Keyfob programming failure Golf 6
MarcoW
Denmark
HUC-2H
Hi guys,
I have a problem with my Golf 6.
Im struggling with programming my key, everything works fine until the car has to "save/remember" the keyfob.
When i reset the keyfobs, program them, turn signals flashes etc. but when im done the car dont know the key again. Then i can wait for 5 minutes, start all over, and same again.
I tried with my 3 different keys, only chose one of them etc. Same problem everytime.
Merry Christmas.
Best regards
Auto-Scan down below:
Wednesday,23,December,2020,21:23:09:31035
VCDS Version: 20.12.0.1 (x64)
VIN: WVWZZZ1KZBW287576   License Plate: ENGLISHAUTO
Mileage: 130800km-81275mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZBW287576   Mileage: 130800km-81275miles
   Part No SW: 03L 906 023 MN    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9971
   Revision: --H43---    Serial number: 00000000000000
   Coding: 08114016032401080000
   ASAM Dataset: EV_ECM16TDI02103L906023MN 003011
   ROD: EV_ECM16TDI02103L906023ND.rod
   VCID: 7EF3AC0AE18E4E7470-802A
6060 - Body Control Module (Central Electric 2)
          U0141 00 [037] - No Communications
                    Mileage: 130805 km
                    Date: 2020.12.23
                    Time: 21:18:49
                    Engine RPM: 0.00 /min
                    Coolant temperature: 63 ∞C
                    Intake air temperature: 15 ∞C
                    Voltage terminal 30: 11.972 V
                    Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 18 ∞C
Readiness: 1110 1000
   Revision: 00H31001
   Coding: 113B600D092A0001881006EB901F0051310050
   VCID: 76E3B42AC1BE063428-8022
   Part No SW: 5ND 907 044 J    HW: 5ND 907 044 J
   Component: Climatronic   H08 0404
   Revision: 00001K04
   Coding: 0000000000
   VCID: 49990FD6E8C039CC95-801C
13636352 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 91
                    Mileage: 130805 km
                    Date: 2020.12.23
                    Time: 21:18:48
Address 09: Cent. Elect.
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 56D 919 475 A    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0006
   Revision: --------    Serial number: 35811407701373
   Coding: 100001
   ASAM Dataset: EV_EPHVA18VW4110000 001007
   ROD: EV_EPHVA18VW4110000.rod
   VCID: 33654D3E9A4C531CCF-8066
12718592 - Databus
                    Reset counter: 91
                    Mileage: 130805 km
                    Date: 2020.12.23
                    Time: 21:18:48
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA2YT74
   Coding: 00003947
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 316947366050610CBD-8064
   Serial number: 3572MSME5813215DZZZV
   Serial number: 3582MSME4514535EZZZZ
   Serial number: 3512QSME5C440979ZZZ+
   Serial number: 3522QSME40220002ZZZ2
   Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number: WHRPIÉeeHHHTê
   Coding: 100A100000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 78FFBA12C3AA70443A-802C
   Serial number: 0422061
   Coding: 820000
267264 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 91
                    Mileage: 130805 km
                    Date: 2020.12.23
                    Time: 21:18:48
   Part No SW: 1K8 920 885 G    HW: 1K8 920 885 G
   Component: KOMBI         H03 1008
   Coding: 170F090000
   Shop #: WSC 01234 567 56789
   VCID: 3B75651EB21C9B5C17-806E
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 270311F6000933
   Coding: 350002
   VCID: 316947366850610CBD-8064
                    Reset counter: 91
                    Mileage: 130805 km
                    Date: 2020.12.23
                    Time: 21:18:51
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 01018B6B74745D545420363E00
   VCID: 2D515B46746805EC99-8078
   Component: IMMO          H03 1008
   Serial number: VWZ7Z0D0121566
   Shop #: WSC 00020 999 00000
   VCID: 6ADB905A8D06D2D4BC-803E
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0131316
   VCID: 31694736A850610CBD-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 34674E2257425424D6-8060
Address 46: Central Conv.
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0131316
   VCID: 326B483AAD565A14C4-8066
Address 56: Radio
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71E98736A8D0210CFD-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370028211
   Coding: 0131216
   Shop #: WSC 01357 011 1012552
   VCID: 356173265C384D2CE1-8060
   Coding: 0131216
   VCID: 3663742A413E4634E8-8062
End-------------------------(Elapsed Time: 02:42)--------------------------
  • Log-ENGLISHAUTO-WVWZZZ1KZBW287576-130800km-81275mi.txt
