Audi A7 mechatronic dsg7 truble
DidrixX
Norway
C?ID=307571
Hi.
Thanks for adding me. Im new to this forum, and hope somone can help me. I have a audi A7 2012 mod. 3.0tdi. I got problems with my gear box. In the instrument panel it showed gearbox malfunction. The contact on gearbox was damage. And 1 pin was loos on mechatronic. So i ordered a new from audi. I put it in the gearbox. No problem. But now the car wount start. It show in the panel N. Even if i put it in revers. Drive. Park and so on. What can i do? Have i missplaced the gear forks? I get trublecode P179E selector level sensor. Please help me. Do i hafto send the car to a aude dealership and program it?
DidrixX
Norway
C?ID=307571
Thursday,31,December,2020,18:04:38:20735
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUZZZ4G8CN029789   License Plate: BT44114
Mileage: 201422km-125157mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 34 36 3B 42 44 46
          47 52 53 55 56 5F 62 69 6D 72 82 85 8B 8E 8F 90
VIN: WAUZZZ4G8CN029789   Mileage: 201422km-125157miles
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  X37 0004
   Revision: 53X37---
   Coding: 1A254012057601020000
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 26002E9559B7F2B649-8072
2937 - Please Check Fault Codes in Transmission Control Module
          U1026 00 [036] - -
          [Transmission control moduleplease read DTC]
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 00:18:46
                    Engine speed: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 12.160 V
                    Accelerator pedal: sensor voltage 1: 757.4 mV
                    Accelerator pedal: sensor voltage 2: 381.0 mV
                    Accelerator pedal: switch positions-Bits 0-7: 72
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 161
                    Limitation: torque: 0.0 Nm
                    Control Module temperature: 32.4 °C
8172 - Selector Lever
          P0919 00 [039] - Malfunction
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 00:02:22
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.980 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 0
                    Active brake system error status-Bits 0-7: 17
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
Readiness: 0 0 0 0 X
   Part No SW: 4G2 927 156 M    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H08 0004
   Revision: --H08---    Serial number: 0000000019
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501021 001026
   ROD: EV_TCMDL501021.rod
   VCID: 383CF0ED83037446EB-806C
10618 - Valve for Transmission Fluid Cooler
          P2755 00 [039] - Short to Plus
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 00:02:23
                    Engine speed: 0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -68 Nm
                    Transmission fluid temperature: 24 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 11.800 V
                    Transmission oil cooler valve: closed
8938 - Base Measurements
          P17CA 00 [167] - Implausible Data
                    Mileage: 201422 km
                    Transmission output speed: 2000 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 0 °C
17594 - Selector Lever Sensor
          P179E 00 [167] - Electrical Malfunction
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 00:02:22
                    W020_BereichsGrenze_Pmax-Data: 89.55 %
                    W021_BereichsGrenze_Pmin-Data: 74.10 %
                    W022_BereichsGrenze_Rmax-Data: 65.15 %
                    W023_BereichsGrenze_Rmin-Data: 55.95 %
                    W024_BereichsGrenze_Nmax-Data: 52.15 %
                    W025_BereichsGrenze_Nmin-Data: 46.05 %
                    W026_BereichsGrenze_Dmax-Data: 41.65 %
                    W027_BereichsGrenze_Dmin-Data: 35.45 %
                    W028_BereichsGrenze_Smax-Data: 31.50 %
                    W029_BereichsGrenze_Smin-Data: 25.40 %
   Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
   Component: ESP PREMIUM   H09 0250
   Coding: 27A6C703E465E3C0EB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 3522F9D99411892EF0-8060
0058 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_Getriebe_01_Timeout]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:44
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BB
                    Uz: A5
0060 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_Getriebe_03_Timeout]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:44
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 20
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BE
                    Uz: A4
0061 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_Getriebe_04_Timeout]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:44
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C8
                    Uz: A4
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Ldm_ApbFailureState]
                    Fault Frequency: 17
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 01
                    Uz: A9
0712 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [SCL_GE_Waehlhebel_Error]
                    Fault Frequency: 25
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C1
                    Uz: A9
   Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
   Component: BCM2 2.0      H31 0330
   Coding: 058A2F00000000000000
   VCID: 78BC30EDCB83B4462B-802C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 9
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:44
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 16071100040752
   Coding: 360300B83C
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 271E23915EBDEBBE72-8072
0276 - Engine Off Timer Performance
          P150A 00 [009] - -
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
                    Voltage terminal 30: 13.13 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001124454
   Coding: 0D07A01009769FE28981008380001800CF9CE3082E090101000308452F01
   VCID: 6E9016B5B9C7FAF6F1-803A
   Component: WWS57X 110615  H35 0051
   Serial number:         110627124153
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11545881
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
   Component: E1 - LDS  H07 0044
   Serial number: 12 07 2011  00000313
   Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0001
   Serial number: 00000000001106283104
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0001
   Serial number: 00000000001106150578
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 853847B5000000000001
   Subsystem 7 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Serial number: 00000000001506103315
   Subsystem 8 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
   Serial number: 00000000001711032706
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:00
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901118601079
   Coding: 090B04
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3B36EFE1B2355F5E06-806E
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H21 0160
   Coding: 3D04010201
   Shop #: WSC 53977 003 1048576
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X_001.rod
   VCID: 679E63919E3D2BBEB2-8032
7 Faults Found:
29696 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_GETRIEBE_01]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:45
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 12.683 V
                    Velocity_vehicle_reference: -0.00 m/s
29952 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_GETRIEBE_03]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:45
30208 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_GETRIEBE_04]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:45
                    Voltage terminal 15: 13.083 V
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_EPB_FAIL]
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 13.128 V
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
82688 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_TSK_FAIL]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 05:53:18
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 12.493 V
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 17
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 20:24:45
                    Control Module temperature: 15 °C
                    Voltage terminal 15: 13.084 V
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG0039VUP
   Coding: 30314530323130303034554A304C34473853
   VCID: 3620FED589178236F9-8062
   Serial number: 3575HRB40530JR9Q5HP0
   Serial number: 3585HRB40570JR9Q98I-
   Serial number: 3515JRB404P0HM7EA8T$
   Serial number: 3525JRB40670J7IAEH68
   Serial number: 3554VRB405L0M38E9GN$
   Serial number: 3564VRB405L0M38E81HI
   Revision: --------    Serial number: 90372KG1000FV
   Coding: 00001C
   VCID: 373EF3D1861D7B3EE2-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
   Serial number: 06 05 2011  11131868
   Part No SW: 4G8 920 931 J    HW: 4G8 920 931 J
   Component: TDieRdwAcc    H71 0375
   Revision: 26181114    Serial number: 658190711592010
   Coding: 138F01021F070008000100
   Shop #: WSC 21163 002 1048576
   ASAM Dataset: EV_RBD4K 004040
   VCID: 3522F9D99411892EF0-FFFE
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000199375
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3228C2C5657F9E16D5-8066
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650865017
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 11188000473021200410
4226 - No Communication with Transmission Control Module
          U0101 00 [008] - -
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 20:32:08
                    Voltage terminal 30: 13.4 V
                    Voltage terminal 15: 0.0 V
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 04018E64747464545425363E
   VCID: 3326C7C19265971EDE-8066
   Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
   Component: KLIMA FOND    H07 0056
   Serial number: 15071100040532
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 302CC8CD6B73AC06A3-8064
   Part No SW: 4G0 907 553 C    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0779
   Coding: 008003
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2B16DFA14255CFDE96-807E
455684 - Sensor for Ride-Height
          C1048 07 [009] - Mechanical Failure
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:26:48
455690 - Sensor for Ride-Height
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 05:57:39
          C10C8 00 [009] - -
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 05:56:07
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006328899
   Shop #: WSC 02311 785 00200
   VCID: 77BE33D1C69DBB3E22-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4201ELNG0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D12D1B97C41C1EE88-8078
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F56225E00628002080403
   VCID: 41CA9D09D8D9358E5C-8014
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0013116626
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0154357725
   Coding: 01000E2020B9B48583200A042E0100000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO1265977B
   Coding: 001F00
   Subsystem 2 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0027
   Serial number: WA102729000000350540
                    Fault Frequency: 8
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:44
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 20:32:08
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000012397
   Coding: 030000
   VCID: 1C740C7D1FFB3866EF-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F56225E00628002080402
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000106601
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A18DAA54DAFD6D66D-807E
329728 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_GETRIEBE_03_MESSAGE_TIMEOUT]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:35:26
                    Voltage terminal 30: 13.2 V
                    Internal Fault ID: 94
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
329984 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_GETRIEBE_04_MESSAGE_TIMEOUT]
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:35:26
                    Internal Fault ID: 95
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
461056 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_GE_WAEHLHEBEL_ERROR_VALUE]
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
                    Internal Fault ID: 145
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 110718-0004-027
   Coding: 11236F601002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C14DCBD475BC8E69F-8078
   Part No SW: 4G1 035 053 C    HW: 4G1 035 053
   Component: Radio U Basic H41 0079
   Revision: AB001007    Serial number: 049G%0BB009465
   Coding: 010003010000000001
   VCID: 1F0E3B710EED237E0A-804A
02981 - Connection between Radio and Impedance Converter 1
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:49
                    Voltage: 13.20 V
   Part No SW: 4G0 035 670 C    HW: 4G0 035 670
   Component: H-BNT-EU      H47 0406
   Revision: --------    Serial number: 428G30B7518765
   Coding: 090100040003FDEF6530AB3E00000003080001000000000000
   VCID: 230637812285079E2E-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB13018ETQ
   Subsystem 3 - Part No SW: 4G1 919 610 A    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KGD000KN
   Component: CD-Database  3371
03389 - Data Set Implausible
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:42
                    Voltage: 13.10 V
                    Bin. Bits:      010
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:35:23
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
01524 - Antenna for Telephone
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:52
                    Voltage: 13.10 V
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14224000628002080002
   VCID: 44C4941DC7CB20A677-8010
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000151551073
   Coding: 0109080000000000
   VCID: 71AA0DC9A8F9E50EEC-8024
   Part No SW: 4G8 959 107 L    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0039
   Revision: 11013001    Serial number: 185100093
   Coding: 0A3305C003
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 3E30E6F5A1274A7621-806A
   Component: TSG HR        H04 0212
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4G8 919 604 D    HW: 4G8 919 604 D
   Component: HeadUpDisplay 007 0103
   Coding: CB0000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
   VCID: 3424C4DD9F6B9026C7-8060
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: EA040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65826999643139AE80-8030
0708 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [EGD_Fahrwerk_01_Signal_Error]
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 20:24:44
                    Outside air temperature: -40.5 °C
                    Voltage terminal 15: 12.9 V
                    Control Module temperature: 19.0 °C
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3D04010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X_001.rod
          U1111 00 [008] - -
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:45
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 12.708 V
          U1111 00 [008] - -
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:45
          U1111 00 [008] - -
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 21:46:45
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 13.245 V
          U1113 00 [009] - -
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 13.177 V
          U1113 00 [009] - -
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 02:07:41
          U1113 00 [008] - -
                    Reset counter: 79
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 05:53:18
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 12.467 V
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H29 0034
   Serial number: 000040180607117
   Coding: 0380AB1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2502299924B1F9AE40-8070
0091 - Function Limitation due to Missing Video Data
          C1108 00 [009] - -
          [DPC_SystemError]
                    Fault Frequency: 8
                    Reset counter: 39
                    Mileage: 201422 km
                    Date: 2020.12.30
                    Time: 23:04:24
                    Outside air temperature: 20.0 °C
                    Voltage terminal 15: 13.3 V
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00660600031F037E000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 6FAE0BB1B6CDF3FEFA-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 70AC08CDABF3EC06E3-8024
End----------(Elapsed Time: 02:51, VBatt start/end: 13.2V/13.2V)-----------
DidrixX
Norway
C?ID=307571
Srry i didnt post it with the first post. Hope it was right 😊
DidrixX
Norway
C?ID=307571
Now i have tryed every thing. None is working.
When i installed the new mechatronic i measured 32mm on the solinoids cause the number on the mechatronic is M09Q1047 its like the Da Vinci Code.
The car is i park cause i cant roll it. but the instrument panel show its in neutral. And i cant start the car. I have no ide what to do.
:confused: I dont think the sensor is damage. Cause it was working perfect before i started the job. (srry my english)
DidrixX
Norway
C?ID=307571
Here is a old Full Scan from 24 April
Friday,24,April,2020,17:36:10:20735
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G8CN029789   Mileage: 186956km-116169miles
3B-Sensor Elect. -- Status: Malfunction 0010
82-Heads Up Display -- Status: Malfunction 0010
   Revision: 53X37---
   VCID: 26002E9559B7F27FFF-8072
14579 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [039] - Electrical Fault
                    Mileage: 186956 km
                    Date: 2020.04.24
                    Time: 17:39:35
                    Engine speed: 819.50 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 24 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 14.500 V
                    Glow-control unit: activation voltage: 14580 mV
                    Glow_period_control_unit_ground_offset_voltage: -260 mV
                    Glow-control unit: calculated glow voltage: 5400 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 230.5 V²s
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 0
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 18
                    Glow status-Bits 0-7: 0
                    Co EOM st Op Mode Short-Bits 0-7: 0
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000000044
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2C14DCBD475BC82F29-8078
                    Mileage: 186956 km
                    Date: 2020.04.24
                    Time: 17:39:36
                    Engine speed: 823 /min
                    Transmission input speed: 823 /min
                    Engine torque: -40 Nm
                    Transmission fluid temperature: 17 °C
   VCID: 3522F9D9941189E746-8060
7 Faults Found:
0766 - Supply Voltage for ABS Valves
          C106A 16 [008] - Voltage Too Low
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:19:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 37
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 43
                    Uz: 4D
0142 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [HydraulicSupplyUndervoltage]
                    Reset counter: 30
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 37
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 67
                    Uz: 52
          U1113 00 [008] - -
                    Fault Frequency: 9
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 01:54:02
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 24
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 01
                    Uz: 72
0560 - Supply voltage
          [NET_Undervoltage]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:19:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 48
                    Uz: 4E
0461 - Supply voltage
          [PowerSupplyPermanentLow]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:28:03
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 24
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 45
                    Uz: 6C
0194 - Return Flow Pump
          C1018 16 [008] - Voltage Too Low
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:19:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 32
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 7B
                    Uz: 4E
0280 - ASR and ESP Switch
          C10A4 16 [008] - Voltage Too Low
          [VacSupplyUndervolt]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:19:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 33
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 5A
                    Uz: 4E
   VCID: 78BC30EDCB83B48F9D-802C
   Coding: 360300B83C
   VCID: 271E23915EBDEB77C4-8072
0378 - Coolant Circulation Pump
          B10D0 04 [008] - Internal System Fault
                    Fault Frequency: 12
                    Reset counter: 36
                    Mileage: 186884 km
                    Date: 2020.04.23
                    Time: 07:42:10
                    Voltage terminal 30: 14.34 V
                    Outside air temperature: 4.5 °C
                    Interior temperature: 11.01 °C
   VCID: 6E9016B5B9C7FA3F47-803A
   Coding: 0045F7
   Coding: 02562B
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:21:00
   Coding: 090B04
   VCID: 3B36EFE1B2355F97B0-806E
   Coding: 3D04010201
   VCID: 679E63919E3D2B7704-8032
10240 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_BLR_BLK8_31]
                    Fault Frequency: 29
                    Reset counter: 36
                    Mileage: 181088 km
                    Date: 2020.01.15
                    Time: 10:08:06
                    Control Module temperature: 0 °C
                    Voltage terminal 15: 14.682 V
                    Velocity_vehicle_reference: 17.15 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.38 m/s²
          U1113 00 [008] - -
                    Reset counter: 36
                    Mileage: 185129 km
                    Date: 2020.03.07
                    Time: 18:11:54
                    Control Module temperature: 2 °C
                    Voltage terminal 15: 13.122 V
                    Velocity_vehicle_reference: -0.88 m/s
                    Longitudinal_acceleration_vehicle_reference: -2.93 m/s²
106240 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_EPB_TENSION_FAIL]
                    Reset counter: 36
                    Mileage: 185129 km
                    Date: 2020.03.07
                    Time: 18:11:54
          U1113 00 [008] - -
                    Reset counter: 36
                    Mileage: 185129 km
                    Date: 2020.03.07
                    Time: 18:11:54
                    Voltage terminal 15: 13.141 V
                    Velocity_vehicle_reference: -0.98 m/s
                    Longitudinal_acceleration_vehicle_reference: -1.82 m/s²
          U1113 00 [008] - -
                    Reset counter: 36
                    Mileage: 182847 km
                    Date: 2020.02.03
                    Time: 16:30:43
                    Voltage terminal 15: 11.864 V
   VCID: 3620FED5891782FF4F-8062
   Coding: 00001C
   VCID: 373EF3D1861D7BF754-8062
                    Reset counter: 29
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:59:06
                    Reset counter: 29
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:00:22
   ROD: EV_RBD4K_AU57.rod
13635840 - Supply voltage
          [Supply voltage too low]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:19:41
   Coding: 00CD077D00
   VCID: 3228C2C5657F9EDF63-8066
   Voltage stabilizer:
          U0101 00 [008] - -
                    Reset counter: 28
                    Mileage: 186576 km
                    Date: 2020.04.07
                    Time: 13:31:36
                    Voltage terminal 30: 11.8 V
                    Control Module temperature: 11 °C
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 23
                    Mileage: 186032 km
                    Date: 2020.03.19
                    Time: 14:13:17
                    Voltage terminal 30: 11.7 V
                    Control Module temperature: 23 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0017 - Supply voltage
          [Versorgungsspannung unterer Grenzwert unterschritten]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:10:06
                    Voltage terminal 30: 8.3 V
                    Control Module temperature: 21 °C
                    System status: A-/F-CAN / FlexRay_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.17
                    Time: 21:52:24
                    Voltage terminal 30: 11.2 V
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Revision: AA001002
   VCID: 3326C7C1926597D768-8066
   Coding: 00
   VCID: 302CC8CD6B73ACCF15-8064
0025 - Motor for Rear Left Upper Body Vent
          B10D3 22 [008] - Signal Amplitude Too High
                    Reset counter: 31
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 05:40:10
                    Voltage terminal 30: 13.32 V
                    Outside air temperature: 4.0 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 11701
                    Left Rear Upper Body Vent Motor-Specified value: 11701
                    Left Rear Upper Body Vent Motor-Stop open: 11400
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 26
                    Mileage: 186410 km
                    Date: 2020.04.02
                    Time: 07:53:19
                    Outside air temperature: -1.5 °C
                    Left rear vent temperature: 8.4 °C
   Coding: 008003
   VCID: 2B16DFA14255CF1720-807E
136194 - Supply voltage
          [VersorgungsspannungSpannung zu niedrig]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 02:23:03
          C10C8 00 [008] - -
                    Reset counter: 32
                    Mileage: 186817 km
                    Date: 2020.04.21
                    Time: 07:59:22
   VCID: 77BE33D1C69DBBF794-8022
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:23:20
   VCID: 2D12D1B97C41C1273E-8078
1048835 - Supply voltage
          U1011 00 [040] - Voltage too Low
          [ECU temporarily disturbed: Undervoltage T30]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:17:03
                    DCU Temperature: 26 °C
                    Voltage Clamp 15: 0.0 V
                    Voltage Clamp 30: 8.4 V
                    Ignition Cycle Count: 49181
                    Voltage UBDZ: 8.4 V
                    Voltage VDD1: 1.5 V
                    Voltage VDD3: 3.3 V
                    Voltage VDD3_STUCK: 1.9 V
                    Voltage VDD5: 5.0 V
                    Voltage VBG2: 2.5 V
                    Voltage GNDA: 0.0 V
   VCID: 41CA9D09D8D93547EA-8014
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:49:43
   Coding: 001F00
03700 - Control Module for Rear Spoiler Positioning
                    Reset counter: 29
                    Mileage: 186607 km
                    Date: 2020.04.17
                    Time: 23:14:49
                    Reset counter: 29
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:35:01
   Coding: 030000
   VCID: 1C740C7D1FFB38AF59-8048
                    Reset counter: 30
                    Voltage: 6.10 V
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:48:00
   VCID: 2A18DAA54DAFD61FDB-807E
10554390 - Supply voltage
          [FC_LOW_V_BATT]
                    Reset counter: 245
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 01:53:01
                    Voltage terminal 30: 9.0 V
                    Internal Fault ID: 40
                    Network management state: Ready for busstat
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: No enabling
   VCID: 1F0E3B710EED23B7BC-804A
                    Reset counter: 243
                    Mileage: 186576 km
                    Date: 2020.04.17
                    Time: 10:47:46
                    Voltage: 11.70 V
   Coding: 090100040003FDED6530AB3E00000003080001000000000000
   VCID: 230637812285075798-8076
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 23
                    Mileage: 186347 km
                    Date: 2020.03.31
                    Time: 11:11:26
                    Voltage: 11.90 V
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:38:14
                    Voltage: 7.60 V
03367 - Supply Voltage for Display Module
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:38:02
                    Voltage: 7.60 V
                    Fault Status: 00101011
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:41:16
                    Voltage: 9.00 V
   VCID: 44C4941DC7CB206FC1-8010
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:51:34
   VCID: 71AA0DC9A8F9E5C75A-8024
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:20:49
   Coding: 0A3305C003
   VCID: 3E30E6F5A1274ABF97-806A
0014 - Supply voltage
          [Versorgungsspannung dauerhaft zu niedrig]
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:10:42
                    Voltage terminal 30: 8.66 V
0011 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 04:34:13
                    Voltage terminal 30: 6.71 V
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:51:23
   Coding: CB0000
   VCID: 3424C4DD9F6B90EF71-8060
                    Reset counter: 30
                    Mileage: 186607 km
                    Date: 2020.04.18
                    Time: 03:25:57
          U1400 00 [008] - -
                    Reset counter: 30
   Coding: EA040000
   VCID: 658269996431396736-8030
   Coding: 3D04010201
          U1113 00 [008] - -
                    Reset counter: 36
                    Mileage: 185129 km
                    Date: 2020.03.07
                    Time: 18:11:54
                    Control Module temperature: 6 °C
                    Voltage terminal 15: 13.182 V
                    Velocity_vehicle_reference: -0.77 m/s
                    Longitudinal_acceleration_vehicle_reference: -3.33 m/s²
          U1113 00 [008] - -
                    Reset counter: 36
                    Mileage: 185129 km
                    Date: 2020.03.07
                    Time: 18:11:54
                    Voltage terminal 15: 13.185 V
                    Velocity_vehicle_reference: -0.97 m/s
                    Longitudinal_acceleration_vehicle_reference: -2.53 m/s²
          U1113 00 [008] - -
                    Reset counter: 36
                    Mileage: 185129 km
                    Date: 2020.03.07
                    Time: 18:11:54
                    Voltage terminal 15: 13.171 V
                    Velocity_vehicle_reference: -1.07 m/s
                    Longitudinal_acceleration_vehicle_reference: -1.66 m/s²
   ROD: EV_BC7.rod
   VCID: 2502299924B1F967F6-8070
   ROD: EV_RGS_L.rod
   VCID: 6FAE0BB1B6CDF3374C-803A
   ROD: EV_RGS_R.rod
   VCID: 70AC08CDABF3ECCF55-8024
End----------(Elapsed Time: 02:41, VBatt start/end: 14.8V/14.8V)-----------
