Diagnosing fuel injectors and catalyst converter on Audi A2 1.4 TDI 75 2004 BHC
Cronus7
C?ID=387435
Hi there,
Can the following be diagnosed using VCDS measuring blocks?.
  1. fuel injectors
  2. catalyst converter
The car has failed MOT emissions test, confirmed symptoms that relate are (very slightly) slow cold start, occasional black soot debris from end tip and no engine fault codes?.
Vehicle: Audi A2 1.4 TDI 75 2004 BHC
MOT Smoke Test Results:
Plated Value = 1.49m-1 (fail) - Min 0.60 - Max 0.70 (pass)
Wednesday,02,December,2020,09:28:24:44470
VCDS Version: 20.12.0.0
Data version: 20201124 DS322.0
VIN: WAUZZZ8ZX4N021416   License Plate: MK54YOV
Mileage: 129620   Repair Order: BETSY
Chassis Type: 8Z (8Z - Audi A2 (2000 > 2005))
Scan: 01 02 03 08 15 16 17 18 37 45 46 56 57 75 76 77
Address 01: Engine        Labels: User\045-906-019-BHC.lbl
   Part No: 045 906 019 BA
   Component: 1,4l R3 EDC G000SG  5265
   Coding: 00002
   Shop #: WSC 02138
   VCID: 55ABC233AFACE02C00-4B04
   WAUZZZ8ZX4N021416     AUZ7Z0C2522485
Address 03: ABS Brakes        Labels: 8Z0-907-379-MK60.lbl
   Part No: 8Z0 907 379 D
   Coding: 0007303
   Shop #: WSC 02154 785 00200
   VCID: 49931E432314B4CC94-5140
   Part No: 8Z2 820 043 C
   Component: A2-KLIMAVOLLAUTOMAT 0406
   VCID: 38756B8718FE3D44FB-257A
01273 - Fresh Air Blower (V2)
            17-10 - Control Difference - Intermittent
Address 15: Airbags        Labels: 8Z0-959-655.lbl
   Part No: 8Z0 959 655 G
   Component: Airbag Front+Seite 0005
   Coding: 01102
   Shop #: WSC 02152
   VCID: 50A53327904E8504D3-5140
Address 17: Instruments        Labels: 8Z0-920-xxx-17.lbl
   Part No: 8Z0 920 980 Q
   Component: KOMBI+WEGFAHRS. VDO D04
   Coding: 10430
   Shop #: WSC 01211
   VCID: 4FA7305B8D709AFCCA-5122
01304 - Radio
            49-00 - No Communications
Address 45: Inter. Monitor        Labels: None
   Part No: 8Z0 951 171
   Component: Innenraumueberw.    D04
   Coding: 00001
   VCID: 7AF1B18F6672EF544D-517A
Address 46: Central Conv.        Labels:. 8Z0-959-433.lbl
   Part No: 8Z0 959 433 AF
   Component: Komfortgerát TBD    1210
   Coding: 07931
   Shop #: WSC 02138
   VCID: 0A11E14F3692FFD45D-4B04
   Subsystem 1 - Part No: 8Z2959802A
   Component: Tõrsteuer.FS BRM 0004
   Subsystem 2 - Part No: 8Z2959801A
   Component: Tõrsteuer.BF BRM 0004
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
00958 - Key 4
            35-10 - - - Intermittent
01560 - Passenger Door
            59-10 - Can't Unlock - Intermittent
End-------------------------(Elapsed Time: 04:27)--------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 45: DTCs cleared
Address 46: DTCs cleared
   Coding: 00002
   Shop #: WSC 02138
   VCID: 55ABC233AFACE02C00-4AEA
Readiness: 0 0 1 1 1
   Coding: 0007303
   VCID: 49931E432314B4CC94-5122
   VCID: 38756B8718FE3D44FB-2574
   Coding: 01102
   Shop #: WSC 02152
   VCID: 50A53327904E8504D3-515C
   Coding: 10430
   Shop #: WSC 01211
01304 - Radio
   Coding: 00001
   Coding: 07931
   Shop #: WSC 02138
End-------------------------(Elapsed Time: 04:25)--------------------------
                Address 01: Engine  (045 906 019 BA)
10:15:30 Group 013: Laufruheregelung (Einspritzmengenabweichung)
  -1.11 mg/str  Einspritzmenge Zylinder 1
  -1.27 mg/str  Einspritzmenge Zylinder 2
  2.40 mg/str  Einspritzmenge Zylinder 3
10:15:30 Group 018: Magnetventilstatus
  0.0  Magnetventilstatus Zylinder 1
  0.0  Magnetventilstatus Zylinder 2
  0.0  Magnetventilstatus Zylinder 3
10:15:30 Group 023: Schaltzeitabweichung
  -37.0  Abweichung Zylinder 1
  -26.0  Abweichung Zylinder 2
  -36.0  Abweichung Zylinder 3
10:16:02 Group 013: Laufruheregelung (Einspritzmengenabweichung)
  -1.22 mg/str  Einspritzmenge Zylinder 1
  -1.20 mg/str  Einspritzmenge Zylinder 2
  2.47 mg/str  Einspritzmenge Zylinder 3
10:16:02 Group 018: Magnetventilstatus
10:16:02 Group 001: Einspritzmenge
  924 /min  Motordrehzahl (G28)
  6.6 mg/str  Einspritzmenge
  6.6°KW  Einspritzbeginn
  93.6°C  Kühlmittel- temperatur (G62)
10:17:27 Group 013: Laufruheregelung (Einspritzmengenabweichung)
  -1.48 mg/str  Einspritzmenge Zylinder 1
  -1.62 mg/str  Einspritzmenge Zylinder 2
  2.99 mg/str  Einspritzmenge Zylinder 3
10:17:27 Group 018: Magnetventilstatus
10:17:27 Group 001: Einspritzmenge
  6.9 mg/str  Einspritzmenge
  95.4°C  Kühlmittel- temperatur (G62)
10:18:01 Group 013: Laufruheregelung (Einspritzmengenabweichung)
  -1.44 mg/str  Einspritzmenge Zylinder 1
10:18:01 Group 018: Magnetventilstatus
  4.0  Magnetventilstatus Zylinder 1
  4.0  Magnetventilstatus Zylinder 2
  4.0  Magnetventilstatus Zylinder 3
10:18:01 Group 001: Einspritzmenge
  4347 /min  Motordrehzahl (G28)
  12.1 mg/str  Einspritzmenge
  1.5°KW  Einspritzbeginn
10:18:04 Group 013: Laufruheregelung (Einspritzmengenabweichung)
10:18:04 Group 018: Magnetventilstatus
10:18:04 Group 001: Einspritzmenge
  4830 /min  Motordrehzahl (G28)
  7.4 mg/str  Einspritzmenge
  -2.0°KW  Einspritzbeginn
10:18:16 Group 013: Laufruheregelung (Einspritzmengenabweichung)
  -1.08 mg/str  Einspritzmenge Zylinder 1
  -1.15 mg/str  Einspritzmenge Zylinder 2
  2.26 mg/str  Einspritzmenge Zylinder 3
10:18:16 Group 018: Magnetventilstatus
10:18:16 Group 001: Einspritzmenge
  945 /min  Motordrehzahl (G28)
  96.3°C  Kühlmittel- temperatur (G62)
Thanks in advanced for the support.
Kindest Regards,
Joe
That's a pretty old-school engine management.
I'm not sure it it has any way to self-check the oxidation catalyst
I guess I would start by looking at MVB 013 to see the injector balance.
HMC
C?ID=28246
Hi Cronus7,
What is the service history? Do you know if they got it hot enough? Might be worth taking it for an "Italian tune up" directly before the smoke test.
Regards HMC
Cronus7
C?ID=387435
Hi HMC,
The service history is good, genuine oil and filters annually, cam belt water pump glow plugs etc at 102k and good quality fuels always used. Unfortunately that morning i forgot to drive it until up to temperature and so would have dropped it off cold 🙄. I have taken it for a few "Italian tune up" this week after adding some Stanadyne and filling the tank with premium. I will be taking it out again for a another "Italian tune up" before the retest.
Kindest Regards
Cronus7
C?ID=387435
Hi Uwe,
Would you possibly know why on this vehicle my vcds MVBs keep reading in German and not English?.
Kindest Regards
NostraJackAss
How about having mechanical injectors spray atomization pattern and drip/leak test done?
Timing mechanically verified yet?
JPPSG yet?
Is programming FOD?
Audi
PartVersion
045906019BA7332
Most likely because the MVB descriptions were not available in English.
