VW T5 and webasto problem
V3lmu
Oulu, Finland
C?ID=229426
Hey! :)
There would be a small problem with Webasto. When cold, Webasto starts to turn on the cabin, the heater starts rotating in less than 1min, but turns off soon. Where should you go for troubleshooting?
Car info:
VW T5 MY10
Parts already replaced:
Original Webasto ecu has been repaired.
Fireplace and glow plug renewed.
Circulating water pump renewed.
1. Round
Wednesday,02,December,2020,19:16:58:00464
Dealer/Shop Name: J.P - V3lmu
VIN: WV1ZZZ7HZAH242427   License Plate: VW TRANSPORTER
Mileage: 356140km-221295mi   Repair Order: 1. kierros
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 18 19 25 56 69 6E 0B
VIN: WV1ZZZ7HZAH242427   Mileage: 356140km-221295miles
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X32 9970
   Revision: 26X32---    Serial number: 00000000000000
   Coding: 0119401A233400080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
   ROD: EV_ECM20TDI01103L906019AM_002.rod
   VCID: 6D87C9A38D11E363895-8038
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [109] - Electrical Fault
                    Mileage: 355702 km
                    Date: 2020.11.18
                    Time: 06:48:50
                    Engine speed: 0.00 /min
                    Coolant temperature: 5 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 12.360 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 2500 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 1
                    Glow cycles below temperature threshold-Bits 0-7: 22
                    Glow cycles below temperature threshold-Bits 0-7: 96
                    Outside air temperature: 5.0 °C
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 708724AD89A80E9724A69173696510
   Shop #: WSC 02736 790 49152
   VCID: 34311CC7AE3B72AB86B-8060
   Part No SW: 7E5 907 047 R    HW: 7E5 907 047 R
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 3E253EEF90F7A8FB60F-806A
   Part No SW: 7H0 937 087 B    HW: 7H0 937 087 B
   Component: BCM T5GP H+4  H46 0207
   Revision: BO046001    Serial number: 0156 036100358
   Coding: A0A0293A0E212002002000003C2B8C540090430F60040000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 33331FDBAB3575939F1-8066
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3310
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3310
03304 - Response Closing Status of Rear Right Door
                    Fault Frequency: 28
                    Reset counter: 104
                    Mileage: 354325 km
                    Date: 2015.03.09
                    Time: 10:35:24
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00N H05 0011
   Revision: --------    Serial number: 003E500159UO
   Coding: 00000000000000000000000000000000304E
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 34311CC7AEBB72AB86B-8060
   Part No SW: 7E0 920 870 A    HW: 7E0 920 870 A
   Component: KOMBI         H16 0111
   Coding: 160A00
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   VCID: 270BFB8B6F6D0933339-8072
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 819 008 C
   Component: J737__Standheizung  0404
   Revision: 00084000    Serial number: 09019169D00000
   Coding: 0000322
   Shop #: WSC 80093 222 71269
   VCID: 290FFDB375F93F4325D-807C
01416 - Signal for Fresh Air Blower Activation
                    Fault Status: 00100111
                    Mileage: 356081 km
                    Date: 2015.04.24
                    Time: 06:19:59
                        Full Throt
                    Temperature: 44.0°C
                    Voltage: 12.17 V
                    Temperature: -50.0°C
00664 - Fuel gauge
                    Mileage: 356097 km
                    Date: 2015.04.24
                    Time: 13:56:57
                    Temperature: 23.0°C
                    Voltage: 14.21 V
                    Temperature: -0.5°C
   Part No SW: 6N0 909 901     HW: 7H0 937 087 B
   Component: GW-K-CAN TP20 0207
   Coding: 042200
   VCID: 70B9D0D79AA30E8BA23-8024
01304 - Radio
                    Reset counter: 111
                    Mileage: 350839 km
                    Date: 2015.01.01
                    Time: 18:44:26
   Component: IMMO          H16 0111
Address 56: Radio
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000126211282
   Coding: 4100000100000000
   VCID: 303910D75A234E8BE23-8064
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W1.clb
   Part No SW: 7E5 919 037 E    HW: 7E5 919 037 E
   Component: Dachdisplay   H15 0165
   Revision: 10100008    Serial number: 152563
   Coding: 000002
                    Fault Status: 00111000
                    Reset counter: 103
                    Mileage: 356110 km
                    Date: 2020.12.02
                    Time: 06:46:37
End----------(Elapsed Time: 01:36, VBatt start/end: 14.4V/14.3V)-----------
DTC Clear and 2. Round
Wednesday,02,December,2020,19:21:50:00464
Mileage: 356140km-221295mi   Repair Order: 2. kierros
6E-Ctrl Head Roof -- Status: OK 0000
   Revision: 00H43001
   Revision: 00004001
   Coding: 0000000002
   Coding: 160A00
   Coding: 0000322
   Coding: 042200
01304 - Radio
                    Reset counter: 67
                    Mileage: 356145 km
                    Date: 2015.04.25
                    Time: 19:20:37
Address 56: Radio
   Coding: 000002
End----------(Elapsed Time: 01:34, VBatt start/end: 14.3V/14.3V)-----------
Regards: V3lmu
dnoermann
C?ID=358118
Hm since there is no error logged after 2. Round it is a bit unclear.
2. Round was really scanned after the Heater was turned on, with the short Self-Turn-Off ?
Or was is directly after Error Clear ?
Else you see the Two Error from 1. Round
00664 - Fuel gauge
Fuel is clear, as long as Tank is near empty the Heater will stop.
So the other one needs to be looked deeper:
Looks like a problem with the Air Blower Motor
V3lmu
Oulu, Finland
C?ID=229426
The second round is run immediately after the first round. After this, the functionality of Webasto was tested, but the problem still occurred even though the fault codes were reset -> 01416 - Signal for Fresh Air Blower Activation 007 - Short to Ground - Intermittent.
So does this section mean this:Fresh air blower?
dnoermann
C?ID=358118
Yes, that is the Fresh air blower of the Heater, that i thought about.
BUT, see here: http://wiki.ross-tech.com/wiki/index.php/01273
That makes more sense, because the Heater only does have a "Combustion Air Blower" or so, not realy a Fresh Air Blower in my mind ...
Probably in this case the Heater is talking about the Car Blower which pumps the Air into the Car ?
Probably only a bad cabling ?
