HEX+CAN Error
amp82
Unverified
LP/IP
Hello
I have an official VAG15 HEX+CAN cable which has in the past worked fine but when I came to try to use it recently, I was presented with an error that reads:
"VCDS Release 20.12.0: Port Test
USB Library Version 03.02.07
USB Driver Version 02.10.00
Interface: Not Found!"
I tried on two different laptops, one running Windows 10 and the other Windows 7.
When the cable is plugged into the computer only the light on the cable connector lights up red. When the connector is also plugged to OBD plug in the car, it turns green.
It used to work fine when I last used it, maybe a couple of years ago.
The connector on the cable says it's a:
"HEX+CAN
Dual-K & CAN <-> USB
Interface for VCDS
Rev.B
www.Ross-Tech.com"
Can any help me get it working again please?
Many thanks
And Merry Christmas!
Andrew
Bruce
Near Philadelphia, PA, USA
No such thing as
I'm sure from that description you have a clone of the HEX+CAN especially since there is no serial number shown on the label.
You'll need to get a real interface device from Ross-Tech or one of our distributors to continue here.
