Hi all I seem to have a million faults in many modules plus my retro fit of blind spot mirrors doesn't work the vehicle is a 2017 GTE... is this because im using a HEX-CAN lead
[/CODE]
[CODE] VIN: WVWZZZAUZJW801056 License Plate:
Chassis Type AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 23 3C 42 44 4B 51 52 5F 65
75 8C A9 C0 C6
VIN: WVWZZZAUZJW801056 Mileage: 133249km-82797miles
3C-Lane Change -- Status: Cannot be reached 0100
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
51-Electric Drive -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 BN HW: 04E 907 309 F
Component: 1.4l TFSI hy H22 4518
Revision: X3H22---
Coding: 011D0012636405082008
ASAM Dataset: EV_ECM14TFS01104E906023BN 008006
ROD: EV_ECM14TFS01104E906023BN.rod
VCID: 6DD1A88DBCF0B8EEC8-8038
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
Mileage: 132825 km
Engine speed: 0.00 /min
Coolant temperature: 56 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.360 V
Unlearning counter according OBD: 25
Part No SW: 0DD 300 046 HW: 0DD 927 770 C
Component: GSG DQ400E H32 1601
Revision: 00032056 Serial number: TFK01705120008
Shop #: WSC 00417 210 00000
ROD: EV_TCMDQ400021.rod
VCID: 65C1D0AD640080AE80-8030
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 61497000000390
Coding: 01FA80A13820216D4777060541C92980011C84E26082947338B15008428203
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003.rod
VCID: 7CF795C9F78A21664F-8028
8362 - Databus
U1121 00 [046] - Missing Message
Mileage: 133123 km
Date: 2020.11.25
Time: 19:41:42
8364 - Databus
U1122 00 [046] - Implausible Message
Mileage: 133249 km
Date: 2020.11.28
Time: 12:08:46
16401 - Tire Pressure Warning
C102D 00 [108] - -
Mileage: 132642 km
Date: 2020.11.21
Time: 14:29:04
Part No SW: 5GE 907 044 AN HW: 5GE 907 044 AN
Component: Climatronic H04 1702
Revision: 00001K01
Coding: 0012101420011001040500400010102A
VCID: 081FF919B3527DC65B-805C
Subsystem 3 - Part No SW: 3Q0 963 231 D HW: 3Q0 963 231 D
Component: J848 HV-PTC 200 0204
Serial number: -00101.7U.4B20340451
Air quality sensor:
Air Conditioning Compressor Sub:
H02
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001716802674
ROD: EV_BCMBOSCH_018.rod
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170517 042 0551
Serial number: 170606093708
Component: RLHS 042 0105
Serial number: S5Y17M06D22H22M35S42
Coding: 00A8DD
Serial number: 000000000ZY171431Q7A
Serial number: 00000000000069554932
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001NBW4Z00000
Coding: 181901
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Reset counter: 62
Mileage: 133249 km
Date: 2020.11.28
Time: 11:42:30
10762 - Bulb for Right Tail Light
B12BF 15 [008] - Open or Short to Plus
Reset counter: 62
Mileage: 133249 km
Date: 2020.11.28
Time: 11:42:30
12298 - License Plate Light
B12CA 15 [008] - Open or Short to Plus
Reset counter: 62
Mileage: 133249 km
Date: 2020.11.28
Time: 11:42:30
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617139
Coding: 1471151811
VCID: 4B950615E2A456DEB6-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Coding: 5500678159FFC728949C810580400600000000000000000000
VCID: 3C7755C9B70AE1660F-8068
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR03436/
Coding: 98CCC000002000005C0000CF00C800000065
VCID: 50AF11790B827506C3-8004
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E16061740095
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E16061750748
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 106 17
Serial number: 3570000000017001542Z
Subsystem 4 - Part No SW: ----------- HW: 480 001 806 17
Serial number: 358000000003C984252I
Subsystem 5 - Part No SW: ----------- HW: 480 401 406 17
Serial number: 35100019B26106C6A45$
Subsystem 6 - Part No SW: ----------- HW: 480 401 706 17
Serial number: 3520001B72625E1386D3
Subsystem 7 - Part No SW: ----------- HW: 480 401 706 17
Serial number: 3550001C526441E4761.
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 16061708490592
Coding: 0410
VCID: 020BEB31956E579605-8056
131108 - Databus
U1121 00 [024] - Missing Message
Operating time: 128338 min
Supply voltage: Terminal 30: 14.3 V
Voltage at switch: 4.98 V
Terminal 15 status: not active
System status: 30
Part No SW: 5G1 920 794 A HW: 5G1 920 794 A
Component: KOMBI 407 3194
Coding: 27A57B082EC8060001886B1D1701030000000000
VCID: 2D51688D7C7078EE88-8078
U1014 00 [009] - -
Fault Frequency: 50
Reset counter: 22
Mileage: 132876 km
Date: 2020.11.22
Time: 17:45:43
16777008 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Reset counter: 22
Mileage: 133123 km
Date: 2020.11.25
Time: 19:42:01
16776982 - Databus
Reset counter: 22
Mileage: 133123 km
Date: 2020.11.25
Time: 19:41:41
Part No SW: 3Q0 907 530 H HW: 3Q0 907 530 D
Component: GW MQB EV 618 6305
Serial number: 27051710800371
Coding: 020100176EF11000FB00527C5C1D00000001070100010000000300000000
ROD: EV_GatewNF_VW37.rod
VCID: 34677DE99F5A2926C7-8060
Subsystem 1 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 39170001424790097233
Coding: 2DFFFF
Subsystem 2 - Part No SW: 5QE 915 181 A HW: 5QE 915 181 A
Serial number: 1452563904
131662 - Lane change assistant control module
U1045 00 [009] - No communication
Reset counter: 22
Mileage: 133249 km
Date: 2020.11.28
Time: 12:01:00
Supply voltage: Terminal 30: 13.1 V
Terminal 15: On
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 G HW: 5QE 909 059 B
Component: EBKV H14 0211
Serial number: 085460010240
Coding: 02720100331900000002060500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 52AB1B71058E0716F5-8006
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861120617150250
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5QD 907 686
Component: HRE_Master H12 0080
Serial number: 6137089427
Coding: 01031203
Shop #: WSC 00046 123 12345
ROD: EV_HREntryHella_VW37.rod
VCID: 3D7158CDAC10E86E38-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5QD 907 685
Component: HRE_Slave H12 0080
Serial number: 6140903862
Coding: 010312
338032 - Databus
Reset counter: 62
Mileage: 133249 km
Date: 2020.11.28
Time: 12:29:10
Component: TSG FS 020 0041
Serial number: 200517EEJ28687
Coding: 001F0620D001048000001000
VCID: 43852E35CAF49E9E4E-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 005 0007
Serial number: 00000000000015261973
Coding: 0D0000
458803 - Databus
Reset counter: 54
Mileage: 132669 km
Date: 2020.11.21
Time: 16:50:03
Component: EPS_MQB_ZFLS 129 1072
Coding: C102
ROD: EV_SteerAssisMQB_013.rod
VCID: 4581302DC4C0A0AE60-8010
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 E HW: 5G0 907 080 E
Component: LE Gen 3.3H11 1032
Revision: 00H11000
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM08530115G0907080E 001008
ROD: EV_DMCM08530115G0907080E.rod
VCID: 29599C9D489864CE64-807C
31797 - No Communication with Diagnostic Gateway
U0146 00 [032] - -
Mileage: 132669 km
Date: 2020.11.21
Time: 16:50:04
Voltage terminal 30: 14.806 V
Unlearning counter according OBD: 35
Drive control condition: DrvInit
Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 0
31815 - No Communication with Diagnostic Gateway
U0146 00 [032] - -
Mileage: 132669 km
Date: 2020.11.21
Time: 16:50:04
Voltage terminal 30: 14.097 V
Component: TSG BFS 020 0041
Serial number: 150417EDF02941
Coding: 003F0020DE01048000801000
VCID: 428B2B31D5EE979645-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 005 0007
Serial number: 00000000000015121070
Coding: 150000
458803 - Databus
Reset counter: 54
Mileage: 132669 km
Date: 2020.11.21
Time: 16:50:03
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER H41 0449
Serial number: VWZAZ2T1400799
Coding: 02731001FF0000005111010100880A001F0509F601200000CE
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 326B7BF1654E2716D5-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT1740525
Subsystem 2 - Part No SW: 5NA 919 866 AH HW: -----------
Component: ECE1 2020/21 --- 1410
U1111 00 [008] - -
Reset counter: 58
Mileage: 132874 km
Date: 2020.11.22
Time: 15:46:57
Voltage terminal 30: 13.1 V
BAP-BAP_Function_ID: 01
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H06 0009
Serial number: 30000000451691
ROD: EV_RDKBERU30_006_VW37.rod
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: --------
Coding: 02739001EA42B80D3FFCBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
9457171 - Audio signal output 1
B14F1 13 [008] - Open Circuit
Reset counter: 56
Mileage: 132825 km
Date: 2020.11.22
Time: 10:09:20
Voltage terminal 30: 14.8 V
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5Q0 915 182 D HW: 5Q0 915 182 C
Component: BECM H05 0921
Serial number: U9130023
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006041
ROD: EV_BECM06020115C6915182_VW37.rod
Battery Junction Box:
Subsystem 1 - Part No SW: 5Q0 915 250 E HW: 5Q0 915 250 E
Component: BJB H28 0240
Cell module: control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D1 H14 0481
Serial number: V013C1712530855
Cell module: control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D2 H14 0481
Serial number: V013C1712530856
Cell module: control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D3 H14 0481
Serial number: V013C1712530849
Cell module: control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D4 H14 0481
Serial number: V013C1712530853
Cell module: control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D5 H14 0481
Serial number: V013C1712530878
Cell module: control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D6 H14 0481
Serial number: V013C1712530848
Cell module: control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D7 H14 0481
Serial number: V013C1712530851
Cell module: control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D8 H14 0481
Serial number: V013C1712530852
Part No SW: 5G0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0017
Serial number: 170411202054
VCID: 2E536F81717603F6B1-807A
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H10 0223
Serial number: EN172101050000
Coding: 90
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_007.rod
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AF HW: 5QE 915 682 AF
Component: OBC KOSTAL H40 4013
Revision: -------- Serial number: 3105170ET0009Q
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
ROD: EV_OBCSinglPhaseKLOMQB12P.rod
VCID: 1129D47DC0083C0E8C-8044
13705485 - Databus
Reset counter: 56
Mileage: 132669 km
Date: 2020.11.21
Time: 16:50:04
13705547 - Databus
Reset counter: 65
Mileage: 132669 km
Date: 2020.11.21
Time: 16:50:04
End-------------------------(Elapsed Time: 05:49)--------------------------
