Steering light after clutch
chris92
Bishop Auckland UK
C?ID=361722
Hi, I recently did a clutch on a mk2 leon fr for a friend and all is well but the steering light wont turn off. I then followed some instructions on how to reset steering angle and now I've lost the assisted steering aswell. This is why I like to avoid modern vehicles just nightmares that shouldn't be :D any one give me some pointers?
Saturday,05,December,2020,18:14:33:55794
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: VSSZZZ1PZ7R109319   License Plate:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R109319   Mileage: 201570km-125249miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 DT    HW: 03G 906 018 DT
   Component: R4 2.0l PPD1.2 G    4352
   Revision: --H42---    Serial number: SEZ7Z0G3770257
   Coding: 0050072
   Shop #: WSC 66565 257 00032
   VCID: 7AADF01360D2C6FB3D7-802E
Readiness: N/A
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 04941 785 00200
   VCID: 73B3DD3747B8B7B37E1-8026
   Part No: 1P0 907 044
   Component: ClimatronicPQ35 010 0502
   VCID: 698FBF5F15747D63C4D-803C
01273 - Fresh Air Blower (V2)
            010 - Open or Short to Plus
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004840772
   Coding: 81880F2F00041000431D00000000000000007F075C4000
   VCID: 6C81C64B1A86684BBFB-8038
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 190407 022  0601
   Coding: 00056208
   Shop #: WSC 04941
   Part No SW: 3C0 909 605 L    HW: 3C0 909 605 L
   Component: R5 AIRBAG VW8   030 2522
   Revision: 12030000    Serial number: 003B0P8ERQN8
   Coding: 0021045
   VCID: 2F3B1147EB10D353DA9-807A
   Subsystem 1 - Serial number: 6332MSME182F2473
   Subsystem 2 - Serial number: 6342MSME19330D5E
   Subsystem 3 - Serial number: 6351HTS6OFJ4SPP6
   Subsystem 4 - Serial number: 6361HTS6LNF0N3I6
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0002042
   VCID: 015F87FF0D0495237CD-8054
   Component: E0221           005 0060
   Part No: 1P0 920 925 A
   Component: KOMBIINSTRUMENT VO3 0422
   Coding: 0002401
   Shop #: WSC 80093 222 69422
   VCID: 2D070B4FE11CA143E85-8078
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0178
   Revision:   H12       Serial number: 33001074020902
   Coding: 3D3F034007000203
   Shop #: WSC 02102 476 94331
   Component: IMMO            VO3 0422
   Shop #: WSC 56337 001 1048576
   Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1130
   Revision: 31008001    Serial number: 00000513178205
   Coding: 0000688
   VCID: 3B2335172F683FF3661-806E
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.142 H07 1806
   VCID: 3537232F094CE983905-8060
02546 - Steering Limit Stop
                    Mileage: 201560 km
                    Temperature: 20.0°C
                    Voltage: 12.60 V
                    Voltage: 12.40 V
   Component:    KSG PQ35 G2  020 0203
   Coding: 998000005283CC7F0006050560085F86107C80
   VCID: 03538DF7171887336E1-8056
   Subsystem 5 - Part No: 1P0 951 171
   Component: Innenraumueberw.010 4971
   Coding: 00000000
   Shop #: WSC 56337
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
   Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1130
   Revision: 31008001    Serial number: 00000054778217
   Coding: 0000688
   VCID: 3C21360B2A6638CB6FB-8068
   Part No: 1P2 035 186 A
   Component: Radio BVX           0006
   Coding: 0040424
   VCID: 2B030557DF08AF73F61-807E
No Faults Found
   Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
   Component: J388   TUER-SG HL   1108
   Revision: 11006001    Serial number: 00000001461837
   Coding: 0000144
                    Fault Status: 01101000
                    Reset counter: 125
                    Mileage: 201555 km
   Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
   Component: J389   TUER-SG HR   1108
   Revision: 11006001    Serial number: 00000001482300
   Coding: 0000144
End----------(Elapsed Time: 01:19, VBatt start/end: 14.3V/14.3V)-----------
chris92
Bishop Auckland UK
C?ID=361722
Just tried what you recommended and still no joy, still have the steering, tyre pressure and traction lights on and steering is still heavy
Did it end with "OK"?
Did you also do the Steering Limit Stop procedure linked in that procedure?
chris92
Bishop Auckland UK
C?ID=361722
Yes ended with a ok, also yes Ive done the steering limit stop procedure aswell. But since ive done them ive lost the steering as
Tuesday,08,December,2020,19:07:09:55794
VIN: VSSZZZ1PZ7R109319   Mileage: 201580km-125256miles
   Coding: 0050072
Readiness: N/A
   Revision: 00H11001
   Coding: 0006786
00898 - Control Circuit A/C compressor
   Coding: 00056208
   Shop #: WSC 04941
   Coding: 0021045
   Coding: 0002042
   Coding: 0002401
   Coding: 0000688
                    Mileage: 201560 km
                    Temperature: 15.0°C
                    Voltage: 12.40 V
                    Voltage: 12.20 V
   Coding: 00000000
   Shop #: WSC 56337
                    Reset counter: 166
   Coding: 0000688
   Coding: 0040424
No Faults Found
   Coding: 0000144
                    Reset counter: 165
                    Mileage: 201555 km
   Coding: 0000144
End----------(Elapsed Time: 01:20, VBatt start/end: 12.8V/12.5V)-----------
sist.
chris92
Bishop Auckland UK
C?ID=361722
Also in the steering assist module 44 in measuring blocks group 007 the steering angle sensor just reads 0.00, never moves when I turn wheel etc
chris92
Bishop Auckland UK
C?ID=361722
Just been on live data for the four wheel speed sensors and the rear right keeps jumping massively up every few seconds, so I'm thinking the ring on bearing or sensor is at fault so I'm guessing that's why it wont let me carry out the procedures as its telling the ecu its doing 50kph when really I'm doing 10kph ish
