I'm in trouble
T-CUT
Nottingham, UK
C?ID=205609
Audi A6 C7 Allroad 2012
Hi,
I change my clock spring because the fault codes lead me to it. After changing with a new one, I got all these codes. I can't reset the steering angle, the steering wont calibrate. So I'm at a loss. Check all the wiring and plugs, which I have touched. Please help if you can.
Thank you
Friday,04,December,2020,13:45:23:23584
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WAUZZZ4G6DN074425   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 40 42
          44 46 52 53 55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90 A9 C0
VIN: WAUZZZ4G6DN074425   Mileage: 204334km-126967miles
04-Steering Angle -- Status: Cannot be reached 0100
20-High Beam Assist. -- Status: Cannot be reached 0100
3B-Sensor Elect. -- Status: Malfunction 0010
40-AC Compressor -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
   Part No SW: 4G0 907 589 C    HW: 4G0 907 589
   Component: 3.0BTD EDC17  X24 0001
   Revision: 57X24---
   Coding: 322A403225760B020000
   Shop #: WSC 00189 210 96593
   ASAM Dataset: EV_ECM30BTD0114G0907589C 001001
   ROD: EV_ECM30BTD0114G0907589C.rod
   VCID: 34311DF11EBEADABA7B-8060
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [039] - -
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:50
                    Engine RPM: 839.50 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 37 °C
                    Intake air temperature: 11 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 14.340 V
                    Cruise Control System (CCS): status-Bits 0-7: 20
                    selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 X
   Part No SW: 4G0 927 158 AA    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1003
   Revision: --H16---
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 6D87C8953D143C63A85-8038
12561 - No Communications with Steering Angle Sender (G85)
          U0126 00 [039] - -
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:49
                    Voltage terminal 30: 14.342 V
                    Engine RPM: 840 /min
                    Status data bus communication diagnostic interface-State Deashboard received: not received
                    Status data bus communication diagnostic interface-State ECM received: not received
                    Status data bus communication diagnostic interface-State ESP received: not received
                    Status data bus communication diagnostic interface-State Gateway received: not received
                    Status data bus communication diagnostic interface-State Parking Brake received: not received
                    Status data bus communication diagnostic interface-State Steering Angle received: not received
                    Status data bus communication diagnostic interface-State Steering Assist received: not received
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 49A7C70592E5E3A0FB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 382929C102D649CB8B3-806C
0067 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
          [ComScl_PDU_LWI_01_Timeout]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: BA
0781 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_LWR_AFS_01_Timeout]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: BA
0782 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
          [SCL_LWR_Hoehenwert_HL_Invalid]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E0
                    Uz: BA
0784 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
          [SCL_LWR_Hoehenwert_VL_Invalid]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 42
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E2
                    Uz: BA
   Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
   Component: BCM2 2.0      H32 0421
   Coding: 01B93046000000000000
   Shop #: WSC 02391 785 00200
   VCID: 77ABEAFD4FC886B3429-8022
   Serial number: 2312000210208011
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 12101200041184
   Coding: 3622007825
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 629DABA9F4CA731B057-8036
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001459586
   Coding: 0600201051F49FF2C98100C380001908CF9DE7082F080341000008406100
   VCID: 6E85CF993092C77B91F-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 120822  H36 0080
   Serial number:         120920000515
   Coding: 0045F7
   Serial number: 20664589
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 13 10 2012  00000194
   Serial number: E8A80E46000000000001
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:00
03110 - Active Steering Control Module (J792)
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:00
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:00
03395 - Control Module for High Beam Assistant
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:00
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061229001247
   Coding: A9EB0C
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD4E5212CD8838CD-8024
13679386 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809F981D276D94B1B3-807C
32512 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_LWI]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 14.380 V
                    Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Voltage terminal 15: 14.450 V
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Voltage terminal 15: 14.489 V
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00AHY9M
   Coding: 30323436313330303539554A305234473053
   VCID: 363527F908C2BFBB99F-8062
   Serial number: 3575HRB405B1IMPK9H3
   Serial number: 3585HRB405F1HPAM49HX
   Serial number: 3515JRB401E4UN9OP8SQ
   Serial number: 3525JRB401C4UN9ON23Z
   Serial number: 3554VRB400K4UNK8A1TK
   Serial number: 3564VRB400G4UNK86P4C
1050112 - Databus
          [CAN: 0x086 LWI_01 Timeout]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:49
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QGR00003
   Coding: 0000FD
   VCID: 382929C1025649CB8B3-806C
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 24 08 2012  C0106888
                    Fault Status: 01100101
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:45
                    (no units): 44.0
                    Text: 2C96FFFFFFFF00C0FF
                    Mass Flow: 364.08 g/s
                    Raw, Index/Key Err.: 255 255 000
   Part No SW: 4G9 920 950 H    HW: 4G9 920 950 H
   Component: TDieGb AccNv  H78 0515
   Revision: 28131207    Serial number: 658220812596054
   Coding: B38F08081F752600010600
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 353720F515C4B4A3905-8060
16776970 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [LWR_AFS_01 keine Kommunikation]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000721063
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001018
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790377423
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 1208100000000000035A
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
                    Voltage terminal 30: 14.3 V
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 18 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5013 - Headlight Range Control Module
          U101E 00 [009] - No Communication
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5701 - High Beam Assistant Control Module
          U1070 00 [009] - No Communication
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5721 - A/C Compressor
          U103B 00 [009] - No Communication
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 20: High Beam Assist.
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0076
   Serial number: 16101200040546
   Coding: 22
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
0094 - No Basic Setting
          B2010 00 [009] - -
          [Basic setting not performed]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
                    Basic setting of flap motors-Left Rear Upper Body Vent Motor: OK
                    Basic setting of flap motors-Right Rear Upper Body Vent Motor: Malfunction
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008003
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050F99F092877BD1F-807A
0018 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000040573590
   Coding: 0078130000006001000001010101102030303232203232
   Shop #: WSC 02311 785 00200
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA8201K9NE
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
3801358 - Databus
          [PDU Timeout]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
                    DCU_Internal_DTC: 3A 01 0E
                    Ignition Cycle Count: 34432
                    DCU Temperature: 11 °C
                    Voltage VBG 22: 2.5 V
                    VIN received: WAUZZZ4G6DN074425
                    Debug Data: 00 00 00 00 00 00 00 00
   Part No SW: 4G0 907 566 E    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0020
   Revision: 00H02000    Serial number: 6PZ 010 287-04
   Coding: 0011104
   VCID: 313F14E5ED2C9883CCD-8064
   Subsystem 1 - Part No: 4G0 907 568 E
   Component: J770  SWA Slave H02 0020
   Subsystem 2 - Serial number: 6PZ 010 287-24
   Subsystem 3 - Serial number: 5F11.10.1200H02000AMS14422ÿ
   Subsystem 4 - Serial number: S14422ÿ
Address 40: AC Compressor
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0506
   Coding: 011F16005E01628002080013
   VCID: 45D7503545A42423005-8010
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0002931404
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1BE9E4AAA39BB57-8066
3158276 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Ausfall Botschaft "PDU_LWI_01"]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Write only channel
4208000 - Steering Angle Sensor
          B1168 F1 [137] - Synchronization Failed
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Write only channel
   Revision: 00002001    Serial number: 0184206701
   Coding: 017F062200B930808320090D2C01040F0000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:45
   Component: TSG BF        H03 0506
   Coding: 011F16005E01628002080002
   VCID: 46D5573978A22F3B09F-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000502100
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B03068DC380F253F61-807E
Address 55: Headlight Range
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109J/0C7582343
   Coding: 010103020100000001
   VCID: 2D070895FD14FC63E85-8078
   Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 H
   Component: H-BNT-EU      H50 1034
   Revision: --------    Serial number: 190JZ0C7523127
   Coding: 080101010002F9EF7FB0EF3E00000003000001000300000100
   VCID: 313F14E5E12C9883CCD-8064
   Subsystem 1 - Part No: 8R0 060 884 GS
   Component: EUR 2020  3001
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9402P8W8
   Subsystem 3 - Part No SW: 4G2 919 612 Q    HW: 4G2 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LJB000N3
   Component: CD-Database  4949
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:50
                    Text: ARU9440,Atmega,M,0,0,6
03623 - Invalid Security/Release Code
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:49
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Component: TSG HL        H03 0506
   Coding: 010F14004001628002080002
   VCID: 49CF5C0569BCC043E4D-801C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000174171115
   Coding: 0109080000000000
   VCID: 71BFD4E521ACD8838CD-8024
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J2XG3DK
   Coding: 1080004
   VCID: 2615F7B9D4E2CF3B29F-8072
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:45
                        Reverse OFF
                    Count: 3
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 272200267
   Coding: 097205C011
   ROD: EV_HDSGAu571.rod
0114 - Load Space Cover
          B12EF 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
                    Voltage terminal 30: 14.70 V
   Component: TSG HR        H03 0506
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: FE060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F7B9D862CF3B29F-8072
0734 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [AFS_Timeout]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:49
                    Outside temperature: -48.5 °C
                    Voltage terminal 15: 14.3 V
                    Control Module temperature: 21.0 °C
0722 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [LWS_Timeout]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
          U1111 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Control Module temperature: 10 °C
                    Voltage terminal 15: 14.411 V
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
          U1113 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Voltage terminal 15: 14.309 V
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H31 0038
   Serial number: 005000052009127
   Coding: 04C23B1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 270BFABDDF68D633129-8072
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [ESP_ESP_01_Signal_Error]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
                    Outside temperature: 3.5 °C
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 12.0 °C
0043 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [LWS_Timeout]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
0147 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [EPS_LH_EPS_03_Signal_Error]
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
0170 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:48
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F14E5E1AC9883CCD-8064
12583690 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
          U1111 00 [009] - -
                    Reset counter: 181
                    Mileage: 204334 km
                    Date: 2020.12.04
                    Time: 13:08:47
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120919201954
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0004
   Serial number: 120820200082
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 2411EDB1AE5E3D2B37B-8070
End----------(Elapsed Time: 02:39, VBatt start/end: 14.7V/14.6V)-----------
Jef
HQ
Thank you for posting the full Auto-Scan! :thumbs:
Details on doing the Steering Angle Sensor relearn for this type of vehicle is found here:
When you do the Basic Settings group 001, do you get the "OK" message? With the steering wheel centered, front wheels pointed straight ahead, what is the value of the G85 Steering Angle Sensor?
T-CUT
Nottingham, UK
C?ID=205609
Thanks, Jef I'll let you know how I get on. No OK message
T-CUT
Nottingham, UK
C?ID=205609
Hi, Not fixed it. No OK message. It just wouldn't calibrate for some reason. Any idea anyone.
Although this is a virtual address
... is not normal. I'd make sure you don't have blown/missing fuses like the B8 thread mentioned under the notes here:
In the meanwhile, also make sure the CodingLog.CSV file located in C:\Ross-Tech\VCDS\Debug does NOT have any entries for Address 19 and 4G0 907 468 AC. I think the [Installation List] function was used to add these modules which are not actually installed:
If you see changes in that file please post it here for review. It can be opened with Notepad and pasted withing CODE tags like a scan.
P.S. The 55-Headlight Range -- Status: Cannot be reached issue would not be an [Installation List] issue. After popping into PL24 by VIN this car was factory fitted with 55-Xenon Range module 4H4 907 357 C (or an older version of that) and it isn't communicating either. J745 - Control unit for cornering light and headlight range control appears so get power from fuse SC8, ST1 -or- SC10, ST1 (depending on equipment).
J527 - Steering column electronics control unit receives power from fuses SC6, ST2 -and- SC7, ST1 per that wiring diagram.
Fuse holder C -SC- should be on the left side of the dash on a RHD car. ST1 is a black row of fuses. ST2 would be the brown row of fuses within that panel. Hopefully you spot an issue with one of those that explains all of the issues. This temp link may be helpful if you aren't familiar with Audi's fuse panel numbering scheme:
Jef
HQ
[Select]
[16 - Steering Wheel]
[Meas. Blocks - 08]
Group 033 Field 3 (Steering Angle Sensor -G85-)
T-CUT
Nottingham, UK
C?ID=205609
Thanks, everyone. I'll come back to you tomorrow, as it is raining outside and dark now
T-CUT
Nottingham, UK
C?ID=205609
Fuses all good checked all the wiring around the steering wheel, nothing apparent.
T-CUT
Nottingham, UK
C?ID=205609
Question! does the new clock spring need to be programmed? or is it plug and play.
steering angle at rest is: 1.09 deg
T-CUT
Nottingham, UK
C?ID=205609
As aforementioned by Dana & Jef it requires adaption.
As fore mentioned by me. I can't adapt or I would do. I'm trying to seeing if anyone can shed any light on what it might be? I changed the clock spring for a brand new one because the other one was broken and now I have all these error codes.
@T-CUT -....... and what of Jeff's suggestion- does G85 actually spew-out a measurement?
[Select]
[Meas. Blocks - 08]
T-CUT
Nottingham, UK
C?ID=205609
Yes it does, I think it goes up to around 176 deg on both sides and straight .09 deg
