ABS controller compatibility
jacquinot
Madagascar
C?ID=377549
hi, it looks like I am having a problem with my ABS module. The guy at the repair shop told me it has to be changed. As I am not planning to buy new, the potential ABS module replacement I found has part number 1K0 907 379 BJ for the controller, 1K0 614 517 CB for the pump.
What is currently installed on the car has part number 1K0 907 379 AE for the controller and 1K0 614 517 BE for the pump.
My question is: will the replacement part mentioned above work as long as the coding for the control module is copied properly?
Thank you.
Monday,28,December,2020,15:45:02:49789
VCDS Version: 20.12.0.0 (x64)  HEX-NET CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WVWZZZ1KZ9W150029   License Plate: AP
Mileage: 197910km-122975mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ9W150029   Mileage: 197910km-122975miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 PR    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000AG  2116
   Revision: --H09---    Serial number: VWXBZ0H0823967
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 7EB0EE3E2935087471-802A
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Frequency: 54
                    Mileage: 197860 km
                    Time: 16:44:45
                    RPM: 1029 /min
                    Speed: 8.0 km/h
                    Load: 19.2 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101000
                    Torque: 129.3 Nm
                    Bin. Bits: 00000000
Readiness: 1 1 0 0 1
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1976
   Revision: 04844002    Serial number: 00000810111462
   VCID: 51EA6582C82B470CDC-8004
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D092700FA880B02E690220042B100
   Shop #: WSC 80093 222 69422
   VCID: 75A2F112DC034B2C20-8020
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 233
                    Mileage: 197910 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 143
                    Count: 49408
                    Count: 255
                    Reset counter: 233
                    Mileage: 197910 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 8213
                    Count: 49408
                    Count: 255
   Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
   VCID: 76A0F61E0105403429-8022
   Revision: 00H54000    Serial number: 00000009004161
   Coding: E5890F2700041500471400001400000000097F075C000100000000000000
   VCID: 33260F0A52F7151CCE-8066
   Component: Wischer 211008 021  0501
   Coding: 00038805
   Shop #: WSC 01357
   Component: RLS     161008 054  0402
   Coding: 00209069
   Shop #: WSC 01357
   Component: 3B AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD28ZNXL
   Coding: 0013122
   VCID: 3D32293264B3D36C28-8068
   Subsystem 1 - Serial number: 6332MSME42526F08D
   Subsystem 2 - Serial number: 6342MSME43030219.
   Subsystem 3 - Serial number: 6352QSME7C0E4516Q
   Subsystem 4 - Serial number: 6362QSME6F0D352CY
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           757 0101
   Coding: 0010042
   VCID: 77BEFB1A060F393C32-8022
   Part No SW: 1K0 920 864 B    HW: 1K0 920 864 B
   Component: KOMBIINSTRUMENT VN4 4005
   Revision: V0010000    Serial number: VWXBZ0H0823967
   Coding: 0003103
   Shop #: WSC 24829 001 1048576
   VCID: 2B16176A8AC74DDC86-807E
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K08A1101C4
   Coding: ED807F060002020002
   VCID: 352231125C830B2CE0-8060
                    Reset counter: 233
                    Mileage: 197910 km
                    Time: 15:31:47
01304 - Radio
                    Reset counter: 233
                    Mileage: 197910 km
                    Time: 15:31:52
   Component: IMMO VN4            4005
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1219
   Coding: 0000182
   VCID: 393A3D22709BEF4C04-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 00000 028 00001
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 989002005103087F2D0484056008CF03E0FCA0
   Shop #: WSC 13204 875 77680
   VCID: 71AAC502686B670CFC-8024
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000438
   VCID: 3A38222E759DE4540D-806E
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 383C38264B91F644FB-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End----------(Elapsed Time: 01:05, VBatt start/end: 13.9V/13.8V)-----------
Gone But Not Forgotten
Thank you.
YES IN ADDITION TO NO FAULTS BEING PRESENT MECHANICALLY AND ADAPTION COMPLETED.
BE SURE TO FIX THE "J500" BY VERIFYING IF SUPPORTED IN WD BY RTFB OR IF CODING IS CORRECT YET?
PART NUMBERFODDESCRIPTIONREMARK
1K0 907 375 APPASS!Control unit for ABS
1K0 614 517 BE
1K0 907 379 AE
1K0 907 375 AE
1K0 614 517 BK
1K0 907 379 AP
Coding: 0000078
Revision: 00H35001
jacquinot
Madagascar
C?ID=377549
According to the previous owner, the ABS control unit has been replaced due to the same issue. The basic adaptation hasn't been completed I could never get passed the "Imp. VL [116/129] >000< Press Pedal 005 "
At the same time I had the " 01117 - Generator Terminal DF Load Signal " error which I ignored for a looooong time.
A Battery/Alternator or Freewheel clutch pulley is in your very near future, huh?
Turns out a cleaning of the ground connections fixed the error. Could that be the culprit that caused the damage to the ABS unit... again? Should I investigate further on WD, other areas?
Did you consider a ground overlay to enhance since clearly original is inadequate?
jacquinot
Madagascar
C?ID=377549
Thank you.
   Coding: 0000078
                    Fault Frequency: 54
                    Mileage: 197860 km
                    Time: 16:44:45
                    RPM: 1029 /min
                    Speed: 8.0 km/h
                    Load: 19.2 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101000
                    Torque: 129.3 Nm
                    Bin. Bits: 00000000
   Revision: 00H35001
                    Reset counter: 233
                    Mileage: 197910 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 143
                    Count: 49408
                    Count: 255
                    Reset counter: 233
                    Mileage: 197910 km
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 8213
                    Count: 49408
                    Count: 255
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 00209069
   Shop #: WSC 01357
   Coding: 0013122
   Coding: 0010042
   Coding: 0003103
                    Reset counter: 233
                    Mileage: 197910 km
                    Time: 15:31:47
01304 - Radio
                    Reset counter: 233
                    Mileage: 197910 km
                    Time: 15:31:52
   Coding: 0000182
   Coding: 0000438
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
Greetings,
I got myself a used ABS module, installed it, copied the coding from the old unit, still could not get get passed the "Imp. VL [116/129] >000< Press Pedal 005" for the hydraulic unit intake valve even though I respected the prerequisites for the adaptation.
Is there anyone who could confirm whether the coding for the ABS module is even correct? I bought the car used with the ABS faults
Here's an autoscan with the new module
Friday,11,June,2021,05:56:39:49789
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
Mileage: 198130km-123112mi   Repair Order:
VIN: WVWZZZ1KZ9W150029   Mileage: 198130km-123112miles
   Coding: 0000078
   VCID: 7EB0EE3E2935087BB1-802A
   VCID: 51EA6582C82B47031C-8004
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Shop #: WSC 51103 001 104857
   VCID: 004C90C693C17E8BC3-8054
                    Reset counter: 124
                    Mileage: 198131 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 143
                    Count: 51456
   VCID: 76A0F61E0105403BE9-8022
   VCID: 33260F0A52F715130E-8066
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 00209069
   Shop #: WSC 01357
   Coding: 0013122
   VCID: 3D32293264B3D363E8-8068
   Coding: 0010042
   VCID: 77BEFB1A060F3933F2-8022
   Coding: 0003103
   VCID: 2B16176A8AC74DD346-807E
   VCID: 352231125C830B2320-8060
                    Reset counter: 124
                    Mileage: 198131 km
                    Time: 05:42:06
01304 - Radio
                    Reset counter: 124
                    Mileage: 198131 km
                    Time: 05:42:11
   Coding: 0000182
   VCID: 393A3D22709BEF43C4-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   VCID: 71AAC502686B67033C-8024
   Coding: 0000438
   VCID: 3A38222E759DE45BCD-806E
Address 56: Radio
   Coding: 0000144
   VCID: 383C38264B91F64B3B-806C
   Coding: 0000144
End----------(Elapsed Time: 01:07, VBatt start/end: 14.1V/14.0V)-----------
