Mk7 GTI
CD CODING
Manchester, UK
C?ID=421908
Hi attempting to do beep on lock & VIM on mk7 GTI however the car won’t allow me to access module 46 or module 35, I’ve disconnected battery and left for 20 minutes re connected and still isn’t allowing me to access them modules in order to change coding here’s my auto scan
Sunday,13,December,2020,11:53:47:29105
VCDS Version: 20.12.0.1 (x64)  HEX-NET2 CB: 0.4529.4
VIN: WVWZZZAUZFW122056   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 32 42 44 52 55 5F A9
VIN: WVWZZZAUZFW122056   Mileage: 102668km-63794miles
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0010
   Revision: --H13---
   Coding: 091D00324464050B2000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001014
   ROD: EV_ECM20TFS0215G0906259.rod
   VCID: 6B88AC605302EB43B60-803E
Readiness: 1110 0001
   Part No SW: 0D9 300 020 G    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4520
   Revision: 03253104    Serial number: TFK01409070568
   ROD: EV_TCMDQ250021.rod
   VCID: 1964A6A8C91EA9D394C-804C
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 62544000001961
   Coding: 01FA93A15422296E0377060541C96980C92A94C0608296F7F8425079C209
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 46DE3DD42820F62B09E-8012
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00120014200100011005000000101000
   VCID: 73B8B4000B3233837E0-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011425901730
   Coding: 03101A46C24122FB0BA44080B10C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0052EBCC4A84181B732-8054
   Component: WWS    140828  042 0551
   Serial number:         140909202547
   Component: RLHS  037 0059
   Serial number: S5Y14M09D23H14M44S21
   Coding: 00A8DD
   Serial number: 000000000ZY142320SLU
   Serial number: 00000000000060359917
   Sunroof control module:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3253452+
   Coding: 181901
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331426002204
   Coding: 0071051011
   VCID: 3D2C52387DF6B5F3584-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 15091403210535
   Coding: 001C1300FE0739
   VCID: 3822432C52D490DB8B2-806C
1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_MISALIGNMENT_HORIZONTAL]
                    Reset counter: 105
                    Mileage: 102668 km
                    Date: 2020.12.13
                    Time: 00:16:34
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 12.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR08RWP-
   Coding: 98CCC000000000005C0000CF00C800000
065
   VCID: 7F506830377A67E30A8-802A
   Left seat belt tensioner:
   Serial number: 34169677B18091470727
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676B18091450358
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 509 14
   Serial number: 35767000000BCC70111U
   Subsystem 4 - Part No SW: -----------    HW: 480 001 509 14
   Serial number: 3586700000037C4DF01+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 209 14
   Serial number: 3516502BF176A6C3608L
   Subsystem 6 - Part No SW: -----------    HW: 480 400 509 14
   Serial number: 35265029B175A8D282BO
   Subsystem 7 - Part No SW: -----------    HW: 480 401 209 14
   Serial number: 3556502C7176A6C3519J
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 16091404400613
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BA89C2023627BC3260-802E
   Part No SW: 5G1 920 956     HW: 5G1 920 956
   Component: KOMBI         301 4270
   Coding: 27AD09082F80260001886A011400000000000000
   VCID: 6C8AAF7C560CEC7BBFA-8038
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002496214
   Coding: 030100042B085900EF00027F1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42D621C40408CA0B256-8016
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 27140002274130054382
   Coding: 2DFFFF
   Serial number: 6504754403
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8040
   Serial number: HA1-00005.08.14
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001001
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 47C030D02F2AEF23F28-8012
   Serial number: 09091406070794
   Coding: 003F0220D001048000001000
   VCID: 40D22BCC0A04D81B332-8014
   Serial number: 00000000000003797979
   Coding: 1D0000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 353C4A1845C66DB3904-8060
   Serial number: 12091403111363
   Coding: 003F0020DE01048000801000
   VCID: 3FD0283077FAA7E34A8-806A
   Serial number: 00000000000003883015
   Coding: 050000
   Coding: 029E01000B000200
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    041 0430
   Serial number: V7F00409140567
   Coding: 02730001FF00000021111201000800001F0203060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6780D0504FEACF23D28-8032
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS403M43
   Subsystem 2 - Part No SW: 5G0 919 866 AF    HW: -----------
   Component:  ECE 2017/18  --- 0067
   Component: SAS-GEN 2     H06 0014
   Serial number: 140711200750
End----(Elapsed Time: 01:48, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
South Molton, UK
That's because a Mk7 Golf doesn't have modules at address 46 or 35 - so the instructions you are trying to follow don't apply to your car.
The functions that used to be done by 46 are now in 09, and the functions that used to be done by 35 are now in 5F. You should look for the correct instructions for a Mk7 Golf - probably in a Golf Mk7 owners forum?
BTW Ross-Tech will not provide assistance with VIM due to liability concerns.
Waxing pedantic: 35-Cent. Locks and 46-Cent. Conv. were mutually exclusive. Older cars tended to have 35, somewhat newer ones had 46, and if a car has neither of these, it all tends to be in 09.
I'm not sure what 5F has to do with anything. 37-Navigation, 56-Radio, and 77-Telephone have generally moved to 5F.
Try 09-Cent.Elect. -> Adaptation:
IDE02269-ENG116667 -- Acknowledgement signals - Akustische Rueckmeldung verriegeln (not active / active)
South Molton, UK
Of course you're right Uwe - I read "VIM" and thought 5F would be the appropriate address?
OK, makes sense. If VIM is doable, it's in 5F, but as you've already stated, RT won't provide explicit assistance with that.
CD CODING
Manchester, UK
C?ID=421908
Thankyou I’ll give it a try and let yous know massive help 😁
