Having problems with the fuel pressure on a Audi A6. Have tried to replace the fuel filter. No improvement. Is okay after fault code clearing for some time, but comes back after a while. Goes into "emergency mode" at high speed some times.
Any suggestions for what the problem could be?
Wednesday,02,December,2020,21:07:04:48853
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WAUZZZ4G4DNxxxxxx License Plate:
Mileage: 97822km-60783mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 34 3B 42 44 46 47 52 53
55 56 5F 62 6C 6D 72 8F 90
VIN: WAUZZZ4G4DN008293 Mileage: 97822km-60783miles
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LB HW: 03L 906 018 JL
Component: R4 2.0l TDI X25 9978
Revision: 45X25---
Coding: 12034012242401080000
Shop #: WSC 22750 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
ROD: EV_ECM20TDI01103L906018HA.rod
VCID: 75B7E706C54ADBF3505-8020
4807 - EGR System
P0401 00 [096] - Insufficient Flow
5211 - Fuel Rail/System Pressure
P0087 00 [232] - Too Low
Mileage: 97562 km
Date: 2020.11.24
Time: 18:59:18
Engine RPM: 2213.00 /min
Normed load value: 99.6 %
Vehicle speed: 67 km/h
Coolant temperature: 53 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.380 V
Fuel temperature: 20.1 °C
Mean injection quantity: 72.83 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 1.0866e+006 hPa
High fuel pressure: specified value: 1.432e+006 hPa
Pressure control valve adaptation factor: 1.1167
Fuel level: 20.00 l
5227 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Mileage: 97605 km
Date: 2020.11.26
Time: 10:28:39
Engine RPM: 3533.50 /min
Vehicle speed: 80 km/h
Coolant temperature: 36 °C
Intake air temperature: 8 °C
Voltage terminal 30: 13.620 V
Unlearning counter according OBD: 29
Fuel temperature: 6.8 °C
Mean injection quantity: 74.49 mg/stroke
Rail pressure regulation: status-Bits 0-7: 4
Fuel high-pressure: actual value: 1.5993e+006 hPa
High fuel pressure: specified value: 1.7884e+006 hPa
Pressure control valve adaptation factor: 1.0869
Fuel level: 40.00 l
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 4G0 927 155 T HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H04 0005
Revision: --H04--- Serial number: 0000000760
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMVL381 A02430
ROD: EV_TCMVL381.rod
VCID: 3C213222A6E04ABB6FB-8068
2310 - Transmission Control Unit
P1701 00 [032] - Locked
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 06A1C7016085E380DB00
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: 3635200A98CC90EB99F-8062
Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
Component: BCM2 2.0 H32 0421
Coding: 01A93046000000000000
VCID: 77ABED0EDFC6A9E3429-8022
00956 - Key 2
Reset counter: 169
Mileage: 94218 km
Date: 2020.09.23
Time: 22:06:28
00955 - Key 1
Fault Status: 01100010
Reset counter: 137
Mileage: 96917 km
Date: 2020.11.14
Time: 00:01:07
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
Component: KLIMA 2 ZONEN H11 0070
Serial number: 28051200111700
Coding: 34820008A9
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 6099A6526AC84E5B133-8034
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 198
Mileage: 97604 km
Date: 2020.11.25
Time: 19:20:54
Voltage terminal 30: 11.97 V
Outside temperature: 2.5 °C
Energy management deactivation stage: 1
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001330297
Coding: 2600201040749FE08981008300001D0CCF9CC7082E090201000004606101
VCID: 6E85C86AA09CE82B91F-803A
Component: WWS57X 120424 H35 0080
Serial number: 120504001833
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20285587
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 22 05 2012 00000634
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: AA088A26000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061213800005
Coding: A8C308
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77ABED0EDF46A9E3429-8022
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG008LZT2
Coding: 30323436313230303133554A304C34473053
Serial number: 3575HRB405T1BBH471NG
Serial number: 3585HRB404P1C4LIGP6/
Serial number: 3515JRB4059197FG513H
Serial number: 3525JRB4059197FGCPAD
Serial number: 3554VRB40184UE20N0JJ
Serial number: 3564VRB401E4UE20EHU2
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LEI0007Q
Coding: 000435
VCID: 38292E329258669B8B3-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0009
Serial number: 04 04 2012 D0049889
Part No SW: 4G8 920 932 D HW: 4G8 920 932 D
Component: TDieRdw H79 0515
Revision: 28460
2 Serial number: 658180512596031
Coding: 13A610001B410008000000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 303916127AA8BEDBC33-8064
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000535682
Coding: 00CD074400
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 70B9D612BA28FEDB833-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790906783
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 07021200000000000642
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 198
Mileage: 97604 km
Date: 2020.11.25
Time: 19:20:53
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.9 V
Control Module temperature: 17 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 1
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02018264747464545425363E00
VCID: 7CA1F222E6E08ABB2FB-8028
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008000
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E05086A609CA82BD1F-807A
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA42050GP30
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: 2D070F666D9AD333E85-8078
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0506
Coding: 011F16005C00628002080002
VCID: 47CB5DCEEFA61963F29-8012
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0001553425
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1C1A74A48CCBB57-8066
Revision: 00002001 Serial number: 0177186560
Coding: 013A062020B93094832009040A01040F0000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.006 H02 0007
Serial number: WOO16184420
Coding: 901F00
Subsystem 4 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.006 H02 0007
Serial number: WOO16183182
Coding: 801F00
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 80
Mileage: 67322 km
Date: 2017.08.16
Time: 17:14:09
02615 - Fuel Tank Cap; Lock
Reset counter: 81
Mileage: 67380 km
Date: 2017.08.21
Time: 17:53:48
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000055357
VCID: 1D67DFA61DBA23B3785-8048
Component: TSG BF H03 0506
VCID: 46D550CAE8AC006B09F-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000347724
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B03017E538EDD03F61-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 120511-0001-046
Coding: 11225F101002A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2C0102625680DA3BFFB-8078
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 227E40C7584829
Coding: 010003010000000001
VCID: 211FE35621C207535CD-8074
Part No SW: 4G0 035 670 H HW: 4G0 035 670 H
Component: H-BNT-EU H49 0526
Revision: -------- Serial number: 190EW0C7504760
Coding: 050100010003F1EF05908B1E00000003000001000000000000
VCID: 2809FE7242F8F61B1B3-807C
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC9401JRB%
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LEP0007G
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Component: TSG HL H03 0506
Coding: 010F14004000628002080002
VCID: 49CF5BF6F9B2EF13E4D-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J24G4GP
Coding: 1080005
VCID: 2615F04A44ECE06B29F-8072
Part No SW: 4G9 959 107 A HW: 4G9 959 107 A
Component: HDSG-Modul H03 0139
Revision: 14003001 Serial number: 133200077
Coding: 097205C010
ASAM Dataset: EV_HDSGAu572 001001
ROD: EV_HDSGAu571.rod
VCID: 34311A028EB082FBA7B-8060
Component: TSG HR H03 0506
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F131671A2B7D3CCD-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:20, VBatt start/end: 11.4V/11.5V. VIgn 11.6V)-----
