2012 Touareg - disable e-brake - missing options in VCDS
Slammer
Norway
C?ID=393427
The rear brake pads and rotors on my 2012 VW Touareg are getting worn out, so I decided to try and change them myself. After doing some research (reading and watching various youtube videos) and buying the necessary equipment and parts, I began work today only to be stopped when trying to retract and reset the e-brake. Apparently the options available to me in Basic Settings under control module 53 Parking Brake are not the same as the ones I need in order to deactivate the electromechanical parking brakes, and thus change rear brake pads. According to the Ross-Tech video on youtube:
I need to select "Start lining change mode" in order to operate the parking brake rotors, but I have no such option available to me.
These are the options I can choose from (Protocol UDS) :
Is there anything I need to tweak or change in order to get the options I need to appear on this list?
I ran a scan of the car, and I do have some fault codes but I'm not sure if they are related to this issue. I have attached the log below.
Any help would be much appreciated!
Saturday,12,December,2020,13:40:03:38866
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WVGZZZ7PZCD030141   License Plate:
Mileage: 144018km-89488mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 34 36 3C 42 46 47
          52 53 55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZCD030141   Mileage: 144018km-89488miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 292A401A237E01020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
   ROD: EV_ECM30TDI011_VW52.rod
   VCID: 323D1CE894A61CBBB57-8066
   Part No SW: 0C8 927 750 AG    HW: 0C8 927 750 AG
   Component: AL1000 AISIN  001 1933
   Coding: 001568
   Shop #: WSC 80093 222 69422
   ROD: EV_TCMAL991031_002.rod
   VCID: 71BFD3E4512067A38CD-8024
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 429110010EC010
   Coding: 5B6B13C30B272F53DAF5C897D0D3F4507700
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 45D7573435289B03005-8010
771080 - Databus
          [Signal Parkbremse unplausibel]
                    Reset counter: 154
                    Mileage: 143472 km
                    Date: 2020.12.02
                    Time: 11:50:43
                    Standard Freeze  Frame Dynamic: 00 41 00 00 24 00 00 02 00 00 02 10 25
   Part No SW: 4H0 907 064 BH    HW: 4H0 907 064 BH
   Component: BCM2 2.0      H31 0333
   Coding: 05A60000000000000000
   VCID: 70B9D6E05AAA6EAB833-8024
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000221769006
03286 - Sensor for Contact with Door Handle; Front Right
            007 - Short to Ground
                    Reset counter: 111
                    Mileage: 143333 km
                    Date: 2020.11.30
                    Time: 12:06:03
                    milliliters: -1664 ml
                    Ign. Timing: 144.8 °ATDC
                    Raw, Index/Key Err.: 250 228 069
                    Temperature: 24.8°C
                    Raw, Index/Key Err.: 227 117 174
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000015929681
   Coding: 0018330000004201000001010101202020202121202020
   VCID: 34311AF06E32128BA7B-8060
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BC    HW: 7P6 907 040 BC
   Component: Klima 2 Zonen H20 1203
   Coding: 3696000E10
   VCID: 76B5E0F8384E409B59F-8022
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001276725
   Coding: 26001011D1345D010021000380005D0C431C670806010241800000020000
   VCID: 6B83C18C738C8D73B61-803E
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    111007  31  0020
   Serial number: 90243400111026040941
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10259253
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002610110041
   Subsystem 4 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA103159000000549855
   Coding: 010300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261128302692
   Coding: 518D01
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 42DD4C282406AC3B257-8016
   Part No SW: 7P6 907 561 A    HW: 7P6 907 561
   Component: ACC3          H13 0230
   Coding: 3F04010101
   ASAM Dataset: EV_AdaptCruisContrVW526 001004
   ROD: EV_AdaptCruisContrVW526_001.rod
   VCID: 3A2D34C84CD6E4FB7D7-806E
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag009 H05 0025
   Revision: --------    Serial number: 003L0000GH1F
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DF43242100B7233CD-8014
   Serial number: 3575LRB40510OPMGCG9+
   Serial number: 3585LRB40510OPMGBH1Y
   Serial number: 3515RRB405R0ODH6KG84
   Serial number: 3525RRB405R0ODH6H06R
   Serial number: 3555NRB405P0Q8K6E8S8
   Serial number: 3565NRB405P0Q8K6M8OD
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 T
   Revision: --------    Serial number: 90815KK20002L
   Coding: 000C9D
   VCID: 38292EC0725AF6EB8B3-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0097906
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 881 A    HW: 7P6 920 881 A
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658311011592031
   Coding: 131733007E080008000004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 7P0 963 272 C    HW: 7P0 963 272 C
   Component: Standheizung  H23 0241
   Revision: 56005006    Serial number: 20111004093200
   Coding: 594200
   VCID: 372B2DFC7F44F993829-8062
   Part No SW: 7P6 907 530 D    HW: 7P6 907 530
   Component: GW-CAN-L-FR-M H08 5202
   Revision: --------    Serial number: 00000000294742
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 392F2BC449D0EFE374D-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650805520
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 11300001681011200181
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000112840851
   Coding: 15210001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 3FDB45DC57F4C1D34A9-806A
0852 - Level Control System
          C10D3 F0 [009] - Manually Switched Off
                    Fault Frequency: 125
                    Reset counter: 2
                    Mileage: 168448 km
                    Date: 2070.03.11
                    Time: 02:49:01
                    Default: 00
                    Default: 83
                    Default: 00
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000016944808
   Coding: 00183B0000004201000001010101202020202121202020
03333 - Motor for Cushion Angle Adjustment
                    Fault Status: 01100101
                    Reset counter: 118
                    Mileage: 143773 km
                    Date: 2020.12.04
                    Time: 13:30:16
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH03 0110
   Revision: 00H03000    Serial number: 6PZ 010 316-01
   Coding: 0010151
   VCID: 7EA5F8D81CFE08DB01F-802A
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H01 0110
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F21.10.1100H010003C521891ÿ
   Subsystem 4 - Serial number: 521891ÿ
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000121127033
   Coding: 011D1620DE00459205080001
   VCID: 43D3492C3B9CA5332E1-8016
   Revision: 00002001    Serial number: 0160994463
   Coding: 01801E2028B91095832006242F0000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO1338489A
   Coding: 191100
   Subsystem 2 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1333606$
   Coding: 191100
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811000969803
   VCID: 75B7E7F425C84B83505-8020
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000121425811
   Coding: 011D1620DE00459205080000
   VCID: 3B2331CC436CDDF3661-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A1192900321
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 363520F878CE009B99F-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AA00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1F2D006621ACB2FB-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Part No SW: 4G0 035 061 G    HW: 4G0 035 061
   Component: Radio U DAB   H52 0097
   Revision: AB001007    Serial number: 233J.0B7504169
   Coding: 010105010000000003
   VCID: 211FE3A4C1C097235CD-8074
   Part No SW: 7P6 035 670 A    HW: 7P6 035 670 A
   Component: H-BNT-EU      H45 0318
   Revision: --------    Serial number: 478KB0B7563746
   Coding: 020100050040CBEF79102B0E00000003F0040101
   VCID: 333319EC6B3C15B3BE1-8066
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9L7800JDB
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000121388121
   Coding: 011C16200000259005080000
   VCID: 3A2D34C84C56E4FB7D7-806E
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 G    HW: 7P0 907 383 C
   Component: Anhaenger     H09 0110
   Revision: 5H001001    Serial number: 00000160272463
   Coding: 0106040000000000
   VCID: 3C2132D04662DACB6FB-8068
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D
   Component: TopView       H05 0097
   Revision: 11001001    Serial number: 82330JE0000600
   Coding: 0100000001010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
10489856 - No Basic Setting
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 111
                    Mileage: 143286 km
                    Date: 2020.11.29
                    Time: 13:32:14
                    Voltage terminal 30: 14.7 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 294100751
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D273FD45DF8D3C3585-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000121387820
   Part No SW: 7P6 907 217 A    HW: 7P6 907 217
   Component: DPC-SG        H23 0033
   Coding: E9070000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 38292EC072DAF6EB8B3-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000003024100_2360
   Part No SW: 7P6 907 541 A    HW: 7P6 907 541
   Coding: 3F04010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 001004
   ROD: EV_AdaptCruisContr2VW526_001.rod
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 A    HW: 7P6 907 107
   Component: BV-SG         H29 0031
   Serial number: 000040191209117
   Coding: 01A03E040000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 006606000317037F00033811594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F13E491A027A3CCD-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   Coding: 00660600031F037F00033811594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:25, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
Slammer
Norway
C?ID=393427
Thank you for your reply Wolfgang. It seems I've misunderstood, and that the procedure is a little different on the Touareg in that it does not require disengagement of the EPB in order to replace rear brake pads and rotors.
Right. Instead of clamping the rear disk pads like a conventional EPB, the 7P T'Reg uses a dedicated set of brake shoes for the parking brake. Pictures here:
Slammer
Norway
C?ID=393427
Brilliant! I've just completed the procedure today, with no fault codes or problems thus far. Thank you for the help.
