Hello, I am a newbie to both VCDS and the forum
and need a little help with understanding how to get rid of the annoying 'Check front Left Main beam' and dash light after upgrading my DRL/High beam halogen bulbs to LEDs on my 2011 VW GOLF MK6 GTI.
I have found a few posts online talking about byte 18 in particular, but between a those posts and VCDS warning me if I code incorrectly I could cause irreversible damage I am apprehensive to try something for a golf of a different year and spec. Therefore I'd like to be a little more sure before I balls something up on my own.
Auto-scan gives me fault code '01495' - I have swapped over the LEDs and still get the same error on the left one only (despite them both working fine). If I put the halogens back in I have no error hence me thinking is a coding issue not a wiring/faulty LED issue.
Here's to hoping the below Auto-scan result is of some use (ignore the other malfunctions for now hah):
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 77
VIN: WVWZZZ1KZBW013550
2E-Media Player 3 -- Status: Cannot be reached 1100
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH17--- Serial number:
Coding: 0403000C18070060
Shop #: WSC 66565 257 00032
VCID: 678BB01B93628093D28-8032
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 163B600D092300FD681006E990190081310800
VCID: 045187978E144B8B57A-8050
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 1012
Revision: 00003001
Coding: 0000000002
Shop #: WSC 00084 002 1048576
VCID: 7EA5F57FE078215B01E-802A
Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
Component: BCM PQ35 M 103 0615
Revision: 00103 AD
Coding: 48180A3A8025F10040080080340001E443510088536D8D60648040200040
VCID: 35372A53954E2203904-8060
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 20051 21 0512
Coding: 009795
Component: RLS 010610 05 54 0403
Coding: 0330AD
Component: LIN BACKUP HO H11 9004
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA8K4DY
Coding: 00003135
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B233C6BB3EAF473660-806E
Serial number: 3572MSME476B4353ZZZ-
Serial number: 3582MSME7C674353ZZZ+
Serial number: 3512QSME10165E23ZZZN
Serial number: 3522QSME1048620BZZZO
Part No SW: 5K0 953 507 BB HW: 5K0 953 549 D
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JEK0003B
Coding: 1082040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 71BFDE43A1264E238CC-8024
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0002482
Coding: 820000
Part No SW: 5K6 920 971 HW: 5K6 920 971
Component: KOMBI H04 0406
Coding: 470B00
VCID: 72BDD14FA420753B756-8026
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 210510F1002537
Coding: E9801F0600061200000001
Shop #: WSC 00363 210 91406
VCID: 6D87C233B19EAAC3A84-8038
03272 - Control Module for Audio Interface
Component: IMMO H04 0406
VCID: 6A8DC92F8CF0BDFBCD6-803E
Address 2E: Media Player 3
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2138
Coding: 0000628
VCID: 3333144B973A3C33BE0-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 313F1E436D260E23CCC-8064
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2112
Coding: 0000628
VCID: 323D114F6820353BB56-8066
Part No SW: 6RD 035 187 B HW: 6RD 035 187 A
Component: Radio 541 5538
Revision: -------- Serial number: VWZZZ4Q5123886
Coding: 0E000400040005
Shop #: WSC 00078 790 00208
VCID: 46D55D9FF8A8B99B09E-8012
00856 - Radio Antenna
00875 - Treble Speaker Front Right (R22)
00877 - Treble Speaker Rear Right (R16)
Address 77: Telephone
End----------(Elapsed Time: 00:59, VBatt start/end: 14.1V/14.0V)-----------
