- May 27, 2017
- 2,084
- 1,310
- Finland
- C?ID=280813
Ok, let's try to iterate a bit more.
For BSD and rear cross traffic alert to work you need to code module 3 ABS (RCTA) module 10 park assist, module 17 instruments, naturally 3C needs to be correct, adaptations module 5F and code A5 to know about lane assist.
ACC I've not coded for BSD. I don't know what it would use that info for?
So ABS coding :
Byte 29 BIT 7 MUST be enabled
Then byte 27, you were debating is it 50 or F0. I had to put it to F0 when I changed my rear sensors to directional ones. Otherwise I would get an error every time I went faster than 80km/h.
I remembered the logic
50 is when you have multi-link rear axle, F0 when you have fixed or "one block" rear axle. 1.4 TSI and bigger engines and all 4motions have multi-link, <1.4 have I think it's called torsion beam rear axle.
Module 10 park assist coding, I noticed this was some reason totally wrong in your autoscan?? The one below should be correct one?
Module 17, seems to have correct coding
3C was not having exactly correct coding, this would be good
5F adaptations were already confirmed ok
A5 seems to have correct coding.
So ABS coding :
