Good evening, it's that time again when something's amiss with the beloved OWdi.
Hoping someone can dispense some wisdom on how scr*wed I am LOL...
I searched the forum but couldn't see any threads to add this on, so I hope it's OK that I start a new one.
Car: 2005 A6 Quattro 3.2L
Recently there is a rattle under the hood when starting up that does go away after a few minutes. However, the car has bad gas mileage and idles rough, like it isn't running on all cylinders. Just popped a MIL and this is the read-out:
** Camshaft Position Sensor B Bank 1 (G300) -- P0366 - 006 - Implausible Signal - MIL ON **
I'm worried about driving it in case there is a problem with the timing chain - could that be causing the rattle sound?
Where is that sensor located and does it look like it needs replacing?
As always, any help would be much appreciated!
Friday,04,December,2020,15:58:36:43060
VCDS Version: 20.12.0.1 HEX-V2 CB: 0.4529.4
VIN: WAUDG74F25N122676 License Plate: TR5DA
Mileage: 198920km-123603mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 65 67 72 77
VIN: WAUDG74F25N122676 Mileage: 198920km-123603miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 B HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0020
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 05139 444 83890
VCID: 2B03FA8C1F0FB313F60-807E
9 Faults Found:
000632 - Fuel Injector #6 (N84)
P0278 - 006 - Contribution/Balance Fault - Intermittent
Fault Status: 00100001
Fault Frequency: 18
Reset counter: 20
Mileage: 194171 km
Date: 2020.04.08
Time: 12:54:37
RPM: 1376 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 79.5°C
Idle
Load: 11.0 %
Speed: 44.0 km/h
000020 - Bank 1: Camshaft B (Exhaust)
P0014 - 008 - Retard Setpoint not Reached (Over-Advanced)
Fault Status: 00001000
Mileage: 198743 km
Date: 2020.11.30
Time: 17:13:47
RPM: 1568 /min
Mass Air / Rev.: 98.1 mg/str
Temperature: 79.5°C
Overrun
Bin. Bits: 00000000
Steering Angle: -100.36°
000870 - Camshaft Position Sensor B Bank 1 (G300)
Fault Status: 10100001
Fault Frequency: 16
Mileage: 198759 km
Date: 2020.12.01
Time: 07:33:31
RPM: 832 /min
Temperature: 85.5°C
Idle
Bin. Bits: 00010000
000769 - Cylinder 1
P0301 - 007 - Misfire Detected - Intermittent
Fault Status: 00000010
Reset counter: 32
Mileage: 198772 km
Date: 2020.12.01
Time: 16:57:46
RPM: 1696 /min
Mass Air / Rev.: 228.9 mg/str
Temperature: 42.0°C
Part Throttle
Time: 25.6 s
Speed: 23.0 km/h
000771 - Cylinder 3
P0303 - 007 - Misfire Detected - Intermittent
Reset counter: 32
Mileage: 198772 km
Date: 2020.12.01
Time: 16:57:46
RPM: 1696 /min
Temperature: 42.0°C
Part Throttle
Time: 25.6 s
Speed: 23.0 km/h
000770 - Cylinder 2
P0302 - 007 - Misfire Detected - Intermittent
Reset counter: 32
Mileage: 198772 km
Date: 2020.12.01
Time: 16:57:46
RPM: 1696 /min
Temperature: 42.0°C
Part Throttle
Time: 25.6 s
Speed: 23.0 km/h
P0300 - 006 - - Intermittent
Reset counter: 35
Mileage: 198772 km
Date: 2020.12.01
Time: 16:57:46
RPM: 896 /min
Mass Air / Rev.: 190.8 mg/str
Temperature: 19.5°C
Idle
Time: 51.2 s
000772 - Cylinder 4
P0304 - 007 - Misfire Detected - Intermittent
Reset counter: 33
Mileage: 198792 km
Date: 2020.12.02
Time: 07:21:49
RPM: 896 /min
Temperature: 19.5°C
Idle
Time: 51.2 s
000773 - Cylinder 5
P0305 - 007 - Misfire Detected - Intermittent
Reset counter: 33
Mileage: 198792 km
Date: 2020.12.02
Time: 07:21:49
RPM: 896 /min
Temperature: 19.5°C
Idle
Time: 51.2 s
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 4028906
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 290F008415F3A10304C-807C
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0020895
Shop #: WSC 02327 785 00200
VCID: 2D07F494211BBD23E84-8078
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300155096
Coding: 0000015
Shop #: WSC 06402 785 00200
VCID: 639352AC375F3B530E0-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H44 0070
Component: FBSAUDIC6 KSG H26 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 360DK057523670
Coding: 0000003
Shop #: WSC 05139 444 104911
VCID: 313FE8E43D23D9C3CCC-8064
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000143950
Subsystem 3 - Serial number: 0120.04.050000000100010067ÿ
Subsystem 4 - Serial number: 010067ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000026 Serial number: 00000000140982
Coding: 0524326
VCID: 5BE36A4C0F2F0393460-800E
01853 - Heated Seat; Left Front (Z45)
Reset counter: 195
Mileage: 198924 km
Date: 2020.12.04
Time: 15:54:22
Temperature: 23.0°C
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0002121
Shop #: WSC 02335 785 00200
VCID: 66954BB8C46D4E7BE9E-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Reset counter: 195
Mileage: 198924 km
Date: 2020.12.04
Time: 15:54:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7162212
VCID: 1C6129504AA144AB8FA-8048
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D3022210
Reset counter: 195
Mileage: 198924 km
Date: 2020.12.04
Time: 15:54:19
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D08CD6Q
Coding: 0013622
VCID: 26150BB804ED8E7B29E-8072
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME090C33570
Subsystem 3 - Serial number: 6342CSME097E1B228
Subsystem 4 - Serial number: 6351HSME07172617+
Subsystem 5 - Serial number: 6361HSME070A2202Y
Subsystem 6 - Serial number: 6371VSME07284D23M
Subsystem 7 - Serial number: 6381VSME07286733K
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025051100025
Coding: 0002041
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H02 0030
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0630
Revision: 01000000 Serial number: 4R850TV45
Coding: 2129263
Shop #: WSC 50451 001 1048576
VCID: 1E6523585CBD56BB61E-804A
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080542881C4
Coding: 6CFE73CD1B5904
VCID: 270B06BC03E79773128-8072
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619F58A42D4329431CC-8034
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0051947
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01003941210000
Coding: 4618301
VCID: 2E05F3982C1DC63BD1E-807A
Fault Status: 01101100
Reset counter: 195
Mileage: 165174 km
Date: 2017.08.24
Time: 17:20:11
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000030664
Coding: 0000026
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0050
Revision: Serial number: 00000000089631
Coding: 0001114
VCID: 5EE563581C3D16BB21E-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0051947
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DE76454113B0DA3384-8008
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000016
Shop #: WSC 05139 444 109253
VCID: 698F4084D5736103C4C-803C
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394ES057543740
Coding: 0000002
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000027842
Shop #: WSC 05139 444 58901
VCID: 231312AC77DF7B534E0-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 0330207712
Coding: 344630393135313035432056413030333330323037373132
Shop #: WSC 57227 000 1048576
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000700004988
Coding: 0062221
Shop #: WSC 05139 444 59514
VCID: 60995DA02649204B132-8034
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000504220168
Shop #: WSC 12336 024 394758
VCID: 3431E1F0C231ECEBA7A-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0051754
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007521822
Coding: 0010900
VCID: 280905800EF9980B1B2-807C
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.1V)-----------
