- Dec 4, 2020
- 3
- 1
- Ithaca, NY, USA
- C?ID=426321
Hey;
Long time VW owner, short time VCDS owner. I finally took the plunge because I picked up a B6 Passat Wagon and started tinkering with it.
I'm in the process of upgrading from the Premium 7 stereo to an RNS-315, in order to get Bluetooth among other things.
As part of that I needed to upgrade the CAN bus interface. It originally came with Rev C hardware, and I installed a Rev Q version.
I tried to pull the HEX programming off the old version and program it into the new one, but I'm not sure I managed it correctly.
I'm getting ABS and AWD lights with the new interface. If I reinstall the old one the lights go away (I don't think fuses do that. I checked the forum I swear!). I think the lights are real because if I drive with the dash errors lights on there is occasionally a driveline thunk, especially around corners. That seems AWDish. I'm inclined to not ignore it and hope the lights go away in 140 cycles.
Any chance someone can point me in the right direction here?
Thanks,
Tim
Thanks,
Tim
Friday,04,December,2020,09:29:22:37232
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WVWVU73C77E132842 License Plate:
Mileage: 138160km-85848mi Repair Order: dec4_2020
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 37 42 44 46 52 53
56 62 65 6D 72 76 77
VIN: WVWVU73C77E132842 Mileage: 138160km-85848miles
0F-Digital Radio -- Status: Not registered 0011
1C-Position Sensing -- Status: Malfunction 0010
22-AWD -- Status: Not registered 0001
36-Seat Mem. Drvr -- Status: Not registered 0011
37-Navigation -- Status: Not registered 0011
6D-Trunk Elect. -- Status: Not registered 0011
76-Park Assist -- Status: Not registered 0011
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 AE HW: 03H 906 032 AB
Component: P3.6-FSI-LEV2 G00 0558
Revision: 5GH02--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 00000
VCID: 6597BAFBA968D123E05-8030
Readiness: 0110 0101
Part No SW: 09G 927 750 FR HW: 09G 927 750 FR
Component: AQ 250 6F 0932
Revision: 00H38000 Serial number:
Coding: 0000072
VCID: 06559D77742E3A3B49F-8052
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 A HW: 3C0 614 109 A
Component: ESP 440 C4 H018 0001
Revision: H018 Serial number: 0668219553
Coding: 0013776
VCID: 1C61DF1FDAA2D0EB8FB-8048
01324 - Control Module for All Wheel Drive (J492)
Reset counter: 44
Mileage: 138162 km
Date: 2020.12.04
Time: 09:21:02
Reset counter: 44
Mileage: 138162 km
Date: 2020.12.04
Time: 09:21:02
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 678BB0F35364C333D29-8032
Reset counter: 170
Mileage: 138162 km
Date: 2020.12.04
Time: 09:17:52
Reset counter: 170
Mileage: 138162 km
Date: 2020.12.04
Time: 09:17:52
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006412121
Coding: F58C8F0340041A00470000000F00000000285D435C0001
VCID: 6C81CFDF4A82E06BBFB-8038
Subsystem 1 - Part No: 3C1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 231106 022 0601
Coding: 00046997
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 161106 014 1201
Coding: 00208933
Shop #: WSC 05311
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0014802
VCID: 2E0505D7BC1E527BD1F-807A
Reset counter: 130
Mileage: 138162 km
Date: 2020.12.03
Time: 23:50:25
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 18 AIRBAG VW8R 031 2522
Revision: 12031000 Serial number: 003B2PP36JY%
Coding: 0012600
VCID: 313F1EABAD204D83CCD-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003EBZQ
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME141139594ÿ†63
Subsystem 5 - Serial number: 139594ÿ†6342MSME14674479Eÿ†63
Subsystem 6 - Serial number: 74479Eÿ†6351HTS6S4C8C7273ÿ†63
Subsystem 7 - Serial number: 8C7273ÿ†6361HTS6S4CS8AU67ÿ†63
Subsystem 8 - Serial number: S8AU67ÿ†63727TS66HBCTM07Kÿ†63
Subsystem 9 - Serial number: CTM07Kÿ†63827TS66HBCT6J6Nÿ
Subsystem 10 - Serial number: CT6J6Nÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 K HW: 3C0 953 549 K
Component: J0527 0015
Revision: 00006000 Serial number: 3C9953507AE
Coding: 0002112
VCID: 343117BF523278ABA7B-8060
Component: E0221 006 0080
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 04149 210 01865
VCID: 2313E4E3E7DCEF134E1-8076
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P1022602DE
Coding: FD807F07001602009002
Shop #: WSC 05314 123 12345
VCID: 2F3B18D3BB145B73DA9-807A
Reset counter: 130
Mileage: 138162 km
Reset counter: 130
Mileage: 138162 km
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1339817TQ9SH03
Reset counter: 170
Reset counter: 170
Reset counter: 170
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 E
Component: HALDEX 4Motion 0110
Coding: 0000001
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 42138 000 1048576
VCID: 73B3D4A317BC3F937E1-8026
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
VCID: 2D0702DBB1182963E85-8078
02346 - Switch for Memory Position 2 (E219)
003 - Mechanical Failure
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H35 0319
Serial number: VWZAZ2M4240903
Coding: 0400040104000B000000100A
Shop #: WSC 09003 957 00200
ROD: EV_RNS315NARV2UDS_VW36.rod
VCID: 2517FAFBE5681123205-8070
Component: NAR_V7N 0060
1048582 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS antenna open load]
Reset counter: 130
Mileage: 138162 km
Date: 2020.12.03
Time: 23:50:48
1048667 - Antenna for Satellite Radio
B10F4 13 [009] - Open Circuit
Reset counter: 130
Mileage: 138162 km
Date: 2020.12.03
Time: 23:50:48
1048659 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[CAN TO phone control unit]
Reset counter: 130
Mileage: 138162 km
Date: 2020.12.04
Time: 09:19:06
1048652 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 130
Mileage: 138162 km
Date: 2020.12.03
Time: 23:50:48
B11CF 53 [009] - Deactivated
Reset counter: 130
Mileage: 138162 km
Date: 2020.12.03
Time: 23:50:49
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 31008001 Serial number: 00000031169113
Coding: 0001463
Shop #: WSC 05311 000 08193
VCID: 3C213F9F7A62B0EB6FB-8068
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.137 H07 1806
Shop #: WSC 02069 000 90108
Component: KSG PQ46 RDK 051 0219
Coding: 13900E80D1032E521004141FF08A8F0E085800
Reset counter: 170
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 31008001 Serial number: 00000123269113
Coding: 0001462
VCID: 3D27329B6178B9E3585-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 E HW: 3C0 907 801 E
Component: EPB VC8HC003 013 0003
Revision: 013
Coding: 0000013
VCID: 2411E7FFE2D2E82B37B-8070
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1114
Revision: 12004001 Serial number: 00000000855816
Coding: 0001168
VCID: 3E2535976C7EA2FB41F-806A
Component: RDK 0440
Coding: 0100101
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0405
Revision: 00H21001
Shop #: WSC 23250 384 715754
VCID: 30391BAFA62A448BC33-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0600H21001001C0218ÿ
Reset counter: 170
Mileage: 138162 km
Date: 2020.12.04
Time: 09:17:52
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1114
Revision: 12004001 Serial number: 00000000780889
Coding: 0001168
VCID: 3FDB48936B74ABF34A9-806A
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930632603221
Coding: 0001124
VCID: 2809F3CF9EFA0C4B1B3-807C
Fault Status: 01100101
Reset counter: 130
Mileage: 138162 km
Date: 2020.12.03
Time: 23:51:45
Address 77: Telephone
End----------(Elapsed Time: 02:03, VBatt start/end: 14.0V/14.0V)-----------
