2016 Caddy abs long code gone after battery change
Aarontvc
England, UK
C?ID=421776
2016 Caddy abs long code gone after battery change can any one help
how can i get this code its 18bit long
auto scan info below
cheers
Monday,14,December,2020,14:33:04:10121
VCDS Version: 20.12.0.1 (x64)  HEX-NET2 CB: 0.4529.4
Dealer/Shop Name:
VIN: WV1ZZZ2KZHX050620   License Plate: EJ66GJZ
Mileage: 55540km-34510mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZHX050620   Mileage: 55540km-34510miles
Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 GT    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1774
   Revision: 8AH20---
   Coding: 01110012042515090000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906016GT 001003
   ROD: EV_ECM20TDI01104L906016GR_001.rod
   VCID: 0154EEF3918B72937CC-8054
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:44
                    Engine RPM: 831.00 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 52 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 12.720 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
   Revision: 00000000    Serial number: 42596000002119
   Shop #: WSC 35110 790 50316
   VCID: 3FD0280BA7FFC4634A8-806A
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 107
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:43
0320 - System Function Test Activated
          C101F 00 [009] - -
                    Reset counter: 107
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:43
4161 - Coding invalid
          U10DA 00 [008] - -
          [mismatch between VIN on CAN and VIN in coding word]
                    Reset counter: 147
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:36:03
8297 - Databus
          U1121 00 [136] - Missing Message
          [ACAN: mIdent signal timeout]
                    Fault Frequency: 9
                    Reset counter: 147
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:50
8319 - Databus
          U1122 00 [137] - Implausible Message
          [ACAN: mMotor_10 Start_Stop coding missmatch]
                    Reset counter: 107
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:43
8324 - Databus
          [ACAN: LW1_ID wrong value]
                    Reset counter: 107
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:43
   Part No SW: 1K8 907 426 AM    HW: 1K8 907 426 AM
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004003
   VCID: 7EAE950FE0750D6B01E-802A
   Part No SW: 5K0 937 085 AD    HW: 5K0 937 085 AD
   Component: BCM PQ35 B+   122 0184
   Revision: BB122001
   Coding: 411A583A8025086B088000829000006403010008424F8160648087000041
   Shop #: WSC 35110 377 00141
   VCID: 75BC8A23D5C34E33504-8020
   Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 06091  26  0512
   Coding: 009795
   Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0480
   Revision: --------    Serial number: 39231625300109
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001007
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 3720402B8FCFFC23828-8062
   Part No SW: 2K5 959 655 C    HW: 2K5 959 655 C
   Component: VW10Airbag007 H08 0018
   Revision: --------    Serial number: 003V20012F3E
   Coding: 000000000000000000000000000000003037
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3C2A5F07B6E9DF7B6FA-8068
   Serial number: 3497ARB405346F8MQGRZ
   Serial number: 3507ARB404P42KLS99U4
          B13BC F2 [137] - No function
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:58
   Part No SW: 5K0 953 521 GB    HW: 5K0 953 569 BE
   Revision: FF010042    Serial number: 20160913200022
   Coding: 1080160010
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 72B6B13FA42D590B756-8026
   Part No SW: 2K5 920 966 C    HW: 2K5 920 966 C
   Coding: 4102011200
   VCID: 353C4A2395C30E33904-8060
   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1682
   Revision:   H58       Serial number: 130916F1000506
   Coding: 357421
   Shop #: WSC 12345 000 00000
   VCID: 79A48613F9DB2A5334C-802C
   Component: IMMO          H03 1104
   VCID: 6A86A95F8CFD91CBCD6-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71B4BE33ADAB62138CC-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 39244613B55BEA5374C-806C
                    Fault Status: 11100100
                    Reset counter: 107
                    Mileage: 55542 km
                    Date: 2020.12.09
                    Time: 00:35:40
                    Voltage: 12.75 V
                        DU
                    Temperature: 23.0°C
                    RPM: 826 /min
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72B6B13FA8AD590B756-8026
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     055 7085
   Serial number: 15091600010720
   Coding: 063307002800000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E0E654F70953DEBD1E-807A
   Component: Batt.regelung H58 1682
   Coding: 030F1873
   VCID: 71B4BE33A1AB62138CC-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75410603001609111013
End----(Elapsed Time: 00:55, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Westbury, UK
U1013 00 [137] - -
U10DA 00 [008] - -
Looks like more has happened than just a battery change - the ABS is complaining of a VIN mismatch.
Has the instrument cluster or engine ECU been changed (even temporarily)?
Aarontvc
England, UK
C?ID=421776
Hi nothing has been changed other than the battery was all fine till the battery was removed
and a new one fitted ,other posts i had looked at that got this fault were from other changes like cluster ect .
is there a way to get the long code back ?
cheers
You scanned it before you started working on it, right?
Look in your Scans sub-folder.
iichel
Eindhoven, NB, NL
C?ID=284912
Can you please, for our peace of mind, post the advanced ID of both the immobiliser and the engine?
Aarontvc
England, UK
C?ID=421776
it wasn't scanned before as it was all working fine with issues just had a battery change than the problem happened .
Aarontvc
England, UK
C?ID=421776
Tuesday,15,December,2020,08:27:31:10121
Dealer/Shop Name:
                Address 01: Engine
Control Module Part Number: 04L 906 016 GT
  Component and/or Version: R4 2,0L EDC   H20 1774
           Software Coding: 01110012042515090000
            Work Shop Code: WSC 65535
Advanced Identification/FAZIT
     Identification: RB8-658
     Revision: 8AH20---
     Date: 19.09.16
     Manufacturer number: 1325
     Test stand number: 0977
Flash Status
     Programming Attempts(application): 3/2/2/2/2
     Successful Attempts(application): 3/2/2/2/2
     Flash Date: 00.00.00
Misc.
     Hardware number: 04L 907 309 K
     Workshop System Name: J623
     ASAM Dataset Revision: 001003
Car Info
     Chassis Number: WV1ZZZ2KZHX050620
     Engine code: DFSD
VCDS Info:
       Labels: 04L-907-309-V1.clb
       Readiness: No script available
Tuesday,15,December,2020,08:28:03:10121
Dealer/Shop Name:
                Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H03 1104
           Software Coding: 000000
            Work Shop Code: WSC 00000
     Identification: VDD-024
     Date: 08.09.16
     Manufacturer number: 1901
     Test stand number: 3999
Flash Status
Software
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A03710
Car Info
Immobilizer
     Transponder ID (Current val.): 08BE39EC
     Transponder ID 1: 08BE3A53
     Transponder ID 2: 08BE39EC
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
iichel
Eindhoven, NB, NL
C?ID=284912
This took me way longer than I'd like to spend but hopefully it works
1079409B9267A47E087B0278498325E3790000
1079409B9267A47E087B0278498325D3790000
Please give these a try
Aarontvc
England, UK
C?ID=421776
hi i have put in both codes and it said code rejected request out of range
iichel
Eindhoven, NB, NL
C?ID=284912
1079409B9267A47E087B0278498325E3790000 rejected
1079409B9267A47E087B0278498325D3790000 rejected
1079409B9267A47E087B0278498325E37900F0 Try this one please first
1079409B9267A07E087B0278498205E3790000 Try this one please if other one fails
1079409B9267A07E087B0278498205E37900F0 Try this one please if next one fails
Aarontvc
England, UK
C?ID=421776
hi this code went in
now just need to set it up hopefully will go ok possibly just need configure it ,i may be back for more advice
thanks for your help with this take care
iichel
Eindhoven, NB, NL
C?ID=284912
Great, take care as well.
dnoermann
C?ID=358118
That is normal when the Coding is Zerroed.
The ABS is validating the 5 Last Digits of VIN. Theese are beeing inside the ABS Coding with a Magic Offset, and if this coding is 00 than the VIN Match fires.
