- Dec 2, 2020
- 11
- 9
- Whitby, Ontario, Canada
- C?ID=421060
Hi all, first post! Glad to finally have VCDS!
I've been wrestling with this one for a couple days now, and after registering for VIS, I've got a bit of a breakthrough, but still not quite enough to go on.
Gear lever position is listed as "ERROR" in MVB's, but the binary codes are coming through, but they seem to be missing the 4th (or 1st, depending on how you look at it) bit.
The car drives (in limp mode unless I clear codes, but it comes back after a shutdown), but PRNDS always indicates "D", except for Reverse, which appears to come up correctly.
F125 has been replaced with a BRAND NEW switch, but still:
I'm seeing:
P - 0001
R - 0100
N - 0101
D - 0110
S - 0111
According to VIS4VAG, I should be seeing:
P - 1001
R - 1100
N - 0101
D - 0110
S - 1111
There is some fraying on 2 of the wires on the connector to F125, but there appears to still be continuity. Resistance may be higher though, causing a bit to not be read.
My question for the forums: is there a pinout of that connector that shows which bit is controlled by which pair of wires? I'd like to tap into the wires and fake that bit out for the computer to test it before I go hard and spend lord knows how much on a new pigtail (looks like $90+ at various online sources...and I'm not even sure if it's the correct part).
EDIT: I should mention, unsurprisingly, when I reset the codes while it's in D or N, indicators between D and N work correctly, because those binary codes are correct with a 0 in the 4th (1st) bit. This lasts until the selector is put into an implausible condition (anything but D or N)
I'm seeing:
P - 0001
R - 0100
N - 0101
D - 0110
S - 0111
P - 1001
R - 1100
N - 0101
D - 0110
S - 1111
