Hello Guys,
I just converted a Passat B8 2016 from RHD to LHD and i have some issues with ABS.
Looking over the error i see that there is mismatch coding between ABS and steering rack.
The only difference it's that i replace the steering rack with a new one from a LHD car.
Can you help me with some information what to code? do you think it's from steering rack coding (i added the options that i see on the car on the current steering rack).
Tuesday,29,December,2020,17:42:49:32554
VCDS Version: 20.12.0.1 (x64) HEX-NET CB: 0.4529.4
Workshop Code: 022 21992 002029
VIN: WVWZZZ3CZHE033786 License Plate:
Mileage: 190906km-118623mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZHE033786 Mileage: 190906km-118623miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2.0l TDI H23 1990
Revision: B5H23---
Coding: 011D001203651D083000
Shop #: WSC 05311 115 00307
ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
ROD: EV_ECM20TDI01104L906026ET_002_VW48.rod
VCID: 004C75E69B7C298402-8054
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 190906 km
Date: 2020.12.02
Time: 00:19:28
Engine RPM: 0.00 /min
Coolant temperature: 56 °C
Intake air temperature: 26 °C
Voltage terminal 30: 12.960 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s²
10065 - Mass Air Flow Sensor (G70)
P0104 00 [036] - Intermittent
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:54
Engine RPM: 740.50 /min
Normed load value: 24.7 %
Coolant temperature: 50 °C
Intake air temperature: 22 °C
Voltage terminal 30: 13.400 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9999
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 29.13 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.07 %
Charge air pressure: specified value: 977 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1019.4 hPa
Mean injection quantity: 5.95 mg/stroke
U0428 00 [039] - -
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:54
Cruise Control System (CCS): status-Bits 0-7: 7
Part No SW: 0D9 300 041 H HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4905
Revision: 06354004 Serial number: TFK01606251134
Shop #: WSC 05311 115 00074
ROD: EV_TCMDQ250021.rod
VCID: 1D722C920CCEE46C09-8048
P1734 00 [002] - -
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 61766000000025
Coding: 0FEC928F34230B6F477E060841C949F0492CD0E2608292711862F078C20202
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_035.rod
VCID: 7BB6020AF29A4A5C57-802E
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 129
Date: 2020.12.02
Time: 00:49:57
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
[FCAN: Mismatch between bytecoding and Lenkerposition signal]
Reset counter: 129
Date: 2020.12.02
Time: 00:49:57
16412 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:50:06
16413 - Display for Tire Pressure Monitoring
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:50:06
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0408455254
Coding: 002F0F0F0F
ASAM Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB.rod
VCID: 3B36C20AB21A8A5C17-806E
Part No SW: 5G0 907 044 AG HW: 5G0 907 044 AG
Component: Climatronic H03 1001
Revision: 00001K10
Coding: 12020104202100012015500000101802
Shop #: WSC 00015 115 00001
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6C94315687F4DDE4CE-8038
197634 - Temperature Sensor for Rear Vent
B1089 15 [009] - Open or Short to Plus
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
Voltage terminal 30: 13.3 V
Outside temperature: 10.0 °C
459015 - Databus
[Feuchtesensor innen - kein Signal/Kommunikation]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
263426 - Air Quality Sensor
B10AF 31 [009] - No Signal
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
System run time-Engine running time: 79 s
System run time-Terminal 15 on: 80 s
1048839 - Function limitation due to crash signal
B1397 00 [009] - -
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
655618 - Control/Display Unit for Rear Climatronic
B10AA 31 [009] - No Signal
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 BF HW: 5Q0 937 086 BF
Component: BCM PQ37BOSCH 032 0222
Revision: -------- Serial number: 865817061600MT
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017.rod
VCID: 7F4EF61AE682567C7B-802A
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141121 042 0607
Serial number: 141128181740
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S7Y16M07D14H16M47S36
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 05 11 2014 00000662
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY161512JSE
Serial number: 00000000000035819008
197132 - Lock Module for Central Locking; Rear Left
B12DB 01 [009] - Electrical Failure
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:19:27
197388 - Lock Module for Central Locking; Rear Right
B12DC 01 [009] - Electrical Failure
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:19:27
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391617407270
Coding: 0071051811
VCID: 44C4B9F6CFE4F5A466-8010
13637426 - Databus
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 3200678251FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3424E9369F444524D6-8060
2055 - Databus
[FAULT_ALP_STEERINGWHEEL_INIT]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:31:21
Control Module temperature: 34 °C
Voltage terminal 15: 11.8 V
0795 - Databus
[FAULT_APS_RELEVANT_ERROR]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:31:21
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:31:21
0928 - Databus
[FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:31:21
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:31:21
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSPCULR24
Coding: 98FCC0C0000000005C5400CC008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EB00B1EE1885F7470-802A
Left seat belt tensioner:
Serial number: 3G2857705E0187Q01716
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G2857706E0005R00067
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 306 16
Serial number: 3576U000000D795C8B1V
Subsystem 4 - Part No SW: ----------- HW: 454 001 106 16
Serial number: 3586U000000CF95C8B1$
Subsystem 5 - Part No SW: ----------- HW: 454 801 606 16
Serial number: 3516R3DEFB00B000000N
Subsystem 6 - Part No SW: ----------- HW: 454 801 306 16
Serial number: 3526R5F04BA0B000000D
Subsystem 7 - Part No SW: ----------- HW: 454 801 806 16
Serial number: 3556VB5C8A90A000000T
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
Part No SW: 3Q0 953 521 DJ HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160418500269
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 941 B HW: 3G0 920 941 B
Component: KOMBI 203 8311
Coding: 07A409182780260001886B011000000000000000
Shop #: WSC 21992 022 02029
VCID: 25020472249E2CAC51-8070
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 26061610520453
Coding: 030300045F087300FB00005C1C0F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7CB40116F7944D645E-8028
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160001204620076243
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001606233850
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000142789008
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA2022A0D6300CFD-8024
Component: TSG FS 020 0041
Serial number: 220616EFL24203
Coding: 00350A20D000028000001000
VCID: 43C6BAEACAEAF29C5F-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000003959550
Coding: 090000
65578 - Motors for Central Locking
B122B 12 [009] - Short to Plus
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
65598 - Motor for mirror fold-in
B11F6 01 [009] - Electrical Failure
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
65799 - Door Warning / Entry Lighting
B1775 01 [009] - Electrical Failure
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
65621 - Locking Module for Central Locking
B122F 29 [009] - Signal Implausible
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 9903
ROD: EV_SteerAssisMQB_010.rod
VCID: 41CAB0E2D0F6E08C4D-8014
15873 - Steering angle sensor
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:10:49
Motor status: 01
System status: Driving mode
Supply voltage: 13.25 V
Temperature: 22.0 °C
KFC: 3E
KFA: 00 01
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 13.31 V
uAdSensI_SwitchedKl30_xdu16: 13.31 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Component: TSG BFS 020 0041
Serial number: 190616EFI24755
Coding: 00350020DE00028000001000
VCID: 42C8BFEED5F0FB9454-8016
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000003963619
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:26:20
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:26:20
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0757
Coding: 02840201FF00000051110101008808001F0100C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 312AE0226056700CBD-8064
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJU02FYR
Subsystem 2 - Part No SW: 3G0 919 866 S HW: -----------
Component: ECE1 2016/17 --- 0635
0004 - Antenna 2 for radio
B111A 11 [009] - Short to Ground
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Short circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 51 dBµV
1637 - Interface for External Media
U11B8 00 [009] - No Communications
[USB - communication error]
Reset counter: 129
Mileage: 190906 km
Date: 2020.12.02
Time: 00:09:51
Voltage terminal 30: 13.1 V
Interface for external media: status-Status: Open circuit
End----(Elapsed Time: 01:31, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
