2013 VW Passat TDI - Unable to modify 46-Central Conv.
captnmarc
Apollo Beach, FL
C?ID=428954
I am new to VCDS but, excited to start using this on my cars, everntually modifying for VIM. Below is my original scan from my 2013 VW Passat SEL TDI. Currently I am trying something basic, trying to get my windows to go up/down with my remote. I did find the setting for the sunroof and it will work remotely now tilting open or closed by holding down lock/unlock on remote. However, the windows setting are nowhere to be found. My understanding is this should be located under Central Conv. 46 but, I am not allowed access to any of those parameters. Actually, I do not have access to many parameters which I didn't expect, I thought this software/hardware tool gave me almost if not full access. Does anyone have any ideas why or where I should look. I have pretty much looked under every setting that I have permissions for at this point and not able to find where I can modify this. Thanks
Friday,25,December,2020,10:08:22:10070
VCDS Version: 20.12.0.1 (x64)  HEX-NET2 CB: 0.4529.4
VIN: 1VWCN7A33DC075003   License Plate: B8LZY
Mileage: 272470km-169305mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A33DC075003   Mileage: 272470km-169305miles
   Component: R4 2.0l TDI   H23 9982
   Revision: 71H23---    Serial number:
   Coding: 001D0012042400008000
   Shop #: WSC 05064 444 00000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B285DB183E7D5B3660-806E
15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05551213    Serial number: 00001208222412
   Shop #: WSC 09003 957 00200
   VCID: 241A86CD12D98A4B37A-8070
   Revision: 00H31001
   Coding: C54BC0F5492900FFA30B03E4921C0042A71000
   VCID: 7DAC93A9DDF31B83184-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0178572823
   Coding: 130C0C
   VCID: 343A768DAEB91ACBA7A-8060
   Part No SW: 561 907 044 M    HW: 561 907 044 M
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0010001012
   VCID: 21148FD9014B9F635CC-8074
9473137 - Motor for Left Temperature Flap
          B108C 71 [008] - Actuator stuck
                    Reset counter: 125
                    Mileage: 258833 km
                    Date: 2020.03.20
                    Time: 14:53:47
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
   Shop #: WSC 07807 444 103846
   VCID: 74BAB68DEEB95ACB67A-8020
   Component: RLS 210912 05  54  0403
   Coding: 22300A
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM050N48
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FB0B9E1871F79139A8-803A
   Serial number: 6940000Y120000MP500M
   Coding: 303047
   Serial number: 3572MSME4C007273ZZZS
   Serial number: 3582MSME10616273ZZZK
   Serial number: 3516KSME0A5E2620ZZZS
   Serial number: 3526KSME2702781FZZZW
   Serial number: 3556LSME5A11751EZZZ
   Serial number: 3566LSME5001751EZZZS
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120720201921
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DAC93A9DD731B83184-8028
   Coding: E20000
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   VCID: 1C6ABE2D2629B28B8FA-8048
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 10111203291614
   Coding: 461000
   VCID: 76BE8C85F8C548DB59E-8022
   Component: IMMO          H07 0705
   Coding: 000007
   VCID: 6A86A8F5BCFD9C3BCD6-803E
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000224294002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 2F3079E1479F3913DA8-807A
   Revision: A1001003    Serial number: 7663363735
   Coding: 010100
   VCID: 2A0668F57CFD5C3B0D6-807E
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000044854163
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 6092CADD4A41D66B132-8034
   Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
   Component: RNS-MID       H02 3696
   Revision: AB001001    Serial number: VWZ6Z7M4267071
   Coding: 04090042010000A6000B
   VCID: 270091C16FEF6153128-8072
                    Fault Frequency: 53
                    Reset counter: 121
                    Mileage: 259136 km
                    Reset counter: 85
                    Mileage: 266376 km
                    Fault Status: 00100111
                    Reset counter: 125
                    Mileage: 263429 km
                    Date: 2014.10.10
                    Time: 18:30:53
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0005643712
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
                    Reset counter: 104
                    Mileage: 271576 km
                    Date: 2020.12.09
                    Time: 09:41:56
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 37204181B34FF1D3828-8062
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0098671
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 659CDBC955E3B343E04-8030
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FB0B9E1879F79139A8-803A
   Serial number: 53388786011224201209
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0005734521
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D6CB3293D33BB83784-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Fault Frequency: 53
                    Reset counter: 121
                    Mileage: 259136 km
                    Reset counter: 85
                    Mileage: 266376 km
                    Reset counter: 125
                    Mileage: 263429 km
                    Date: 2014.10.10
                    Time: 18:30:53
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663548260
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2658B58CDDECBB7D6-806E
End----(Elapsed Time: 01:21, VBatt start/end: 11.9V/11.7V. VIgn 11.9V)-----
Hi and welcome.
What do you have in Adaptation Channel 006?
Also look at Long Coding, Byte 3. Comfort Operation via Remote Control does not look to be enabled there.
captnmarc
Apollo Beach, FL
C?ID=428954
I am not sure how to get to Adaptation Channel 006 or Long Coding, Byte 3. Once I select a control module that I have access to I can then dive in deeper to select Adaptation and Long Coding. What Control Module are you referencing so I can select that and check the Adaptation and Long Coding. Thanks
Sorry, I hadn't had enough coffee before my first reply and missed the fact that you were trying to do this in 46, a module that doesn't exist in your car. :facepalm:
Heade for 09-Central Elect -- the BCM into which all the stuff that was in 46 in earlier cars has been incorporated.
captnmarc
Apollo Beach, FL
C?ID=428954
Adaptation Channel 06 is on and I tested it too....all ok there. Checked Byte 3 and it looks like I have all the right boxes checked off. The sunroof is the only window that I can operate with the remote lock/unlock buttons.
South Molton, UK
If you open the sunroof with the ignition on, can you then close the sunroof using a long press on the lock button on the remote?
On my previous Audi you could enable sunroof open from the remote but it didn't actually work because in their wisdom VAG hadn't included the ability to do it in their firmware!
BTW VCDS can only enable/disable functions that VAG have included in their firmware.
captnmarc
Apollo Beach, FL
C?ID=428954
Below are the specifics I have selected in Byte 3 and 4. With these selections I am only able to operate the sunroof (tilt) with the lock/unlock buttons on my remote. Oh and Mirror lowering doesn't work after enabling. Maybe all functions aren't capable of working for my car even though the options are listed??? Thanks in advance for any pointers you can provide!
Byte 3
Bit 0 - Comfort Opening for Sliding Roof Active - (This is checked and ON)
Bit 1 - Comfort Closing for Sliding Roof Active - (This is checked and ON)
Bit 2 - Comfort Opening Type for Sunroof (0 = Open/ 1 Lift) - (This is NOT checked OFF)
Bit 3 - Comfort Lock via Door Lock Active - (This is checked and ON)
Bit 4 - Comfort Operation via Power Window Switch Active - (This is checked and ON)
Bit 5 - Comfort Operation via Remote Control Active - (This is checked and ON)
Bit 6 - Comfort Operations only for Drivers Door Active - (This is NOT checked OFF)
Bit 7 -Comfort Operation via Lock/Unlock Button independent from Terminal 15/ignition active - (This is NOT checked OFF)
Byte 4
Bit 0 - No data available to modify (Blank)
Bit 1 - No data available to modify (Blank)
Bit 2 - Remote Control with "Terminal 15 ON" Inactive - (This is checked and ON)
Bit 3 - Mirror lowering With Reverse Rear - (This is checked and ON)
Bit 4 - Power Windows/Sunroof disabled after door Opening - (This is NOT checked OFF)
Bit 5 - Comfort Operations Windows/Sunroof via Rain Sensor (0 = non reoccurring / 1 = permanent) - (This is NOT checked OFF)
Bit 6 - Comfort Operations Windows/Sunroof via Rain Sensor (rain closing) Active - (This is NOT checked OFF), I don't have a rain sensor on this car.
Bit 7 - Power Windows/Sunroof enabled after Terminal 15/ignition Off - (This is NOT checked OFF)
captnmarc
Apollo Beach, FL
C?ID=428954
I am able to open/tilt my sunroof with a long press unlock (opens) and long press lock (closes). So that works as expected and I like it.
Please post a fresh Auto-Scan because Comfort Operation via Remote Control (Byte 3, bit 5) was definitely not on in your original scan.
I have a fuzzy recollection that some of the BCMs used in NMS Passats don't support comfort via remote for the windows.
