HEX-NET IS FREEZING 15 SECOND. BUT, ONLY AT THIS PAGE. I CAN'T UNDERSTANT.
I'M USING THE ACCESS POINT MODE.
My problem isn't that. Thank you...Did you select the desired operation from the drop-down menu?
Thank you so much. But, my problem isn't that. VCDS is freezing...You need a keyboard fix, CAPS LOCK is stuck (on forums this is called SHOUTING!)
The screens gives you the latest Service information... if you don't want to reset it click Done, Go Back or choose one of the options available and click Perform SRI...
I'm so sorry for laughing emoji. I can't exit the SRI Reset Window. New screenshot is here;Based on the screenshot, this cannot be seen. No “hourglass” or anything to indicate program freezing?
I also don't see what's funny in my post (#2).
New screenshot is here; (I'm using the Access Point Mode.) I can't exit the SRI Reset Window.You say it freezes. What were you expecting it to do at the point where you made the screen shot?
My PC is Windows 10. And, New.many of my friend complain that HEX v2 is much slower with older car, not like old HEX CAN , my Hext Net many time "connection to cloud" ...always when i need them urgent
try other Windows , maybe RAM memory is not much ?
There is not a problem on the wired connection. Problem is on the wireless acces point mode.not all clusters use this same chanells for Service reset, and this function not read them first, only do function run , even if not available
try via USB first
make sure yo ucan do that manually ,
then try utomatic function reset
What WiFi chipset does your PC use?There is not a problem on the wired connection. Problem is on the wireless acces point mode.
Broadcom 802.11n Wireless SDIO AdapterWhat WiFi chipset does your PC use?
Maybe. I try it. Thank you so much for your support. Have a nice day.Have you tried a different PC, or tried a different WiFi adapter? Cheapo USB WiFi adapters are available for under $10...
I tried on new laptop computer. But, the problem continues. I think, this problem is general problem of VCDS. Please check it. You can fix the problem with a new VCDS Update.Have you tried a different PC, or tried a different WiFi adapter? Cheapo USB WiFi adapters are available for under $10...
