Hi,
sometimes VCDS freezes up when you try to connect to a control module. All of the buttons (e.g. reading fault codes, coding, adaption etc) are greyed out (can not push them), and when you hit «close controller» (or, if you are running an auto scan, hit «ESC - to cancel auto scan» (or whatever the button says), the software freezes up, and you get the message «not responding» on the title line.
This has ONLY happened when I connect to my HEX-NET interface by wifi (AP mode). I have never experienced this bug when I use the USB cable (but, I have not used the USB nearly as much as I have used the wifi).
Today I was trying to do an autoscan, and it failed twice (I have never had two fails after each other before). The first time it was stuck on module 09. The second it was module 46. The third time I used the USB cable
But as I said, I have also experienced this bug when I am trying to connect to one module (e.g. 01-engine). I then hit "close controller". The software freezes up (the message "not responding" is shown on the title line, corresponding to the norwegian "Svarer ikke" which you can see on the picture), and after 10-15 sec (my guess) you get back to the «select module» screen.
Is this a known bug ? If you need me to do some «debugging» stuff with my equipment, please let me know. I will be more than happy to assist.
