Instrument Cluster Swap problem
defalg
C?ID=405881
Audi A6 2.7t C5
Replaced LCD in my cluster and now the LCD don't work at all. The car runs fine with the cluster. However, now I am trying to swap out the original cluster with a donor cluster. Below are the steps I used with no success.
Used VCD k+CAN to retrive Original cluster PIN, and then retrieved Donor PIN.
Using VCDS x64 Rel (20.12)
With the donor cluster in the vehicle:
[Select]
[17 - Instruments]
The module Displays:
EXTRA: WAULDXXXXXX3099 AUZXXXXXXXXXX | WAULDXXXXXXX3099 (why does donor vin show twice here)
NEXT:
[Login - 11]
used the PIN of the "Donor Pin" [Do it!]
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
4-digit PIN [original pin]
05552 into the New value field
[Test]
The values may change to "32000", this is normal
The above illustration displays:
["System"] ["Not OK" ] ["N/A" ] [ "N/A"] is this good?
[Save]
[Done, Go Back]
Close Controller, [Done, Go Back ]
Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
Verify that the REPLACEMENT (Donor) instrument cluster now shows the VIN/IMMO-ID of the original vehicle.
Still Displays:
So the Donor cluster did not accept the adaptation. Maybe the donor cluster was already adapted?
please advise.
Below is a copy of my scan
Sunday,06,December,2020,09:36:40:13100
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
[URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
VIN: WAUCD64B24N103099   License Plate:
Mileage: 148582   Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 S
   Component: 2.7L V6/5VT     G   0020
   Coding: 07752
   Shop #: WSC 02334
   VCID: 53F37A2C52E67A539E1-5160
   WAULD64B94N032872     AUZ7Z0C2459265
No Faults Found
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      3428
   Coding: 06397
   Shop #: WSC 12345
   VCID: 2615F3F831F43FFB29F-51F2
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AR
   Component: A6-Klimavollautomat 0208
   Coding: 00010
   VCID: 6A8DC7C8E55CDB9BCD7-2586
            27-00 - Implausible Signal
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 Q
   Component: Airbag 8.4EP        3001
   Coding: 0000607
   Shop #: WSC 02334 785 00200
   VCID: 3E253B98CC64873B41F-5184
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01002
   Shop #: WSC 02334
   VCID: 2F3B16DC1E3E7EB3DA9-5184
            80-10 - Single-Wire Operation - Intermittent
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 983 F
   Component: KOMBI+WEGFAHRS. VDO D16
   Coding: 16264
   Shop #: WSC 00001
   VCID: 2B0302CC2A160293F61-5184
   WAUCD64B24N103099     AUZ7Z0D2612947
12 Faults Found:
00771 - Fuel Level Sensor (G)
01128 - Immobilizer Pickup Coil (D2)
            35-10 - - - Intermittent
01177 - Engine Control Unit
            65-10 - Unauthorized - Intermittent
01176 - Key
01176 - Key
00849 - S-contact at Ignition/Starter Switch (D)
            31-10 - Open or Short to Ground - Intermittent
01304 - Radio
01327 - Control Module for Parking Aid (J446)
            49-00 - No Communications
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D38
   Coding: 15885
   Shop #: WSC 02334
   VCID: 33331AACF2165A53BE1-4F2E
01561 - Rear left door
            59-00 - Can't Unlock
01562 - Rear right door
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0204
   Coding: 00001
   VCID: 2C0101D02F2805ABFFB-4B1E
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00050
   Shop #: WSC 02334
   VCID: 04518970E7382DEB57B-4B1E
   Part No: 4B0 035 195 N
   Component: symphony II NP2    0400
   Coding: 02005
   Shop #: WSC 73472
   VCID: 2B0302CC2A260293F61-5066
00879 - Connection to Speaker Front Right
            36-10 - Open Circuit - Intermittent
End----------(Elapsed Time: 04:50, VBatt start/end: 12.2V/12.3V)-----------
Address 17,4B0 920 983 F,channel 50,adapted from,32000,to,05552,
Hi and welcome.
Your scan is basically impossible to read because some software you passed it through stripped out all the NewLines. Can you please have a look in your Scans sub-folder, find that scan again, open it with Notepad, and paste the contents in here again?
As for images, please see: How to Post Pictures.
defalg
C?ID=405881
Hi and welcome.
Thanks for the advice.
I did as you recommended. Hope that is better.
defalg
C?ID=405881
Audi A6 2.7t C5
Replaced LDC and now the LCD don't work at all. The car runs fine.
Used VCD k+CAN to retrive Original cluster PIN, and retrieved Donor PIN.
Using VCDS x64 Rel (20.4)
Sorry, I don't know how to upload images so I will type Displays
[Select]
[17 - Instruments]
[Login - 11]
*Next select
[Adaptation - 10]
[Read]
Displays:
01234.
[Test]
Displays:
The top fields display: ["System"] ["Not OK" ] ["N/A" ] [ "N/A"]
[Save]
[Done, Go Back]
Verify that the REPLACEMENT (NEW or USED) instrument cluster now shows the VIN/IMMO-ID of the vehicle now.
Displays:
<blockquote class="imgur-embed-pub" lang="en" data-id="a/byUf9Qg" data-context="false" ><a href="//imgur.com/a/byUf9Qg"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
          75 76 77
   Coding: 07752
   Shop #: WSC 02334
No Faults Found
   Coding: 06397
   Shop #: WSC 12345
   Coding: 00010
   Coding: 0000607
   Coding: 01002
   Shop #: WSC 02334
   Coding: 16264
   Shop #: WSC 00001
12 Faults Found:
01176 - Key
01176 - Key
01304 - Radio
   Coding: 15885
   Shop #: WSC 02334
   Coding: 00001
   Coding: 00050
   Shop #: WSC 02334
   Coding: 02005
   Shop #: WSC 73472
[/QUOTE]
          75 76 77
   Coding: 07752
   Shop #: WSC 02334
No Faults Found
   Coding: 06397
   Shop #: WSC 12345
   Coding: 00010
   Coding: 0000607
   Coding: 01002
   Shop #: WSC 02334
   Coding: 16264
   Shop #: WSC 00001
12 Faults Found:
01176 - Key
01176 - Key
01304 - Radio
   Coding: 15885
   Shop #: WSC 02334
   Coding: 00001
   Coding: 00050
   Shop #: WSC 02334
   Coding: 02005
   Shop #: WSC 73472
Hi and welcome.
It took a little bit but I think I finally have my post cleaned up. please advise.
Scan is legible now. I'm not sure what the imgur mess is. I can usually clean up bad imgur links, but have not gotten anywhere with this one.
Anyway, you have a metric ship-ton of fault codes in that cluster. Please clear them and show us what comes back immediately.
defalg
C?ID=405881
Sunday,06,December,2020,21:44:36:13100
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
          75 76 77
   Coding: 07752
   Shop #: WSC 02334
   VCID: 53F37A2C52E67A539E0-5160
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4B0 927 156 FE
   Component: AG5 01V 2.7l5VT USA 2222
   Coding: 01002
   Shop #: WSC 02334
   VCID: 6FBBD6DCDE8E3EB39A8-5184
   Coding: 06397
   Shop #: WSC 12345
   VCID: 2615F3F831F43FFB29E-51F2
   Coding: 00010
   VCID: 6A8DC7C8E55CDB9BCD6-2586
   Coding: 0000607
   VCID: 3E253B98CC64873B41E-5184
   Coding: 01002
   Shop #: WSC 02334
   VCID: 2F3B16DC1E3E7EB3DA8-5184
   Coding: 16264
   Shop #: WSC 00001
   VCID: 2B0302CC2A160293F60-5184
   Coding: 15885
   Shop #: WSC 02334
   VCID: 33331AACF2165A53BE0-4F2E
   Coding: 00001
   VCID: 2C0101D02F2805ABFFA-4B3C
   Coding: 00050
   Shop #: WSC 02334
   VCID: 04518970E7382DEB57A-4B1E
   Coding: 02005
   Shop #: WSC 73472
   VCID: 2B0302CC2A260293F60-5066
End----------(Elapsed Time: 05:20, VBatt start/end: 12.2V/12.4V)-----------
Interesting that there are no immobilizer-related fault codes that have come back immediately. Yet it's plain to see that the VIN in the cluster doesn't match the one in the ECU. I'm a bit puzzled by this. Have you tried starting the car?
defalg
C?ID=405881
No, it does not start.
The immo light is flashing too.
should I try adapting the key to the donor cluster?
Also, there is a remote car starter in the car. It has a immo bypass, from what I remember. I disabled it, but no difference.
Do tell us more. How does that "immo bypass" work?
defalg
C?ID=405881
How it works I’m not fully sure. It’s a viper / directed remote start system. To bypass the the immo, there is a key inserted into a coil, with in a boxed circuit board. If I turn off the vale switch it is not an issue.
That’s all I know.
defalg
C?ID=405881
That’s all I know.
Here is a picture
OK, it's reading a spare key that's matched to the immo.
You can't. It's Immo-3. Transponders in keys have a lock bit; once matched to an Immo, they can't be matched to a different one. The cluster needs to be matched to your ECU and key. This should be doable provided they key and the ECU match.
I wonder if things are getting confused because there are two keys (one in the ignition and the other in the "bypass")?
defalg
C?ID=405881
Ok, to rule out the spare key. tomorrow, I will put the original cluster back in, dicsonnect the remote starter. remove the spare key away from the car, confirm it starts. Then I will return the Doner, and scan again.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
On AudiA6 , A4 , TT not possible to do used cluster on immo status 06 with VCDS .
Only 2 ways to do this , Transfer manually iimmo part to donor cluster or make it donor cluster Virgin New mode 04 or 01.
BTW, I have good high quality LCD and I can replace it on originla cluster if you did not mess up Board. You can look at my website
