Downloading to new PC
cschmitz20
Verified VCDS-Lite User
C?ID=385099
Hi get an error when trying to download vcds on a new pc. This pc has no normal usb drives only usb c drives. I got an adaptor to plug the hex into.
It says i have to run a 64 bit version of DP.inst.exe? What is this?
cschmitz20
C?ID=385099
Also of note it is a 64 bit ARM processor.
Ashields
Orkney, UK
C?ID=325834
Hello
Here is what the Faqs say. It says ARM Processors will not work
Andrew
1.4 What are the computer requirements?
VCDS requires a computer running Microsoft Windows (the HEX-NET can be used with VCDS-Mobile on other platforms but that use is still in beta testing). A Laptop is most convenient but a desktop PC can also be used.
We recommend a PC running Windows 7, 8.1, or 10 with at least 2GB of RAM (single-core Atom�-class processors are no longer recommended and devices with ARM CPUs are NOT SUPPORTED). Screen resolution of at least 800x600 is recommended.
If you are using a power supply for a laptop, it should be one specifically designed for that purpose, NOT a "universal" adapter.
Systems running Windows in a virtualized environment (for example Virtual PC on a Mac) are not supported. See also Question 1.8.
