DTC's post Cruise Control Retrofit - Start/Stop Not working
fordcapri
London, UK
C?ID=400773
Hi all,
Nice to meet you and seasons greetings.
My first post here and a newbie to VCDS. Bored and in perpetual lockdown = new realms of tinkering. I was hoping somebody may be able to shine some light on an issue I'm having with my Audi A5 (2012).
I fitted Cruise Control the day before yesterday, all went seemingly OK - following this guide.
I went for a test drive, all was working OK, about 20 mins into the drive however, cruise control completely stopped working.
Yesterday morning I hopped back in the car to find the cruise control was working as normal! It has been fine since, tested on three separate occasions. I run a scan, finding the below error codes:
Tuesday,22,December,2020,13:31:11:50009
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WAUZZZ8T8DA034832   License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F
VIN: WAUZZZ8T8DA034832   Mileage: 113320km-70413miles
Address 01: Engine (J623-CJEB)       Labels:. 06L-906-264-CJE.clb
   Part No SW: 8K0 906 264     HW: 8K0 906 264
   Component: 1.8l R4 TFSI  H07 0008
   Revision: --H07---
   Coding: 1A190032232501022000
   Shop #: WSC 06208 123 12345
   ASAM Dataset: EV_ECM18TFS0218K0906264 002007
   ROD: EV_ECM18TFS021_AU48.rod
   VCID: 6E85C85EC01B30EB91E-803A
17186 - Databus
          U1123 00 [036] - Received Error Message
                    Mileage: 113295 km
                    Date: 2020.12.21
                    Time: 22:36:51
                    Engine RPM: 1635.75 /min
                    Normed load value: 19.2 %
                    Vehicle speed: 86 km/h
                    Coolant temperature: 100 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 13.906 V
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Engaged OFF: No
                    Cruise control switch actuation-Tap delay: No
                    Cruise control switch actuation-Tap acceleration: No
                    Cruise control switch actuation-Set: No
                    Cruise control switch actuation-Resume: No
                    Cruise control switch actuation-Plausibility check of main switch: No
                    Cruise control switch actuation-Tip acceleration/deceleration second level: No
                    Cruise control switch actuation-Operating error: No
                    Cruise control switch actuation-Hardware signal main switch: No
                    Cruise control switch actuation-Operating lever: Implausible coding: No
                    Cruise control switch actuation-Limiter button pressed: No
                    Cruise control switch actuation-Main switch off via CAN: No
                    Cruise control switch actuation-variance adapted successfully: No
                    ACC variants: ACC
17187 - Cruise Control Switch (E45)
          P0568 00 [036] - Implausible Signal
                    Mileage: 113295 km
                    Date: 2020.12.21
                    Time: 22:36:59
                    Engine RPM: 1494.00 /min
                    Normed load value: 4.3 %
                    Vehicle speed: 79 km/h
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.003 V
                    Cruise control switch actuation-Hardware signal main switch: Yes
                    ACC variants: ACC
   Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
   Component: ESP8 front    H09 0100
   Coding: 031D4C
   Shop #: WSC 06325 000 00000
   VCID: 015F83E2E1053F937CC-8054
   Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H11 0621
   Coding: 03B04000000000000000
   VCID: 79AFEB0289D5675334C-802C
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0812000166837021
   Serial number: 2312000219538009
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 S    HW: 8K2 820 043 S
   Revision: D0000000    Serial number: 01270920121495
   Coding: 642602C000
   VCID: 392F2B02C955A75374C-806C
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
   Revision: 07016001    Serial number: 00000489478101
   Coding: 260000108034AFC00081400000001D0D0F1D038827090201000008000400020100000024000000
   VCID: 77ABED3ABFC17123428-8022
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 210912  H13 0080
   Serial number: SWF12090215245
   Coding: 00FD11
   Serial number: 20632837
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000410124404
   Serial number: E5188D46000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD95ZVMO
   Coding: 30533933363030303030554A305238543053
   VCID: 48C95EC6823FCEDBFB2-801C
   Serial number: 6334MSME7261441DB
   Serial number: 6344MSME7213543A9
   Serial number: 6352QSME2D234F4EY
   Serial number: 6362QSME04240240.
   Serial number: 63732SME60222B7C+
   Serial number: 63832SME6022135EX
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20121009001172
   Coding: 000016
   Shop #: WSC 06325 123 12345
   VCID: 4FFB75DA67D119E3BA8-801A
                    Reset counter: 76
                    Mileage: 113289 km
                    Date: 2020.12.21
                    Time: 22:32:27
00895 - Cruise Control Switch (E45)
                    Reset counter: 76
                    Mileage: 113295 km
                    Date: 2020.12.21
                    Time: 22:36:50
   Part No SW: 8T0 920 983 K    HW: 8T0 920 983 K
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RAM31XG5D
   Coding: 3387000003012600010401
   VCID: 46D550FE88ABD8AB09E-8012
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y12920027B
   Coding: 80CF07FF00
   VCID: 44D14AF6BE97EABB17A-8010
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 36
                    Mileage: 113280 km
                    Date: 2020.12.21
                    Time: 16:21:52
                    Bin. Bits:    11111
                    Voltage: 13.90 V
                    Count: 6
                    Bin. Bits:    10000
03705 - Voltage Regulator
                    Reset counter: 36
                    Mileage: 113280 km
                    Date: 2020.12.21
                    Time: 16:21:52
                    Bin. Bits:    11111
                    Voltage: 13.90 V
                    Count: 6
                    Bin. Bits:    10000
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011D02225C01120102
   VCID: 56F580BE580B682B79E-8002
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0026915830
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311A36EEB75A3BA7A-8060
   Revision: 00002001    Serial number: 0184475854
   Coding: 011F068200B900C48030003680000000
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H03 0220
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 35
                    Mileage: 113280 km
                    Date: 2020.12.21
                    Time: 16:28:15
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 35
                    Mileage: 113280 km
                    Date: 2020.12.21
                    Time: 16:29:35
   Revision: 00005001    Serial number: 94813006785502
   VCID: 2D070F520D1D0BF3E84-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   Coding: 011D02225E01120102
   VCID: 55F787B2450D6333704-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000106644
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 38292E06F2DFBE5B8B2-806C
   Part No SW: 4G0 035 061 D    HW: 4G0 035 061
   Component: Radio U DAB   H60 0100
   Revision: AB001007    Serial number: 470JY0C7534520
   Coding: 010103010000000001
   VCID: 1E65D89E70BBE06B61E-804A
   Part No SW: 8R2 035 652 A    HW: 8R2 035 652
   Component: B-BN-EU       H62 0175
   Revision: --------    Serial number: 147I+0C7517705
   Coding: 010101020106F9ED01800B4E000000030000
   VCID: 323D1C2E1423540BB56-8066
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0098
   Serial number: 9465I40C2575584
   Subsystem 2 - Part No SW: 8T0 919 611     HW: 8T0 919 611
   Component: E0380 Bedient  H01 0100
   Serial number: 00000001291809
                    Reset counter: 35
                    Mileage: 113280 km
                    Date: 2020.12.21
                    Time: 16:21:58
                    Bin. Bits: 00000001 01100000
                    Bin. Bits: 00000000 00000000
End----------(Elapsed Time: 01:22, VBatt start/end: 13.9V/13.9V)-----------
As everything was working OK, I just cleared and went for a drive - however I noticed that the start stop function no longer works. Prior to fitting the Cruise Control, this operated as normal and I've never had an issue with this before. It's worth noting, whilst fitting the cruise control, I did have the battery disconnected for around 1 hour.
The error codes for 01/06 have not reappeared (yet!).
But, I am having persistent issues with modules 19/5F. I have included a scan I did last night below that includes the 2 faults under module 19 and module 5f that won't resolve.
Tuesday,22,December,2020,17:03:36:50009
   Revision: --H07---
Readiness: 1110 0001
   Coding: 031D4C
   Coding: 642602C000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000016
   Coding: 80CF07FF00
                    Reset counter: 36
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 16:55:51
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 36
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 16:55:51
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
   Coding: 010101020106E1ED01800F4E000000030000
                    Reset counter: 36
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 16:54:55
                    Bin. Bits: 00000001 00000000
End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
Here's the newest scan:
Wednesday,23,December,2020,18:51:16:50009
VIN: WAUZZZ8T8DA034832   License Plate: RE62
Mileage: 113320km-70413mi   Repair Order:
   Revision: --H07---
Readiness: 0110 0001
   Coding: 031D4C
   Coding: 642602C000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000016
   Coding: 80CF07FF00
                    Reset counter: 77
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 16:55:51
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 77
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 16:55:51
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 36
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 17:04:26
                    Reset counter: 36
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 17:05:17
                    Reset counter: 36
                    Mileage: 113326 km
                    Date: 2020.12.22
                    Time: 16:54:55
End----(Elapsed Time: 01:22, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
Does anyone know what I've messed up on here? And how I can fix these fault codes to hopefully restore the Stop Start function?
(sorry for the long post).
Thank you,
Kyle
Hi and welcome.
Looks like the LIN bus from the Gateway to the voltage regulator in the alternator and the battery monitoring module was off-line. In the last scan, those faults have reverted to "Intermittent". Try clearing them.
