Limit Switch for Windshield Wiper
B12D6 29 [008] - Signal Implausible
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM09B2U1
Coding: 8CCCFC00000000005000001AC20800000065
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000009CSOUK
Coding: 303445
Subsystem 2 - Part No SW: ----------- HW: 480 002 604 18
Serial number: 35700000000FD1893E2.
Subsystem 3 - Part No SW: ----------- HW: 480 002 604 18
Serial number: 35800000000B44893E2S
Subsystem 4 - Part No SW: ----------- HW: 480 402 904 18
Serial number: 3510001C929B6A84177A
Subsystem 5 - Part No SW: ----------- HW: 480 402 904 18
Serial number: 3520001C129C6BF5A74J
Subsystem 6 - Part No SW: ----------- HW: 480 401 905 18
Component: FrontSensor_D 004 6149
Serial number: 3550001242AF26F36250
Subsystem 7 - Part No SW: ----------- HW: 480 401 905 18
Component: FrontSensor_P 004 6149
Serial number: 3560001242AF26F3350$
Part No SW: 17A 920 840 HW: 17A 920 840
Component: KOMBI 208 0310
Coding: 09B4010A2380CF05020823001000000020000000
Shop #: WSC 34124 003 1048576
VCID: E0924BCA2AC0BA5B933-80B4
Part No SW: 3Q0 907 530 K HW: 3Q0 907 530 B
Component: GW MQB Mid 517 5323
Serial number: 09051800840234
Coding: 030100047F085708FB0000481C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: B720C096DFCE9DE3029-80E2
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 AA HW: 5G0 959 442 AA Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 28180000754840091439
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 7890315800
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 011 0032
Serial number: 7038815403445
Coding: 00200B200100028000000000
VCID: C5DCBA5E9522FF73805-8090
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000433146
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: D0F29B0A5A602ADB233-8084
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 011 0032
Serial number: 8038815301471
Coding: 002003200100028000000000
VCID: C4DAA75A9E18C67B97B-8090
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000435717
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 17A 035 868 HW: 17A 035 868
Component: MU-E--ER 680 8740
Serial number: 12041800020318
Coding: 02730100AA00000041220001001000009F0000D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: E78050D6CFEECD63529-80B2
End----------(Elapsed Time: 10:09, VBatt start/end: 11.7V/13.2V)-----------
;SW:04E-906-024-L HW:04E-907-309-BT --- Engine
;Component:R4 1.4l TSI H20 5595, Coding:012A0012232411086000
;EV_ECM14TFS01104E906024L,001003,EV_ECM14TFS01104E906024B.rod
;Saturday,05,December,2020,17:00:27:14741
;VCDS Version: Release 20.12.0 (x64) Data version: 20201124 DS322.0
;VCID: AA06E9E21C7C300B8D7-80FE
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VWC57BU8KM054019,
IDE00019,Voltage terminal 30,13.100, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,878, /min
IDE00025,Coolant temperature,38, °C
IDE00078,Time since engine start,149, s
IDE00083,Throttle valve position (absolute),12.9, %
IDE00084,Absolute load value,23, %
IDE00085,Normed load value,17.6, %
IDE00086,Accelerator pedal position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,27.8, Nm
IDE00148,Mean injection time,1.002, ms
IDE00150,Pressure in brake servo unit,335.16, hPa
IDE00151,Oil fill level,58.184, mm
IDE00152,Oil warning threshold,45.000, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,369.6, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-25.000, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.266, °
IDE00178,Camshaft adjustment intake bank 1: specified value,21.164, °
IDE00179,Camshaft adjustment intake bank 1: actual value,21.227, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,9.8, °C
IDE00188,Fuel high-pressure: actual value,9.982, MPa
IDE00190,Charge air pressure: specified value,335.39, hPa
IDE00191,Charge air pressure: actual value,972.27, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,10.4, °C
IDE00194,Coolant temperature at radiator output: specified value,95.3, °C
IDE00196,Engine oil temperature,9.2, °C
IDE00201,High fuel pressure: specified value,10.000, MPa
IDE00202,Low fuel pressure: specified value,415.0, kPa
IDE00304,Fuel level,48.00, l
IDE00348,Intake air temperature,12, °C
IDE00349,Throttle valve position: normed,3, %
IDE00350,Air mass: specified value,10.2, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,10.5, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,975.31, hPa
IDE00371,Fuel consumption,0.93, l/h
IDE00375,Generator: load signal,32.23, %
IDE00380,Coolant fan 1: activation,26.56, %
IDE00392,Accelerator pedal: sensor voltage 1,738.6, mV
IDE00393,Accelerator pedal: sensor voltage 2,379.6, mV
IDE00394,Camshaft position: start of phase window,111.29, °
IDE00406,Camshaft RPM,437.5, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 feedback-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00432,Particle filter: time since last regeneration,0.000, H
IDE00434,Particle filter: soot mass calculated,45, mg
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00451,Currently running routine,Unknown (0),
IDE00474,Ambient air pressure,97, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,7.9, Nm
IDE00496-ENG57549,Oil pressure switch valve activation-Bits 0-7,1,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,37,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,10, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.006 Lambda / -0.016 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.830, V
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00583,Throttle valve specified value,4, %
IDE00584,Distance driven since erasing DTC memory,14226, km
IDE00588,Fuel tank fill level,99.6, %
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,3.0, Degrees
IDE00594,Absolute intake pressure,31, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,4.7, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00604,Short term adaptation of mixture formation bank 1,1.6, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,10.996, mm
IDE00700,ESI: maximum oil level in service interval,29.620, mm
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00000,
IDE00752,Oxygen sensor control test,Test off,
IDE00752-ENG127302,Oxygen sensor control test-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside temperature,10.5, °C
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.0000,
IDE01260,Generator performance,348.717, W
IDE01267,Height correction,0.96265,
IDE01378,Fuel high pressure: control deviation,-0.0100, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01407,Particle filter: fuel consumption since last regeneration,0.000, l
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.833, V
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01834,Battery voltage,13120, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.56, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.1367,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01876,Adaptation of loss torque,-2.1, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,5,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000100 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,31.075, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01888,Cold start enrichment: adaptation area 1,0.953,
IDE01889,Cold start enrichment: adaptation area 2,0.922,
IDE01890,Cold start enrichment: adaptation area 3,0.875,
IDE01891,Cold start enrichment: adaptation area 4,0.852,
IDE01892,Cold start enrichment: adaptation area 5,0.852,
IDE01893,Fuel pump: specified value,43.112, %
IDE01898,Load value: specified value,117.77, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,0.1, Nm
IDE01902,Lost torque adaptation A/C compressor,-2.1, Nm
IDE01903,Lost torque adaptation driving mode,-3.8, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,-4.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.05206,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.09381,
IDE01911,Leakage air,3.4, kg/h
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01922,Vehicle distance driven,46758, km
IDE01923,Control module distance driven,46740451, m
IDE01928,Close cam shaft angle at quantity control valve,23.8, °
IDE01929,Open cam shaft angle at quantity control valve,-4.0, °
IDE01930,High pressure regulation: adaptation value,-0.058, MPa
IDE01932,High pressure pump injection volume,-1.39, mm³
IDE01975,Numb.of misfir.: cylinder 1,8638,
IDE01976,Numb.of misfir.: cylinder 2,7160,
IDE01977,Numb.of misfir.: cylinder 3,5209,
IDE01978,Numb.of misfir.: cylinder 4,6188,
IDE02115-ENG57549,Requirements for basic setting-Bits 0-7,158,
IDE02116,Exhaust gas temperature before catalytic converter,258.74, °C
IDE02117,Relative load value,21.28, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.00, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,3990,
IDE02757,Number of automatic engine starts,4182,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,1031,
IDE03010-MAS01627,Number of prevented stop processes-Steering,1399,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,27,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,2053,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,3354,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,1543,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,96,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,2,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,768,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,853,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,3,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,143,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,7,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.490, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.503, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.834, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.158, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status of neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3930.2, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,161,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.016, °
IDE03711,Mass flow through throttle valve,10.0, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,31.140, %
IDE03805,Test of brake booster pump: result,Test off,
IDE03805-ENG127323,Test of brake booster pump: result-Test_Program_Channel 603,235,
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,O2 Sensor B1-S2: Status-Bits 0-7,2,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,552.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,146.88, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,38.031, %
IDE03932,Charge pressure actuator: specified position,140.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3195.4, mV
IDE03935,Charge air pressure actuator: adaptation for upper stop,95.4, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.07712,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge air pressure control,BP_A act:97, kPa
IDE04003,Charge air temperature sensor,B1S1:13 °C / °C,
IDE04010,Engine torque: normalized,9, %
IDE04011,Nominal torque,280, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:9920/--- kPa,
IDE04083,Coolant temperatures,ECT 1:39 °C / ECT 2:10 °C,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/14 °C / Compr. in/out---/--- °C,
IDE04110,Additional inputs and outputs,,
IDE04278,Bypass valve f high press turboch turbine inlet: target value,100.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,98.96, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,0.17, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,-0.17, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,10.65, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3164.8, mV
IDE04410,Intake manifold pressure: specified value,313.28, hPa
IDE04420,Secondary air system activation,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,3.0, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,1.0010,
IDE04685,Setpoint generation interior torque,27.7, Nm
IDE04693,Increasing desired torque intervention of ESP,-55705.6, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04858,Brake booster low pressure actual value,643.98, hPa
IDE04887,Powertrain target torque,69.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,12.8, Nm
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05140,Intake manifold pressure raw value,307.42, hPa
IDE05221,Electric drive torque: actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,1,
IDE05436,Engine operating condition,Idle,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,10.5, °C
IDE05438,Rear cat conv temp main cat conv model value,194.94, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000008,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,21.42, %
IDE05449,O2 sensor 2: B1: internal resistance limit,33000, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00171,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.92, °C
IDE05470,Cat converter oxygen storage capacity,551.3, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,0.0000,
IDE05474,Main cat converter OSC age correction factor,0.789,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,10.7, kg/h
IDE05479,Misfire recognition reference moment,6.796, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05593,Secondary air injection sensor 1,971.91, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,3.735, %
IDE06015,Time since terminal 15 off: start/stop,65535, s
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,13.5, °C
IDE06021,Intake air temperature before throttle valve: raw value,15.0, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,875.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0240, MPa
IDE06045-ENG57549,Output diagnostic test status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,327.23, hPa
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06098,Sensor control factor: output value,1.01862,
IDE06307-MAS00106,Stop prevention history data-Year,2020,
IDE06307-MAS00107,Stop prevention history data-Month,12,
IDE06307-MAS00108,Stop prevention history data-Day,4,
IDE06307-MAS00109,Stop prevention history data-Hours,12,
IDE06307-MAS00110,Stop prevention history data-Minutes,40,
IDE06307-MAS00111,Stop prevention history data-Seconds,48,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Slow traffic detected,
IDE06308-MAS00106,Start request history data-Year,2020,
IDE06308-MAS00107,Start request history data-Month,12,
IDE06308-MAS00108,Start request history data-Day,2,
IDE06308-MAS00109,Start request history data-Hours,13,
IDE06308-MAS00110,Start request history data-Minutes,32,
IDE06308-MAS00111,Start request history data-Seconds,12,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Brake under pressure too low,
IDE06386,Oil level: static measurement,59.092, mm
IDE06387,Oil level: last valid dynamic value,16.300, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06446-ENG57549,Status: incline angle-Bits 0-7,1,
IDE06567,Frequency counter deactivate start/stop function,1977,
IDE06568,Stop prevention by driver frequency counter,12882,
IDE06569,Frequency counter vehicle standstill,25149,
IDE06610,Frequency counter vehicle standstill with stop,5702,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,130,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,1,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06758,Air mass since engine start,0.73, kg
IDE06759,Cam shaft adaptation inlet: counter,3,
IDE06760,Camshaft adaptation: exhaust: counter,3,
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07094,Correction factor injector cylinder 1,1.0028,
IDE07095,Correction factor injector cylinder 2,0.9980,
IDE07096,Correction factor injector cylinder 3,1.0000,
IDE07097,Correction factor injector cylinder 4,1.0038,
IDE07164,Number injections,5838,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07234,Status bid for valid static oil level,0,
IDE07235,Status bid for dynamic oil level,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07573,Throttle valve adapter: actual value,3.69, %
IDE07693,Maximum supply pressure low-pressure fuel pump,0.0, kPa
IDE07697,System test status of fuel supply,32,
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE08562,Basic correction factor: Injector cyl. 1: filtered,0.9886,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,1.0049,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,1.0045,
IDE08565,Basic correction factor: Injector cyl. 4: filtered,1.0018,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,1,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,1,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,1,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,1,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,1,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,1,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,Correct result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,1,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-0.836, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-0.242, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,0.18, °
IDE09932,Intake camshaft B1: adaptation value sensor tolerance,0.48, °
IDE10040,Outlet camshaft bank 1 active operating mode,1,
IDE10041-ENG57549,Intake camshaft B1 active operating state-Bits 0-7,0,
IDE10041-ENG57549,Intake camshaft B1 active operating state-Bits 0-7,1,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,185.1, s
IDE10303,Integrated air masse at first engine start,0.8292, kg
IDE10641,Low fuel pressure adaptation value for EFP: modeled,-9.0, kPa
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,hood open,
IDE10989,Immobilizer: historic data,Function locked due to frequent stalling,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,321,
IDE11116,Start/stop driver request: counter internal-motor restart,141,
IDE11293,Fuel consumption difference: injectors/sensors,13.637, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,13.723, l
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,9.04, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,-8.40, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-4.74, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,1.72, %
IDE12210,Particle filter: water mass,0.0, g
IDE12355,ESI: consumption equivalent of the engine control module,0.00000054,
IDE12460,Low pressure procedure: pressure regulation valve open,0.00, kPa
IDE12461,Pressure regulator valve pulse duty factor,0.00, %
IDE12462,Pressure regulator valve opening pressure,0.0, kPa
IDE12463,Pressure regulator valve minimum pulse duty factor,False result,
IDE12463-ENG127289,Pressure regulator valve minimum pulse duty factor-Test_Program_B TRUE UBYTE,0,
IDE12464,Rail pressure at end of test,0.000, MPa
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,5600, mg
IDE13086,Particle filter: maximum soot build-up reached,8000, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
MAS15845,Fuel: tank fill level,48.5, l
MAS15866,High pressure buildup gradient during pressure limitation valve opening test,0.000, MPa/revolution
MAS15883,Maximum fuel high-pressure with extended value range,0.000, MPa
MAS16287,High pressure buildup process with engine of: extended range,0.000, MPa/s
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,1,
ENG101413,Calibration Identification,04E024L 5595DXAA,
ENG99697,Calibration Verification Number,76 07 50 BA,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG115973,Engine Exhaust Flow Rate,10.6, kg/h
ENG20102,Engine Friction - Percent Torque,5.0, %
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.58, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.58, g/s
ENG123647,Gsl Pfil dst Veh Cyc Rgn VW,0.000, km
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,05 90 0F 16 08 AA 05 90 00 00 00 00 06 FA 05 90 00 00 00 00 0B B8 05 90 04 14 02 19 01 3F 01 17 05 C7 05 90 00 00 00 00 03 40 05 90 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2020,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,12,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,4,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,13,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,30,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,43,
ENG127734,Life_cycle_data_start_requirement_development,not active,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2020,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,12,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,4,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,11,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,33,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,54,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,Motor,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2020,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,5,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,26,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,14,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,51,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,34,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Motor,
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,available.,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG115976,Vehicle Odometer,46758.0, km
Elapsed Time: 00:39
;Saturday,05,December,2020,17:13:09:14741
IDE00019,Voltage terminal 30,12.320, V
IDE00021,Engine RPM,755, /min
IDE00025,Coolant temperature,80, °C
IDE00078,Time since engine start,911, s
IDE00083,Throttle valve position (absolute),11.8, %
IDE00084,Absolute load value,19, %
IDE00085,Normed load value,14.1, %
IDE00100,Engine torque,21.2, Nm
IDE00148,Mean injection time,0.775, ms
IDE00150,Pressure in brake servo unit,323.20, hPa
IDE00151,Oil fill level,63.000, mm
IDE00152,Oil warning threshold,45.652, mm
IDE00167,Exhaust temperature 1 bank 1,569.6, °C
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.203, °
IDE00178,Camshaft adjustment intake bank 1: specified value,20.148, °
IDE00179,Camshaft adjustment intake bank 1: actual value,20.016, °
IDE00182,Camshaft adaptation intake bank 1: phase position,1.08, °
IDE00188,Fuel high-pressure: actual value,10.000, MPa
IDE00190,Charge air pressure: specified value,308.36, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,12.5, °C
IDE00196,Engine oil temperature,53.6, °C
IDE00348,Intake air temperature,21, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,7.0, kg/h
IDE00357,Fuel temperature,36.0, °C
IDE00371,Fuel consumption,0.60, l/h
IDE00375,Generator: load signal,29.01, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,741.0, mV
IDE00394,Camshaft position: start of phase window,111.64, °
IDE00406,Camshaft RPM,376.5, /min
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00477,Torque request: sum of auxiliary aggregate,3.7, Nm
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.003 Lambda / -0.020 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.735, V
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00593,Ignition timing adjustment cylinder 1,4.5, Degrees
IDE00594,Absolute intake pressure,28, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,1.6, %
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,-0.8, %
IDE00612,Target position of EVAP canister valve,1.2, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,-0.00006,
IDE01260,Generator performance,197.92, W
IDE01267,Height correction,0.96271,
IDE01378,Fuel high pressure: control deviation,-0.0040, MPa
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.737, V
IDE01650,Throttle valve position 2,12, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Syst. OK,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,228,
IDE01834,Battery voltage,12320, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.23, %
IDE01873,Test of catalytic converter: measured value,5.0000,
IDE01876,Adaptation of loss torque,-1.8, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01884,Camshaft adjustment intake bank 1: activation,32.491, %
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,49.974, %
IDE01898,Load value: specified value,119.16, %
IDE01901,Lost torque adaptation: idle,-1.8, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01903,Lost torque adaptation driving mode,0.0, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.98407,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.09412,
IDE01911,Leakage air,3.7, kg/h
IDE01923,Control module distance driven,46740727, m
IDE01928,Close cam shaft angle at quantity control valve,22.1, °
IDE01930,High pressure regulation: adaptation value,-0.062, MPa
IDE01932,High pressure pump injection volume,-3.00, mm³
IDE01978,Numb.of misfir.: cylinder 4,6189,
IDE02115-ENG57549,Requirements for basic setting-Bits 0-7,190,
IDE02116,Exhaust gas temperature before catalytic converter,397.44, °C
IDE02117,Relative load value,17.39, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,-0.8, %
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,2056,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,3355,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3842.4, mV
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,128,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,160,
IDE03709,Angle difference actual-specified camshaft adjuster,0.133, °
IDE03711,Mass flow through throttle valve,6.8, kg/h
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,40.050, %
IDE03805,Test of brake booster pump: result,Syst. OK,
IDE03805-ENG127323,Test of brake booster pump: result-Test_Program_Channel 603,228,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,410.000, Ohm
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.27, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,34.967, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3176.8, mV
IDE03935,Charge air pressure actuator: adaptation for upper stop,90.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.00201,
IDE04003,Charge air temperature sensor,B1S1:21 °C / °C,
IDE04010,Engine torque: normalized,7, %
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:9900/--- kPa,
IDE04083,Coolant temperatures,ECT 1:79 °C / ECT 2:12 °C,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/28 °C / Compr. in/out---/--- °C,
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,99.60, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-0.42, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,0.42, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,11.34, %
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3167.2, mV
IDE04410,Intake manifold pressure: specified value,296.41, hPa
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,1.0061,
IDE04685,Setpoint generation interior torque,21.1, Nm
IDE04858,Brake booster low pressure actual value,671.99, hPa
IDE04887,Powertrain target torque,91.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,8.8, Nm
IDE05140,Intake manifold pressure raw value,285.39, hPa
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05438,Rear cat conv temp main cat conv model value,331.65, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0166, rad
IDE05444,Air filling: specified value,17.77, %
IDE05449,O2 sensor 2: B1: internal resistance limit,7828, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,-0.00006,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,720.13, °C
IDE05470,Cat converter oxygen storage capacity,1000.0, mg
IDE05474,Main cat converter OSC age correction factor,0.703,
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,7.3, kg/h
IDE05479,Misfire recognition reference moment,5.321, %
IDE05482,Tank venting adaptation factor,-1.260,
IDE05797,Throttle valve adapter: specified value,2.251, %
IDE06017,Camshaft position deviation from reference position,0.02, °
IDE06020,Intake air temperature in intake manifold bank raw value,21.8, °C
IDE06021,Intake air temperature before throttle valve: raw value,28.5, °C
IDE06039,Required RPM at idle speed,750.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0500, MPa
IDE06049,Pressure in brake booster: raw value,303.28, hPa
IDE06098,Sensor control factor: output value,0.97424,
IDE06307-MAS00108,Stop prevention history data-Day,5,
IDE06307-MAS00109,Stop prevention history data-Hours,17,
IDE06307-MAS00110,Stop prevention history data-Minutes,12,
IDE06307-MAS00111,Stop prevention history data-Seconds,9,
IDE06307,Stop prevention history data,Mixture adaptation,
IDE06393,Oil level: dynamic average value,17.768, mm
IDE06568,Stop prevention by driver frequency counter,12885,
IDE06569,Frequency counter vehicle standstill,25152,
IDE06758,Air mass since engine start,3.55, kg
IDE06759,Cam shaft adaptation inlet: counter,0,
IDE06760,Camshaft adaptation: exhaust: counter,0,
IDE07094,Correction factor injector cylinder 1,1.0083,
IDE07095,Correction factor injector cylinder 2,0.9976,
IDE07096,Correction factor injector cylinder 3,0.9988,
IDE07097,Correction factor injector cylinder 4,1.0011,
IDE07164,Number injections,30699,
IDE07573,Throttle valve adapter: actual value,2.22, %
IDE08562,Basic correction factor: Injector cyl. 1: filtered,0.9893,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,1.0066,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,1.0038,
IDE08565,Basic correction factor: Injector cyl. 4: filtered,1.0002,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-1.875, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-1.078, °
IDE10302,Time since engine start,947.2, s
IDE10303,Integrated air masse at first engine start,3.5961, kg
IDE10641,Low fuel pressure adaptation value for EFP: modeled,120.0, kPa
IDE11293,Fuel consumption difference: injectors/sensors,0.105, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.113, l
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,9.16, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,-8.10, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-4.86, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,-0.94, %
IDE12355,ESI: consumption equivalent of the engine control module,0.00000016,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG115973,Engine Exhaust Flow Rate,7.4, kg/h
ENG20102,Engine Friction - Percent Torque,4.0, %
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.34, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.34, g/s
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,05 90 0F 16 08 AA 05 90 00 00 00 00 06 FA 05 90 00 00 00 00 0B B9 05 90 04 14 02 19 01 3F 01 17 05 C7 05 90 00 00 00 00 03 40 05 90 00 00 00 00 00 00 00 00 00 00 00 00,
ENG115976,Vehicle Odometer,46758.3, km
Elapsed Time: 00:39
;SW:09S-927-158-R HW:09S-927-158 --- Auto Trans
;Component:AISIN 8G30/18 301 3552, Coding:0100000100000000000000000000000000000000
;EV_TCMAQ300031,001008,EV_TCMAQ300031_VW37.rod
;Saturday,05,December,2020,17:01:12:14741
;VCID: CECE857240543C2B31F-809A
IDE00008-ENG103646,Software version-VW Application Software Version Number,3552,
IDE00018,Voltage terminal 15,12.8, V
IDE00019,Voltage terminal 30,13.1, V
IDE00019,Voltage terminal 30,13.166, V
IDE00021,Engine RPM,872, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,826, /min
IDE00023,Transmission output speed,0, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,10, °C
IDE00025-ENG101037,Coolant temperature-Engine coolant temperature,39.75, °C
IDE00025,Coolant temperature,40, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00031-ENG101217,Torque transmitting function-Transmission function,0.0,
IDE00037-MAS02112,Programmability status-Programmability,programmable,
IDE00037-MAS02113,Programmability status-Program consistency,Program present,
IDE00072,ASAM/ODX file identification,EV_TCMAQ300031,
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0, km/h
IDE00086,Accelerator pedal position,0.0, %
IDE00087-ENG102622,Tiptronic status-Tiptroni Minus,not active,
IDE00087-ENG98977,Tiptronic status-Tiptronic gate,not active,
IDE00087-ENG100388,Tiptronic status-Tiptronic Lenkrad Minus,not active,
IDE00087-ENG103352,Tiptronic status-Tiptronic Lenkrad Plus,not active,
IDE00087-ENG102721,Tiptronic status-Tiptronik Plus,not active,
IDE00089-ENG101851,Driving position-Automatic Transmission shift position,P,
IDE00090,selected gear,PN range,
IDE00094,Kick-down status,OFF,
IDE00095,Status of selector lever lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00098-ENG103732,Transmission position-POS_INFO Signal,P,
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,was not yet started,
IDE00358-ENG101555,Limitation: torque-Engine torque limitation,109, Nm
IDE00544,Factor torque,Factor 0.5,
IDE00548-ENG101198,Converter clutch slip-Slip Speed LU,50, /min
IDE00609-ENG110904,Communication status of data bus 1-ACC ECU support/not support,Not supported,
IDE00609-ENG110905,Communication status of data bus 1-ACC Status active/not active,not active,
IDE00609-ENG110906,Communication status of data bus 1-Airbag ECU support/not support,Not supported,
IDE00609-ENG110907,Communication status of data bus 1-Airbag Status active/not active,not active,
IDE00609-ENG110902,Communication status of data bus 1-Aircon ECU support/not support,Not supported,
IDE00609-ENG110903,Communication status of data bus 1-Aircon Status active/not active,not active,
IDE00609-ENG30405,Communication status of data bus 1-BCM ECU support/not support,supported,
IDE00609-ENG30406,Communication status of data bus 1-BCM Status active/not active,active,
IDE00609-ENG110900,Communication status of data bus 1-Brake ECU support/not support,supported,
IDE00609-ENG110901,Communication status of data bus 1-Brake Status active/not active,active,
IDE00609-ENG130510,Communication status of data bus 1-Column Lock ECU support/not support,Not supported,
IDE00609-ENG130511,Communication status of data bus 1-Column Lock Status active/not active,not active,
IDE00609-ENG110898,Communication status of data bus 1-Engine ECU support/not support,supported,
IDE00609-ENG110899,Communication status of data bus 1-Engine Status active/not active,active,
IDE00609-ENG110916,Communication status of data bus 1-EPB ECU support/not support,supported,
IDE00609-ENG110917,Communication status of data bus 1-EPB Status active/not active,active,
IDE00609-ENG110912,Communication status of data bus 1-Gateway ECU support/not support,supported,
IDE00609-ENG110913,Communication status of data bus 1-Gateway Status active/not active,active,
IDE00609-ENG130512,Communication status of data bus 1-Hybrid Charge Battery Manager ECU support/not support,Not supported,
IDE00609-ENG130513,Communication status of data bus 1-Hybrid Charge Battery Manager Status active/not active,not active,
IDE00609-ENG110910,Communication status of data bus 1-Kombi ECU support/not support,supported,
IDE00609-ENG110911,Communication status of data bus 1-Kombi Status active/not active,active,
IDE00609-ENG110918,Communication status of data bus 1-Shifter ECU support/not support,supported,
IDE00609-ENG110919,Communication status of data bus 1-Shifter Status active/not active,active,
IDE00609-ENG110908,Communication status of data bus 1-Steering Wheel ECU support/not support,Not supported,
IDE00609-ENG110909,Communication status of data bus 1-Steering Wheel Status active/not active,not active,
IDE00609-ENG110914,Communication status of data bus 1-Transfercase ECU support/not support,Not supported,
IDE00609-ENG110915,Communication status of data bus 1-Transfercase Status active/not active,not active,
IDE00798-ENG28485,Number of possible access authorizations-Number of Logins,01,
IDE00820-ENG114742,Activating and deactivating all development messages-Activation of Development Messages,00,
IDE00972,Idle speed increase,OFF,
IDE02211,Brake pressure,-0.00, bar
IDE02220-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,valid value,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,OFF,
IDE02714,Brake test switch,OFF,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,1,
IDE02820,Transmission mileage,46758.0, km
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03008-ENG28321,Stop process prevented-Start_/_Stop_prohibition,not condition,
IDE03010-ENG31515,Number of prevented stop processes-Frequency_counter_Start_/_Stop_ prohibition,0,
IDE03127-ENG101616,Prevented stop processes (ring memory)-Frequency_counter_Start_/_Stop_prohibition_ring_buffer,2000,
IDE03152-ENG100761,Neutral due to driver registr. proced. cond.: cause-cause: when it happened last time,N after R,
IDE03152-ENG102840,Neutral due to driver registr. proced. cond.: cause-distance [s] = km: last time it occurred,0, km
IDE03152-ENG100645,Neutral due to driver registr. proced. cond.: cause-how often over life time,0, counts
IDE03171-ENG103012,Driving strategy transmission mileage-Total Driving Time2,N/A---,
IDE03172-ENG103276,Driving Strategy Percentage Driving in D or S w/Cruise-Driving Time Ecological,0, %
IDE03173-ENG103020,Driving Strategy Percentage Driving in S w/o cruise-Driving Time Sporty,0, %
IDE03174-ENG100072,Driving strategy driving portions in Tiptronic-Driving Time Manual,0, %
IDE03180-ENG103176,Number of standard trips-General Denominator,1410,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,3748,
IDE03212-ENG100620,Start/stop conditions-Start_/_Stop_conditions,Stop release,
IDE03361-ENG130487,Driver intention torque-Driver Requested Torque,3, Nm
IDE03404-ENG130574,AUTOSAR Standard application software identification-software ID,20 00,
IDE03404-ENG104191,AUTOSAR Standard application software identification-Vendor ID,00 01,
IDE03404-ENG99019,AUTOSAR Standard application software identification-Version number,01 01 00,
IDE05398-ENG130490,Transmission output speed: uncond voltage-Automatic transmission output speed raw voltage,0.6, V
IDE05400-ENG102986,Hill factor driving strategy-DSP Mountain Index,0.0, %
IDE05401-ENG130491,Transmission input speed: uncond voltage-Automatic transmission input speed raw voltage,0.6, V
IDE05403-ENG130492,Accelerator pedal idling-Accelerator Idle signal,Not operated,
IDE05668-ENG101751,Transmission control module torque request-TCM Requested Torque,initialized,
IDE06323-ENG102841,Status: switch valve S1/S2-S2,Open,
IDE06323-ENG55631,Status: switch valve S1/S2-S3,Open,
IDE06323-ENG56246,Status: switch valve S1/S2-S4,Open,
IDE06323-ENG55712,Status: switch valve S1/S2-S5,Open,
IDE06323-ENG55997,Status: switch valve S1/S2-SL,closed,
IDE06323-ENG55341,Status: switch valve S1/S2-sr,closed,
IDE06658-ENG99605,Pressure control valve 2: act. current-Actual current SLB1,0.10, A
IDE06659-ENG101258,Pressure control valve 3: act. current-Actual current SLC1,0.10, A
IDE06660-ENG101181,Pressure control valve 3: spec. current-Order current SLC1,0.10, A
IDE06661-ENG100294,Pressure control valve 2: spec. current-Order current SLB1,0.10, A
IDE06662-ENG100356,Pressure control valve 4: spec. current-Order current SLC2,0.10, A
IDE06663-ENG99880,Pressure control valve 4: act. current-Actual current SLC2,0.09, A
IDE06664-ENG99347,Pressure control valve 5: act. current-Actual current SLC3,0.10, A
IDE06665-ENG101266,Pressure control valve 5: spec. current-Order current SLC3,0.10, A
IDE06666-ENG101252,Pressure control valve 6: act. current-Actual current SLC4,0.10, A
IDE06667-ENG103324,Pressure control valve 6: spec. current-Order current SLC4,0.10, A
IDE06668-ENG103285,Pressure control valve 1: act. current-Actual current SLT,0.40, A
IDE06669-ENG103245,Pressure control valve 1: spec. current-Order current SLT,0.40, A
IDE06670-ENG55516,Pressure control valve 7: act. current-Actual current SLB2,0.31, A
IDE06671-ENG55517,Pressure control valve 7: spec. current-Order current SLB2,0.31, A
IDE06672-ENG130501,Current gear/clutch status-Actual Gear And LU Mode,0 ,
IDE06674-ENG102023,Driving strategy: rolling resistance-DSP Road Resistance,-0.3, %
IDE06675-ENG100839,Driving strategy: Sport Index-DSP Sport Index,0, %
IDE06676-ENG130488,Driving strategy: driving mode-DSP Driving Mode,DS,
IDE06677-ENG100939,Driving strategy: Sport Index Hybrid-DSP Sport Index Hybrid,Not supported,
IDE06875-ENG101762,Height-Altitude,0.96063, mbar
IDE06879-ENG103976,Software level supplier-ATCU software level,3,
IDE06880-ENG06100,Calc. transmission fluid temp.-Temp TC Lifetime Max Value,113, °C
IDE06881-ENG130493,Max. transmission fluid temperature over lifetime-ATF Temperature Lifetime Max Value,102, °C
IDE06882-ENG102253,Trans. fluid temp. model value-Transmission fluid temperature (Model),14, °C
IDE06883-ENG130500,Max. transmission fluid temp. model value over lifetime-ATF Temperature Model Lifetime Max Value,100, °C
IDE06884-ENG99385,Trans. fluid temp. sensor: voltage-ATF-Temperature Voltage,3.4, V
IDE06885-ENG102696,Torque converter: torque loss-Converter Loss Torque,0, Nm
IDE06887-ENG130498,Driver for electric oil pump: max. temperature-DrivingRecorder - highest temperature of the choke coil estimate temperature,200, °C
IDE06888-ENG130499,battery voltage: distribution-DrivingRecorder - distribution of Battery voltage,N/A---,
IDE06889-ENG130497,Driver for electric oil pump: temperature distribution-DrivingRecorder - distribution of choke coil estimate temperature,N/A---,
IDE06893-ENG130489,Trans. thermal management request-DSP Fan control,heating,
IDE06894-ENG130495,Hot running progr. status-DSP Hotmode Status,normal,
IDE06895-ENG130502,Level/hill recognition-DSP Plain/Mountains,Ebene (Plain),
IDE06896-ENG103489,Driving strategy: software version-DSP software level,3,
IDE06897-ENG99419,Engine torque loss-Engine Loss Torque,Not supported,
IDE06898-ENG101044,Engine torque with external intervention-Engine Torque With External Engagement,3, Nm
IDE06899-ENG99632,Engine torque without external intervention-Engine Torque Without External Engagement,3, Nm
IDE06913-ENG102247,Trans. pilot control torque-Idle Speed Loss Torque,6, Nm
IDE06914-ENG99114,Unfiltered transmission input speed-Turbine Speed Signal Current Value,810, /min
IDE06915-ENG98331,Trans. position switch: raw signal-a,closed,
IDE06915-ENG98436,Trans. position switch: raw signal-B,closed,
IDE06915-ENG98435,Trans. position switch: raw signal-C,closed,
IDE06915-ENG98824,Trans. position switch: raw signal-Pa,closed,
IDE06916-ENG101593,Software_ID-Mot-File,JL208B35.MOT ,
IDE06917-ENG100970,Software enable status-Software Level,3,
IDE06919-ENG102285,Torque converter clutch: status-Lock Up Clutch Status,Open,
IDE06920-MAS00115,Tiptronic: raw signal-Tiptronic gate,OFF,
IDE06920-MAS00116,Tiptronic: raw signal-Tiptronic +,OFF,
IDE06920-MAS00117,Tiptronic: raw signal-Tiptronic -,OFF,
IDE06920-MAS00118,Tiptronic: raw signal-Tiptronic steering wheel +,OFF,
IDE06920-MAS00119,Tiptronic: raw signal-Tiptronic steering wheel -,OFF,
IDE06921-ENG100848,Calculated vehicle speed-Vehicle Speed Sensor (Dev),0.0, km/h
IDE07159-ENG28759,Control module switch-off: counter-Knockout_counter,0,
IDE13953-ENG56038,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(BIST error),0,
IDE13953-ENG55833,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Clock check),0,
IDE13953-ENG56042,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Communication check for between CPU and PCU),0,
IDE13953-ENG56620,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(core check),0,
IDE13953-ENG56660,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Power Supply check),0,
IDE13953-ENG55853,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Program flow check),0,
IDE13953-ENG55954,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(RAM check),0,
IDE13953-ENG55730,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(ROM check),0,
IDE13953-ENG56641,Error code of the main and monitoring processors-Maximum of consecutively error counter in this IG cycle.(Self test result),0,
IDE13953-ENG56382,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(BIST error),0,
IDE13953-ENG55852,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Clock check),0,
IDE13953-ENG55967,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Communication check for between CPU and PCU),0,
IDE13953-ENG55918,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(core check),0,
IDE13953-ENG55856,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Power Supply check),0,
IDE13953-ENG56139,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Program flow check),0,
IDE13953-ENG56707,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(RAM check),0,
IDE13953-ENG55621,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(ROM check),0,
IDE13953-ENG55902,Error code of the main and monitoring processors-Total of error counter in the total lifetime.(Self test result),0,
IDE13953-ENG56109,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(BIST error),0,
IDE13953-ENG56466,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Clock check),0,
IDE13953-ENG56170,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Communication check for between CPU and PCU),0,
IDE13953-ENG56430,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(core check),0,
IDE13953-ENG56404,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Power Supply check),0,
IDE13953-ENG55926,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Program flow check),0,
IDE13953-ENG56338,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(RAM check),0,
IDE13953-ENG56428,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(ROM check),0,
IDE13953-ENG56394,Error code of the main and monitoring processors-Total of error counter in this IG cycle.(Self test result),0,
IDE14325-MAS00207,Oil pressure switch status-Oil pressure switch 2,Open,
IDE14325-MAS18242,Oil pressure switch status-Oil pressure switch 6,Open,
IDE14325-MAS18243,Oil pressure switch status-Oil pressure switch 8,Open,
IDE14703-ENG102978,Pressure control valve for torque converter lock-up clutch: actual flow-Actual current SLU,0.09, A
IDE14704-ENG101564,Pressure control valve for torque converter lock-up clutch: specified flow-Order current SLU,0.10, A
IDE80020,Analysis 20,0,
IDE80021,Analysis 21,0,
IDE80022,Analysis 22,100,
IDE80023,Analysis 23,100,
IDE80024,Analysis 24,100,
IDE80025,Analysis 25,100,
IDE80026,Analysis 26,100,
IDE80027,Analysis 27,100,
IDE80028,Analysis 28,100,
IDE80029,Analysis 29,100,
IDE80030,Analysis 30,100,
IDE80031,Analysis 31,93,
IDE80032,Analysis 32,100,
IDE80033,Analysis 33,100,
IDE80034,Analysis 34,73,
IDE80035,Analysis 35,270,
IDE80036,Analysis 36,183,
IDE80039,Analysis 39,3641886,
IDE80040,Analysis 40,N/A---,
IDE80041,Analysis 41,N/A---,
IDE80042,Analysis 42,N/A---,
IDE80043,Analysis 43,N/A---,
IDE80046,Analysis 46,N/A---,
IDE80049,Analysis 49,100,
ENG101413,Calibration Identification,9S927158R_ 3552,
ENG99697,Calibration Verification Number,C2 91 91 00,
ENG100152-ENG104003,ECUNAME-ECU,CM-,
ENG100152,ECUNAME,ransmisCtrl,
ENG125778,EMOP Demand Duty %,0, %
ENG125927-ENG125781,EMOP_Feedback_ON OFF-EMOP Feedback ON/OFF,OFF,
ENG02239,The counter and interval timer for Race up shifting,60000,
ENG02241-ENG02261,The status monitor for Free Wheel Function-110 <= Vehicle speed < 130 Counter,0,
ENG02241-ENG02262,The status monitor for Free Wheel Function-110 <= Vehicle speed < 130 Total distance,0, m
ENG02241-ENG02263,The status monitor for Free Wheel Function-130 <= Vehicle speed Counter,0,
ENG02241-ENG02264,The status monitor for Free Wheel Function-130 <= Vehicle speed Total distance,0, m
ENG02241-ENG02255,The status monitor for Free Wheel Function-50 <= Vehicle speed < 70 Counter,0,
ENG02241-ENG02256,The status monitor for Free Wheel Function-50 <= Vehicle speed < 70 Total distance,0, m
ENG02241-ENG02257,The status monitor for Free Wheel Function-70 <= Vehicle speed < 90 Counter,0,
ENG02241-ENG02258,The status monitor for Free Wheel Function-70 <= Vehicle speed < 90 Total distance,0, m
ENG02241-ENG02259,The status monitor for Free Wheel Function-90 <= Vehicle speed < 110 Counter,0,
ENG02241-ENG02260,The status monitor for Free Wheel Function-90 <= Vehicle speed < 110 Total distance,0, m
ENG02241-ENG02253,The status monitor for Free Wheel Function-Vehicle speed < 50 Counter,0,
ENG02241-ENG02254,The status monitor for Free Wheel Function-Vehicle speed < 50 Total distance,0, m
Elapsed Time: 00:19
;SW:5Q0-614-517-CT HW:5Q0-614-517-AG --- ABS Brakes
;Component:ESC H62 0653, Coding:70FB6AA124252170C5770201A0CC250E562484A34005A4700041F058C202430B00000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB,037009,EV_Brake1UDSContiMK100IPB_037_VW37.rod
;Saturday,05,December,2020,17:01:38:14741
;VCDS Version: Release 20.12.0 (x64) Data version: 20201124 DS322.0
;VCID: 855C7A5ED5A23F73C05-80D0
Group,Description,Actual
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Electronics,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,Open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,BU54019,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.21875, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,1,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,25,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,65535,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,65535,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,4,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2020,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,10,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,11,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,12,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,21,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,23,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,2,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,11,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,8,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,7,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,16,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,56,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,48,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,26,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,58,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,26,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,54,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,16,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,58,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,5,
IDE03127,Prevented stop processes (ring memory),Inclination limit,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2020,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2126,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,4,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,14,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,12,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,5,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,2,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,25,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,12,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,30,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,11,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,18,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,13,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,6,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,33,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,10,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,62,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,29,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,22,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,2,
IDE03128,Requested start processes (ring memory),AUTO HOLD slippage recognition,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,2,
IDE03527-IDE02445,CAN signals-Transmission type,26,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,4.994, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,13.256, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-653, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.00, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,65535, mm
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 09 2018,
IDE04442-IDE00010,Vacuum sensor-Serial number,01 54 DA 01 FD,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,available.,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-653, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,2,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,0.15696, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.15696, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.00000, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.21875, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,0.197, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,18.069, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,18.069, °
IDE04446-IDE01599,Hill descent control-Incline,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,available.,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,46753, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MZERAC00033,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,11, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,available.,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-653, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.00, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,666, mbar
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04645-IDE02657,Electromechanical parking brake-Cut-off current: left: reached,0.00, A
IDE04645-IDE02658,Electromechanical parking brake-Cut-off current: right: reached,0.00, A
IDE04645-IDE04496,Electromechanical parking brake-Left parking brake motor: status,closed,
IDE04645-IDE04497,Electromechanical parking brake-Right parking brake motor: status,closed,
IDE04645-IDE04506,Electromechanical parking brake-Calculated left rear brake temperature,11.0, °C
IDE04645-IDE04507,Electromechanical parking brake-Calculated right rear brake temperature,11.0, °C
IDE04645-IDE04647,Electromechanical parking brake-Left parking brake motor: current,0.00, A
IDE04645-IDE04648,Electromechanical parking brake-Right parking brake motor: current,0.00, A
IDE04645-IDE05048,Electromechanical parking brake-Left parking brake motor: actuation counter,277,
IDE04645-IDE05049,Electromechanical parking brake-Right parking brake motor: actuation counter,277,
IDE04765-IDE02955,Counter steer support-System status,available.,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,46753, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Incline,2, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,available.,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,252,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,252,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,252,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,252,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,42935, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,42853, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,42935, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,40258, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,39622, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,39067, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,34068, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,31152, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,254,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,254,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,Not available due to specific system,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,50030,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,234602,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,6460,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,4298,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2126,
IDE07280-MAS00107,Multiple collision brake-Month,14,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,30,
IDE07280-MAS00110,Multiple collision brake-Minutes,62,
IDE07280-MAS00111,Multiple collision brake-Seconds,62,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 35 38 36 38 33 31 33 30 30 30 30 35 31 38 34 32 36 30 30 36 45 41 2F 02 2A 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,98.0406, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,95.3064, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,99.9936, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,3688,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,99.9936, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,5633,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,99.603, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,2102,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,99.603, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,3553,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,available.,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,11.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,11.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,11.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,11.0, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00210-IDE80007,Parking Brake-Analysis 7,35149, km
MAS00210-IDE80008,Parking Brake-Analysis 8,46758, km
MAS00210-IDE80009,Parking Brake-Analysis 9,0, km
MAS00210-IDE80010,Parking Brake-Analysis 10,0, km
MAS00210-IDE80011,Parking Brake-Analysis 11,46758, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,available.,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,Condition not met,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,available.,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,available.,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,available.,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG26281-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
;SW:5GM-907-426-H HW:5GM-907-426-H --- Auto HVAC
;Component:AC Manuell H03 2007, Coding:01020004200110001000000000010004
;EV_ACManueBHBVW37X,004134,EV_ACManueBHBVW37X_004.rod
;Saturday,05,December,2020,17:02:24:14741
;VCID: CDCC827E4D520733485-8098
IDE00019,Voltage terminal 30,13.2, V
IDE00021,Engine RPM,800, /min
IDE00025,Coolant temperature,44, °C
IDE00198,Refrigerant pressure,7.6, bar
IDE00767,No. of unscheduled ECU resets,18,
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.410, A
IDE00967,Compressor current: specified value,0.415, A
IDE00968,Compressor speed,900, /min
IDE00969,Compressor load,5.2, Nm
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,11.0, °C
IDE00974,Outside air temperature internally calculated,11.0, °C
IDE00982,Temperature downstream of evaporator,3.3, °C
IDE00987,Blower voltage: specified value,3.8, V
IDE00989,Blower status,active,
IDE00992,Recirculation flap specified value,Fresh air,
IDE01046,Temperature flap: actual value,90.5, %
IDE01046,Temperature flap: actual value,214,
IDE01047,Temperature door - Specified value,215,
IDE01048,Temperature flap: cold stop,27,
IDE01049,Temperature flap: warm stop,233,
IDE01059,Air distribution flap: actual value,227,
IDE01059,Air distribution flap: actual value,74.5, %
IDE01060,Air distribution flap: specified value,229,
IDE01063,Status of recirculation air,Fresh air,
IDE01066,Convertible top status,to,
IDE01076,Time since ignition off,240, min
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Target value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Target value,0,
IDE01226,Blower voltage: actual value,3.8, V
IDE01227,Blower current,1.00, A
IDE01232,Supply voltage for external components,5.1, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,9554,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,7,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Outside air temperature too low,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01577,Pressing a button-Parking heater,Not operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01443,Left push-and-rotary knob counter,193,
IDE01444,Right push-and-rotary knob counter,48,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE03008-MAS01564,Stop process prevented-Front windshield heater,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Front windshield heater,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to specifications,not active,
IDE03009-MAS02803,Start process requested-Blowout temperature difference to specifications,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05009,Start process requested-A/C request: auxil. heat mode,not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,35,
IDE03010-MAS01564,Number of prevented stop processes-Front windshield heater,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,301,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Front windshield heater,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,34,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,16,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,17,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,11,
IDE03127,Prevented stop processes (ring memory),Defrost active,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,10,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,21,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,15,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,12,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,36,
IDE03128,Requested start processes (ring memory),max A/C,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04797,Center push-and-rotary knob counter,82,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,195,
IDE07991-MAS04446,A/C clutch-Relay activation status,active,
IDE12141-MAS00106,History memory: parking heater-Year,2127,
IDE12141-MAS00107,History memory: parking heater-Month,15,
IDE12141-MAS00108,History memory: parking heater-Day,31,
IDE12141-MAS00109,History memory: parking heater-Hours,31,
IDE12141-MAS00110,History memory: parking heater-Minutes,63,
IDE12141-MAS00111,History memory: parking heater-Seconds,63,
IDE12141-MAS02526,History memory: parking heater-Activation,Measuring value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measuring value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,5,
MAS00464-MAS00109,Standard - ambient data 1-Hours,17,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,1,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,189,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,46758, km
Elapsed Time: 00:08
;SW:5Q0-937-087-AR HW:5Q0-937-087-AN --- Cent. Elect.
;Component:BCM PQ37BOSCH 034 0246, Coding:
;EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
;Saturday,05,December,2020,17:02:52:14741
;VCID: 8B484C66F3C64903961-80DE
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,not coded/not installed,
IDE00973,Outside temperature,11.00, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Front windshield heater-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Front windshield heater-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Front windshield heater-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal lamp-Diagnosis,normal,
IDE01943-MAS02248,Turn signal lamp-Signal state,not active,
IDE01943-MAS03873,Turn signal lamp-Duty cycle,0.0, %
IDE01943-MAS04351,Turn signal lamp-Connector terminal number,36,
IDE01943-MAS04352,Turn signal lamp-Connector number,Connector B,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,to,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,to,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,not active,
IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear wiper,not coded/not installed,
IDE02743-MAS01737,High Beam-Diagnosis,normal,
IDE02743-MAS02248,High Beam-Signal state,not active,
IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
IDE02743-MAS04351,High Beam-Connector terminal number,39,
IDE02743-MAS04352,High Beam-Connector number,Connector B,
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS04136,Steering wheel heating-Current,0.00, A
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,-50, °C
IDE02857-IDE03111,Activation current-Interior lighting,1130, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,0, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,65532, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,0, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,65532, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,65532, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,not coded/not installed,
IDE02957-MAS02248,Ambient lighting-Signal state,NOT-DEFINED,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,0,
IDE02957-MAS04352,Ambient lighting-Connector number,not coded/not installed,
IDE02957-MAS06670,Ambient lighting-Channel,Not available,
IDE03111-MAS01737,Interior lighting-Diagnosis,normal,
IDE03111-MAS02248,Interior lighting-Signal state,active,
IDE03111-MAS03873,Interior lighting-Duty cycle,99.00, %
IDE03111-MAS04351,Interior lighting-Connector terminal number,12,
IDE03111-MAS04352,Interior lighting-Connector number,Plug C,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,0.0, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,0.0,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,0.0, V
IDE03310-MAS01737,Brake lamp-Diagnosis,normal,
IDE03310-MAS02248,Brake lamp-Signal state,not active,
IDE03310-MAS03873,Brake lamp-Duty cycle,0.0, %
IDE03310-MAS04351,Brake lamp-Connector terminal number,71,
IDE03310-MAS04352,Brake lamp-Connector number,Connector A,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,not coded/not installed,
IDE03388-MAS02201,Left front heated seat: status-Temperature,not installed,
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,not coded/not installed,
IDE03389-MAS02201,Right front heated seat: status-Temperature,not installed,
IDE03504-IDE02022,Personalized settings-Comfort opening,All windows,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,not active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,not active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,active,
IDE03504-MAS06456,Personalized settings-Auto lock,active,
IDE03504-MAS06457,Personalized settings-Auto unlock,active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,all,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,not active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,5, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,5, s
IDE03504-MAS07987,Personalized settings-Light intensity,normal,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,Stationary cornering lamp-Diagnosis,not coded/not installed,
IDE03638-MAS02248,Stationary cornering lamp-Signal state,Measuring value not available,
IDE03638-MAS03873,Stationary cornering lamp-Duty cycle,0.0, %
IDE03638-MAS04351,Stationary cornering lamp-Connector terminal number,0,
IDE03638-MAS04352,Stationary cornering lamp-Connector number,not coded/not installed,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded freeze frame conditions-DTC,00 00 00,
IDE04347-IDE07836,Expanded freeze frame conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,Measuring value not available,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,not coded/not installed,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,26.00, %
IDE05045-IDE05183,Front wiper module-Malfunction left,not coded/not installed,
IDE05045-IDE05184,Front wiper module-Malfunction right,not coded/not installed,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,0,
IDE05045-MAS05878,Front wiper module-Stage,Stage 1,
IDE05323-MAS01737,Fog lamp-Diagnosis,normal,
IDE05323-MAS02248,Fog lamp-Signal state,not active,
IDE05323-MAS03873,Fog lamp-Duty cycle,0.0, %
IDE05323-MAS04351,Fog lamp-Connector terminal number,10,
IDE05323-MAS04352,Fog lamp-Connector number,Connector B,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,Measuring value not available,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,NOT-DEFINED,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,not coded/not installed,
IDE05533,Heater for nozzles,not coded/not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not coded/not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,Measuring value not available,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,not coded/not installed,
IDE05739-MAS01737,Footwell lamp-Diagnosis,not coded/not installed,
IDE05739-MAS02248,Footwell lamp-Signal state,Measuring value not available,
IDE05739-MAS03873,Footwell lamp-Duty cycle,0.0, %
IDE05739-MAS04351,Footwell lamp-Connector terminal number,0,
IDE05739-MAS04352,Footwell lamp-Connector number,not coded/not installed,
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded/not installed,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,Not operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,not coded/not installed,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,0,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not coded/not installed,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded/not installed,
IDE05836-MAS03638,Rain recognition sensor-Wipe speed,not coded/not installed,
IDE05836-MAS04806,Rain recognition sensor-Splash,not coded/not installed,
IDE05836-MAS04807,Rain recognition sensor-park position,not coded/not installed,
IDE05838-MAS01794,Light recognition sensor-Freeway,not coded/not installed,
IDE05838-MAS02248,Light recognition sensor-Signal state,not coded/not installed,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,101600, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6132, lx
IDE05838-MAS04808,Light recognition sensor-Rain,not coded/not installed,
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839-MAS01737,Parking lamps-Diagnosis,normal,
IDE05839-MAS02248,Parking lamps-Signal state,not active,
IDE05839-MAS03873,Parking lamps-Duty cycle,0.0, %
IDE05839-MAS04351,Parking lamps-Connector terminal number,10,
IDE05839-MAS04352,Parking lamps-Connector number,Connector B,
IDE05841-MAS06441,Central locking history data-Control-section / cause,Trunk lid remote unlocking: int. button,
IDE05841-MAS07519,Central locking history data-Command,Individual rear unlock.,
IDE05841-MAS07942,Central locking history data-Additional information,Measuring value not available,
IDE05841-ENG29969,Central locking history data-command_direction_locking,Lock door,
IDE05841-ENG29970,Central locking history data-command_direction_unlocking,no_unlocking,
IDE05842-MAS00218,Comfort function history data-Driver door,not active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,not active,
IDE05842-MAS00220,Comfort function history data-Left rear door,not active,
IDE05842-MAS00221,Comfort function history data-Right rear door,not active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,keine Bedienstelle,
IDE05842-MAS07560,Comfort function history data-convertible top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,not active,
IDE05842-MAS07941,Comfort function history data-Operating command,Open,
IDE06012-MAS01737,Background lighting-Diagnosis,normal,
IDE06012-MAS02248,Background lighting-Signal state,not active,
IDE06012-MAS03873,Background lighting-Duty cycle,0.0, %
IDE06012-MAS04351,Background lighting-Connector terminal number,62,
IDE06012-MAS04352,Background lighting-Connector number,Plug C,
IDE06012-MAS15156,Background lighting-terminal,Variant A,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.1, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,87.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,127.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.1, °C
IDE06096-IDE03111,Interior lights-Interior lighting,100, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,0.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,100.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,99.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470-MAS01737,Periphery lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Periphery lighting-Signal state,Measuring value not available,
IDE06470-MAS03873,Periphery lighting-Duty cycle,0.0, %
IDE06470-MAS04351,Periphery lighting-Connector terminal number,0,
IDE06470-MAS04352,Periphery lighting-Connector number,not coded/not installed,
IDE06507-MAS13127,Button in center console-Status of button 1,Not operated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,Not operated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,OFF,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lamps,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded/not installed,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
IDE06695-MAS00107,Energy management: last critical state-Month,0,
IDE06695-MAS00108,Energy management: last critical state-Day,0,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2000,
IDE06864-MAS01737,Daytime running lamps-Diagnosis,normal,
IDE06864-MAS02248,Daytime running lamps-Signal state,not active,
IDE06864-MAS03873,Daytime running lamps-Duty cycle,0.0, %
IDE06864-MAS04351,Daytime running lamps-Connector terminal number,10,
IDE06864-MAS04352,Daytime running lamps-Connector number,Connector B,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,6553.5, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,65.535, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Implausible,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,to,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking system-Auto lock,not active,
IDE08177-MAS06740,Central locking system-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking system-Status exterior skin,Open,
IDE08177-MAS09896,Central locking system-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking system-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking system-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking system-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG09185,Central locking system-Load_compartment_closing,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,2000,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,39,
IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
IDE08343,Immobilizer Challenge,B1 15 3E 11,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-Stationary cornering lamp,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lamps,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943-MAS01737,Signature lamp-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature lamp-Signal state,Measuring value not available,
IDE11943-MAS03873,Signature lamp-Duty cycle,0.0, %
IDE11943-MAS04351,Signature lamp-Connector terminal number,0,
IDE11943-MAS04352,Signature lamp-Connector number,not coded/not installed,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,not installed,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,13.10, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,13.20, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,13.10, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,13.25, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,5.00, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,13.20, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,36,
MAS00829-MAS00244,Access/start authorization-Prompt wire,not coded/not installed,
MAS00829-MAS01763,Access/start authorization-Signal Strength,0,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,0, ms
MAS01281-MAS01737,Back-up lamp-Diagnosis,normal,
MAS01281-MAS02248,Back-up lamp-Signal state,not active,
MAS01281-MAS03873,Back-up lamp-Duty cycle,0.0, %
MAS01281-MAS04351,Back-up lamp-Connector terminal number,64,
MAS01281-MAS04352,Back-up lamp-Connector number,Connector A,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,not coded/not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,not coded/not installed,
MAS01490-MAS01564,Energy management-Front windshield heater,not coded/not installed,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,2106,
MAS01490-MAS05795,Energy management-Rear seat heater,not coded/not installed,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded/not installed,
MAS01490-MAS06552,Energy management-Front seat heating,not coded/not installed,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,10,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,6, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Position lamps-Diagnosis,normal,
MAS03835-MAS02248,Position lamps-Signal state,not active,
MAS03835-MAS03873,Position lamps-Duty cycle,0.0, %
MAS03835-MAS04351,Position lamps-Connector terminal number,10,
MAS03835-MAS04352,Position lamps-Connector number,Connector B,
MAS03836-MAS01737,Rear fog lamp-Diagnosis,not coded/not installed,
MAS03836-MAS02248,Rear fog lamp-Signal state,Measuring value not available,
MAS03836-MAS03873,Rear fog lamp-Duty cycle,0.0, %
MAS03836-MAS04351,Rear fog lamp-Connector terminal number,0,
MAS03836-MAS04352,Rear fog lamp-Connector number,not coded/not installed,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,no reason for cancellation,
MAS07959-MAS00107,Remote start history data-Month,15,
MAS07959-MAS00108,Remote start history data-Day,31,
MAS07959-MAS00109,Remote start history data-Hours,31,
MAS07959-MAS00110,Remote start history data-Minutes,63,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,No reason for prevention,
MAS08228-MAS01632,Light sensor-Status,Light on,
MAS08228-MAS02851,Light sensor-Brightness,2430, lx
MAS08228-MAS04121,Light sensor-Voltage,3.4, V
MAS13141,Test voltage,0, V
ENG116910,Control unit internal measured value (supplier),31 36 30 35 30 30 30 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,0,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,keine Stoerschutzursache,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,not coded/not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,not coded/not installed,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG128380,Parametermonitor_0,82 14 64 64 A0 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 00 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A A7 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 1E 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,11,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,5,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,15,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,25,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,1,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,1,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,1,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654-MAS00107,Personalized_Signals-Month,11,
ENG126654-MAS00108,Personalized_Signals-Day,5,
ENG126654-MAS00109,Personalized_Signals-Hours,15,
ENG126654-MAS00110,Personalized_Signals-Minutes,25,
ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,1,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,1,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,1,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
ENG116792-ENG115817,Power up history-Funktionsanforderung,1,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,32439, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.4, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.6, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.1, V
ENG116791,Temperatures,11.00, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG30013,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 01 84 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG30027,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG30075,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG30182,Valeo_Entwickler_MWB-WakeUp2,OFF,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,Not operated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,keine Stoerschutzursache,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside temperature,11.0, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,Not operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Position lamps,Not operated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,13.2, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,Not operated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,Not operated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,operated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,OFF,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,OFF,
Elapsed Time: 00:43
;SW:5Q0-959-655-AG HW:5Q0-959-655-AG --- Airbags
;Component:AirbagVW21 004 0336, Coding:8CCCFC00000000005000001AC20800000065
;EV_AirbaVW20SMEVW37X,002158,EV_AirbaVW20SMEVW37X_VW37.rod
;Saturday,05,December,2020,17:05:50:14741
;VCDS Version: Release 20.12.0 (x64) Data version: 20201124 DS322.0
;VCID: 855C7A5ED5A23F73C05-80D0
Group,Description,Actual
IDE00821,Seat belt switch 2nd row driver's side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Seat belt switch 2nd row center,not installed,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.8, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.1, Ohm
IDE01102,Driver thorax airbag igniter ohm value,2.3, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.3, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.2, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.2, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.2, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.2, Ohm
IDE01115,side belt force limiter igniter ohm value,2.2, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,Too Small,
IDE01194,Frt.pass. belt tensioner ohm value,Too Small,
IDE01195,Front passenger side seat occupancy detection: Ohm value,no measured value present,
IDE01197,Key switch contact 1 ohm value,too large,
IDE01198,Key switch contact 2 ohm value,too large,
IDE01200,Driver seat position sensor current value,5.7, mA
IDE01201,Frt.pass. seat position sensor current value,5.7, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01555,Number of frontal crashes,0,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,00,
IDE06959,Seat occupant detection: diagnosis signal,42.0, %
IDE06960,Seat occupant detection: msmt. signal,0.0, %
IDE06961,Seat occupant detection: ref. signal,1.0, %
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,0.0, Ohm
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,0.0, Ohm
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,cannot be measured currently,
MAS00008,Passenger side rear thorax airbag igniter,cannot be measured currently,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,cannot be measured currently,
MAS00012,Front passenger knee airbag igniter,cannot be measured currently,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver's Safety Belt Tensioner Igniter 2,correct,
MAS00016,Front passenger seat belt tensioner igniter 2,correct,
MAS00017,Driver's Belt Force Limiter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,cannot be measured currently,
MAS00020,Passenger side rear seat belt tensioner igniter,cannot be measured currently,
MAS00022,Battery Interrupt Igniter,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00038,Seat occupied recognition: driver side: rear,not installed,
MAS00039,Seat occupied recognition: passenger side: rear,not installed,
MAS00040,Seat occupied recognition: center: rear,not installed,
MAS00044,Terminal 15 power supply,13.2, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:12
;SW:17A-920-840 HW:17A-920-840 --- Instruments
;Component:KOMBI 208 0310, Coding:09B4010A2380CF05020823001000000020000000
;EV_DashBoardVDDMQBAB,009060,EV_DashBoardVDDMQBAB_009_VW37.rod
;Saturday,05,December,2020,16:58:02:14741
;VCID: E0924BCA2AC0BA5B933-80B4
IDE00019,Voltage terminal 30,14.4, V
IDE00021,Engine RPM,1224.00, /min
IDE00025,Coolant temperature,9.00, °C
IDE00196,Engine oil temperature,197, °C
IDE00301,Mileage,46758, km
IDE00310,Outside temperature,11.0, °C
IDE00316-IDE00500,Time-Hour,16, H
IDE00316-IDE00501,Time-Minute,57, min
IDE00316-MAS00111,Time-Seconds,23, s
IDE00317-IDE00502,Date-Year,2020, yr
IDE00317-IDE00503,Date-Month,12, Months
IDE00317-IDE00504,Date-Day,5, d
IDE00323,Security Access: Number of invalid keys,1,
IDE00510,ESI: distance driven from inspection,15442, km
IDE00511,ESI: time from inspection,275, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,20400, km
IDE00520,Photo transistor,138,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,560, km
IDE00698,ESI: remaining running time,90, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,901, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2019, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2019, mm
IDE00935,ESI: Theoretical service interval,37700, km
IDE01076,Time since ignition off,98229, s
IDE01153,SIA: maximum value of distance to service,16000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-MAS06854,FAZIT identification test sum-Version,03,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,B8 35 2C 27,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,11.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,DF,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,3287,
IDE03349,FIX:Max. distance driven until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,731, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,15400, km
IDE03352,FIX: Time since last time-dependent inspection,275, d
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,46.5, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,48.5, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,51.7, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,44.9, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,8.4, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,48.5, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,51.7, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,9.5, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,13.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,30.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,30.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,13.4, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,8.6, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,31.9, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,31.9, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,9.1, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,46600,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,46500,
IDE03472-MAS06155,Volume after refueling-Third to last distance,46300,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,46000,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,53, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,0, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,846,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2401,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,48.5, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,53, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,51.5, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,51.5, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,51.5, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,51.5, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,51.5, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.18750, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.00,
IDE03474-ENG101623,Calculated volume-reference_volume,51.5, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,112,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0033331,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,0, H
IDE03477-IDE00501,GPS time-Minute,0, min
IDE03477-IDE00502,GPS time-Year,2000, yr
IDE03477-IDE00503,GPS time-Month,1, Months
IDE03477-IDE00504,GPS time-Day,1, d
IDE03477-MAS00111,GPS time-Seconds,0, s
IDE03477-MAS03493,GPS time-last synchronization year,2000, yr
IDE03506,Distance: high resolution,02 C9 78 D1,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,6F F0 01 4B,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,2F F0 3C BE,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,AF F0 3C BE,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,EF F0 01 4B,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,AF F0 7A 54,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,EF F0 02 72,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,6F F0 02 72,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,2F F0 7A 54,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,32200, km
IDE05932,FIX: Reset value for next time-dependent inspections,731, d
IDE06566-IDE00008,Key identification-Software version,006A,
IDE06566-IDE00016,Key identification-Hardware version,H91,
IDE06566-MAS04970,Key identification-Part Number,5G6959753AC,
IDE09552-IDE07944,Vehicle configuration 2-electronic brake booster,Correct coding,
IDE09552-MAS06008,Vehicle configuration 2-Internal noise sound actuator,Correct coding,
IDE09552-MAS08940,Vehicle configuration 2-Collision warning,Correct coding,
ENG124477-MAS06854,Adapted_transponders_checksum-Version,01,
ENG124477-MAS06855,Adapted_transponders_checksum-Test sum,B4 9E EA 31,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,32, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,14, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,62, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,63, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,53, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,56, km
ENG106922,Immobilizer - Challenge,6C 13 E5 A2,
ENG99439,Instrument_recorder,03 03 31 00 4D 51 42 56 57 31 37 53 31 4D 00 00 00 00 00 00 01 00 83 00 1B 00 00 00 D7 00 00 00 00 80 00 08 3D 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 0A FF FF FF FF FF FF FF FF FF 00 00 1B 00 83 00 D7 00 00 00 00 00 00 00 1B 00 83 00 E9 00 00 00 00 00 00 00 1B 00 83 00 D7 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 7E 3B,
ENG107920-ENG100914,onboard_computer-current_consumption,300.0,
ENG107920-ENG119788,onboard_computer-range_average_consumption,6.3, l/100km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,6.3, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,7.9, l/100km
ENG107920-ENG119791,onboard_computer-range_display_value,724, km
ENG107920-ENG119792,onboard_computer-range_R,723,
ENG107920-ENG112418,onboard_computer-total_range_gas,724, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,122,
ENG103405,read_out_measured_value_block,46,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108925-ENG103300,Service_Key_Data_Current_Page-Service_Data,D4 84 07 22 28 C0 14 0C 04 0C 28 01 94 B6 00 00 04 30 5B 10 69 30 C9 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 FF FF 00 00 41 08,
ENG108926-ENG103300,Service_Key_Data_Previous_Page-Service_Data,DD 93 07 22 28 C0 14 0C 04 0B 35 33 7F B6 00 00 04 30 5B 10 69 30 C9 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 FF FF 00 00 41 08,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,1726,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,1724,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,2,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,1,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,Update_Error,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Start_Delay,
ENG119884-ENG119838,Service_Key_Mileage_Date-CRC_Block_0,46 1C,
ENG119884-ENG119860,Service_Key_Mileage_Date-CRC_Block_1,46 38,
ENG119884-ENG119856,Service_Key_Mileage_Date-CRC_Block_2,46 2D,
ENG119884-ENG119857,Service_Key_Mileage_Date-CRC_Block_3,46 C6,
ENG119884-ENG119858,Service_Key_Mileage_Date-CRC_Block_4,9D BF,
ENG119884-ENG119859,Service_Key_Mileage_Date-CRC_Block_5,9D 93,
ENG119884-ENG119861,Service_Key_Mileage_Date-CRC_Block_6,C6 67,
ENG119884-ENG119873,Service_Key_Mileage_Date-CRC_Block_7,C6 18,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,4, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,4, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,4, d
ENG119884-ENG119866,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3,4, d
ENG119884-ENG119865,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_4,3, d
ENG119884-ENG119864,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_5,3, d
ENG119884-ENG119863,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_6,4, d
ENG119884-ENG119872,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_7,4, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,12, Months
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,12, Months
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,12, Months
ENG119884-ENG119851,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3,12, Months
ENG119884-ENG119852,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_4,12, Months
ENG119884-ENG119853,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_5,12, Months
ENG119884-ENG119854,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_6,12, Months
ENG119884-ENG119855,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_7,12, Months
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2020, yr
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2020, yr
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2020, yr
ENG119884-ENG119846,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3,2020, yr
ENG119884-ENG119847,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_4,2020, yr
ENG119884-ENG119848,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_5,2020, yr
ENG119884-ENG119849,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_6,2020, yr
ENG119884-ENG119862,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_7,2020, yr
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,46670,
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,46698,
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,46719,
ENG119884-ENG119841,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3,46740,
ENG119884-ENG119842,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_4,46620,
ENG119884-ENG119843,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_5,46640,
ENG119884-ENG119844,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_6,46645,
ENG119884-ENG119871,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_7,46666,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,Bank_1,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,1724,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,1724,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,1724,
ENG100879-ENG118224,State Blocking Time-blocking_time,00 00 00 00 00 00,
ENG103899-ENG99298,State of Immobilizer-State,02 01 03 D5 02 00 00 00 00 00,
ENG103284-ENG118223,State of Immobilizer Slaves-ELV_State,00,
ENG103284-ENG118222,State of Immobilizer Slaves-GSG_State,00,
ENG103284-ENG118217,State of Immobilizer Slaves-Immobilizer_State,00,
ENG103284-ENG118216,State of Immobilizer Slaves-key_state,FC,
ENG103284-ENG118218,State of Immobilizer Slaves-MSG_1_State,F8,
ENG103284-ENG118219,State of Immobilizer Slaves-MSG_2_State,00,
ENG103284-ENG118220,State of Immobilizer Slaves-MSG_3_State,00,
ENG103284-ENG118221,State of Immobilizer Slaves-MSG_4_State,00,
ENG103284-ENG20775,State of Immobilizer Slaves-OCU_state,00,
ENG103284-ENG20776,State of Immobilizer Slaves-VTS_state,00,
ENG109575,Transponder ID current Key,00 29 6D 4D,
ENG109576,Transponder ID Key 1,00 29 6D 4D,
ENG109577,Transponder ID Key 2,00 29 50 59,
Elapsed Time: 00:14
;SW:3Q0-907-530-K HW:3Q0-907-530-B --- CAN Gateway
;Component:GW MQB Mid 517 5323, Coding:030100047F085708FB0000481C0F00010001070000000000000000000000
;EV_GatewNF,013023,EV_GatewNF_VW37.rod
;Saturday,05,December,2020,16:59:06:14741
;VCID: B720C096DFCE9DE3029-80E2
IDE00019,Voltage terminal 30,13.2, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056-ENG20489,History data 1-Life Cycle Data String,2020-12-01-13:16*00.0*02*00021***
2020-11-16-10:01*00.0*02**
2020-10-31-15:43*00.0*02**
2020-03-24-09:20*00.2*01*00000***
2020-03-24-09:06*00.1*01**
2020-03-24-08:56*00.5*01**,
IDE00057-ENG20489,History data 2-Life Cycle Data String,-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058-ENG20489,History data 3-Life Cycle Data String,2020-03-24-09:28*3*0*070*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-24-09:24*3*0*088*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-24-09:21*3*0*089*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-24-09:21*1*0*089*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-24-09:07*3*0*089*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-24-08:57*3*0*089*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-24-08:21*3*0*089*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-24-08:21*1*0*089*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-23-18:23*3*0*090*000*0-0-0-0-0-0-0*0*0*00.0*00.0**
2020-03-23-18:23*1*0*090*000*0-0-0-0-0-0-0*0*0*00.0*00.0**,
IDE00059-ENG20489,History data 4-Life Cycle Data String,2020-03-24-00:09*02*058*VAO*2222222222*10010*01678*049.7*000.0*000.0**
0000000km*01*059*JCB*1111111111*10010*01873*106.3*000.0*000.0**
IDE00060-ENG20489,History data 5-Life Cycle Data String,2020-03-23-13:10*3*+0.000*10.24*000*09*+00.0*01870*10010*032536*0-0-0-0-0-0-0*0*1*0*00.0*00.0*000.0*04*00*00*01*02**
2020-03-23-05:54*2*+0.000*07.93*000*09*+00.0*01870*10010*032432*0-0-0-0-0-0-0*0*1*0*00.0*00.0*000.0*00*01*00*01*01**
2020-03-21-09:50*3*+0.000*08.77*000*09*-00.1*01867*10010*032406*0-0-0-0-1-0-0*0*1*1*00.0*00.0*000.7*06*03*00*00*01**,
IDE00061-ENG20489,History data 6-Life Cycle Data String,2020-12-04-13:20*034*+24*+000.5*00.30*0.02*004**
2020-12-04-12:48*035*+21*+000.2*00.00*0.00*000**
2020-12-04-12:20*035*+20*+001.2*00.30*0.00*000**
2020-12-04-11:36*037*+18*-000.1*00.30*0.00*000**
2020-12-04-11:22*037*+18*+000.6*00.20*0.00*000**
2020-12-04-10:46*037*+16*+000.6*00.30*0.00*000**
2020-12-04-08:57*035*+08*+000.4*00.50*0.00*000**
2020-12-03-06:46*031*+06*+000.1*00.60*0.06*006**
2020-12-02-17:15*036*+28*+000.6*00.20*0.00*001**
2020-12-02-16:35*036*+27*+000.2*00.20*0.00*003**,
IDE00062-ENG20489,History data 7-Life Cycle Data String,2020-12-04-13:40*033*+000.0*027.2*00.0*00.0**
2020-12-04-12:50*034*+000.0*000.4*00.0*00.0**
2020-12-04-11:58*036*+000.0*000.3*00.0*00.0**
2020-12-04-11:06*037*+000.0*000.2*00.0*00.0**
2020-12-04-09:32*034*+000.0*001.1*00.0*00.0**
2020-12-03-07:28*034*+000.0*025.4*00.0*00.0**
2020-12-02-17:28*030*+000.0*013.2*00.0*00.0**
2020-12-02-16:48*035*+000.0*000.4*00.0*00.0**
2020-12-02-14:17*035*+000.0*002.2*00.0*00.0**
2020-12-02-12:40*034*+000.0*000.5*00.0*00.0**,
IDE00063-ENG20489,History data 8-Life Cycle Data String, 0032536km*1*05*00*00*01*-------------:--*01**
0000030km*1*04*00*00*01*-------------:--*01**
2018-08-03-11:04*4*03*00*00*01*2011-02-16-06:53*01**,
IDE00064-ENG20489,History data 9-Life Cycle Data String,2020-04-13-17:22*093*098*077*038*00031*12.50*+26*04*02*03.75*00219*00019**
2020-11-12-07:52*098*095*081*043*01626*12.50*+30*05*02*03.75*65535*01127**
2020-11-02-13:19*092*093*076*033*01567*12.50*+12*05*02*03.75*65535*01106**
2020-10-09-08:21*100*095*081*042*01437*12.50*+28*05*02*03.75*65535*01004**
2020-09-22-13:16*098*096*078*039*01330*12.50*+35*05*02*03.60*65535*00935**
2020-08-26-12:43*100*096*080*047*01196*12.50*+46*05*02*03.65*65535*00855**
2020-08-17-16:15*100*096*081*046*01105*12.50*+44*05*02*03.65*65535*00766**
2020-07-22-09:59*100*100*083*050*00931*12.60*+38*04*02*03.50*65535*00664**
0039001km*100*100*082*049*00785*12.50*+33*04*02*03.50*65535*00640**
2020-06-21-09:58*100*099*084*050*00674*12.60*+35*04*02*03.55*46230*00586**
2020-06-13-13:44*100*100*078*051*00549*12.50*+51*04*02*03.40*33870*00556**
2020-05-27-10:12*100*100*084*050*00411*12.60*+28*04*02*03.45*18558*00446**,
IDE00065-ENG20489,History data 10-Life Cycle Data String,-------------:--*-*---.-*----.-*-*---.-*----.-*--.--*-------**
IDE00066-ENG20489,History data 11-Life Cycle Data String,2020-12-04-13:20*000*000*000*015*0173*020*00.0*01.0*077*034*078*034*05*00239*00247*00770*01374*04797**
2020-12-04-12:48*000*000*000*001*0000*001*00.0*00.3*079*035*079*035*01**
2020-12-04-12:46*000*000*000*000*0000*000*00.0*00.0*079*035*079*035*01**
2020-12-04-12:20*000*000*000*019*0150*023*00.0*01.2*077*036*079*035*01**
2020-12-04-11:36*000*000*000*019*0194*021*00.0*00.5*081*037*081*037*01**,
IDE00067-ENG20489,History data 12-Life Cycle Data String,2020-12-04-09:30*0-0-0-1-0-0-0-0**
2020-12-04-09:27*0-0-0-1-0-0-0-0**
2020-12-04-09:23*0-0-0-1-0-0-0-0**
2020-12-04-09:19*0-0-0-1-0-0-0-0**
2020-12-04-09:15*0-0-0-1-0-0-0-0**
00000*00000*00000*00025*00000*00000*00000*00000**
2020-12-03-07:24*0-0-0-0-0-1-0-0**
2020-11-19-10:09*0-0-0-1-0-0-0-0**
2020-09-11-10:54*0-0-0-1-0-0-0-0**
2020-04-12-14:37*0-0-0-1-0-0-0-0**
2020-03-12-06:41*0-0-0-0-0-1-0-0**
00000*00000*00000*00003*00000*00001*00000*00000**
2020-12-05-16:57*1*082*033*+10*05*025*-16.39*11.4*1**
2020-12-03-07:24*1*078*030*+06*05*015*-21.21*11.9*0**
2020-12-02-10:03*1*086*034*+06*05*025*-05.64*12.3*1**
2020-12-01-10:48*1*079*027*+00*05*025*+17.73*13.5*1**
2020-11-18-09:38*1*076*028*+04*05*025*+09.09*12.4*1**
00006*00000*00000**,
IDE00068-ENG20489,History data 13-Life Cycle Data String,-------------:--*---------*---.-*-----**
IDE00071-ENG20489,History data 16-Life Cycle Data String, 0046758km**
00019*00461*00648*00000*00000**
07638*00505*00025*00004**
22268*00021*00000*00000**
00876*01086*00638*01296**
01894*01467*00535**
01650*00050*00170**
00000*00000*00000**
00013*00000*00000**
01099*00566*00394*00294*00232*00168*00262*00163*00118*00350*00005**,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,CCS Switch,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,3,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,35,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,1,
IDE01459,Energy management heat output control status,Stage 1,
IDE01805-ENG20489,History data 19-Life Cycle Data String,-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x-- $-- (empty entry),
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Extended data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,1.5, H
IDE01810-MAS00106,History data 24-Year,2020,
IDE01810-MAS00107,History data 24-Month,10,
IDE01810-MAS00108,History data 24-Day,31,
IDE01810-MAS00109,History data 24-Hours,20, H
IDE01810-MAS00110,History data 24-Minutes,0, min
IDE01810-MAS14375,History data 24-Cycle counter,3990,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,20,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,1B FC 72 0A,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,1,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Comfort data bus,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,1B 00 00 0E,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,1,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 03 CE,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,1,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Comfort data bus,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 03 D0,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,1,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Comfort data bus,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 00 00,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,0,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Unknown,
IDE01812-MAS01468,History data 26-Terminal 15,4105,
IDE01812-MAS03173,History data 26-Powertrain data bus,3414,
IDE01812-MAS03174,History data 26-Comfort data bus,15580,
IDE01812-MAS03175,History data 26-Extended data bus,0,
IDE01812-MAS03177,History data 26-Infotainment data bus,0,
IDE01812-MAS03178,History data 26-Suspension data bus,22,
IDE01812-MAS03180,History data 26-Local data bus,1,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,19017,
IDE01813-MAS03173,History data 27-Powertrain data bus,2945,
IDE01813-MAS03174,History data 27-Comfort data bus,22549,
IDE01813-MAS03175,History data 27-Extended data bus,0,
IDE01813-MAS03177,History data 27-Infotainment data bus,193,
IDE01813-MAS03178,History data 27-Suspension data bus,565,
IDE01813-MAS14374,History data 27-Totals,26252,
IDE01814-MAS03173,History data 28-Powertrain data bus,0,
IDE01814-MAS03174,History data 28-Comfort data bus,25267,
IDE01814-MAS03175,History data 28-Extended data bus,0,
IDE01814-MAS03177,History data 28-Infotainment data bus,0,
IDE01814-MAS03178,History data 28-Suspension data bus,17,
IDE01814-MAS14374,History data 28-Totals,25284,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,26.7, H
IDE01816-MAS00106,History data 30-Year,2020,
IDE01816-MAS00107,History data 30-Month,3,
IDE01816-MAS00108,History data 30-Day,8,
IDE01816-MAS00109,History data 30-Hours,16, H
IDE01816-MAS00110,History data 30-Minutes,8, min
IDE01816-MAS14375,History data 30-Cycle counter,2869,
IDE01816-ENG20570,History data 30-Bus_1,Powertrain data bus,
IDE01816-ENG20572,History data 30-Bus_2,Unknown,
IDE01816-ENG20574,History data 30-Bus_3,Unknown,
IDE01816-ENG20576,History data 30-Bus_4,Unknown,
IDE01816-ENG20578,History data 30-Bus_5,Unknown,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,0.2, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.0, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.0, H
IDE01817-MAS00106,History data 31-Year,2000,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,1,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,0, min
IDE01817-MAS14375,History data 31-Cycle counter,0,
IDE01817-MAS14376,History data 31-ECU 1,Node_0x-- $-- (empty entry),
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,Node_0x-- $-- (empty entry),
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,1.5, H
IDE01819-MAS00106,History data 33-Year,2020,
IDE01819-MAS00107,History data 33-Month,10,
IDE01819-MAS00108,History data 33-Day,31,
IDE01819-MAS00109,History data 33-Hours,20, H
IDE01819-MAS00110,History data 33-Minutes,0, min
IDE01819-MAS14375,History data 33-Cycle counter,3990,
IDE01819-MAS14393,History data 33-ID of the alerting message,1B FC 72 0A,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,27.2, H
IDE01820-MAS00106,History data 34-Year,2020,
IDE01820-MAS00107,History data 34-Month,12,
IDE01820-MAS00108,History data 34-Day,5,
IDE01820-MAS00109,History data 34-Hours,16, H
IDE01820-MAS00110,History data 34-Minutes,55, min
IDE01820-MAS14375,History data 34-Cycle counter,4108,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 4A,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,3, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,4109,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01827,Specified generator voltage,13.3, V
IDE01828,Generator DF Signal,25.825, %
IDE01829,Generator exciter current,1.375, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,110A - 150A MOSFET,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,13.238, V
IDE01836,Battery current,0.844, A
IDE01837,Temperature of battery sensor,11, °C
IDE01838,Battery temperature,10, °C
IDE01839,Battery charge level,81, %
IDE01841,Battery internal resistance,5.2, mOhm
IDE01842,Usable battery charge,32, Ah
IDE01843,Battery voltage at rest,12.5, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.1, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,Initialization,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,active,
IDE01855,Generator current,17.3, A
IDE01948,Battery internal resistance not normed,5.2, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,42 5E 01 80,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG06041,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG06043,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG06044,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG06045,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG06046,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG06047,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG06048,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG06049,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG06042,Play protection status-function_calls_counter_1,0,
IDE02578-ENG06050,Play protection status-function_calls_counter_2,0,
IDE02578-ENG06051,Play protection status-function_calls_counter_3,0,
IDE02578-ENG06052,Play protection status-function_calls_counter_4,0,
IDE02578-ENG06053,Play protection status-function_calls_counter_5,0,
IDE02578-ENG06054,Play protection status-function_calls_counter_6,0,
IDE02578-ENG06055,Play protection status-function_calls_counter_7,0,
IDE02578-ENG06056,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer/component current too high,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,3,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer/component current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,11,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,170,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,351,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,11,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer/component current too high,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,9,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,6,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2020,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,12,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,4,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,9,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,23,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,15,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,19,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,30,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,27,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,29,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,56,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,28,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,51,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,Possible standing time too short,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,Possible standing time too short,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,Possible standing time too short,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,Possible standing time too short,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,Possible standing time too short,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2020,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,12,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,3,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,3,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,12,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,7,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,6,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,24,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,41,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,48,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,22,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,Standing time timed out,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,Standing time timed out,
IDE03212,Start/stop conditions,Stop prohibition: no start request,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,58, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,Fleece,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,VAO,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,2222222222,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,present,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Preconditions met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,invalid,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05583-IDE02766,Break recommendation-Malfunction status,not installed,
IDE05583-MAS03095,Break recommendation-Function status,not installed,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Break recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,not engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,6F 1C F7 6F 66,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,Refused switch-over,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Headlight activation,
IDE06007-MAS00106,Driving profile history data 1-Year,2020,
IDE06007-MAS00107,Driving profile history data 1-Month,4,
IDE06007-MAS00108,Driving profile history data 1-Day,1,
IDE06007-MAS00109,Driving profile history data 1-Hours,22,
IDE06007-MAS00110,Driving profile history data 1-Minutes,8,
IDE06007-MAS00111,Driving profile history data 1-Seconds,29,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,32666, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,Refused switch-over,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Ambient light,
IDE06008-MAS00106,Driving profile history data 2-Year,2020,
IDE06008-MAS00107,Driving profile history data 2-Month,4,
IDE06008-MAS00108,Driving profile history data 2-Day,1,
IDE06008-MAS00109,Driving profile history data 2-Hours,22,
IDE06008-MAS00110,Driving profile history data 2-Minutes,8,
IDE06008-MAS00111,Driving profile history data 2-Seconds,29,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,32666, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Not available,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,Refused switch-over,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,A/C behavior,
IDE06009-MAS00106,Driving profile history data 3-Year,2020,
IDE06009-MAS00107,Driving profile history data 3-Month,3,
IDE06009-MAS00108,Driving profile history data 3-Day,23,
IDE06009-MAS00109,Driving profile history data 3-Hours,12,
IDE06009-MAS00110,Driving profile history data 3-Minutes,4,
IDE06009-MAS00111,Driving profile history data 3-Seconds,44,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,32452, km
IDE06009-MAS03095,Driving profile history data 3-Function status,available.,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,Unexpected switch-over,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,2,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Transmission override clutch,
IDE06010-MAS00106,Driving profile history data 4-Year,2020,
IDE06010-MAS00107,Driving profile history data 4-Month,3,
IDE06010-MAS00108,Driving profile history data 4-Day,21,
IDE06010-MAS00109,Driving profile history data 4-Hours,9,
IDE06010-MAS00110,Driving profile history data 4-Minutes,55,
IDE06010-MAS00111,Driving profile history data 4-Seconds,57,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,32406, km
IDE06010-MAS03095,Driving profile history data 4-Function status,available.,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,AUTO,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,44866,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,0,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,14300,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2000,
IDE06230-MAS00107,Break recommend.: last message-Month,0,
IDE06230-MAS00108,Break recommend.: last message-Day,0,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,02,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,40,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 04,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,1,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,2,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,Not available,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,3,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,0,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,0,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,0,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,0,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,Timeout,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,0,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,Not available,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,8,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,Not available,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,9,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,Timeout,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,0,
IDE07431-IDE04447,Status: driving mode selection for AFS & headlamp range control-Function status,Not available,
IDE07431-IDE06260,Status: driving mode selection for AFS & headlamp range control-ID number,11,
IDE07431-MAS01156,Status: driving mode selection for AFS & headlamp range control-Communication status,Timeout,
IDE07431-MAS01447,Status: driving mode selection for AFS & headlamp range control-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,Timeout,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,Not available,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,12,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,0,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,0,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,18,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,2,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop mode,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,Not permitted,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,13.2, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07637,Current charge contingent for feedback,360.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,8.15,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.70, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.80, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,912, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,904, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,1727.2, Ah
IDE07681-MAS06087,Battery total charging throughput-Entire energy throughput,1678.5, Ah
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Not Used,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Not Used,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Not Used,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,ECONOMY,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,Not Used,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Not Used,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Not Used,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,A4 AA B5 1E,
IDE08346-MAS06117,Generator Analysis-Specified voltage,13.3, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,13.2, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,28, °C
IDE08347,adapted battery capacity,64, Ah
IDE08354-IDE04447,Status: driv.profile select. for front axle differential lock-Function status,engaged,
IDE08354-IDE06260,Status: driv.profile select. for front axle differential lock-ID number,0,
IDE08354-MAS01156,Status: driv.profile select. for front axle differential lock-Communication status,Timeout,
IDE08354-MAS01447,Status: driv.profile select. for front axle differential lock-Act.val.,0,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,Timeout,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08680-MAS03173,Allocation data bus identifier-Powertrain data bus,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Extended data bus,15,
IDE08680-MAS03177,Allocation data bus identifier-Infotainment data bus,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Powertrain data bus,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Extended data bus,not installed,
IDE08681-MAS03177,Data bus defect error-Infotainment data bus,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Powertrain data bus,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Extended data bus,not installed,
IDE08682-MAS03177,Data bus single wire err.-Infotainment data bus,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Powertrain data bus,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Extended data bus,not installed,
IDE08683-MAS03177,Data bus TimeOut error-Infotainment data bus,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT09757,Allocation LIN system number-Generator,00 1D,
IDE08684-SFT09777,Allocation LIN system number-Multifunction steering wheel control module,00 31,
IDE08684-SFT09783,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT09833,Allocation LIN system number-Inverter for electrical outlet,00 69,
IDE08684-SFT09842,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT10031,Allocation LIN system number-Control head driving profile,01 2F,
IDE08684-SFT10046,Allocation LIN system number-Steering Wheel Touch Recognition Control Module,00 00,
IDE08685-SFT09757,Status LIN user-Generator,active,
IDE08685-SFT09777,Status LIN user-Multifunction steering wheel control module,active,
IDE08685-SFT09783,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT09833,Status LIN user-Inverter for electrical outlet,not active,
IDE08685-SFT09842,Status LIN user-Analog clock,not active,
IDE08685-SFT10031,Status LIN user-Control head driving profile,not active,
IDE08685-SFT10046,Status LIN user-Steering Wheel Touch Recognition Control Module,not active,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,0,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,0,
IDE08797-IDE04447,Status: drive profile for area view-Function status,engaged,
IDE08797-IDE06260,Status: drive profile for area view-ID number,0,
IDE08797-MAS01156,Status: drive profile for area view-Communication status,Timeout,
IDE08797-MAS01447,Status: drive profile for area view-Act.val.,0,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,0,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,Timeout,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE09561,Static current last LIN sleep phase,-1.268, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10737-IDE04447,Status: driving profile selection for range calculation-Function status,engaged,
IDE10737-IDE06260,Status: driving profile selection for range calculation-ID number,0,
IDE10737-MAS01156,Status: driving profile selection for range calculation-Communication status,OK,
IDE10737-MAS01447,Status: driving profile selection for range calculation-Act.val.,0,
IDE10738-IDE04447,Status driving profile selection for electronic brake booster-Function status,engaged,
IDE10738-IDE06260,Status driving profile selection for electronic brake booster-ID number,0,
IDE10738-MAS01156,Status driving profile selection for electronic brake booster-Communication status,Timeout,
IDE10738-MAS01447,Status driving profile selection for electronic brake booster-Act.val.,0,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,0,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initialization,
IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,No malfunction detected,
IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Standby-mode,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No malfunction detected,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11911-SFT09769,48V activation restriction-Auxiliary Air Heater Control Module/PTC,not active,
IDE11911-SFT09997,48V activation restriction-Electrical compressor,not active,
IDE12084,Component protection participant status,00 14 19 00 00 00 0E 13 00 00 00 57 20 00 00 00 15 11 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,12.2, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Freewheel engine off block,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,8,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12135-MAS14363,Belt driven starter generator 12V-Specified voltage: lower limit,16.90, V
IDE12135-MAS14364,Belt driven starter generator 12V-Specified voltage limit,16.90, V
IDE12135-MAS14365,Belt driven starter generator 12V-Recommended specified voltage,13.3, V
IDE12135-MAS14366,Belt driven starter generator 12V-Maximum ramp time,3, s
IDE12135-MAS14367,Belt driven starter generator 12V-Minimum voltage for start,7.8, V
IDE12135-MAS14368,Belt driven starter generator 12V-Specified voltage of the belt driven starter generator,15.0, V
IDE12135-MAS14369,Belt driven starter generator 12V-Actual mode belt driven starter generator,Neutral,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,5,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,59,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,3,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,189,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,46758, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,1,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG06039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG06040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG20970,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG06038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG06036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118787-ENG06066,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_AGK,0,
ENG118787-ENG06070,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_EDS,0,
ENG118787-ENG20951,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_FMA,0,
ENG118787-ENG06074,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_HHC,0,
ENG118787-ENG118757,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_IVB,0,
ENG118787-ENG06078,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_PLA,0,
ENG118787-ENG06067,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_AGK,OK,
ENG118787-ENG06071,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_EDS,OK,
ENG118787-ENG20952,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_FMA,OK,
ENG118787-ENG06075,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_HHC,OK,
ENG118787-ENG118759,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_IVB,OK,
ENG118787-ENG06079,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_PLA,Timeout,
ENG118787-ENG06065,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_AGK,engaged,
ENG118787-ENG20953,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_EDS,engaged,
ENG118787-ENG20954,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_FMA,Not available,
ENG118787-ENG06073,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_HHC,engaged,
ENG118787-ENG118755,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_IVB,engaged,
ENG118787-ENG06077,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_PLA,engaged,
ENG118787-ENG06064,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_AGK,0,
ENG118787-ENG06072,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_BAS,0,
ENG118787-ENG06068,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_EDS,0,
ENG118787-ENG20955,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_FMA,75,
ENG118787-ENG118753,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_IVB,0,
ENG118787-ENG06076,Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_PLA,0,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,active,
ENG06004-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG06004-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG06004-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG06004-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG06004-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,13.5, V
ENG06004-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,active,
ENG20108,EM_electrical_system_current,16.452, A
ENG118437,EM_IAlternatorReserve,125.8, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,350, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,92, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,87, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG115189,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,1,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG36229,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG36251,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,1,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG121521,EM_Recuperation_Restriction-limited_by_48V_consumer,1,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG36309,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG36310,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,0915,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG06026,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,2002,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,7240,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0500,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG32644,Gateway app. software identification-software_version_mv-em,,
ENG118782-ENG32645,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7180,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG20113-ENG09375,MV-EM_48V_electrical_system_components-48V_Ptc_installed,not installed,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09372,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG20113-ENG09373,MV-EM_48V_electrical_system_components-eAv_installed,not installed,
ENG20113-ENG09371,MV-EM_48V_electrical_system_components-eAws_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,Initialization,
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,Initialization,
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initialization,
ENG20115-ENG09356,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG20115-ENG09355,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG20115-ENG09357,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG20115-ENG09354,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG20115-ENG09353,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG20115-ENG09358,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initialization,
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,Initialization,
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,102.25, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,-204.0, A
ENG20120,MV-EM_dc_power_desired,-6325, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,-511, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
Elapsed Time: 00:48
;SW:5Q4-959-393-E HW:5Q4-959-393-B --- Door Elect, Driver
;Component:TSG FS 011 0032, Coding:00200B200100028000000000
;EV_DCUDriveSideEWMAXCONT,006001,EV_DCUDriveSideEWMAXCONT.rod
;Saturday,05,December,2020,17:06:10:14741
;VCDS Version: Release 20.12.0 (x64) Data version: 20201124 DS322.0
;VCID: C5DCBA5E9522FF73805-8090
Group,Description,Actual
IDE01766-MAS02248,Distance impulses-Signal state,Not available,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,12.9, V
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,13.2, V
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
IDE04216-MAS01458,Mirror heater-Operating condition,not_active,
IDE04216-MAS02965,Mirror heater-Performance percentage,255, %
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not installed,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04411,Child safety button,Not operated,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,255, %
IDE04581,Dimming for interior ambient lighting,255, %
IDE04586,Mirror fold-in activation,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,54, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.0, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle condition,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.0, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,215, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,3R03,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,13.0, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.5, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.5, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.5, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,21.5, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,14.0, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.5, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.5, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.5, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not detected,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,2,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,21, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,34, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.0, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,2,
MAS00464-MAS00109,Standard - ambient data 1-Hours,17,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,5,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,36,
MAS01872,Rear lid remote control lock switch,Not operated,
MAS02101,Child safety lock,not active,
ENG117313-ENG99000,control_event_memory_driver_side_rear-Value,00 14 0B 08 08 01 34 12 C8 14 0B 06 06 35 1B 12 64 14 0B 08 08 01 2D 11 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117295-MAS00966,Driver_Rear_VW_FAZIT_Identification_String-Manufacturer index location,YEY-540,
ENG117295-MAS00968,Driver_Rear_VW_FAZIT_Identification_String-Day of manufacture,01.06.18,
ENG117295-MAS00969,Driver_Rear_VW_FAZIT_Identification_String-Manufacturer- test stand number,0031,
ENG117295-MAS00970,Driver_Rear_VW_FAZIT_Identification_String-Running manufacturer number,0441,
ENG117309,Window_Regulator_Driver_Side_Rear_Sleep_Indication,not active,
ENG117315-ENG99000,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-Value,J926 ,
Elapsed Time: 00:08
;SW:5QM-909-144-B HW:5QM-909-144-B --- Steering Assist
;Component:EPS_MQB_ZFLS 172 1081, Coding:011F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Saturday,05,December,2020,17:06:29:14741
;VCID: D0F29B0A5A602ADB233-8084
IDE00018,Voltage terminal 15,13.22, V
IDE00019,Voltage terminal 30,13.06, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,876, /min
IDE00102,Control Module temperature,22.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,0A,
IDE00550-MAS01078,Identification of parameterization-Vehicle model,A1,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,21,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,01,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assist-System status,Function cannot be performed,
IDE02006-IDE04227,Lane assist-Directional stab. asst w/ pwr steering asst: steering status,31.999, Nm
IDE02006-MAS03095,Lane assist-Function status,not activated,
IDE02006-MAS03368,Lane assist-Steering wheel vibration,not active,
IDE02202,End stage temperature,14.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Electric motor speed,0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,-85.8, °
IDE03682-MAS03083,motor position sensor-Cosine signal,2.421, V
IDE03682-MAS03211,motor position sensor-Sine signal,2.444, V
IDE03682-MAS05053,motor position sensor-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,Dynamic,
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,4095.9, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,4073.3, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,-0.032, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,-0.032, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-0.3, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-0.3, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active default-Restoring force: setpoint,-2, N
IDE04183,Steering assistance: target engine torque,-0.003, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,13.16, V
IDE04187,Steering torque: raw value 1,11.816, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-90.918, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,11.914, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-90.918, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.39, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.38, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.40, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,-0.1, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,0.1, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.0, A
IDE04194,Steering assistance: electromotor power,-0.83, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,18.0, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,0.1, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.69, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical middle,0.07, mm
IDE04460,Steering angle sensor: offset straight line running,-1.9, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,0,
IDE04511,Steering angle sensor external via CAN: angle,Measuring value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measuring value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine RPM,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05155,Power steering current consumption,0.00, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.41, mm
IDE05162-MAS01850,Software end stop-Right,-80.27, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,300547,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,299741,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG08146,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG08147,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG30242,Engine specified torque load-above_11_kilo_newton,11638,
IDE05994-ENG30407,Engine specified torque load-below_-11_kilo_newton,11638,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,3840721,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,132,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,120,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,112,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,10391,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adaptation value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,0,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Control active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS00976-IDE80003,Counter-Analysis 3,1757755566,
MAS00976-IDE80004,Counter-Analysis 4,159132,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG37819-ENG37964,Strain_detection-Calculated_worm_gear_temperature,25.0, °C
ENG37819-ENG38046,Strain_detection-High_count_worm_gear_alt,159132,
ENG37819-ENG38061,Strain_detection-KlimaSensor02_alt,0,
ENG37819-ENG38097,Strain_detection-Low_count_worm_gear_alt,1757755566,
ENG37819-ENG38105,Strain_detection-Mileage_counter,0, km
ENG37819-ENG38117,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG37819-ENG102605,Strain_detection-outside_temperature,11.0, °C
ENG37819-ENG37918,Strain_detection-revolutions_per_minute_electric_motor,-1, /min
ENG37819-ENG26208,Strain_detection-Steering_angle,18.1, °
ENG37819-ENG37919,Strain_detection-steering_moment,-0.032, Nm
ENG37819-ENG37920,Strain_detection-Steering_Support_Engine_Commanded_Torque,-0.002, Nm
ENG37819-ENG38151,Strain_detection-Strain_detection_per_cent,0.0000011952, %
Elapsed Time: 00:07
;SW:5Q4-959-392-E HW:5Q4-959-392-B --- Door Elect, Pass.
;Component:TSG BFS 011 0032, Coding:002003200100028000000000
;EV_DCUPasseSideEWMAXCONT,006001,EV_DCUPasseSideEWMAXCONT.rod
;Saturday,05,December,2020,17:06:44:14741
;VCID: C4DAA75A9E18C67B97B-8090
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,12.8, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,13.3, V
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05726,Dimmer terminal 58xd,52, %
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.0, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Idle condition,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.0, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,215, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,3R03,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,13.5, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.5, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.5, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.5, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.5, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,21, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,34, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,93.5, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,93.5, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,93.5, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,93.5, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,93.5, %
MAS00464-MAS00110,Standard - ambient data 1-Minutes,6,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9,
ENG117314-ENG99000,control_event_memory_passenger_side_rear-Value,01 14 0B 08 08 01 2D 11 00 14 0B 08 08 01 34 12 C8 14 0B 06 06 35 1B 12 6A 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117296-MAS00966,Passenger_Rear_VW_FAZIT_Identification_String-Manufacturer index location,YEY-540,
ENG117296-MAS00968,Passenger_Rear_VW_FAZIT_Identification_String-Day of manufacture,02.06.18,
ENG117296-MAS00969,Passenger_Rear_VW_FAZIT_Identification_String-Manufacturer- test stand number,0021,
ENG117296-MAS00970,Passenger_Rear_VW_FAZIT_Identification_String-Running manufacturer number,0261,
ENG117310,Window_Regulator_Passenger_Side_Rear_Sleep_Indication,not active,
ENG117316-ENG99000,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-Value,J927 ,
Elapsed Time: 00:07
;SW:17A-035-868 HW:17A-035-868 --- Information Electr.
;Component:MU-E--ER 680 8740, Coding:02730100AA00000041220001001000009F0000D40000010000
;EV_MUEnt4CGen2LGE,001041,EV_MUEnt4CGen2LGE_VW26.rod
;Saturday,05,December,2020,17:07:02:14741
;VCID: E78050D6CFEECD63529-80B2
IDE00019,Voltage terminal 30,13.2, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine RPM,874.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,90, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-9, °C
IDE00655-MAS02238,Temperature of processor circuit board-Up-to-date,40, °C
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,5.80, mA
IDE00668-MAS03232,Microphone voltage consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,4, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Condition not met,
IDE00916-IDE02128,Speaker status-Right front speaker,Condition not met,
IDE00916-IDE02129,Speaker status-Left rear speaker,Condition not met,
IDE00916-IDE02130,Speaker status-Right rear speaker,Condition not met,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measuring value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measuring value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measuring value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measuring value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measuring value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measuring value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measuring value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measuring value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measuring value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measuring value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measuring value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01442-MAS06123,Pressing a button-Eject button,Not available,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measuring value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measuring value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measuring value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measuring value not available,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,255, dBµV
IDE01700-MAS01765,Status of tuner for digital radio (DAB)-Audio Signal,Not available,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not activated,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,0, kHz
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,Not available,
IDE01700-ENG117350,Status of tuner for digital radio (DAB)-Audio_Mode,00,
IDE01700-ENG117354,Status of tuner for digital radio (DAB)-Audio_Quality,0,
IDE01700-ENG117330,Status of tuner for digital radio (DAB)-availability_traffic_data_TMC,Not available,
IDE01700-ENG117329,Status of tuner for digital radio (DAB)-availability_traffic_data_TP,Not available,
IDE01700-ENG117348,Status of tuner for digital radio (DAB)-Bit_Rate,65535, kbps
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG117327,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_FIC,16.777215,
IDE01700-ENG117326,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_MSC,16.777215,
IDE01700-ENG117328,Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_NET,16.777215,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label, ,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117331,Status of tuner for digital radio (DAB)-Ensemble_ID,00 00 00 00,
IDE01700-ENG117332,Status of tuner for digital radio (DAB)-Ensemble_Label, ,
IDE01700-ENG117333,Status of tuner for digital radio (DAB)-Ensemble_Label_Mask,00 00,
IDE01700-ENG117334,Status of tuner for digital radio (DAB)-Extended_Country_Code,00,
IDE01700-ENG117342,Status of tuner for digital radio (DAB)-Label_Masks,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,00 00 00 00,
IDE01700-ENG117351,Status of tuner for digital radio (DAB)-Protection_Level,Not available,
IDE01700-ENG117349,Status of tuner for digital radio (DAB)-Sample_Rate,65535, kHz
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,00,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label, ,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,00 00,
IDE01700-ENG117325,Status of tuner for digital radio (DAB)-signal_quality,0,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,00,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label, ,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01700-ENG117353,Status of tuner for digital radio (DAB)-SYNC/OFDM_Lock,not activated,
IDE01700-ENG117352,Status of tuner for digital radio (DAB)-Transmission_Mode,0,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,68, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,61, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,47, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,14, dBµV
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,0, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01771-ENG117327,Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC,1.068390,
IDE01771-ENG117326,Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC,1.068387,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Infotainment data bus,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,9, min
IDE04317-MAS00108,Total system run time-Day,45, d
IDE04317-MAS00109,Total system run time-Hours,10, H
IDE04317-MAS00110,Total system run time-Minutes,29, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,available.,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 06 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,available.,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Preconditions met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,B4 CF 3F 44 7C B9 D4 C5 21 6D 4A 2F 2B 1A 20 5F E9 9E 80 90 EB BF 1C 29 EE 40 C2 C8 9F 54 41 7E 1E E2 AD 0C 42 E2 28 A7 7E 20 1F BB D8 61 70 21 DC 61 A6 00 5A 15 05 EA E6 24 85 A8 45 50 4E B8 AA FC F5 AC 93 02 8F 27 89 14 26 07 6B 49 3A BD F4 94 57 E7 44 E8 60 61 A2 76 5D 68 5B C3 9D 13 ED 44 00 C6 23 F0 F3 B9 B4 43 83 70 41 06 49 EF EE B9 94 98 C4 95 7D 6E 51 AF 23 15 D8 67 45 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04547,Traffic information,OFF,
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Infotainment data bus,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth: device address,30 C3 D9 2F B6 F4,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05597-IDE03615,Bluetooth: Paired device 1-Variant,ÙA Noah Robbinsâs iPhone "Apple Inc." iPhone12,5 Version 13.7 (Build 17H35) ÿÿ
ÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth: device address,8C 86 1E D9 41 AD,
IDE05597-MAS01483,Bluetooth: Paired device 1-Software version,ÙA Noah Robbinsâs iPhone "Apple Inc." iPhone12,5 Version 13.7 (Build 17H35) ÿÿ
ÿÿ
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),8C 86,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),8C 86,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,ÙA Noah Robbinsâs iPhone "Apple Inc." iPhone12,5 Version 13.7 (Build 17H35) ÿÿ
ÿÿ
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Noah Robbinsâs iPhone
"Apple Inc."
iPhone12,5
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,8C 86,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,8C 86,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,8C 86,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,8C 86,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,8C 86,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,8C 86,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,8C 86,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,8C 86,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,8C 86,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,8C 86,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,8C 86,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,8C 86,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,8C 86,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,8C 86,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,8C 86,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,8C 86,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,8C 86,
IDE05598-IDE03615,Bluetooth: Paired device 2-Variant,<r.{ Brandonâs iPhone "Apple Inc." iPhone11,8 Version 14.1 (Build 18A8395) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth: device address,FC 18 3C 72 2E 7B,
IDE05598-MAS01483,Bluetooth: Paired device 2-Software version,<r.{ Brandonâs iPhone "Apple Inc." iPhone11,8 Version 14.1 (Build 18A8395) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),FC 18,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),FC 18,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,<r.{ Brandonâs iPhone "Apple Inc." iPhone11,8 Version 14.1 (Build 18A8395) ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,Brandonâs iPhone
"Apple Inc."
iPhone11,8
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,FC 18,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,FC 18,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,FC 18,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,FC 18,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,FC 18,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,FC 18,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,FC 18,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,FC 18,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,FC 18,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,FC 18,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,FC 18,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,FC 18,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,FC 18,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,FC 18,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,FC 18,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,FC 18,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,FC 18,
IDE05599-IDE03615,Bluetooth: Paired device 3-Variant,d@rÜ Nicoleâs iPhone "Apple Inc." iPhone12,1 Version 14.0 (Build 18A373)
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth: device address,88 64 40 72 82 DC,
IDE05599-MAS01483,Bluetooth: Paired device 3-Software version,d@rÜ Nicoleâs iPhone "Apple Inc." iPhone12,1 Version 14.0 (Build 18A373)
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),88 64,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),88 64,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,d@rÜ Nicoleâs iPhone "Apple Inc." iPhone12,1 Version 14.0 (Build 18A373)
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,Nicoleâs iPhone
"Apple Inc."
iPhone12,1
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,88 64,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,88 64,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,88 64,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,88 64,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,88 64,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,88 64,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,88 64,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,88 64,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,88 64,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,88 64,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,88 64,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,88 64,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,88 64,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,88 64,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,88 64,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,88 64,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,88 64,
IDE05600-IDE03615,Bluetooth: Paired device 4-Variant,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth: device address,FF FF FF FF FF FF,
IDE05600-MAS01483,Bluetooth: Paired device 4-Software version,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),FF FF,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),FF FF,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,FF FF,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,FF FF,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,FF FF,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,FF FF,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,FF FF,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,FF FF,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,FF FF,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,FF FF,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,FF FF,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,FF FF,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,FF FF,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,FF FF,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,FF FF,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,FF FF,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,FF FF,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,FF FF,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,FF FF,
IDE05601-IDE03615,Bluetooth: Paired device 5-Variant,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth: device address,FF FF FF FF FF FF,
IDE05601-MAS01483,Bluetooth: Paired device 5-Software version,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),FF FF,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),FF FF,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,FF FF,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,FF FF,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,FF FF,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,FF FF,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,FF FF,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,FF FF,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,FF FF,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,FF FF,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,FF FF,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,FF FF,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,FF FF,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,FF FF,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,FF FF,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,FF FF,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,FF FF,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,FF FF,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,FF FF,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05726,Dimmer terminal 58xd,67.55, %
IDE05814,Individualization characteristic,A3 2B 87 8E 1A,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,FF,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06425,Dynamometer mode: functional,not activated,
IDE06516-MAS01424,Temperature: optical drive-max.value,205, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,205, °C
IDE06516-MAS02238,Temperature: optical drive-Up-to-date,205, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,100, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,-9, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,37, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,205, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,205, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Up-to-date,205, °C
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardware version,---,
IDE10479-MAS01483,Interface for external media: identification-Software version,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-MAS01482,Function module: identification-Hardware version,100,
IDE10843-MAS04326,Function module: identification-Device name,MU ,
IDE10843-MAS11354,Function module: identification-Bootloader version,8740,
IDE10843-MAS11355,Function module: identification-Application version,8740,
IDE10843-MAS11356,Function module: identification-Module Name,CPU ,
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE12277-MAS01632,External optical drive (USB): status-Status,Measuring value not available,
IDE12420-MAS01482,iPod chip: identification-Hardware version,01,
IDE12420-MAS01483,iPod chip: identification-Software version,03,
IDE12420-MAS02832,iPod chip: identification-Malfunction status,00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,5,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,35,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,189,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,46758, km
MAS00481-ENG117777,BAP-BAP_Function_ID,00,
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,3,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,103.5, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,61, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,40, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),930, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01991-IDE00010,Card reader-Serial number,FF FF FF FF,
MAS01991-IDE01001,Card reader-Application,--,
MAS01991-MAS01632,Card reader-Status,not connected,
MAS01991-MAS03159,Card reader-Manufacturer,FF,
MAS01991-MAS03375,Card reader-Major version,15,
MAS01991-MAS03376,Card reader-Minor version,15,
MAS01991-MAS03959,Card reader-Write-protection,Not available,
MAS01991-MAS04388,Card reader-Card type,-----,
MAS01991-MAS13476,Card reader-Manufacturing date: month,15, Months
MAS01991-MAS13477,Card reader-Manufacturing date: year,2255, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,930665212682322,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,Mute,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,0, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,21, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,0, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,0, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,0, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,0, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,0, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,0, s
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,0,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,0,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
Elapsed Time: 00:16
;33-OBD2
;Saturday,05,December,2020,17:07:52:14741
03,Fuel system 1/2 status,Closed loop,,using O2 sensors,Engine off
04,Calculated load value,16.9 %,16.9 %
05,Engine coolant temperature,59 °C,59 °C
06,Short Term Trim - Bank 1,-0.8 %
07,Long Term Trim - Bank 1,4.7 %
0B,Intake Manifold Absolute Pressure,30 kPa abs
0C,Engine RPM,877 /min,884 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,-1.0 Degrees
0F,Intake air temperature,16 °C
11,Throttle position sensor,12.5 %,12.5 %
12,Secondary Air Status,Atmosphere/off
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.725 V
1C,OBD Requirements Met,OBD + OBD II
1F,Time since engine start,596 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,6.3 %
2F,Fuel Level Input,99.6 %
30,Warm-ups since DTC cleared,255
31,Distance since DTC cleared,14226 km
33,Barometric pressure,97 kPa abs
34,Bank 1 Sensor 1 Status,1.003 Lambda,-0.020 mA
3C,B1S1 Cat. Temp.,385.7 °C
42,Control module voltage,13.120 V,13.166 V
43,Absolute Load Value,22 %,22 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,3 %
46,Ambient Air Temp,10 °C
47,Absolute Throttle Position B,13 %
49,Accelerator Pedal Position D,15 %,15 %
4A,Accelerator Pedal Position E,15 %
4C,Commanded Throttle Actuator Control,3 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,0.0 %
62,Torque actual,9 %
63,Torque Reference,280 Nm
65,Auxiliary Input/Output,
67,Engine Coolant Temp,ECT 1:60 °C,ECT 2:11 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:9870/--- kPa,FRTemp:---/--- °C
70,Boost Press Ctrl A/B,BP_A act:97 kPa
75,Turbo A Temp.,Compr. in/out---/20 °C,Compr. in/out---/--- °C
77,Charge Air Temp.,B1S1:16 °C, °C
Type 02 - VIN : 3VWC57BU8KM054019 (Address E8)
Type 04 - Calibration ID : 04E024L 5595DXAA (Address E8)
Type 04 - Calibration ID : 09S927158R_ 3552 (Address E9)
Type 06 - Calibration Verification Number : 760750BA (Address E8)
Type 06 - Calibration Verification Number : 2EC29191 (Address E9)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 1424
Ignition cycle count : 3862
Catalyst monitor bank 1 : 2218 / 1424
Catalyst monitor bank 2 : 0 / 0
O2 Sensor monitor bank 1 : 1786 / 1424
O2 Sensor monitor bank 2 : 0 / 0
EGR-VVT monitor : 3000 / 1424
AIR monitor : 1044 / 537
EVAP monitor : 319 / 279
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
