- Nov 19, 2020
- 18
- 3
- Saudi Arabia
- C?ID=424807
Here is a full scan and as you can see there is an issue with communication.
I also tried to go back in hex08 from 5 Bytes to original 4 Bytes but VCDS didn't allow me to do that and it's weird because I think VCDS wont allow to force fit a fifth byte in the first place.
Any explanations of how VCDS allowed to force fit a fifth byte in hex08 and can this force fit make this communication error to other modules?
Thursday,03,December,2020,20:08:14:01997
VCDS Version: 20.4.2.0 (x64) HEX-NET2 CB: 0.4527.4
VIN: 1VWZZZA3ZFC090110 License Plate:
Mileage: 19550km-12147mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 42 44 46 47 4F 52
56 62 72
VIN: 1VWZZZA3ZFC090110 Mileage: 19550km-12147miles
01-Engine -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
2B-Steer. Col. Lock -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Sporadic communication error 1000
47-Sound System -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PK HW: 03L 907 309 AD
Component: R4 2.0l TDI H25 9977
Revision: 42H25--- Serial number:
Coding: 001D0012042400080000
Shop #: WSC 13170 875 00000
ASAM Dataset: EV_ECM20TDI01103L906018PK 003006
ROD: EV_ECM20TDI01103L906018PK.rod
VCID: 0256E014948F6DCB447-8056
Readiness: 0 0 0 0 X
Component: GSG DSG AG6 531 4015
Revision: 05653104 Serial number: 00001501311824
Shop #: WSC 09003 957 00200
VCID: 147AD64CF27BF37BE6B-8040
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Reset counter: 22
Mileage: 18761 km
Date: 2020.11.26
Time: 21:54:25
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Reset counter: 23
Mileage: 18761 km
Date: 2020.11.27
Time: 18:02:45
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Reset counter: 22
Mileage: 18761 km
Date: 2020.11.26
Time: 21:54:25
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
Reset counter: 22
Mileage: 18761 km
Date: 2020.11.26
Time: 21:54:25
01196 - Engine-Transmission Data Bus
Reset counter: 22
Mileage: 18761 km
Date: 2020.11.26
Time: 21:54:25
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5092B00FAA30C03E590190042A1100011
VCID: 045AE60C8E1B63FB76B-8050
Reset counter: 60
Mileage: 18743 km
Date: 2020.11.26
Time: 00:02:29
Count: 2
Count: 14
Count: 29184
Count: 16390
Count: 51456
Count: 1
Count: 254
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Count: 14
Count: 8208
Count: 46592
Count: 1023
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Count: 14
Count: 8226
Count: 46592
Count: 1023
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Count: 14
Count: 8194
Count: 46592
Count: 1023
Reset counter: 78
Mileage: 18385 km
Date: 2020.11.21
Time: 23:57:47
Count: 16384
Count: 32768
Count: 8704
Count: 8225
Count: 50463
Count: 1
Count: 761
Count: 1024
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0360313397
Coding: 030C0C
VCID: 372041C08FCDF863A39-8062
Part No SW: 561 907 044 AR HW: 561 907 044 AR
Component: Climatronic H03 0808
Revision: 00001K01
Coding: 0010019002
VCID: 6780D1809FEDA8E3F39-8032
Part No SW: 1K0 937 087 AM HW: 1K0 937 087 AM
Component: BCM PQ35 H+ 113 0771
Revision: AF113771
Coding: 68000E3B8C2908D4408800813600854800F1008645A085B064806000A060
VCID: 7CAA9EECF6EB1B3B0EB-8028
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 270115 05 54 0403
Coding: 02300A
11 Faults Found:
Reset counter: 78
Mileage: 18384 km
Date: 2020.11.21
Time: 23:56:15
Voltage: 13.85 V
Term 50 Off
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Voltage: 12.75 V
Term 50 Off
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:08:29
Voltage: 12.70 V
Term 50 Off
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD064D4D
Coding: 00004D38
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72B6B0D4A42F5D4B547-8026
Serial number: 6940000Y150001BKZW0T
Coding: 303047
Serial number: 3572MSME08141B4EZZZ-
Serial number: 3582MSME0A4D6A4DZZZB
Serial number: 3516KSME07516035ZZZG
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME25313735ZZZJ
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME24116B34ZZZQ
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME5C0C6B34ZZZ5
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20150121100475
Coding: 0002140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EAE94E4E077092B20F-802A
Component: E221__MFL-8LP H07 0023
Serial number: 00000000000001033074
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 E HW: 561 920 870 E
Component: KOMBI H05 0813
Coding: 131E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1B68BD701325BC03A71-804E
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 29031503000270
Coding: 461000
VCID: 0052EA1C9A037FDB523-8054
13 Faults Found:
Fault Status: 00110100
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Reset counter: 60
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Fault Frequency: 12
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
Reset counter: 60
02811 - Control Module for Electronic Steering Column Lock (J764)
Fault Frequency: 11
Reset counter: 60
00456 - Control Module for Access and Start Control (J518)
Fault Frequency: 12
Reset counter: 60
Component: IMMO H05 0813
Coding: 000007
VCID: 6A86A8B48CFF958BEC7-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000060730003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW01.rod
VCID: 30327ADC6AA32F5BE23-8064
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7666692008
Coding: 010100
VCID: 2B086DB043054C83D71-807E
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0183
Revision: AA000000 Serial number: 00000137220388
Coding: 00581B0000000000000021010100202020202120202020
VCID: 2216809434CF8DCB647-8076
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0009443372
Coding: 0415FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C6ABE6C162BBB3BAEB-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630150327195314
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
VCID: 392447F8B559EE1355D-806C
Reset counter: 60
Mileage: 18761 km
Date: 2020.11.27
Time: 18:02:45
Voltage: 12.88 V
DU
Temperature: 31.0°C
RPM: 1498 /min
Reset counter: 60
Mileage: 18761 km
Date: 2020.11.27
Time: 18:02:45
Voltage: 12.88 V
DU
Temperature: 31.0°C
RPM: 1498 /min
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0042413
ROD: EV_AudioVerst10KanalSTT3_VW41.rod
VCID: 280292BC5273679B3A3-807C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FB0B9A0B79D70A3BB9-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011432000482
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 009 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0009431938
Coding: 0415FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D6CB3680D31B233595-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631150327111842
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C8 035 685 A HW: 3C8 035 685 A
Component: RNS-MID H27 1086
Revision: AB001001 Serial number: VWZ6Z7R6061007
Coding: 04060040010000A2000B
VCID: 2A0668B44CFF558B2C7-807E
Reset counter: 60
Mileage: 18756 km
Date: 2020.11.26
Time: 17:04:20
End----------(Elapsed Time: 01:13, VBatt start/end: 13.8V/13.6V)-----------
Address 09,1K0 937 087 AM,recoded (Long Coding),from,68000E3B882908D4408800813600854800F1008645A085B064806000A060,to,68000E3B8C2908D4408800813600854800F1008645A085B064806000A060,(09003/957/00200),Thursday,26,November,2020,15:03:00:01997
Address 09,1K0 937 087 AM,recoded (Long Coding),from,68000E3B8C2908D4408800813600854800F1008645A085B064806000A060,to,68000E3B8C2908D4408800813600854800F1008645A085B064806000E060,(09003/957/00200),Thursday,26,November,2020,15:52:01:01997
Address 17,561 920 870 E,recoded (Long Coding),from,131E01,to,631E01,(09003/957/00200),Thursday,26,November,2020,15:56:30:01997
Address 09,1K0 937 087 AM,recoded (Long Coding),from,68000E3B8C2908D4408800813600854800F1008645A085B064806000E060,to,68000E3B882908D4408800813600854800F1008645A085B064806000E060,(09003/957/00200),Thursday,26,November,2020,16:09:20:01997
Address 09,1K0 937 087 AM,recoded (Long Coding),from,68000E3B882908D4408800813600854800F1008645A085B064806000E060,to,68000E3B8C2908D4408800813600854800F1008645A085B064806000E060,(09003/957/00200),Thursday,26,November,2020,16:12:09:01997
Address 17,561 920 870 E,recoded (Long Coding),from,631E01,to,131E01,(09003/957/00200),Thursday,26,November,2020,20:13:24:01997
Address 17,561 920 870 E,recoded (Long Coding),from,131E01,to,131E09,(09003/957/00200),Thursday,26,November,2020,20:14:49:01997
Address 08,561 907 044 AR,recoded (Long Coding),from,0010019002,to,001001C002,(09003/957/00200),Thursday,26,November,2020,20:15:47:01997
Address 17,561 920 870 E,recoded (Long Coding),from,131E01,to,131E09,(09003/957/00200),Thursday,26,November,2020,20:18:10:01997
Address 08,561 907 044 AR,recoded (Long Coding),from,0010019002,to,10019002,(09003/957/00200),Thursday,03,December,2020,20:42:00:01997
Address 56,3C8 035 685 A,recoded (Long Coding),from,04060040010000A2000B,to,06060040010000A2000B,(09003/957/00200),Thursday,03,December,2020,20:50:43:01997
