So since ACC+Lane Assist are almost done, I'm in search of the next retrofit quest and that would be direct TPMS. Seems easy, quite cheap and I also plan to change my tires within the next 1-2 months so the timing is right for the sensors to be fitted at the same time.
As always I will choose the hard way and that is the TPMS system that can display tire temperature as well as air pressure. To my knowledge this kind of TPMS is used on a few MQB cars such as the TTRS 8S and the RS3 8V. The part no for this module is 8S0907273 and it works with the same tire sensors as almost any other VAG module (5Q0907275B). A parameter file for the 8S already exists and everything seems compatible up to this point. Only problem is that my tire size is 235/35/19 and the TT is fitted with 245/35/19. How much of a problem is that?
The easy way would be to fit the 5Q0907273B module which is tested and works fine with the Leon but it only shows air pressure and I would prefer to have more info than that.
