Saturday,19,December,2020,12:40:04:41679
VCDS Version: 20.12.0.1 (x64) HEX-NET CB: 0.4529.4
VIN: WVWZZZE1ZMP0xxxxx License Plate:
Chassis Type: E1-VWE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 5F 6C 75
8C A5 C0 C6 D6 D7 8105 8107 811E 811F 8120 8121 8123 8124 8125 8128 C002 C003
51-Electric Drive -- Status: Malfunction 0010
8105-DC/DC Converter 12V -- Status: Malfunction 0010
8107-Antenna -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Cannot be reached 0100
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623-EBJC) Labels: None
Part No SW: 0EA 906 012 AA HW: 0EA 907 425 C
Component: E-Vehicle H01 1101
Coding: 010200000364140070080000001000402000060000000000
ASAM Dataset: EV_VCU00XXX0200EA906012AA 001009
ROD: EV_VCU00XXX0200EA906012AA.rod
VCID: 6A9816538DDD26D4BC-803E
9 Faults Found:
43522 - Unauthorized Software/Coding Detected
P064F 00 [032] - -
Reset counter: 35
Mileage: 147 km
Engine RPM: 16383.75 /min
Normed load value: 100.0 %
Vehicle speed: 255 km/h
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Ambient air pressure: 2550 mbar
Voltage terminal 30: 12.617 V
Unlearning counter according OBD: 35
Driver intention torque: 0.0 Nm
PV: 0.00 %
LV_IGK: 00000000
TAA: 255.992 °C
Driving position: Initialization
Brake light switch status-actuated__activated: Not operated
Brake light switch status-Ident_32: 0
Hybrid batt charge cond act val standardized: 127.50 %
23076 - Implausible Data Received from Diagnostic Gateway Module
U0447 00 [032] - -
Reset counter: 32
Mileage: 26 km
Date: 2020.11.18
Time: 20:02:25
Voltage terminal 30: 12.246 V
Unlearning counter according OBD: 32
LF_MVB_PDU_INTC_DIAG_1: 32768
LF_MVB_PDU_INTC_DIAG_2: 1024
LF_MVB_PDU_INTC_DIAG_3: 0
LF_MVB_PDU_INTC_DIAG_4: 32768
LF_MVB_PDU_INTC_DIAG_5: 517
LF_MVB_PDU_INTC_DIAG_6: 0
LF_MVB_BUS_INTC_DIAG: 256
43206 - Controls in Steering Wheel
U108F 00 [032] - Implausible Signal
Fault Frequency: 9
Reset counter: 39
Mileage: 7 km
Date: 2020.11.10
Time: 11:39:22
Voltage terminal 30: 13.144 V
LF_MVB_PDU_INTC_DIAG_1: 32793
LF_MVB_PDU_INTC_DIAG_2: 15416
LF_MVB_PDU_INTC_DIAG_3: 2558
LF_MVB_PDU_INTC_DIAG_4: 64896
LF_MVB_PDU_INTC_DIAG_5: 32287
LF_MVB_PDU_INTC_DIAG_6: 28588
LF_MVB_BUS_INTC_DIAG: 0
43559 - Release / Enable Active
B184C 00 [040] - -
Reset counter: 31
Mileage: 5 km
Date: 2020.11.10
Time: 11:09:48
Voltage terminal 30: 14.765 V
Unlearning counter according OBD: 31
PV: 0.00 %
LV_IGK: 00000001
TAA: 12.500 °C
Driving position: P
Hybrid batt charge cond act val standardized: 22.50 %
15364 - Unauthorized Software/Coding Detected
P064F 00 [032] - -
[Unauthorized Software/Calibration Detected]
Reset counter: 35
Mileage: 147 km
PV: 0.00 %
LV_IGK: 00000000
TAA: 255.992 °C
43491 - Unknown Error Code
U3035 00 [032] - -
[Communication Authentication Signal Invalid Data]
Reset counter: 31
Mileage: 7 km
Date: 2020.11.10
Time: 11:29:37
Voltage terminal 30: 14.746 V
PV: 0.00 %
LV_IGK: 00000001
TAA: 13.000 °C
Driving position: R
Brake light switch status-actuated__activated: operated
Brake light switch status-Ident_32: 1
Hybrid batt charge cond act val standardized: 21.00 %
34298 - Databus
U1122 00 [032] - Implausible Message
Reset counter: 31
Mileage: 7 km
Date: 2020.11.11
Time: 09:03:11
Voltage terminal 30: 13.730 V
CCS Switch: ACC operating unit
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
ACC variants (coding): ACC with braking until standstill / Stop & Go
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
ACC variants: ACC with Stop & Go
ECU_STATE: ENG_STOP
17176 - Databus
Reset counter: 32
Mileage: 52 km
Date: 2020.11.22
Time: 13:05:06
Voltage terminal 30: 13.496 V
38468 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Reset counter: 32
Mileage: 26 km
Date: 2020.11.18
Time: 20:02:25
Voltage terminal 30: 11.738 V
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1EA 614 517 N HW: 1EA 614 517
Component: ESC-ZF_EBC470 H14 0143
Serial number: B000XG3
Coding: 09954A84153C90385244A8E711D911A648294916443111492888886512949268228C889214D6CBBCFC006BD33D3F00
ASAM Dataset: EV_Brake1ZFESCEPBMEB 003042
ROD: EV_Brake1ZFESCEPBMEB_003_VWE3.rod
VCID: 3D32ED0FACD3616C29-8068
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5WA 959 436 G HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0706
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003_VW38.rod
VCID: 58FC5C9B23B1A4441A-800C
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 1EA 907 727 L HW: 1EA 907 727 L
Component: Climatronic H01 0213
Coding: 002122017010120000100010110001102000102100101101000000000000
ASAM Dataset: EV_ACClimaBHBMEB31X 001045
ROD: EV_ACClimaBHBMEB31X_001_VWE3.rod
VCID: 43C69BF7CA37179C5F-8016
131076 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Reset counter: 32
Mileage: 26 km
Date: 2020.11.18
Time: 19:42:28
Voltage terminal 30: 0.00 V
Outside temperature: 10.50 °C
Engine RPM: 16383.8 /min
System run time-Terminal 15 on: 0 s
2097409 - Heater for Spray Nozzles
B1224 11 [040] - Short to Ground
Reset counter: 35
Mileage: 52 km
Date: 2020.11.22
Time: 14:09:44
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 1EA 937 089 D HW: 1EA 937 089 A
Component: SAM_H H22 0117
Serial number: 06102022700215-
ASAM Dataset: EV_SAMVW31x 003001
ROD: EV_SAMVW31x.rod
VCID: 3FCE9707A6DF737C3B-806A
9 Faults Found:
539157 - Databus
U1121 00 [046] - Missing Message
[Klima Datenbus fehlende Botschaft]
Fault Frequency: 134
Date: 2020.11.10
Time: 16:48:03
1074806 - Databus
U1123 00 [100] - Received Error Message
[ICAS1_Gateway Datenbus empfangener Fehlerwert]
1059076 - Lamp 1 for Contour Lighting of Dashboard
U117E 00 [036] - No Communications
1059588 - Lamp 3 for Contour Lighting of Dashboard
U1182 00 [036] - No Communications
1061380 - Lamp 1 for Ambient Lighting of Front Center-Console
U1190 00 [036] - No Communications
15401216 - Unknown Error Code
U14FE 00 [100] - -
[Sichere on-board Kommunikation: Signaturüberprüfung fehlgeschlagen]
934408 - Rain/Light Recognition Sensor
B1366 29 [036] - Signal Implausible
953092 - Control Module for Roof Electronics
U1165 00 [100] - No Communications
72192 - Unknown Error Code
C1036 F1 [036] - Unknown Error Elaboration
[Drehwinkelsensorhintenlinks:Sensortauscherkannt]
Address 10: Park/Steer Assist (-----) Labels:* None
Part No SW: 1EA 919 294 C HW: 1EA 919 294
Component: PDC08K------- H01 0087
Serial number: 000003082094560
Coding: 0040010001
ASAM Dataset: EV_EPHBO18VW3100000 002016
ROD: EV_EPHBO18VW3100000_VWE3.rod
VCID: 3C34E00BB7C968641E-8068
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 1EA 907 572 D HW: 1EA 907 572
Component: ARS510VW19 H02 0075
Coding: 010310714071404512474000000040C5AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARCONTIVW310 003008
ROD: EV_FRONTRADARCONTIVW310.rod
VCID: 393AF91FB8FB5D4C05-806C
0527 - Activation Code Inconsistent
B188C 00 [168] - -
[FAULT_CONSISTENCY_NO_TSKACC]
Reset counter: 20
Mileage: 147 km
Date: 2020.11.29
Time: 15:33:05
2063 - Databus
U1122 00 [168] - Implausible Message
[FAULT_MAINSWITCH_INIT]
Reset counter: 20
Mileage: 147 km
Date: 2020.11.29
Time: 15:33:34
0846 - Databus
U1122 00 [160] - Implausible Message
[FAULT_LEARNING_PLAUS_BR_REIFENUMFANG]
MIL ON - Intermittent - Not Confirmed - Tested Since Memory Clear
0844 - Databus
[FAULT_LEARNING_PLAUS_ESP_ZAEHNEZAHL]
2064 - Databus
[FAULT_LEARNING_PLAUS_CONTROL_UNIT_TYPE]
Address 15: Airbags (J234) Labels: None
Part No SW: 1EA 959 655 CC HW: 1EA 959 655 BN
Component: VW40Airbag 009 0241
Serial number: U177OkE08F2
Coding: 88CC008000F0C000000000200000000051540000A1540000C000F68000AB0065
ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
ROD: EV_AirbaVW40ALVVW38X_001_VWE3.rod
VCID: 044458EB8FB9D0A426-8050
1075464 - Databus
[NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
1075461 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
1075462 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
1075463 - Databus
U1123 00 [096] - Received Error Message
[NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
1075465 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
Address 16: Steering wheel (J527) Labels:* None
Part No SW: 1EA 953 507 G HW: 1EA 953 507 G
Component: GSMMEB 006 0071
Serial number: 000000250820260
Coding: 0000
ASAM Dataset: EV_SMLSKLOMEB 010001
ROD: EV_SMLSKLOMEB_010.rod
VCID: 3B36E317B2C76F5C17-806E
131380 - Databus
U1121 00 [032] - Missing Message
Reset counter: 32
Mileage: 7 km
Date: 2020.11.11
Time: 09:03:12
Address 17: Instruments (J1254) Labels:* None
Part No SW: 10A 920 320 B HW: 10A 920 320
Component: FAHRERDISPLAY 009 0465
Serial number: 0G1X2437-563385
Coding: E670
ASAM Dataset: EV_DashBoardLGMEB 001026
ROD: EV_DashBoardLGMEB.rod
VCID: 146468ABFFD94024B6-8040
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 1EA 937 012 G HW: 1EA 937 012 A
Component: ICAS1 Host-SG 064 0095
Serial number: SJ8ICS260820117
ASAM Dataset: EV_GatewICAS1MEB 005001
ROD: EV_GatewICAS1MEB_VWE3.rod
VCID: 3424C82B9F99A024D6-8060
20 Faults Found:
1049259 - Ethernet Databus; Branch 11
U14A8 00 [044] - No Communication
Reset counter: 36
Mileage: 98 km
Date: 2020.11.27
Time: 13:54:57
2502759 - Unknown Error Code
U1642 00 [044] - -
[Emergency-call_module_no_communication_vlan]
Fault Frequency: 26
Reset counter: 36
Date: 2020.11.11
Time: 08:09:00
2498675 - Unknown Error Code
U1645 00 [046] - -
[Information_electronics_control_module_1_no_communication_vlan]
Fault Frequency: 70
Date: 2020.11.11
Time: 08:08:37
2502842 - Unknown Error Code
U1646 00 [046] - -
Fault Frequency: 92
Mileage: 5 km
Date: 2020.11.10
Time: 11:11:16
8397062 - Unknown Error Code
P1A85 00 [044] - -
[12_V_test_pulse_not_available_by_reason_of_EMHLR]
Reset counter: 36
Mileage: 52 km
Date: 2020.11.24
Time: 17:09:54
Reason for rejection: 1
Bad counter: 3
Test pulse counter not OK: 0
Counter increase not OK: 0
BZE_test_pulse_request: 1
BZE_test_pulse_result: 0
8397570 - Battery terminal recognition
U1411 00 [036] - Open circuit
Fault Frequency: 151
Reset counter: 38
Mileage: 246 km
Date: 2020.12.12
Time: 11:11:05
8397571 - LV Energy Management
B1802 F1 [044] - Warning Triggered
Fault Frequency: 152
Reset counter: 38
Mileage: 7 km
Date: 2020.11.17
Time: 11:22:23
22
8540417 - Unknown Error Code
U15FA 00 [044] - -
Reset counter: 38
Mileage: 7 km
Date: 2020.11.10
Time: 16:48:22
8491266 - Unknown Error Code
U14FE 00 [108] - -
[SOK_signature_verification_failed]
Fault Frequency: 17
Reset counter: 38
Mileage: 7 km
Date: 2020.11.10
Time: 11:39:26
8511746 - Unknown Error Code
U173E 00 [036] - -
Reset counter: 31
Date: 2020.11.11
Time: 09:02:59
9371914 - predictive route data
B1630 02 [046] - Signal Failure
Fault Frequency: 113
Mileage: 7 km
Date: 2020.11.10
Time: 11:33:15
8557314 - Databus
U1122 00 [038] - Implausible Message
[ZM_GNSS_Implausible]
Mileage: 259 km
Date: 2020.12.19
Time: 12:21:13
2494551 - Unknown Error Code
U163C 00 [036] - -
Reset counter: 32
Mileage: 52 km
Date: 2020.11.22
Time: 13:00:37
2494569 - Unknown Error Code
U1643 00 [047] - -
[Rearview_camera_system_control_module_no_communication_vlan]
Mileage: 5 km
Date: 2020.11.10
Time: 11:10:07
8515664 - Control Pilot
P0CF4 00 [108] - Implausible Signal
[HVLM_no_cp_communication_possible]
Reset counter: 38
Mileage: 147 km
Date: 2020.11.27
Time: 20:58:13
B184C 00 [036] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Reset counter: 31
Mileage: 5 km
Date: 2020.11.10
Time: 11:09:52
2240526 - Body Control Module (Central Electric)
U0140 00 [040] - No Communications
[Body_control_module_no_communication_data_bus_connect]
Reset counter: 35
Mileage: 7 km
Date: 2020.11.10
Time: 16:07:28
8515586 - Databus
[HVLM_occ_01_timeout]
Fault Frequency: 116
Mileage: 7 km
Date: 2020.11.10
Time: 16:10:46
8515587 - Databus
[HVLM_occ_02_timeout]
Fault Frequency: 111
Mileage: 7 km
Date: 2020.11.10
Time: 16:10:47
8516406 - Unknown Error Code
C1249 F6 [046] - Unknown Error Elaboration
Mileage: 7 km
Date: 2020.11.10
Time: 16:10:47
Address 23: Brake Booster (J539) Labels: None
Part No SW: 1EA 909 059 H HW: 1EA 909 059
Component: EBB-ZF-Gen1 H27 0241
Serial number: ÿÿÿÿÿÿÿ
Coding: 08951184003C1038884400E720D92020202020202021212121000404040404040404848484840008001000
ASAM Dataset: EV_BrakeBoostZFMEB 002035
ROD: EV_BrakeBoostZFMEB_VWE3.rod
Address 2B: Steer. Col. Lock (J764) Labels:* None
Part No SW: 1EA 905 861 HW: 2Q0 905 861 B
Component: ELV-MEB H09 0040
Serial number: 20000196980007
Coding: 8800000000000000
Shop #: WSC 00028 000 00000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 74A4082BDF19E02416-8020
12666379 - Databus
[Timeout Message ESP_21]
Mileage: 7 km
Date: 2020.11.18
Time: 09:08:38
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: Not operated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: OFF
Clamp 15: OFF
Clamp 15 Status: valid
Remote Start: not active
Driver door: For
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c timeout
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: Yes
Lifestate: Immobilizer download obtained
Learn mode: Adapted
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 0.00 km/h
UBat internal: 11.6 V
UMotorBridge: 6.4 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition E2E clamp status: Condition met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition not met
Lock condition E2E distance pulse: Condition not met
Lock condition difference distance pulse: Condition not met
Part No SW: 1EA 959 593 A HW: 1EA 959 593
Component: TSG FS 003 0541
Serial number: 0000416524671
Coding: 003D1220D001848005001000
ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
ROD: EV_DCU3DriveSideMAXHCONT.rod
VCID: 40CC94FBDB210C8442-8014
Part No SW: 1EA 907 144 AD HW: 1EA 907 144 G
Component: BASGEN1MQB37 215 5023
Serial number: 00226699
Coding: 0000000000000201000002010100010000000100010102
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
VCID: 75A2352FD463F92C21-8020
Address 51: Electric Drive (J841) Labels: None
Part No SW: 1EA 907 121 C HW: 1EA 907 121 C
Component: MEB PSM H08 6034
Serial number: NRR_M7000063174
ASAM Dataset: EV_DMCM15000F11EA907121C 001008
ROD: EV_DMCM15000F11EA907121C.rod
VCID: 2E10DA4371B58AF4A0-807A
41735 - Databus
U1123 00 [047] - Received Error Message
Fault Frequency: 36
Reset counter: 8
Mileage: 259 km
Date: 2020.12.19
Time: 12:28:12
Inverter_operating_state: FREEWHEEL_MODE
Actual_mechanical_torque_calculated: 3192648441 Nm
Actual_mechanical_torque_commanded_value: 0
Temperature_IGBT_phase_U: 1094312418 °C
Temperature_IGBT_phase_V: 1094004013 °C
Temperature_IGBT_phase_W: 1094620822 °C
CAN_operation_mode_HV_battery_module_control: Fahren_HV_aktiv
Voltage_Terminal_15: 13.925 V
DC_link_voltage: 1138009823 V
Freewheel_active: Fehler__EM_im_Freilauf
Actual_possible_maximum_torque: 3192648441 Nm
Actual_possible_minimum_torque: 3192648441 Nm
Absolut_value_RPM_e_machine: 3167749007 /min
Inverter_damping_control_gear_ratio: 11.531
Inverter_damping_control_tooth_number: 43
Expected_model_type: 0
41716 - Control Module Improper Shut Down
U3001 00 [040] - -
Reset counter: 0
Mileage: 147 km
Date: 2000.11.28
Inverter_operating_state: NACHLAUF_MODE
Actual_mechanical_torque_calculated: 0 Nm
Temperature_IGBT_phase_U: 1094158216 °C
Temperature_IGBT_phase_V: 1093849811 °C
Temperature_IGBT_phase_W: 1094466620 °C
CAN_operation_mode_HV_battery_module_control: HV_inaktiv
Voltage_Terminal_15: 0.031 V
DC_link_voltage: 1066990429 V
Freewheel_active: Init
Actual_possible_maximum_torque: 0 Nm
Actual_possible_minimum_torque: 0 Nm
Absolut_value_RPM_e_machine: 0 /min
Inverter_damping_control_tooth_number: 0
Part No SW: 1EA 959 592 A HW: 1EA 959 592
Component: TSG BFS 003 0541
Serial number: 0000417065058
Coding: 003D1020DC01048001801000
ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
ROD: EV_DCU3PasseSideMAXHCONT.rod
Part No SW: 10A 035 820 D HW: 10A 035 820 A
Component: IC3-SF--EU H20 0564
Coding: 23106038000000000000000000000000000000000000000000
ASAM Dataset: EV_MUICASSAFEPart 001001
ROD: EV_MUICASSAFEPart_VWE3.rod
VCID: 187C1C9BE3316444DA-804C
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 1EA 980 556 C HW: 5WA 980 556 A
Component: RV eCompact H21 0233
Serial number: FCL-K2011.08.20
Coding: 0203E204E43000
ASAM Dataset: EV_CamSysRVCCompaFicosMEB 003010
ROD: EV_CamSysRVCCompaFicosMEB.rod
13705529 - Databus
Part No SW: 10A 035 284 B HW: 10A 035 284
Component: OCUGen4 H15 0090
Serial number: 0000000007VIKE4
Coding: 02310010106880008005460000000000
ASAM Dataset: EV_OCUGen4 001035
ROD: EV_OCUGen4_VWE3.rod
VCID: 1A7806931D3D7654EC-804E
1375744 - Unknown Error Code
U14FE 00 [040] - -
Mileage: 99 km
Date: 2020.11.27
Time: 13:55:33
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 0Z1 915 184 D HW: 0Z1 915 184 D
Component: J840 K8C BMC 007 0840
Serial number: 000000030920210
ASAM Dataset: EV_BMCeVWBSMEB 001011
ROD: EV_BMCeVWBSMEB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 1EA 980 654 D HW: 1EA 980 654
Component: MEB MFK 4.1 H03 5215
Coding: 0009302C151108E0062420000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK41ValeoMEB 001017
ROD: EV_MFK41ValeoMEB_VWE3.rod
1124497 - Databus
U1123 00 [044] - Received Error Message
[ACC_18_ACC_Status_ACC_irreversibel_ERROR]
Reset counter: 35
Mileage: 52 km
Date: 2020.11.22
Time: 13:05:09
1124755 - Databus
U1121 00 [044] - Missing Message
Reset counter: 31
Mileage: 7 km
Date: 2020.11.11
Time: 09:03:10
Address C0: Act. for Ext. Noise (J943) Labels: None
Part No SW: 10A 035 335 A HW: 1EA 035 335
Component: E_SOUND_SG H05 0004
Serial number: JTK072120820812
ASAM Dataset: EV_ESoundMEBHarma 004010
ROD: EV_ESoundMEBHarma.rod
VCID: 166012A3E9255234C8-8042
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 1EA 915 684 BF HW: 1EA 915 684 BF
Component: HV_CHARGER H52 0012
Serial number: 92832TFO000AP
Coding: 1080
ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002008
ROD: EV_OCCXPhase1KLOMEB01B.rod
VCID: 004C54FB9BA1CC8402-8054
3280899 - Unknown Error Code
B1AD0 F0 [109] - Unknown Error Elaboration
Mileage: 7 km
Date: 2020.11.10
Time: 11:30:12
DID 1DA0: AC main charge
DID 1DAC: Charging
Frequency: 1000 Hz
Control voltage: 6015.0 mV
Duty cycle: 26.3 %
Activation charge cover lock charge socket A: not requested
Lock for high-voltage charging connector: locked
Status connect. recognition: detected
Charge socket temperature sensor AC: 30.0 °C
Temperature sensor 1: resistance value: 1092 Ohm
DID 15E2: 18.0 °C
DID 081C: 0 W
DID 081D: 769 W
DID 081E: 458 W
DID 0286: 14.7 V
DID 497C: active
DID 537A: 14.3 V
DID 1525: 3222 mV
Status of voltage freedom: High voltage power off not recognized
DID 5372: 17.0 °C
No. of lockings: 5
No. of connections: 0
Number of successful charging connector locks: 1
Wake-up counter: contact (proximity): 1
Wake-up counter: Control Pilot: 2
Charging standard abort: status: not active
Loading plan: status: Not available
Price/performance table: status: Not available
Transport Layer Security (TLS) status communication: not active
DID 103A: supported
number_evse_slac: 0
PLC_modem_status: active
number_slac_attemps: 1
DID 1033: SLAC_failed
DID 1038: no_description
DID 1039: supported
Target HV charge current: 0.5 A
5242881 - Unknown Error Code
U14FE 00 [096] - -
13705218 - Databus
U1121 00 [040] - Missing Message
Fault Frequency: 99
Reset counter: 39
Mileage: 5 km
Date: 2020.11.10
Time: 11:11:21
DID 0286: 14.1 V
DID 1DA0: Internal malfunction
DID 1DAC: Standby
Lock for high-voltage charging connector: not locked
Status connect. recognition: not detected
Temperature sensor 1: resistance value: 1089 Ohm
DID 15E2: 16.0 °C
DID 497C: not active
DID 537A: 14.2 V
Status of voltage freedom: High voltage power off recognized
DID 5372: 16.0 °C
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 992 941 572 AE HW: 992 941 572 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 6680626399C502B498-8032
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H08 9202
Address 8105: DC/DC Converter 12V (A19) Labels: None
Part No SW: 1EA 907 190 B HW: 1EA 907 190 B
Component: DCDC Gen4H11 1136
Revision: 00H11000
ASAM Dataset: EV_DCDC10030111EA907190B 001019
ROD: EV_DCDC10030111EA907190B.rod
VCID: 3326CB379A97A71CCF-8066
0372 - Implausible Data Received from Engine Control Module
U0401 00 [040] - -
Reset counter: 32
Mileage: 52 km
Date: 2020.11.22
Time: 14:09:39
DC/DC Converter traction power supply: 0.25 V
DC/DC Converter controlled output current terminal 30: 12.117 V
DC/DC converter: voltage 1 active rectifier: 9.096 V
DC/DC converter: voltage 2 active rectifier: 9.076 V
DC/DC converter: transformer current 1: 0.000 A
DC/DC converter: transformer current 2: 0.000 A
DCDC temperature sensor 1: 12.80 °C
DCDC temperature sensor 2: 12.08 °C
DC/DC converter: operating mode output path 1: rbe_CmnGlb_DcdcMod_Stb_e
DC/DC converter: operating mode output path 1-Test_Program_Rbe Asw Dcdc Sym Enum rbe Cmn Glb St Dcdc Mod UBYTE: 1
Address 8107: Antenna (J666) Labels:* None
Part No SW: 1EA 035 741 C HW: 1EA 035 741 C
Component: TrxModulHigh H07 0145
Serial number: 0000000007VIZC3
Coding: 02310611040200
ASAM Dataset: EV_TrxMLGEMEB 006014
ROD: EV_TrxMLGEMEB_006.rod
1375488 - Unknown Error Code
U14FD 00 [104] - -
[SOK_timeserver_not_available]
Reset counter: 3
Date: 2020.12.05
Time: 13:41:29
U14FE 00 [109] - -
Mileage: 5 km
Date: 2020.11.10
Time: 11:09:53
Failed verification status: valid
Number of failed verifications: 14
Verification failed: 00 15
12608768 - Databus
U1201 00 [032] - No Communications
[CAN_No_Communication]
Address 811E: Burglary Protection FL (J518) Labels: None
Part No SW: 5WA 962 133 D HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002_VW38.rod
VCID: 49DA89DFE81BCDCC95-801C
Address 811F: Burglary Protection FR (J518) Labels: None
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518) Labels: None
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: None
ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4) Labels: None
Part No: V04 007 003 AR
Component: ICAS1 Sys_Ada 0095
ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
ROD: EV_AppServe1Syste1ICAS1_VWE3.rod
VCID: 77BE3F27CE6F8B3C33-8022
Address 8124: App server 1 system 2 Java (SWC5) Labels: None
Part No: V04 007 003 AS
Component: ICAS1 Sys_Jav 0095
ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
ROD: EV_AppServe1Syste2ICAS1_VWE3.rod
VCID: 78BC3C1BC37184443A-802C
Address 8125: App server 3 system 1 infotaint. (SWC6) Labels:* None
Part No: V04 007 001 CK
Component: IC3-IVI-D-EU 0564
ASAM Dataset: EV_MUICASIVIPart 002007
ROD: EV_MUICASIVIPart_002_VWE3.rod
VCID: 70AC043BAB01DC04F2-8024
7191 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 36
Mileage: 7 km
Date: 2020.11.11
Time: 08:14:26
BAP: 00
Voltage terminal 30: 13.7 V
1872 - Unknown Error Code
B1994 F4 [008] - Unknown Error Elaboration
[a2b_bus_micro_defect]
Reset counter: 36
Mileage: 52 km
Date: 2020.11.22
Time: 14:50:08
Voltage terminal 30: 11.9 V
amount_of_nodes: 2
Node number: 1
Node name: Emergency call module and communication unit
Node status: OK
1856 - Unknown Error Code
U1514 00 [008] - -
Reset counter: 36
Mileage: 52 km
Date: 2020.11.24
Time: 17:06:44
Voltage terminal 30: 11.8 V
amount_of_nodes: 2
Node number: 1
Node status: not_active
1865 - Unknown Error Code
B1994 F5 [008] - Unknown Error Elaboration
[a2b_bus_next_node_defect]
Reset counter: 36
Mileage: 52 km
Date: 2020.11.24
Time: 17:06:44
amount_of_nodes: 2
Node number: 1
Address 8128: Light line display
End----------(Elapsed Time: 01:49, VBatt start/end: 13.9V/13.9V)-----------
