2007 Audi 8E AUK Readiness with PDTC
Shzeps
C?ID=11561
Hi Group,
I need to generate readiness on this car. I scanned the car and cleared all the codes (fixed Evap). When I ran the readiness script it completed with no issues and said system OK however when I checked the readiness status, both the Oxygen sensor heating and Oxygen sensors show failed or incomplete. I ran the readiness script a second time with the same result.
There are no codes in the ECU read with VCDS however there is one of the previous codes stored as a PDTC (Permanent DTC) which I used a generic OBD II reader to see. Will a PDTC cause a readiness monitor to not complete? I had the same situation on a car yesterday where there was a PDTC stored but was able to generate all readiness codes, so I don't believe the PDTC will interfere with the monitors.
Lastly, the readiness script was automatic with 13 steps but after that it said to raise the RPM to 3000 and then let off until the bits read 01000000. The bits read 01000000 before I even raised the RPM but I did it anyway a couple of times and there was no change in the bits. I went into basic settings and looked at all the documented settings with oxygen sensor and they all showed ok.
Am I doing something wrong? Is there another basic setting MVB undocumented that will complete the readiness for these two monitors?
Thanks for any help or info,
Shep
Thursday,03,December,2020,09:48:31:57829
VCDS Version: 20.12.0.0 (x64)  HEX-NET CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WAUSH78E97A155254   License Plate:
Mileage: 241970km-150353mi   Repair Order:
          67 69 75 76 77
VIN: WAUSH78E97A155254   Mileage: 241970km-150353miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 8E1 910 559 E    HW: 8E0 907 559 J
   Component: 3.2l V6 FSI         0010
   Revision: --H21---    Serial number:
   Coding: 010C0109190F0120
   Shop #: WSC 26097 444 83501
   VCID: B02C4AA923C2360433-80E4
001109 - EVAP System
               P0455 - 009 - Large Leak Detected - MIL ON
                    Fault Status: 10100100
                    Fault Frequency: 16
                    Mileage: 240082 km
                    Lambda: -3.5 %
                    Temperature: 19.5°C
                    Temperature: 85.5°C
                    Speed: 105.0 km/h
                    Time: 563.2 s
                    Temperature: 800.0°C
012555 - Low Pressure Fuel regulation
               P310B - 006 - Fuel Pressure Outside Specification - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 56
                    Reset counter: 39
                    Mileage: 240636 km
                    RPM: 2368 /min
                    Mass Air / Rev.: 288.9 mg/str
                    Temperature: 84.0°C
                        Part Throttle
                    Pressure: 4.9 bar
                    Speed: 112.0 km/h
004409 - Fuel Trim: Bank 2 (Add)
               P1139 - 007 - System too Rich - Intermittent
                    Fault Status: 00000010
                    Reset counter: 20
                    Mileage: 241040 km
                    RPM: 768 /min
                    Mass Air / Rev.: 158.1 mg/str
                    Temperature: 91.5°C
                        Idle
                    Time: 76.8 s
                    Bin. Bits: 00000010
   Part No SW: 8E1 910 156 L    HW: 09L 927 156 B
   Component: AG6 09L 3,2 FSI USA 0010
   Revision: --H01---    Serial number:        4263770
   Coding: 0000002
   Shop #: WSC 06335 000 00000
002309 - Gate Select Position Circuit for Tiptronic (F189)
               P0905 - 000 - Implausible Signal - Intermittent
                    Fault Status: 00110000
                    RPM: 768 /min
                    (no units): 1.0
                    (no units): 35.0
                    Temperature: 45.0°C
                    T.B. Angle: 0.0°
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004532
   VCID: AE1054D139F620F421-80FA
   VCID: D5E2DB3D2DE0332C80-50F4
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 11023
   Shop #: WSC 65536
   VCID: BD32639DB590CB6CA8-4AA4
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0N47$
   Coding: 0032607
   VCID: BC346E99FF8AC2649F-80E8
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3HLFP
   Subsystem 3 - Serial number: 0001.01.000000200000000000я†63
   Subsystem 4 - Serial number: 000000я†6332DRB404694815Kя†63
   Subsystem 5 - Serial number: 94815Kя†6342DRB4046ACA17Yя†63
   Subsystem 6 - Serial number: ACA17Yя†6352ARB401DA3B4D.я†63
   Subsystem 7 - Serial number: A3B4D.я†6362ARB401DA45C9.я†63
   Subsystem 8 - Serial number: A45C9.я†63729RB401E03B18Lя†63
   Subsystem 9 - Serial number: 03B18Lя†63829RB401E03A7ATя
   Subsystem 10 - Serial number: 03A7ATя
   Part No: 8E0 953 549 Q
   Component: Lenksбulenmodul     0701
   Coding: 04142
   Shop #: WSC 06335
   VCID: C1CA1F6DC968AF8CCC-4AA4
   Part No SW: 8E0 920 951 N    HW: 8E0 920 951 N
   Component: KOMBI+WFS 4     H14 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0023268
   Shop #: WSC 26097 444 85826
   VCID: B5227BBDDDA0132C60-5118
   Coding: 0023268
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: F1AA8FADBA487F0C7C-4B3C
            06-10 - Signal too High - Intermittent
   Part No: 8E0 959 433 CG
   Component: Komfortgerбt T7B    4135
   Coding: 12076
   Shop #: WSC 06335
   VCID: F8BCB289DA322E44BB-4AA4
   Subsystem 1 - Part No: 8E1959801G
   Component: Tхrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tхrsteuer.BF BRM 0706
   Component: Tхrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tхrsteuer.HR BRM 0606
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: A91AA7CD001847CCF4-80FC
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H04 0020
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH04 0020
   Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
   Component: R Symphony2+    H06 0220
   Revision: 00H06000    Serial number: AUZ1Z4F3855477
   Coding: 0610122
   VCID: E89CE2C9D992BEC42B-5160
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 97
                    Time Indication: 15
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005015424
   Coding: 0001677
   VCID: BD32639DE590CB6CA8-50F4
End----------(Elapsed Time: 05:26, VBatt start/end: 14.1V/14.1V)-----------
Shzeps
C?ID=11561
Update, I ran thru the readiness again this morning and now the PDTC is clear however both Oxygen sensor heating and Oxygen sensor are incomplete. I noticed that the script is for a BHK engine and this is a AUK, is that an issue. Also, I used a generic scanner and checked mode 06 data and all tests showed pass. I then performed a battery reset and created a code then cleared the code and ran readiness again. Now all are complete except Oxygen sensor. Any ideas? I guess I am going to go drive it for an extended period of time but I never have readiness that won't complete with VCDS.
Hmm. I would try Basic Settings group 200 to see if the ECMs built-in EOL test runs the O2 sensor.
Shzeps
C?ID=11561
It's strange that in mode 06 all monitors showed pass, I am not sure what was missing.
I was also wondering if the last setting in the readiness script to accelerate the rpm over 3000 and then let off was meant to be while driving and not at a standstill. I only did it at a standstill and the bits showed 01000000 and then after several revs it changed to 00000000. The bits never reverted back to the specified 01000000 after that.
I didn't get a chance to try basic setting 200 before I went and drove it. After a normal readiness drive the monitor passed and now everything is complete.
Thanks, Shep
