2009 Volkswagen Jetta Problems
dantev03
Maryland, USA
C?ID=419176
Hello everyone, I have a major issue with my 2009 Volkswagen Jetta Wolfsburg edition. When I purchased the car, the EPC light was on and the power steering light were on. They come on occasionally. It doesn't matter what speed. It seems like the issue is worse at lower speed city driving but the lights still come on when I'm highway driving. When these lights come on, I loose the speedometer and cruise control stops functioning. I checked to see if my car was part of the ABS module recall and it appears that it isn't. When the EPC light and the steering light come on, the gas gauge goes into a "floating state" and it moves depending on the pitch of the car, so even if I have half a tank, it will register as empty and the fuel light will come on momentarily. On a side note, the windshield wipers only come on when the car is moving and the washer pump never works even though I can command it on using VCDS. My guess is that it is related to the hood latch. I also have no blinker acoustics. The main problem is the EPC and power steering light. They do go away on their own sometimes or after I restart the car for a little bit. Here is the scan data, and anything relating supply voltage is probably because I left my headlights on and the battery died.
Saturday,05,December,2020,21:24:56:03955
VCDS Version: 20.12.0.0  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: 3VWRJ71K09M044004   License Plate:
Mileage: 272050km-169044mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRJ71K09M044004   Mileage: 272050km-169044miles
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH17---    Serial number: VWX7Z0H724U0Z5
   Coding: 0403010A18070160
   Shop #: WSC 09130 444 100827
   VCID: 698FB96305791573C4D-803C
   Subsystem 1 - Part No: 1K0 907 115 AE
No Faults Found
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 113B600D492600FE880B06E4921D00413000
   Shop #: WSC 65178 001 1048576
   VCID: 76B5E21F48C7CA8B59F-8022
7 Faults Found:
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 223
                    Mileage: 271102 km
                    Count: 2
                    Count: 4608
                    Count: 125
                    Count: 48142
                    Count: 1289
                    Reset counter: 14
                    Mileage: 271188 km
                    Count: 7
                    Count: 3
                    Count: 12288
                    Count: 128
                    Count: 30208
02781 - ASR/ESP Button (E256)
                    Reset counter: 14
                    Mileage: 271188 km
                    Count: 7
                    Count: 3
                    Count: 12288
                    Count: 156
                    Count: 29440
                    Fault Frequency: 15
                    Reset counter: 23
                    Mileage: 271136 km
                    Count: 7
                    Count: 32768
                    Count: 4608
                    Count: 49
                    Count: 49711
                    Count: 254
                    Fault Frequency: 27
                    Reset counter: 238
                    Mileage: 271102 km
                    Count: 2
                    Count: 12800
                    Count: 8213
                    Count: 49408
                    Reset counter: 236
                    Mileage: 271102 km
                    Count: 2
                    Count: 8704
                    Count: 166
                    Count: 49152
01312 - Powertrain Data Bus
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 26
                    Reset counter: 238
                    Mileage: 271102 km
                    Count: 2
                    Count: 2
                    Count: 8704
                    Count: 161
                    Count: 49408
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CA1F0377AEB90DB2FB-8028
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001061404
   Coding: 04058E234004150007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 000 00000
   VCID: 323D1E0FE82F96ABB57-8066
   Component: Wischer 020908 021  0501
   Coding: 00038805
   Shop #: WSC 00066
8 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 14
                    Mileage: 271188 km
                    Voltage: 11.20 V
                    Reset counter: 14
                    Mileage: 271188 km
                    Voltage: 11.20 V
                    Reset counter: 14
                    Mileage: 271188 km
                    Voltage: 8.85 V
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00111010
                    Reset counter: 14
                    Mileage: 271089 km
                    Voltage: 13.45 V
                    Reset counter: 14
                    Mileage: 271089 km
                    Voltage: 13.45 V
                    Reset counter: 14
                    Mileage: 271188 km
                    Voltage: 7.60 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 14
                    Mileage: 271188 km
                    Voltage: 9.25 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 14
                    Mileage: 271188 km
                    Voltage: 9.25 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0404057
   Coding: 0000100
   VCID: 33331B0B17359FA3BE1-8066
                    Reset counter: 14
                    Mileage: 271188 km
                    Time: 23:03:47
                    Voltage: 8.40 V
                    Reset counter: 14
                    Mileage: 271188 km
                    Time: 23:03:39
                    Voltage: 8.40 V
                    Reset counter: 222
                    Mileage: 271089 km
                    Time: 00:40:55
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M06L2M7
   Coding: 0013889
   VCID: 6C81C0770A8B005BBFB-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3753362DD
   Subsystem 3 - Serial number: 6342MSME38760D6FU
   Subsystem 4 - Serial number: 6351HSME17194125/
   Subsystem 5 - Serial number: 6361HSME174A5B48I
   Subsystem 6 - Serial number: 63727SME173C5D5EK
   Subsystem 7 - Serial number: 63827SME17476B01+
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0000021
   VCID: 03538BCB0715EF236E1-8056
   Part No SW: 1K0 920 954 R    HW: 1K0 920 954 R
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H724U0Z5
   Coding: 0023203
   VCID: 3B23332B3F6557E3661-806E
                    Fault Frequency: 214
                    Reset counter: 23
                    Mileage: 271089 km
                    Time: 01:05:17
                    Reset counter: 14
                    Mileage: 271188 km
                    Time: 23:06:27
                    Reset counter: 14
                    Mileage: 271188 km
                    Time: 23:07:23
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 090708F2002568
   Coding: E9807F070003021002
   VCID: 3537251319418193905-8060
   Subsystem 1 - Part No: 1K0 907 530 Q
No Faults Found
   Component: IMMO            3HL 1222
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000789088816
   Coding: 0001205
   VCID: 6FBBD77B3B9DFB439A9-803A
   Subsystem 1 - Part No: 1K0 959 701 AC
No Faults Found
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D066FC0FFDE6B0D7-807E
                    Fault Frequency: 111
                    Reset counter: 33
                    Mileage: 272056 km
                    Time: 09:21:20
                    Voltage: 13.63 V
                        DU
                    Temperature: 28.0°C
                    RPM: 762 /min
                    Fault Status: 00101101
                    Fault Frequency: 16
                    Reset counter: 33
                    Mileage: 271852 km
                    Time: 06:39:45
                    Voltage: 14.00 V
                        DU
                    Temperature: 20.0°C
                    RPM: 2458 /min
                    Speed: 101.0 km/h
                    Speed: 101.0 km/h
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 13900F880186083F0904058FB0880F0488DCA0
   Shop #: WSC 00066 123 12345
   VCID: 045188D7021BE81B57B-8050
   Subsystem 1 - Part No: 1K0 959 433 CT
   Subsystem 2 - Component:   Sounder n.mounted
   Subsystem 3 - Component:       NGS n.mounted
   Subsystem 4 - Component:      IRUE n.mounted
No Faults Found
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08073102471002
   Coding: 0001204
   VCID: 70B9D40726A3E4BB833-8024
                    Reset counter: 14
                    Mileage: 271188 km
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio ZSW       019 0035
   Revision: 00019000    Serial number: VWZ5Z7H6080280
   Coding: 0040401
   VCID: 290FF963C5F9D57304D-807C
                    Reset counter: 13
                    Mileage: 271188 km
                    Time: 22:57:41
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003424891
   Coding: 0001168
   VCID: 76B5E21F44C7CA8B59F-8022
01813 - Supply Voltage for Door Controller; Rear Left (J388)
                    Reset counter: 14
                    Mileage: 271188 km
   Coding: 0100101
                    Reset counter: 232
                    Mileage: 271206 km
                    Time: 07:43:54
00625 - Vehicle Speed Signal
                    Fault Frequency: 119
                    Reset counter: 23
                    Mileage: 272056 km
                    Time: 09:21:24
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003406787
   Coding: 0001168
   VCID: 77ABEF1B43CDB383429-8022
01814 - Supply Voltage for Door Controller; Rear Right (J389)
                    Reset counter: 14
                    Mileage: 271188 km
End----------(Elapsed Time: 03:03, VBatt start/end: 13.7V/13.7V)-----------
One might think your ABS controller is in the process of failing, but... This shouldn't affect the fuel gauge. Maybe a poor connection to power or ground somewhere?
Anyway, the signal-to-noise ratio in that scan is pretty poor. Please clear all fault codes. Drive the car until the problem recurs, then scan it immediately to see what faults actually come up as a result.
Gone But Not Forgotten
Has TSB or campaign recall/service action been performed as per NHTSA TSB for TV harness yet or observed?
Good visual inspection performed with wiggle test for chafe points?
[/URL]
RTFB.... JPPSG
dantev03
Maryland, USA
C?ID=419176
Ok, so I cleared all the DTC's and directly after, the lights came on. I scanned it again and here is what I got. Definitely looks like the ABS module.
Sunday,06,December,2020,11:25:55:03955
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 272056 km
                    Time: 23:20:56
                    RPM: 750 /min
                    Load: 22.0 %
                    Temperature: 56.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
Readiness: 0110 0101
   Revision: 00H35001
                    Reset counter: 238
                    Mileage: 272056 km
                    Count: 2
                    Count: 12800
                    Count: 8213
                    Count: 50176
                    Reset counter: 238
                    Mileage: 272056 km
                    Count: 2
                    Count: 8704
                    Count: 166
                    Count: 50176
            014 - Defective
                    Reset counter: 238
                    Mileage: 272056 km
                    Count: 2
                    Count: 2
                    Count: 8704
                    Count: 161
                    Count: 50432
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 0000100
                    Reset counter: 238
                    Mileage: 272056 km
                    Time: 23:20:06
   Coding: 0013889
   Coding: 0000021
   Coding: 0023203
                    Reset counter: 23
                    Mileage: 272056 km
                    Time: 23:20:56
                    Reset counter: 22
                    Mileage: 272056 km
                    Time: 23:20:57
   Coding: 0001205
   Revision: 00H15000
                    Fault Status: 11100100
                    Reset counter: 238
                    Mileage: 272056 km
                    Time: 23:23:31
                    Voltage: 13.88 V
                        DU
                    Temperature: 14.0°C
                    RPM: 768 /min
   Coding: 0001204
   Coding: 0040401
   Coding: 0001168
   Coding: 0100101
                    Reset counter: 238
                    Mileage: 272056 km
                    Time: 23:20:51
                    Reset counter: 238
                    Mileage: 272056 km
                    Time: 23:24:04
   Coding: 0001168
End----------(Elapsed Time: 01:24, VBatt start/end: 13.9V/13.9V)-----------
dantev03
Maryland, USA
C?ID=419176
Alright. I cleared all the codes and did a scan of the ones that came back.
Check all power and ground connections, including relevant fuses and connections in for the fuses for the ABS module before condemning it.
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD <<<<<<<<<<<<<<<<<<<<<<<< PSSST OVER HERE!
Revision: 00H35001
Since a software update was done already allegedly, should not this be reported to NHTSA due to sounding so MUCH more widespread than the actual recall covers?
For Marin......
dantev03
Maryland, USA
C?ID=419176
I went over all the fuses and it checked out okay. What wires should I test to make sure it is definitely the control module? I just want to make sure that it is definitely the control module before I buy one. Any wiring diagrams or test procedures?
Bruce
Near Philadelphia, PA, USA
You can have access to all the info you need including the wiring diagrams for something like $35 at the erWin websites:
Official Factory Repair Information
The pages there are in pdf format so bring along a large jump drive and download all the details so you have them for the future.
Fredrick Awuor
Kenya
C?ID=309834
ABS/ESP control is most probably the cause of most of your problems here, for some reason, a failing MK60EC1 ABS/ESP control does interfere with cluster fuel gage display,get another one according to your VIN,fit and keep us posted
dantev03
Maryland, USA
C?ID=419176
I found one on ebay that has the same hardware number brand new for 310$. Would it work? Dealership wants 700$ for it. No way thats happening.
dantev03
Maryland, USA
C?ID=419176
Okay. So I found one with the same hardware and software number. That one should work?
Assuming it's the correct part for the car, yes.
Hardware number is not what determines if it's the correct module. Software number determines that.
Nein sir hardware does indeed matter and some hardware will cause a rejection of software that is not acceptable in some, however, not all cases.
Both should always be considered to be in sync or researched if compatible in a project.
dantev03
Maryland, USA
C?ID=419176
Alright, so I got the new module installed and good news, it accepted the long coding. I then followed the MK60EC1 abs module coding video by ross tech. Is there anything else I need to do?
If the module is happy, there are no fault codes, and the ABS works as expected (test it on a slippery surface!) then you should be good-to-go, but please post a follow-up scan.
dantev03
Maryland, USA
C?ID=419176
Alright, well for some reason, it's saying that the module is not coded. Here is the autoscan followed by the ABS module DTC'S after I cleared all the codes. I also noticed that when I hit the ESP button, nothing happens.
Saturday,19,December,2020,12:52:01:03955
Mileage: 273110km-169702mi   Repair Order:
VIN: 3VWRJ71K09M044004   Mileage: 273110km-169702miles
04-Steering Angle -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 1010
7 Faults Found:
                    Mileage: 272056 km
                    Time: 23:20:56
                    RPM: 750 /min
                    Load: 22.0 %
                    Temperature: 56.0°C
                    Temperature: 9.0°C
                    Voltage: 13.843 V
001287 - Idle Control System RPM
               P0507 - 000 - Higher than Expected. - Intermittent
                    Fault Frequency: 19
                    Mileage: 272073 km
                    Time: 00:52:29
                    RPM: 913 /min
                    Load: 15.3 %
                    Temperature: 97.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.335 V
000369 - Fuel Trim; Bank 1
               P0171 - 000 - System Too Lean - Intermittent
                    Fault Frequency: 14
                    Mileage: 272086 km
                    Time: 05:02:12
                    RPM: 765 /min
                    Load: 15.3 %
                    Temperature: 63.0°C
                    Temperature: 21.0°C
                    Voltage: 13.716 V
               U1017 - 015 -  - Intermittent
                    Fault Status: 00101111
                    Fault Frequency: 21
                    Mileage: 272649 km
                    Time: 07:45:22
                    RPM: 2805 /min
                    Load: 22.0 %
                    Speed: 62.0 km/h
                    Temperature: 91.0°C
                    Temperature: 13.0°C
                    Voltage: 13.589 V
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -  - Intermittent
                    Mileage: 272178 km
                    Time: 23:24:32
                    Temperature: 67.0°C
                    Temperature: 25.0°C
                    Voltage: 10.922 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Mileage: 272352 km
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 8.890 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 24.0°C
                    Temperature: 14.0°C
                    Voltage: 8.382 V
Readiness: 0010 0001
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 56224 002 104857
                    Reset counter: 32
                    Mileage: 273069 km
                    Count: 2
                    Count: 4608
                    Count: 125
                    Count: 47886
                    Count: 1024
01486 - System Function Test Activated
                    Reset counter: 32
                    Mileage: 273069 km
                    Count: 3
                    Count: 12800
                    Count: 320
                    Count: 50176
                    Reset counter: 32
                    Count: 7
                    Count: 12800
                    Count: 195
                    Count: 50176
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 45
                    Mileage: 272352 km
                    Voltage: 8.50 V
                    Reset counter: 46
                    Mileage: 272352 km
                    Voltage: 8.85 V
                    Reset counter: 45
                    Mileage: 272352 km
                    Voltage: 9.70 V
                    Reset counter: 45
                    Mileage: 272352 km
                    Voltage: 9.70 V
   Coding: 0000100
                    Reset counter: 45
                    Mileage: 272352 km
                    Time: 00:19:02
                    Voltage: 8.20 V
                    Reset counter: 45
                    Mileage: 272352 km
                    Time: 00:19:46
                    Voltage: 8.40 V
                    Reset counter: 17
                    Mileage: 272634 km
                    Time: 10:55:56
   Coding: 0013889
   Coding: 0000021
   Coding: 0023203
                    Reset counter: 72
                    Mileage: 272056 km
                    Time: 23:20:56
                    Reset counter: 35
                    Mileage: 272178 km
                    Time: 23:24:32
                    Reset counter: 45
                    Mileage: 272352 km
                    Time: 00:20:35
                    Reset counter: 45
                    Mileage: 272352 km
                    Time: 00:21:31
                    Fault Status: 00110100
                    Reset counter: 72
                    Mileage: 272056 km
                    Time: 23:20:57
                    Reset counter: 34
                    Mileage: 272178 km
                    Time: 23:24:33
                    Reset counter: 34
                    Mileage: 272178 km
                    Time: 23:24:33
                    Reset counter: 45
                    Mileage: 272352 km
                    Time: 00:19:59
   Coding: 0001205
                    Fault Status: 00100101
                    Reset counter: 66
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 01101100
                    Fault Frequency: 116
                    Reset counter: 33
                    Mileage: 272056 km
   Revision: 00H15000
                    Fault Frequency: 255
                    Reset counter: 82
                    Mileage: 273069 km
                    Time: 06:53:59
                    Voltage: 13.88 V
                        DU
                    Temperature: 15.0°C
                    RPM: 752 /min
                    Fault Frequency: 24
                    Reset counter: 82
                    Mileage: 273032 km
                    Time: 00:18:56
                    Voltage: 14.00 V
                        DU
                    Temperature: 17.0°C
                    RPM: 2163 /min
                    Speed: 88.0 km/h
                    Speed: 89.0 km/h
                    Reset counter: 45
                    Mileage: 272352 km
                    Time: 00:21:02
   Coding: 0001204
   Coding: 0040401
                    Reset counter: 45
                    Mileage: 272352 km
                    Time: 23:43:54
   Coding: 0001168
   Coding: 0100101
                    Fault Status: 00111000
                    Fault Frequency: 223
                    Reset counter: 72
                    Mileage: 273069 km
                    Time: 06:54:01
                    Fault Status: 01110100
                    Reset counter: 33
                    Mileage: 273079 km
                    Time: 11:48:23
   Coding: 0001168
                    Reset counter: 45
                    Mileage: 272352 km
End----------(Elapsed Time: 01:50, VBatt start/end: 12.2V/12.1V)-----------
Saturday,19,December,2020,12:55:19:03955
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 CD    HW: 1K0 907 379 AD
  Component and/or Version: ESP MK60EC1   H35 0120
           Software Coding: 000000000000000000000000000000000000
            Work Shop Code: WSC 56224 002 104857
                    Reset counter: 33
                    Mileage: 273114 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 195
                    Count: 42752
                    Count: 256
                    Reset counter: 33
                    Mileage: 273114 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 320
                    Count: 42752
                    Count: 256
dantev03
Maryland, USA
C?ID=419176
I see that the ABS coding is all zeros even though it accepted the old module coding.
dantev03
Maryland, USA
C?ID=419176
So I got it to save the coding, but here is the issue that I have. First, the implausible signal DTC always shows up. Second, I noticed that no matter what, the ABS, Traction control and brake lights never show up on the dashboard. I ran the instruments output test and the things that don't work are those 3 lights and any of the sounds. My guess is that the previous owner disabled it somehow. I was looking at the instrument cluster coding and it seems normal. I looked into the abs operation test and I see that I need to complete it for that code to go away by doing a test drive. I can't really do it as the lights never show up on the dashboard. I'm wondering how the previous owner may have disabled it. I even went into the CAN gateway output test and I tried the parking brake test and the parking brake light never comes on either. I don't get an error when running the output test so maybe the previous owner disconnected the lights. So my questions are, how do I get the ABS test code to go away and what is the implausible signal code about, also is there any other way to test the lights? I put the codes that are still in the module.
                    Reset counter: 32
                    Mileage: 273069 km
                    Count: 2
                    Count: 4608
                    Count: 125
                    Count: 47886
                    Count: 1024
                    Reset counter: 32
                    Mileage: 273069 km
                    Count: 3
                    Count: 12800
                    Count: 320
                    Count: 50176
