A3 2009 (8P) ABS Unit Partial Replacement Possible?
T-Dubs
Howdy, everyone. I have an A3 with an ailing ABS unit (dealership confirmed and wants 2400 to swap it out). Partial VIN: waukd98p99aXXXXXX I'm guessing that their fix includes both the controller module and the pump that's attached to it given the cost (about 2k for the part), plus labor. I've also seen the controller part alone for around 700-800, which is much more reasonable. I was curious if it's possible to swap just that part and if so, if it's necessary to mess with the pump at all. If the pump must be disconnected, I'm assuming I'll have to bleed the system, which is fine, I just want to avoid it if I can. Also, I've read that some VCDS mojo (I have the USB cable version) is needed after the new part is installed with steering angle sensors and other unswapped parts. Does anyone have a tutorial on that piece of the process?
Thanks in advance, all.
South Molton, UK
Without knowing the exact part number of the ABS unit fitted to your A3 it's likely to be difficult/impossible to answer that question until you past a full unedited VCDS Auto-Scan of your A3.
justjames
C?ID=330612
it depends what the fault is
ABS faults can be electrical in the controller or can mechanical in the aluminium section, or just be the pump motor its self
Dealerships are not able to replace part of the pump
Without a fault code scan to see what the codes are no one can answer your question
T-Dubs
Thanks for the replies, I appreciate it. Here's the full report.
I didn't include it initially as I was asking mainly for a yes/no on "can you only swap the module without the pump?" as that will determine if I do this myself or have the Audi dealership do it given that the cost of the pump+module assembly negates any savings a DIY job would accomplish. Also, it seems like a DIY might be difficult/impossible since when I looked for the part, the passenger-side strut tower sort of covers the unit and with a 3.2 engine, there's not a ton of room to work. Does anyone who's done this successfully care to weigh in here?
Thanks again, all.
Monday,28,December,2020,11:53:06:45168
VCDS Version: 20.12.0.1 (x64)
VIN: WAUKD98P99A032467   License Plate:
Mileage: 154770km-96169mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 37 42 44 46 52 55 56 62
          65 72 77
VIN: WAUKD98P99A032467   Mileage: 154770km-96169miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 LQ    HW: 022 906 032 GP
   Component: A3-3.2-DQ-LEV2  G   2570
   Revision: 1QH02---    Serial number: AUX7Z0H7FND0RX
   Coding: 0000178
   Shop #: WSC 06314 000 00000
   VCID: 65EF6911ACD1B6AC91-8030
006481 - Radiator Fan 2 (V177)
               P1951 - 002 - Movement Restricted / Jammed - Intermittent
                    Mileage: 152970 km
                    Date: 2020.07.02
                    Time: 10:37:58
                    RPM: 1757 /min
                    Load: 95.3 %
                    Speed: 22.0 km/h
                    Temperature: 91.0∞C
                    Temperature: 69.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
   Part No SW: 02E 300 011 CP    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1814
   Revision: 04843012    Serial number: 00000807240662
   VCID: 5FE37BF98E8DEC7C5B-800A
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 14426012492500FC280F06EA92200041B900
   Shop #: WSC 44575 001 1048576
   VCID: 77D33359C67D343C33-8022
16352 - Control Module - Electrical Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 42
                    Mileage: 154571 km
                    Date: 2020.10.16
                    Time: 04:19:17
                    Count: 32768
                    Count: 4608
                    Count: 96
                    Count: 51527
   Part No SW: 8P0 820 043 BH    HW: 8P0 820 043 BH
   Component: KlimavollautomatH09 0100
   Revision: 000430      Serial number: 8P0820043BH
   VCID: 73CB07491205581C0F-8026
00716 - Air recirculation Flap Positioning Motor (V113)
                    Fault Status: 00100011
                    Fault Frequency: 114
                    Reset counter: 72
                    Mileage: 149663 km
                    Date: 2019.02.05
                    Time: 11:04:29
                    Voltage: 9.20 V
                    Temperature: 24.0∞C
                    (no units): 135.0
                    (no units): 166.0
                    Temperature: 7.5∞C
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 P    HW: 8P0 907 279 P
   Component: Bordnetz-SG     H54 2903
   Revision: 00H54000    Serial number: 00000008726079
   Coding: F18C1F81C0141380EF00000A0080000000284E0564164003643000000000
   Shop #: WSC 06314 000 08192
   VCID: 4AB5BAAD250F79D49C-801E
   Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
   Coding: 00150573
   Shop #: WSC 06314
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0377716
   Coding: 0000100
   VCID: 334BC7495285181CCF-8066
                    Reset counter: 185
                    Mileage: 151748 km
                    Date: 2019.09.10
                    Time: 20:44:47
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 K    HW: 8P0 959 655 K
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142393041303030364A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4AB5BAADED0F79D49C-801E
   Subsystem 1 - Part No SW: 8P0 910 339 C    HW: 8P0 959 339 C
   Component: BF-Gewichtss.  H02  0030
   Serial number: 5810000R0000002VU8
   Serial number: 3572DRB400007DE0F25%
   Serial number: 3582DRB400007DE0B90+
   Serial number: 35128RB400003FD42A5R
   Serial number: 35228RB400003F47E95X
   Serial number: 35547RB400003F95260K
   Serial number: 35647RB400003F951B1Q
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0014142
   VCID: 41A79D811839BA8C4D-8014
   Component: E0221           H02 0030
01301 - Control Module for Voice Recognition (J507)
   Part No SW: 8P0 920 982 G    HW: 8P0 920 982 G
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 2247H006001191
   Coding: 0017288
   Shop #: WSC 00776 002 1048576
   VCID: 3D5FE17164C1DE6C29-8068
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K088090AD5
   Coding: ED837F074007022102
   VCID: 354FF9515CF1062CE1-8060
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43AB97890225A89C5F-8016
   Revision: D0H18006    Serial number: AUX7Z0H7FND0RX
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 193 A    HW: 8P0 035 193 A
   Component: RNS-E US        H77 0260
   Revision:      04S    Serial number: AUZBZ7H4200340
   Coding: 0209677
   Shop #: WSC 08307 444 68373
   VCID: 2E7DD63DB9A735F4A0-807A
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0001213
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   Shop #: WSC 08307 444 83898
   VCID: 2F43CB39BEAD3CFCAB-807A
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 K
   Component:    KSG          H11 0080
   Coding: 1B80228001382D090F0FCC8F0477
   VCID: 44A99495072BAFA466-8010
00956 - Key 2
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0001213
   Part No: 8P0 907 357 J
   Component: Dynamische LWR  H01 0020
   Coding: 0000013
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0209677
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
   Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
   Component: J502-RDK        H03 0370
   Revision: --H03-H0    Serial number: 13137786001013
   Coding: 0860022
   Shop #: WSC 06435 000 00000
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0001176
   VCID: 42A5928D1D3FA19454-8016
   Part No SW: 8P0 862 335 P    HW: 8P0 862 335 P
   Component: FSE_256x BT     H34 0520
   Revision: 00000000    Serial number: 00000005005756
   Coding: 0011477
End-------------------------(Elapsed Time: 01:58)--------------------------
