Diagnosing possible optical issue (2017 Golf R)
yeahforbes
HN1-2H
Does the 2017 Golf R (USA spec) have an optical MOST bus? I have a DTC in address 5F that mentions "Optical Data Bus" which led me to try doing this https://www.ross-tech.com/vcds/tour/optical-bus.php but I receive the attached error message when doing so (same exact error regardless of 3dB option): "The vehicle either does not support this function, or there was an error during the test."
Auto-scan:
Monday,07,December,2020,13:58:15:19087
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.12.0.1 (x64)  HEX-NET CB: 0.4529.4
VIN: x   License Plate:
Mileage: 59602km-37034mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 75 A5 A9
VIN: x   Mileage: 59602km-37034miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CYFB)       Labels: None
   Part No SW: 8V0 9C0 BB0 1    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00122466000E3004
   ASAM Dataset: EV_ECM20TFS0208V09C0BB01 001002
   ROD: EV_ECM20TFS0208V09C0BB01.rod
   VCID: CFEE2D52969723FC4B-809B
Readiness: 1110 0101
   Part No SW: 0D9 300 014 Q    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5006
   Revision: 06454104    Serial number: TFK01611171596
   ROD: EV_TCMDQ250021.rod
   VCID: A600A8F6D9AD02B4D8-80F3
          P1734 00 [002] - -
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 63426000000482
   Coding: 01FA6BA154260973457D030540C76980D62A90A2C0029637184050D8C2A8430000000012121212B835351919323200
   VCID: F9BAB38A78935D4CC5-80AD
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0425484538
   Coding: 032C0C
   VCID: BB366982322FAF5C97-80EF
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000010500401211140A
   VCID: ED9297DA3CDBF1EC59-80B9
   Air quality sensor:
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061633500203
   Coding: 00011B46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 8444D27E0F5110A4A6-80D1
   Component: WWS    161111  043 0551
   Serial number:         161130202128
   Component: RLHS  042 0105
   Serial number: S5Y16M12D12H17M56S45
   Coding: 00A8DD
   Revision: --------    Serial number: 39331634803055
   Coding: 0071155011
   VCID: C3C611624ADFD79CDF-8097
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 350040C151FFC428949C810530301600000000000000000000
   VCID: BC346A9E3721A8649E-80E9
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 17
                    Mileage: 58695 km
                    Date: 2020.11.10
                    Time: 15:31:57
                    Control Module temperature: 36 ∞C
                    Voltage terminal 15: 13.8 V
                    Velocity_vehicle_reference: 3.31 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.82 m/s≤
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 16
                    Mileage: 59424 km
                    Date: 2020.12.05
                    Time: 14:01:58
                    Control Module temperature: 23 ∞C
                    Voltage terminal 15: 14.3 V
                    Velocity_vehicle_reference: 0.23 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.70 m/s≤
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Fault Frequency: 9
                    Reset counter: 17
                    Mileage: 59169 km
                    Date: 2020.11.28
                    Time: 16:09:25
                    Control Module temperature: 16 ∞C
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Fault Frequency: 11
                    Reset counter: 17
                    Mileage: 59169 km
                    Date: 2020.11.28
                    Time: 16:09:25
                    Voltage terminal 15: 14.2 V
   Serial number: 12111641350945
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: B83C768E031984447A-80ED
   Serial number: 003GCR06MS0S
   VCID: C7DE05727EE7FBBC03-8093
   Serial number: IBH0000000000066LC38
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 000 812 16
   Serial number: 35700000000C702D9E1U
   Subsystem 3 - Part No SW: -----------    HW: 480 000 712 16
   Serial number: 35800000000986DCFF19
   Subsystem 4 - Part No SW: -----------    HW: 480 400 912 16
   Serial number: 3510001A5234EB14428Z
   Subsystem 5 - Part No SW: -----------    HW: 480 400 912 16
   Serial number: 3520001A1230E744975Y
   Subsystem 6 - Part No SW: -----------    HW: 480 400 712 16
   Serial number: 3550001A7230E745739%
   Subsystem 7 - Part No SW: -----------    HW: 480 400 712 16
   Component: FrontSensor_P  000 6149
   Serial number: 3560001A7230E74472D2
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 06121604221682
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 895AC34A28734DCCD5-80DD
   Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
   Component: KOMBI         304 8311
   Coding: 03AD081A7F88CF0502887F0B5400000000000000
   VCID: AF2E4DD2F65743FC2B-80FB
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005668972
   Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: FCB4AA9E77A16864DE-80A9
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29160001990120016424
   Coding: 35FFFF
   Serial number: HA1-00018.11.16
   Coding: 0001
   VCID: CAD83C466DF506D41C-809F
   Revision: 00000000    Serial number: 16000212828010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: B42442BE1F71602456-80E1
   Serial number: 0422735008
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Serial number: 0423359837
   Coding: 020111
   Serial number: 251116EKO34972
   Coding: 003E13208000040000000000
   Serial number: 00000000000012646542
   Coding: 111000
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: BA386C863D1596548C-80EF
Address 47: Sound System
   Serial number: 131116EKC51192
   Coding: 003E13208C00040000800000
   VCID: C2C8146655C5DE94D4-8097
   Serial number: 00000000000012565890
   Coding: 091000
   Coding: 022202000B000400
   VCID: C0CC1E6E5BC9CC84C2-8095
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0751
   Coding: 027300020000000051220002001808009F0307F401200105C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: B22844A6E5656E1444-80E7
   Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
2562 - Navigation System
          B126C F0 [008] - Navigation Database Faulty
                    Reset counter: 17
                    Mileage: 59481 km
                    Date: 2020.12.05
                    Time: 17:54:15
                    Voltage terminal 30: 12.7 V
          B11CF 53 [009] - Deactivated
                    Reset counter: 214
                    Mileage: 48945 km
                    Date: 2020.04.11
                    Time: 13:09:18
                    Voltage terminal 30: 12.0 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 136 mA
                    SDARS_tuner_status_2-Reception quality: weak_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
6669 - Optical Data Bus for Digital Sound System
          U10CC 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in sound]
                    Reset counter: 17
                    Mileage: 59438 km
                    Date: 2020.12.05
                    Time: 16:06:36
                    Voltage terminal 30: 14.4 V
                    System_Temperature_Sensor_6-max.value: -50 ∞C
                    System_Temperature_Sensor_6-min.value: -16 ∞C
                    System_Temperature_Sensor_6-Up-to-date: 39 ∞C
6678 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Control module for sound system: no communication]
                    Fault Frequency: 8
                    Reset counter: 232
                    Mileage: 59411 km
                    Date: 2020.12.05
                    Time: 13:45:37
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Serial number: 12121612K23013
   Coding: 0003070000000205002213548046890084000E100020
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 16
                    Mileage: 59416 km
                    Date: 2020.12.05
                    Time: 13:52:44
                    Control Module temperature: 30 ∞C
                    Outside temperature: 8.5 ∞C
                    Vehicle speed: 62.95 km/h
                    System run time: 955.1 s
                    Voltage terminal 15: 14.4 V
                    mid: 01 F8
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 161121201396
End----(Elapsed Time: 02:09, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Depending on how it's equipped, it might, but it's not of the level of complexity as the traditional MMI optical bus.
Assuming this car actually has a separate sound-system amp, I would look at why it's off-line. Check fuses and power to it first and foremost.
yeahforbes
HN1-2H
Thanks. Actually, address 47 not being reachable is intermittent, therefore it's not a fuse but I suppose it could be wiring. However, I have strong reasons to believe that it's software-related rather than intermittent due to vibration/etc., because the entire infotainment system freezes every 8 minutes or so. I'm slightly out of warranty so I'm in talks with VW about a goodwill repair but trying to self-diagnose as much as possible in parallel.
When it freezes, music stops, the screen turns off, and no buttons do anything except holding down the infotainment power button for some 15 seconds, which brings it back to life for another 8 minutes.
Address 47 not being reachable occurs only when the system is actually frozen. The other codes in address 5F persist.
@yeahforbes : For obvious reasons related in the main to my residency on a far away continent in the very deep south - I'm not qualified to answer your first question!! :D
However, it does appear from the value of the long-code string on the hex5F module in your auto-scan that the MIB in your car has MOST activated and based on the software switches on this module, the MIB expects that an external amplifier (which the WD calls "J525") will manage audio.
Notwithstanding the intermittent nature of the hex47 DTC, IMO it's still worth checking the fuse to J525 to ensure that it's seated correctly. According to my WD (which unfortunately is RoW), J525 is the only device protected by the fuse, so a wonky fuse will only affect the external amplifier.
The other "easy try" might be to check the physical environment for J525 for stuff like water ingress and also check the integrity of the connector on the rear of the module - which is located under the driver seat like this:
yeahforbes
HN1-2H
@DV52 Thanks for the tips! By any chance do you mean J525 each time you say J585? I ask because I've just checked a few fuse diagrams and none of them mention J585, but they do mention J525 (as does your under-driver-seat diagram) being at fuse position 27.
yeahforbes
HN1-2H
I looked under the seat and found the optical connection (photo attached). Definitely no water or similar peril. I re-seated the optical, and wanted to re-seat the wiring harness, but I can't figure out that ridiculous pink clip :banghead:
I also checked the fuse, and to be 100% certain, I swapped it with another identical fuse.
I then went for a drive. The problem was the same as before, with the screen and sound shutting off (actually, mostly rebooting on its own, but not always) at roughly 8 minute intervals. Sometimes 4 minutes, sometimes 13 minutes, etc.
I should also mention that this all started back in March, but then in early April it went back to normal until a few days ago when it started happening again.
George Ab
C?ID=232965
The pink clip has a keep on the end. If I recall correctly you push the keep down and then the pink lever can be pulled which releases the connector evenly. Being familiar with that clip as I have replaced that unit as part of an upgrade, it is a stout quality connector and IMO the probablility of a bad connection in that connector approaches zero. Based on the symptoms of the rebooting it sounds like the 5F infotainment unit (glovebox headunit) has gone. Interesting your scan shows the 47 soundsystem cannot be reached (amp under seat). Sorry, cannot be 100% sure if that could be related to the head unit. If it is the headunit, I would buy a used unit of same part number and replace. You will need a VAS5054 with OKI chip set and D-Link Dub E100 Network Adapter, there are a few folks on the MK7 Golf forum who rent out or you can purchase. Mine is currently rented. Someone with ODIS account and knowledge can remove component protection remotely with VAS5054 and then reinstall your functional enablement codes (FeC) applicable to your VIN. So for approximately $200 for used head unit (salvage yard or eBay). Rental is usually around $30, and the guy I use is 85Euro/hour when everything is working and it would likely be done in under an hour.
darkchina811
ITALY
C?ID=333184
I also vouch for a defective 5F unit. as Geoge said, if you replace it with the VERY SAME part number, and you have the tools, you'll be back on track very soon.
I agree with the 5F suggestions but if the OP doesn't mind driving without any sound just to see if the screen / system still goes down he could install a loop tool at the amp. I'm just not sure if the old/standard Audi loop is the same tool or not. This was the Audi part number:
I would need the VIN to dig deeper and check PL24.​
Either way, the loop test may help confirm if the failure is at 47 or 5F before purchasing a control module. If it still crashes with 47 looped you know 5F is the bad guy.
yeahforbes
HN1-2H
To clarify, the autoscan only shows that "47 cannot be reached" if I wait for the MIB to freeze (~8 minutes) and autoscan while it is frozen. If I autoscan while the MIB is operational (for example, right after key-on, or right after holding the MIB power button to reset it), then 47 can be reached just fine, and it never has any DTCs. But I can read the DTCs in 5F any time, regardless of whether it's frozen.
As for junkyard/ebay/ODIS/VAS5054/etc, that is what I will explore if VWoA declines my goodwill request.
That is exactly where my head was at in creating this thread, based on what I was trying to learn from https://www.ross-tech.com/vcds/tour/optical-bus.php and the accompanying video (which is very well-done, I must say). But then I ran into the error message (see attachment of first post) so if anyone can help me understand that message, I would appreciate it! Also, do you think I can cheap out on the loop like this? I just ordered and it'll be here Monday... can return if it doesn't match.
My bad - yes I did mean J525 (I will fix my boo-boo so as not to confuse others)
I would give that Amazon thing a shot! Worst case it doesn't work and you return it -or- toss it in the tool box and use it on a car it does work on one day in the future.
In regards to the screen shot, the MK7 doesn't use a traditional MMI optical bus system like an Audi where the 19-CAN Gateway is the ringleader. Instead, you have a master 5F and a slave 47 (when applicable/installed) and 19 is not involved (which is why VCDS can't ping 19 for the data). For instance my prior Alltrack (code name WaterTrack) had 47 installed and the MOST bus was literally a point A to B connection (rather than a real loop with 3 - 9 control modules):
Neither of my current Mk7s have 47 sound system so that's a wiring diag clip from based on the 2017 VIN in the above scan. I suspect yours would be similar, if not identical, due to the MIB2 2017 NAR config.
George Ab
C?ID=232965
You could also code out the external amplifier. If 5F goes into reboot after coding out and reboot, head unit problem is not related to external amplifier.
5F control module, Long coding, Byte 4-7, 2 channel 4 passive speakers, then go to Byte 11 and change to internal sound system (from external). Byte 19 Most Off (from On), Reboot, then see if 5f has reboot problem.
You may ask dealer for software update as that too could resolve your issue. Just a thought, separate from one above.
PS: Did not intend to be the bearer of bad news on replacement of your head unit, and mentioned alternative used replacement as an options to a $1,300 new head unit and couple hours of shop time from dealer. Also, I do feel your pain. I recently had to replace my head unit as it would intermittently turn on randomly turning on external amplifier draining my battery. No parasitic leakage just total random turn on once every few days or so. Maddening to troubleshoot. Took a year of disconnecting battery after drives until I happened to be in car when head unit turned on. Put in switch inline with fuse to infotainment to verify that it was the head unit. Turned switch off after use and no battery drain for a month. Software upgrade may have resolved, but I was so sick of the problem I changed head unit.
@Dana: I assume that your comment about the ring-circuit-break-wire topology relates more to MQB platform vehicles, rather than to the distinction between Mk7 and Audi vehicles. The arrangement in the WD for my Audi A3 8V (see below) confirms that J533 is not part of the physical wire circuit for the MOST diagnostic function.
However, page 26 0f SSP 519 (The Infotainment System in the Golf 2013 Part II) which describes the MOST system on MQB golf mk7 says the following:
Diagnostics and working on the MOST150 data bus
The procedure for ring circuit break diagnostics is primarily the same as for the check plan for the Touareg 2011.
One difference with the Golf 2013 is that, due to the faster transmission and reception units, it is necessary to use
a modified tool: the optical replacement control unit VAS 6778.
Now, Page 24 of SSP 473 ( Infotainment in the Touareg 2011) which describes the service arrangement for MOST on the PL71 platform car shows "a traditional MMI optical bus system" topology for the ring-circuit-break-wires (i.e. where J533 is the master).
So, notwithstanding the different role of J794 as the master for ring-circuit-break detection on MQB platform cars, I wonder for the purposes of user diagnosis whether J533 is still involved? Perhaps the fault records are transferred via CAN messages to the hex19 module for this purpose - I'm not sure?
yeahforbes
HN1-2H
I just went to try this, but I'm holding off for now because the coding options aren't completely aligned with your suggestion, although bytes 11 and 19 are much more aligned if I use the experimental long coding helper. Photos attached.
George Ab
C?ID=232965
Pardon, understand they are not completely aligned, but the idea is to use the internal amp in your headunit which will put power to pins connected to nothing rather then having the signal sent via fiber optic to your external amplifier.
Copy your current coding settings and save. You will put them back once you have completed this test to verify failure of 5F in unrelated to 47 soundsystem. I have RossTech micro can so I am not sure if I can get to experimental settings. How do you toggle to experimental long coding helper?
I just checked my settings, and compared to your screen shots. I had the Fender, but removed for external amplifier and DSP.
From your screen shots:
Byte 4 in standard mode from “sound system installed” to “4 channels 8 passive speakers” (any choice but sound system installed).
Byte 11 in standard mode to “internal sound system active”
Byte 19, bit 5 in experimental mode: uncheck “Most On” I just checked my byte 19 and I did not have the bit 5 option.
Reboot. Test the unit, it will not make any sound, but if it reboots after a few minutes you should know the headunit is not being effected by soundsystem and is the problem. From there you can put back your original coding. If it doesn't reboot, then it may be related to external amplifier.
yeahforbes
HN1-2H
Thanks for the clarification. I just made the coding changes, and it continues to freeze in the exact same manner.
I can also do the optical bypass loop test when I receive that part on Monday, but if I understand properly, that will be redundant to this, right?
George Ab
C?ID=232965
Yes, redundant. You have isolated problem, congrats. Now you can move forward on getting it fixed.
@DV52 Yeah, I was referring to the early (old school) Audi models from the D3 through the MLB based platform which used the 4E0 973 802 loop referenced on the manual page and briefly in video the OP was referring to.
Prior to this thread I had not received a MQB/Mk7 based optical bus diagnostics inquiry to date so I'm not entirely familiar with the diagnostic either. Due to the high failure rate of those 5F units I suspect many are failing within warranty which is why we may not be receiving many troubleshooting inquiries. If that's the case it will be a matter of time however @George Ab's entirely different, and far more simple, approach to just code it out is probably the best way to go since this was a small (2 module) loop!
I took a look at that fancy VAS6778 tool you referenced and it was not only eye opening from an education point of view (I should refresh myself on those SSPs) but look at the list price :eek:
If this type of J794 unit supports a ring break diag directly we may be able to implement that into VCDS one day but I don't know how difficult the results will be to interpret.
For instance, it looks like most are Adapted to IDE03902-Automatic ring break diagnostic,No automatic start and Basic Settings [*IDE01857-ENG114972*] Start ring break diagnostic - Routine Control Option may be supported even without an ADP change but at that point would a user then interpret Adv MVBs like these
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1
IDE01868-MAS00844,Ring break diagnostic result-Radio
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module
while that Basic Settings is running? Hmm.
