I'm working on a 14' GTI with AFS Xenon headlights that had a rear access cover dislodged for the RF unit that in turn allowed water intrusion. I attempted to recover the OG module (PN 7L6 941 329 B)via cleaning and got the Up/Down function to return but the swivel is still a no go. I ordered a used AFS module that is the same PN but from a different model car and am attempting to program it (Old coding is 0000022 and used module is 0000019) but its not taking any changes via Lcode or any other methods since its consistently stated that these units are coded on a 2nd level after coding module 55 (headlight range control). I have tried coding 55 with OE info and also EU coding numbers (pulled from a forum which 55 did accept) but the used module still will not take any changes nor will is communicate or respond to tests, adaptation, or resets but all measurement values show up and are plausible. I've spent a fair amount of time looking online and searching various forums including Ross-Tech with no solid results to this question "can a used AFS module be programmed/coded". I'm attaching the VCDS data if anyone wants to look but its not likely to provide any additional insight.
The main info needed here is if this is a One and Done module(code it from new and it wont accept new info) or if there is a back door that will allow a module that isn't coded for this specific vehicle to be adjusted at a later date, such as dealer level software or something else since the 55 module via VCDS doesn't allow for any programming Lcode mods.
I've got 20yrs experience as a BMW dealer tech with mixed Euro products all through those years and all bmw headlight parts are one and done(VIN Specific or coding) whereas VAG modules can be swapped between vehicles until you get into the later 2010's(this puts this module directly in the this date range).
FYI, The corrosion in the headlight and connector has been repaired and is no longer a issue.
VEHICLE DATA PRIOR TO ANY REPAIR ATTEMPTS
DATA FROM USED MODULE INSTALLED IN CAR!!!!
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0148
Coding: 1446940
VCID: 34675A6657A63D26C7-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
8 Faults Found:
02234 - Right Headlight Power Output Stage (J668)
Fault Status: 00101110
Fault Frequency: 51
Reset counter: 150
Mileage: 89117 km
Date: 2015.03.23
Time: 19:36:16
Voltage: 13.49 V
Speed: 18.2 km/h
ABS 1
02626 - Dynamic Cornering Light Motor; Right (V319)
Fault Status: 00101010
Reset counter: 115
Mileage: 89569 km
Date: 2015.03.31
Time: 14:35:25
Voltage: 13.77 V
ABS 1
Reset counter: 117
Mileage: 89699 km
Date: 2015.04.02
Time: 16:26:25
Voltage: 13.63 V
Speed: 44.2 km/h
ABS 1
Fault Frequency: 51
Reset counter: 150
Mileage: 89117 km
Date: 2015.03.23
Time: 19:36:16
Voltage: 13.49 V
Speed: 18.2 km/h
ABS 1
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 110
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Reset counter: 110
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Reset counter: 110
Invalid
Invalid
Invalid
Fault Status: 11100101
Reset counter: 110
Invalid
Invalid
Invalid
Coding: 1446940
VCID: 34675A6657A63D24D7-8060
Coding: 00000022
Component: AFS-Lst.-Modul r X008
Coding: 00000019
000 - - - MIL ON
Reset counter: 110
Invalid
Invalid
Invalid
000 - - - MIL ON
Reset counter: 110
Invalid
Invalid
Invalid
Reset counter: 110
Invalid
Invalid
Invalid
Control Module Part Number: 5M0 907 357 C
Component and/or Version: AFS-Steuergeraet 0148
Software Coding: 1446940
Work Shop Code: WSC 01357
VCID: 34675A6647A63D24D7-8060
Additional Info: 7L6941329B AFS-Lst.-Modul l 0004 7L6941329B AFS-Lst.-Modul r X008
Advanced Identification
Identification: SME-RBG
Revision: 00H04000
Date: 01.08.13
Test stand number: 0007
Manufacturer number: 1020
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: --.--.--
Software
A00526F
S000210
030500
012301
023000
X01000B
Misc.
Hardware number: 5M0 907 357 C
VCDS Info:
Labels: 5M0-907-357-V2.LBL
Address 55,5M0 907 357 C,channel 2,adapted from,0,to,0,
Adaptation Channel 000:
Stored value
Address 55,5M0 907 357 C,channel 0,adapted from,---,to,000,
Address 55,5M0 907 357 C,recoded (Short coding),from,1446940,to,1446940,(015284/011/00200),
Address 55-02,7L6 941 329 B,recoded (Short coding),from,00000019,to,0000022,(15284/011/00200),
Address 55,5M0 907 357 C,recoded (Short coding),from,1446940,to,1446941,(15284/011/00200),
Address 55,5M0 907 357 C,recoded (Short coding),from,1446940,to,0000000,(15284/011/00200),
Address 55,5M0 907 357 C,recoded (Short coding),from,1446940,to,1446940,(01357/011/00200),
Address 55-02,7L6 941 329 B,recoded (Short coding),from,00000019,to,0000022,(01357/011/00200),
Address 55: Headlight Range (5M0 907 357 C)
16:09:10
60.8 % Actuator Motor Left Headlight
101.6 % Actuator Motor Right Headlight
0.0 % Static Cornering Light Left
101.6 % Static Cornering Light Right
102.0 % Dynamic Cornering Light Left
101.6 % Dynamic Cornering Light Right
No Cornering Light deactived
Address 55: Headlight Range Labels: 5M0-907-357-V2.LBL
Control Module Part Number: 5M0 907 357 C HW: 5M0 907 357 C
Work Shop Code: WSC 15284 011 00200
000 - - - MIL ON
Reset counter: 110
Invalid
Invalid
Invalid
000 - - - MIL ON
Reset counter: 110
Invalid
Invalid
Invalid
Reset counter: 110
Invalid
Invalid
Invalid
