Polo 6R Steering Assist not reachable
vastechnics
C?ID=143747
I have a very strange problem with a Polo 6R. The 44 Steering Assist was not reachable. I have tried 3 different Steering Pumps. All have same problems. I have tried these thing:
- Other 09 Central Electronics
- Other slip ring
- Canbus wiring straight to BCM
- Ignition supply straight to fuse box
- Ground new wire
- Constant supply new wire
All result in the same problem. No communication with the steering assist. But it is a strange no communication, but i can enter it and see the faultcode. But I see no part no hw no nothing.
Below the autoscan:
Sunday,27,December,2020,13:56:54:43540
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WVWZZZ6RZBY148374   License Plate: POLO6RROYAL
Mileage: 156110km-97002mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBY148374   Mileage: 156110km-97002miles
Address 01: Engine (J623-CGPA)       Labels: None
   Part No SW: 03E 906 019 AH    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 7106
   Revision: --H03---    Serial number:
   Coding: 00110016000400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12MPI02103E906019AH 001006
   ROD: EV_ECM12MPI021.rod
   VCID: 6A8C340D6CF5481BCD7-803E
17827 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [039] - Malfunction / Open Circuit
                    Mileage: 156113 km
                    Date: 2020.12.27
                    Time: 22:09:31
                    Engine RPM: 911.00 /min
                    Normed load value: 29.8 %
                    Coolant temperature: 21 °C
                    Intake air temperature: 6 °C
                    Ambient air pressure: 900 mbar
                    Voltage terminal 30: 14.257 V
                    Time since engine start: 110 s
                    Heated oxygen sensor bank 1: sensor 1: resistance-Lambda probe heater: resistance: bank 1: probe 1: 65535 Ohm
                    Exhaust gas temperature before catalytic converter-TEG_DYN_LS_UP[1]: 389.91251 °C
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 200200E3007100BA042800E900D500000000
   VCID: 005876A57A49A24B733-8054
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 313EE3618123FBC3CCD-8064
   Part No SW: 6R0 937 086 H    HW: 6R0 937 086
   Component: BCM PQ25 M++4 H46 0230
   Revision: BD046001    Serial number: 0392 307100448
   Coding: 24B02BBF08A10000002000003D2B0CD00040410F60060000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 41DEB3A131836B433CD-8014
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU020.10.1012372
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU025.10.1015648
   Coding: 08BC30
03589 - Switch for Driver Side Window Regulator
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 23
                    Mileage: 156113 km
                    Date: 2015.05.20
                    Time: 22:09:31
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX009YNPE
   Coding: 00314D
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 4ACC948D0C35A81BED7-801E
   Serial number: 3575HRB405507A9Q68J2
   Serial number: 3585HRB405507A9QC1TC
   Serial number: 3515RRB404P04QLUI141
   Serial number: 3525RRB404P04QLUEG8H
          B1000 1B [137] - Resistance Too High
                    Mileage: 156113 km
                    Date: 2020.12.27
                    Time: 22:09:31
   Part No SW: 6R0 920 860 E    HW: 6R0 920 860 E
   Component: KOMBI         H04 0304
   Coding: 140200
   VCID: 3634D07D68CDDCFB99F-8062
   Part No SW: 6N0 909 901     HW: 6R0 937 086
   Component: GW-K-CAN TP20 0230
   Coding: 002200
   VCID: 70B826654AA9B2CB833-8024
   Component: IMMO          H04 0304
Address 44: Steering Assist        Labels: None
   VCID: 55F677F1DC4BF7E3705-8000
            49-00 - No Communications
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2K8565800
   Coding: 0500040002
   VCID: 6B823109638F5113B61-803E
End----------(Elapsed Time: 00:47, VBatt start/end: 14.2V/14.3V)-----------
That is indeed quite strange and puzzling.
vastechnics
C?ID=143747
I don’t know what to try anymore. Maybe somone here has an idea...
Gone But Not Forgotten
Is it possible the terminal 15 is by CAN wake and not direct being a virtual terminal 15 from BCM?
What's WD reveal?
Look for a very small damaged all black wire to BCM from 0x44?
vastechnics
C?ID=143747
I will look for this. But do you mean terminal 15 wire from bcm or from 44?
From bcm to 0x44 or even 0x16
Vehicle Identification No.WVWZZZ6RZBY148374
ModelPolo
PO
Date of production11.11.2010
Model year2011
Sales type6R12C4
Engine CodeCGPA
Transmission CodeLNR
Vehicle class differentiation
powertrains/platform parts
0DFVehicle class differentiation - 6R0-
for build status Europe
Tailpipes0P0Rear exhaust tailpipe (standard)
Hill start assistUG0Without hill start assist/hill descent
control/comfort driving assist
Emission standard7MGEmission standard EU5
Coding: 002200
Is it possible this car has 0x04 instead of 0x44?
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Donor scan similar hardware...............
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BF034001
Coding: 002300
Shop #: WSC 31414 790 31414
VCID: 70EBBDDDA32F53C4E8-8024
vastechnics
C?ID=143747
what i see now is that gateway does not show 04 Steering Angle. I will try look at that tomorrow. But how is this steering angle connected?
Compare this scan data with same engine and trans code plus rack PR data...........
vastechnics
C?ID=143747
I will look at this. Thanks. I will post when i have something.
strange thing is never is something changed.
I would qualify all part numbers & codification if I were you for FOD.
JPPSG
@vastechnics: very excellent question indeed - to which th answer is "oddly". Here's the CAN network arrangement for this most peculiar car (from the SSP):
So- at least according to the SSP, G85 seems to be a fully fledged member of the CAN bus with the same standing as J500 (hex44 module). As to why it's disappeared from your scan report and taken-down J500 in sympathy - I don't know. Perhaps it's designed to operate that way - read the EDITs below-maybe?
EDIT: and this from the repair manual:
  • Vehicles with ESP are additionally equipped with a steering angle sensor -G85- . It is fitted in a housing together with the slip ring and coil connector.
So, if I'm reading the note correctly G85 is ONLY fitted with ESP - ??
And this also from the repair manual:
  • After the battery has been connected and ignition is switched on, the ESP and TCS warning lamp - K155- will light up permanently The warning lamp will go out automatically when the vehicle is driven at 15 to 20 km/h in a straight line. This has the effect of reactivating the steering angle sender - G85-
Was the battery disconnected - maybe clearing the DTC is as simple as driving @> 15 km/h?
OP can ignore this.......
NOTE:
For Uwe
This is example where hardware is used to identify the part in microfiche by legacy generic & as example inverse to what most think by software used typically & until you click it but it still might not be referenced, in this case is in supersession.
PART NUMBERILLUSTRATIONDESCRIPTIONREMARKMODELRRP
* 03E 990 990 Control unit for petrol engine
03E 906 019 B
CGPA+PR:7MG+
G0C+7L3
on request
Dropped: May 1, 2014 (EKZ: L)
Vehicle intelligent genuine part.
Order only with additional instructions.
Supersession
03E 906 019 AH Control unit for petrol engine on request
vastechnics
C?ID=143747
I don't understand where the G85 is located as it is not by canbus behind steering wheel.
I have tried coding 0x04 but then gateway gives fault no communication and in gateway list says also not reachable
Since the car has no ESP, why do you think it should have a steering angle sensor? What function would it serve?
iichel
Eindhoven, NB, NL
C?ID=284912
experienced this quite a few times myself. thought it was just my frankencar playing up though.
this car in particular has no G85 since it has no ESP or static cornering lights.
vastechnics
C?ID=143747
Ok lets say it doesnt has G85 ok leave that a side. Then I dont understand why the 0x44 can not be reached and still saying no comm with G85. So that confuses me a bit
i have tried 3 different pumps all same. I can not imagine that 3 are broken.
iichel
Eindhoven, NB, NL
C?ID=284912
I'm tempted to call it a VCDS bug since I'm experiencing the same things when connecting to a Polo 6R. But I'm not able to verify since my own car has a 6C1 steering rack (electromechanical) rather than the 6R0 electrohydraulic pump.
vastechnics
C?ID=143747
Hello iichel,
i can confirm that it has to do with VCDS. Have now got maybe 5-6 cars display same. No coding available. So i think but since update.
