GLIRob
Hi all... so my car faults in Drive mode with faults:
17178 - Implausible Data Received from ESP Control Module
U0416 00 [040] - -
Intermittent
013
Any thoughts ?? I’m going nuts here for 2weeks now.
My findings with the ESP in sport mode not ECS OFF completely:
-Drive mode in 3.5miles, it faulted again after clearing them.
-Sport mode, cleared faults and after 10miles of driving never faulted once.
U0416 00 [040] - -
Intermittent
013
Monday,07,December,2020,20:34:25:21683
VCDS Version: 20.4.2.0 (x64)
VIN: 3VW4T7AJXGM236099 License Plate: ROB 12-7-20
Address 01: Engine Labels: 06K-907-425-V2.clb
Control Module Part Number: 06K 906 071 AT HW: 06K 907 425 C
Component and/or Version: R4 Stg2 TFS H13 4876
Software Coding: 001D0012242400171000
Work Shop Code: WSC 00066 000 00293
ASAM Dataset: EV_ECM20TFS02006K906071AT 001005 (VW36)
ROD: EV_ECM20TFS02006K906071AT.rod
VCID: 7DF1F6C0ECA5DD6E78-8028
U0416 00 [040] - -
Mileage: 37889 km
Date: 2059.14.24
Time: 16:23:46
Engine speed: 1667.75 /min
Normed load value: 45.9 %
Vehicle speed: 60 km/h
Coolant temperature: 86 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.238 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
Monday,07,December,2020,20:35:59:21683
VIN: License Plate: ROB ABS 12-07-20
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 CB HW: 1K0 907 379 CB
Component and/or Version: ESP MK60EC1 H46 0174
Software Coding: A14B600C49250000850B06ED922200412018F06A
Work Shop Code: WSC 00066 000 00000
VCID: 74E7D3E4D7EF9C2607-8020
Fault Status: 00101101
Reset counter: 41
Mileage: 37889 km
Date: 2059.14.24
Time: 16:23:46
Count: 24
Count: 32768
Count: 4608
Count: 8196
Count: 51259
Count: 1
Count: 258
